500466
500466
    MUXLAB
    MUXLAB - 500466 - HDMI TO VGA CONVERTER 59AC8356
500466 数据手册
HDMI to VGA Converter 500466 __________________________________________________________________________________ Overview The HDMI to VGA Converter (500466) converts a single HDMI channel to analog VGA/RGB. The converter allows HDMI sources to be used with legacy VGA/RGB equipment thereby helping to maximize investment in existing VGA hardware. Applications Commercial and residential AV systems, laptop to projector, boardroom systems, retrofit installations, medical information systems. Specifications Environment Devices Key Features Converts HDMI to VGA Supports up to 1080p/1920x1200 Deep Color Use HDMI sources with legacy VGA displays Supports DVI when used with a DVI to HDMI cable No external power required HDMI 1.3, VESA VGA DVD, HDTV, projectors, monitors, TV, PC, laptops and other equipt supporting HDMI and/or VGA Compliant 1080p, 1920x1200 Transparent to the user HDMI 1.3 One (1) HDMI Type A cable lead One (1) HD15F for VGA No external power required Operating: 0º to 40º C. Storage:-20º to 85º C. Humidity: up to 95% non-condensing. Plastic 1.77” x 7.48” x 0.59” (45 x 190 x 15 mm) 3.2 oz (91 grams) FCC Class A, CE, RoHS Lifetime 500466 HDMI to VGA Converter HDCP Maximum resolution Transmission Standard Connectors Power Temperature Enclosure Dimensions Weight Compliance Warranty Order Information Typical Application © MuxLab Inc. 2014 draft MuxLab Inc. 8495 Dalton Road, Mount Royal, Quebec, Canada, H4T 1V5 Tel: (514) 905 0588 Fax: (514) 905 0589 Toll Free:1 877 689-5228 E-mail: videoease@muxlab.com URL:www.muxlab.com HDMI to VGA Converter
500466 价格&库存
很抱歉,暂时无法提供与“500466”相匹配的价格&库存,您可以联系我们找货
