772100
772100
    PILZ
    PILZ - 772100 - SAFETY RELAY, 24VDC, DIN RAIL
772100 数据手册
PNOZ m B0 772100 Configurable safe small controllers PNOZmulti 2, base unit, expandable, 20 safe digital inputs, 4 safe semiconductor outputs. Technical details General data Approval: CE, UKCA, cULus Listed, KOSHA, TÜV, EAC (Eurasian) Application range: Failsafe Technical data Electrical data Purpose of U1: System supply Supply voltage (V): 24 - 24 V Type of supply voltage U1: DC Purpose of U2: Supply of SC outputs Supply voltage 2 (V): 24 - 24 V Type of supply voltage U2: DC Potential isolation U2: Yes Permitted loads: Resistive, Inductive, Capacitive Configurable inputs/outputs Number of configurable I/Os: 8 Potential isolation of IO: No Short circ. prot. n/safe S/C O: Yes Voltage at 1 n/safe S/C O: UB - 2 V at 0.1 A Inputs U input to EN 61131-2 Type 1: 24 V DC Pilz GmbH & Co. KG, Felix-Wankel-Strasse 2, 73760 Ostfildern, Germany Page 1/6 Potential isolation input: No Semiconductor outputs Potential isolation of S/C O: Yes S/C output short circuit proof: Yes Test clock outputs Number of test pulse outputs: 4 Environmental data Ambient temperature standard: EN 60068-2-14 Ambient temperature: 0 - 60 °C Storage temperature standard: EN 60068-2-1/-2 Climatic suitability standard: EN 60068-2-30, EN 60068-2-78 Condensation permitted?: Not permitted Perm. operating height ASL: 2000 m EMC to standard ...: EN 61131-2 Vibration to standard ...: EN 60068-2-6 Acc. shock to standard1: 15g Clearance & creepage dist. to: EN 61131-2 Overvoltage category: II Pollution degree clear.&creep.: 2 Protection type standard: EN 60529 Potential separation Potential isolation 1 between: SC output and system voltage Type of potential isolation 1: Basic insulation Mechanical data Mounting position: horizontal on top hat rail DIN-rail dimensions: 35 x 7.5 EN 50022 Housing material lower section: PC Housing material front plate: PC Housing material upper part: PC Pilz GmbH & Co. KG, Felix-Wankel-Strasse 2, 73760 Ostfildern, Germany Page 2/6 Connection terminal: Spring-loaded terminal, Screw terminal Terminal style: plug-in Flex. cond. c/s AWG info: 24 - 12 AWG Height dimension: 101.4 mm Width dimension: 45 mm Depth dimension: 120 mm Net weight: 235 g Gross weight: 250 g Environment RoHS directive: 2011/65/EU, 2015/863/EU RoHS conformity: yes RoHS exceptions: yes RoHS except.s acc. to direct.: 7a, 7c I REACh compliance: contains min. 1 SVHC-substance REACh included substances: Lead, Lead oxide %-part of the pollutant: > 0,1 CAS No.: 7439-92-1, 1317-36-8 WEEE classifikation (08/2018): 5 devices (feed size < 50cm) Commercial data ECLASS version: ECLASS-9.1 ECLASS Reference Feature: 27242207 ETIM Version: ETIM-7.0 ETIM Reference Group: EG000024 Obligatory accessories 773010B Pilz GmbH & Co. KG, Felix-Wankel-Strasse 2, 73760 Ostfildern, Germany Basic Licence for PNOZmulti Config. Page 3/6 779211 Chipcard 1 piece 32kB 779201 PNOZmulti Chipcard 1 piece 8kb 751008 PNOZ s Set1spring loaded terminals 45mm 750008 PNOZ s Set1screw terminals 45mm 779200 PNOZmulti Chipcard Set 10 piece 8KB 779212 PNOZmulti Chipcard Set 10 pieces 32kB 779261 PNOZ mm0.xp terminator left (10 pcs.) 779250 PNOZmulti Seal 12 pieces Optional accessories Pilz GmbH & Co. KG, Felix-Wankel-Strasse 2, 73760 Ostfildern, Germany Page 4/6 779240 PNOZmulti Chipcard Holder (Sparepart) 779230 PNOZ Chip Card Reader 312993 PSSu A USB-CAB05 773011U Basic Upgr Licence for PNOZmulti Service 312992 PSSu A USB-CAB03 773010U Basic Upgr Licence for PNOZmulti Config 779260 PNOZ mm0.xp connector left (10 pcs) 773011V User Upgr Licence for PNOZmulti Service 773011B Basic Licence for PNOZmulti Service Pilz GmbH & Co. KG, Felix-Wankel-Strasse 2, 73760 Ostfildern, Germany Page 5/6 773011K User Licence for PNOZmulti Service 773010K User Licence for PNOZmulti Config Pilz GmbH & Co. KG, Felix-Wankel-Strasse 2, 73760 Ostfildern, Germany Page 6/6
772100 价格&库存
很抱歉,暂时无法提供与“772100”相匹配的价格&库存,您可以联系我们找货
  • 1+5885.875901+761.42790
  • 5+5465.462445+707.04100
库存:2
