500444
500444
    MUXLAB
    MUXLAB - 500444 - HDMI 4X4 MATRIX SWITCH, 4K/60
500444 数据手册
HDMI 4x4 Matrix Switch, 4K/60 500444 Overview: The HDMI 4x4 Matrix, 4K/60 (4:4:4) connects four HDMI sources to four displays. This matrix provide four HDMI outputs supporting up to 4K/60 (4:4:4) plus all 3D formats, and supporting independent EDID control. It works with Blu-Ray players, Media Players/Streamers, Cameras, Set-Top boxes, Home Theater systems, and game consoles that connect to an HDMI display. Any source is accessible at all times by any display by selecting it via the supplied IR Remote Control, RS232, TCP/IP or by using the selection buttons on the front panel. Key Features: Applications:            Commercial and residential AV systems Classroom training systems Digital signage Boardroom systems Collaborative PC systems  Medical information systems     Supports HDMI 2.0 (4K/60, 4:4:4) Supports 4K/60 (4:2:0) for compatibility with HDBT extenders HDCP 2.2 compliant Full HDR support Powerful EDID management Supports LPCM 7.1CH, Dolby TrueHD, Dolby Digital Plus, Dolby Atmos, DTS-HD Master Audio & DTS:X Supports a Coax digital audio out (S/PDIF) Available Window’s GUI control software Controllable via front panel, IR, RS232 and Telnet Fits on a standard 19” rack Typical Application © MuxLab Inc. 2017 HDMI 4x4 Matrix Switch, 4K/60 HDMI 4x4 Matrix Switch, 4K/60 500444 __________________________________________________________________________________ Specifications Environment Devices Transmission Video Bandwidth Maximum Pixel Clock Signals Video Resolution Connectors Audio Cable Maximum Distance Cables not included. Power Supply Temperature HDMI 2.0a 4K Blu-Ray, media players/streamers, projectors, monitors, TV, PC, laptops. Transparent to the user. 18Gbps 594Mhz HDMI 2.0a (4K/60 4:4:4) protocol and HDCP 1.4 & 2.2 VESA and SMPTE 480p to 2160p (4K) With 3D Bit depth: 8, 10, 12 Four (4) HDMI connectors, for HDMI Input Four (4) HDMI connectors, for HDMI Output One (1) 3.5mm Jack, for IR Sensor One (1) DB9 connector for RS232 management One (1) RJ45 Shielded connector for Ethernet Four (4) Coax Digital Audio Outputs One (1) 2.1mm barrel locking connector for Power Supports LPCM 7.1CH, Dolby TrueHD, Dolby Digital Plus, Dolby Atmos, DTS-HD Master Audio & DTS:X Eight (8) HDMI cables of appropriate length for video resolution selected Cat 5e/6 or better twisted pair cable for Ethernet One DB9 serial cable for RS232 10m for HDMI cable Enclosure Bracket Dimensions Weight One (1) 110-240VAC to 12VDC/5.0A power supply Operating: 0° to 40°C Storage: -20° to 85°C Humidity: Up to 95% non-condensing Metal enclosure Included 17.20” x 1.69” x 8.86” (437mm x 43mm x 225mm) 9.69lbs (4.40kg) Compliance Warranty Order Information Regulatory: FCC, CE, RoHS 2 years 500444-US HDMI 4x4 Matrix Switch, 4K/60, US (UPC: 627699014448) 500444-UK HDMI 4x4 Matrix Switch, 4K/60, UK (UPC: 627699914441) 500444-EU HDMI 4x4 Matrix Switch, 4K/60, EU (UPC: 627699814444) © MuxLab Inc. 2017 HDMI 4x4 Matrix Switch, 4K/60 MuxLab Inc. 8495 Dalton Road, Mount Royal, Quebec, Canada, H4T 1V5 Tel: (514) 905 0588 Fax: (514) 905 0589 Toll Free:1 877 689-5228 E-mail: videoease@muxlab.com www.muxlab.com
500444 价格&库存
很抱歉,暂时无法提供与“500444”相匹配的价格&库存,您可以联系我们找货
