500760-TX-US
500760-TX-US
    MUXLAB
    MUXLAB - 500760-TX-US - AV OVER IP 4K/60 UNCOMPRESSED TX, UTP
500760-TX-US 数据手册
AV over IP 4K/60 Uncompressed Extender, UTP 500760 Overview: The AV over IP 4K/60 Uncompressed Extender, UTP allows HDMI and DisplayPort source equipment supporting up to 4K @ 60Hz resolution to be connected and extended to create a 4K/60 HDMI based Video Wall, Virtual Matrix Switch, and Virtual Splitter arrangements of user configurable size (X by Y) supporting 100’s of screens, depending on network bandwidth, utilizing one Receiver for each display in the array. Each Transmitter (500760-TX) and Receiver (500760-RX) can be connected via Cat5e/6 cable up to 330ft (100m) from a 10Gig Ethernet Switch. The Transmitter supports 2CH audio insertion and the Receiver supports 2CH audio extraction. The Transmitter and Receiver, each come with a power supply, an IR Emitter and IR Sensor for IR based remote control applications, a wall mount bracket kit for securing the unit to a wall and a 4-pin terminal block connector for RS232 connectivity. The MuxLab Pro Digital Network Controller (500811) is available to simplify centralized configuration and control, software updates and allows for third party smartphone and tablet management. Key Features:           Supports HDMI up to 4K/60 on Transmitter and Receiver Support DisplayPort 1.2a up to 4K/60 on transmitter Uncompressed up to 4K/60 (4:2:0) (zero latency), and light compression visually lossless at (4:4:4) (1 frame latency) Supports Video Wall, Virtual Switch & Splitter configurations Supports point-to-point, point-to-multipoint and multipoint-tomultipoint applications Transmission up to 330ft (100m) over Cat5e/6 Supports audio insert (TX) & audio extract (RX) 1G Ethernet Switch port to connect network devices Supports RS232 and IR transmission for remote control Control via any web device (mobile, tablet) with use of model 500811 (Pro Digital Network Controller) Specifications Environment HDMI 2.0 and HDCP 2.2 Devices Bandwidth Signals Connectors Blu-Ray, projectors, monitors, TV, PC, laptops, and media servers supporting HDMI. 594MHz HDMI 2.0 and DisplayPort 1.2a protocol Connectors per TX and RX: One (1) HDMI receptacle. One (1) DisplayPort connector (TX only). Two (2) RJ45S for Cat 5e/6 unshielded or shielded twisted pair (for 10GbE and 1GbE ports). Two (2) 3.5mm jacks for IR emitter and IR sensor. One (1) 3.5mm jacks for audio insertion/extraction (insert on TX, and extract on RX). One (1) 4-pin terminal block connector for RS232. One (1) 2.1mm power jack (for DC power). Cat5e/6: 330ft (100m) up to 4K @ 60Hz Note: When installed in an electrically noisy environment, an STP cable must be used. Also, cross-connection reduces the effective distance depending on the grade of twisted cable used. Note: Cables not included. Maximum Distance Based on a maximum length of 6.6ft (2m) of HDMI cable per end. Latency Compression Network Bandwidth Network Requirement IR Frequency RJ45 Pin Configuration Reverse Polarity Sensitive. Use EIA/TIA 568A or 586B straight-through wiring. Cable Power Source Power Consumption Temperature Dimensions Weight Compliance Warranty Order Information © MuxLab Inc. 2017 No Compression (Zero Latency) up to 4K/60 (4:2:0), and less than one Frame (16ms) @ 4K/60 (4:4:4) Uncompressed up to 4K/60 (4:2:0), and light compression for 4K/60 (4:4:4) only < 10Gbps 10Gig Network XFI, IEEE 802.3 38 to 56KHz RJ45 Link Pin 1 (R) Pin 2 (T) Pin 3 (R) Pin 6 (T) Pin 4 (R) Pin 5 (T) Pin 7 (R) Pin 8 (T) One (1) Cat 5e/6 or better twisted pair cables required Input: 100-240V/1.5A (max) @ 50-60Hz Output: 12DC @ 3A Includes appropriate power cord for region (US, UK or Euro) Transmitter: 13.32Watt Receiver: 15.96Watt Operating: 0° to 40°C Storage: -20° to 85°C Humidity: Up to 95% non-condensing 8.25” x 16.14” x 1.37” (21cm x 14cm x 3.5cm) 4.06lbs (1.85kg) Regulatory: FCC, CE, RoHS Flammability: 94V0 3 years 500760-TX-US AV over IP 4K/60 Uncompressed Transmitter, UTP, US (UPC: 627699907603) 500760-RX-US AV over IP 4K/60 Uncompressed Receiver, UTP, US (UPC: 627699807606) 500760-TX-UK AV over IP 4K/60 Uncompressed Transmitter, UTP, UK (UPC: 627699917602) 500760-RX-UK AV over IP 4K/60 Uncompressed Receiver, UTP, UK (UPC: 627699817605) 500760-TX-EU AV over IP 4K/60 Uncompressed Transmitter, UTP, EU (UPC: 627699927601) 500760-RX-EU AV over IP 4K/60 Uncompressed Receiver, UTP, EU (UPC: 627699827604) AV over IP 4K/60 Uncompressed Extender, UTP AV over IP 4K/60 Uncompressed Extender, UTP 500760 _____________________________________________________________________________________________ Typical Application © MuxLab Inc. 2017 AV over IP 4K/60 Uncompressed Extender, UTP MuxLab Inc. 8495 Dalton Road, Mount Royal, Quebec, Canada, H4T 1V5 Tel: (514) 905 0588 Fax: (514) 905 0589 Toll Free:1 877 689-5228 E-mail: videoease@muxlab.com www.muxlab.com
500760-TX-US 价格&库存
很抱歉,暂时无法提供与“500760-TX-US”相匹配的价格&库存,您可以联系我们找货
