500390
500390
    MUXLAB
500390 数据手册
DVI/Audio Extender Kit 500390 Overview The DVI/Audio Extender Kit (500390) allows one DVI channel and one line level stereo audio audio channel to be transmitted to 230 ft (70 m) at all resolutions up to 1080p via one (1) Cat 5e/6 cable in a point-to-point configuration. Applications Commercial and residential AV systems, classroom projector systems, digital signage, boardroom systems, collaborative PC systems, medical information systems, video walls. Specifications Environment Devices Transmission Bandwidth Signals Audio Connectors Max. Distance via Cat5e/6* *Based on a maximum length of 6.6 ft (2m) of DVI cable per end RJ45 Pin Configuration Reverse Polarity Sensitive Use EIA/TIA 568 A or B, straight-through wiring. Cable Power Supply Power Consumption Temperature Enclosure Dimensions Weight Compliance Warranty Order Information © MuxLab Inc. 2013 Key Features HDBaseT technology Extends DVI and stereo audio via Cat5e/6 cable Up to 230 ft (70m) at all resolutions up to 1080p via one Cat5e/6 Supports 4K up to 115 ft (35m) DVI 1.0 (Single Channel), HDBaseT technology DVD, plasma, projectors, monitors, TV, PC, laptops Transparent to the user 340 MHz DVI 1.0 protocol Does not embed or de-embed audio over DVI. Transmits audio in common mode over UTP and completely isolated from the DVI signal One (1) DVI-D receptacle One (1) RJ45S for Cat5e/6 link One (1) 3.5mm jack for line level stereo audio Note: DVI and audio cables not included. All resolutions up to 1920x1200: 230 ft (70 m) 4K: (3840 X 2160/24,25,30 Hz): 115 ft (35m) When installed in an electrically noisy environment, STP cable must be used. Also, cross-connection reduces the effective distance depending on the grade of twisted cable used. RJ45 Pin 1 (R) Pin 2 (T) Pin 3 (R) Pin 6 (T) Pin 4 (R) Pin 5 (T) Pin 7 (R) Pin 8 (T) One (1) Cat5e/6 or better twisted pair cable required. Two (2) 110-240V/5VDC power supply with interchangeable blades included Transmitter: 1.6 Watt Receiver: 3.2 Watt Operating: 0º to 40º C. Storage:-20º to 85º C. Humidity: up to 95% non-condensing. Aluminum 4.50” x 3.00” x 1.25” (11.4 x 7.6 x 3.2 cm) 2.6 lb (1.2 kg) Regulatory: FCC, CE, RoHS Flammability: 94V0 2 years 500390 DVI/Audio Extender Kit DVI/Audio Extender Kit DVI/Audio Extender Kit 500390 __________________________________________________________________________________ Typical Application Rear panels © MuxLab Inc. 2013 DVI/Audio Extender Kit MuxLab Inc. 8495 Dalton Road, Mount Royal, Quebec, Canada, H4T 1V5 Tel: (514) 905 0588 Fax: (514) 905 0589 Toll Free:1 877 689-5228 E-mail: videoease@muxlab.com URL:www.muxlab.com
500390 价格&库存
很抱歉,暂时无法提供与“500390”相匹配的价格&库存,您可以联系我们找货
