750126
750126
    PILZ
750126 数据手册
PNOZsigma - Base units ● Sensors Control and Communication Electronic monitoring relays Safety Relays PNOZ X ● Register Login Back to overview PNOZsigma - Base units Safe monitoring of E-STOP, safety gate, light grid and two-hand control PNOZsigma PNOZ s6.1 24VDC 3 n/o 1 n/c Order numbers: 750126 PNOZelog PNOZmulti ● PNOZpower ● Configurable control systems ● Programmable safety and control systems ● ● Industrial communication Motion Control ● Operating and Monitoring ● ● Software ● ● Picture shows similar item ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● Type: PNOZ s6.1 Application options: Two-hand monitoring type III A Category in accordance with: EN 954-1 SIL value: -Standards: EN 954-1 , VDE 0113-1 , EN 574 TYPE III A , EN 60204-1 , EN 62061 Approvals: BG , CCC , UL/cUL Operating modes: Detection of shorts across contacts , Dual-channel Selectable times: -Number of instantaneous safety contacts: 3 Number of delayed safety contacts: -Number of auxiliary contacts: 1 Number of delayed auxiliary contacts: -Number of semiconductor outputs: 1 Stop category: 0 Supply voltage [V]: 24 Supply voltage range: -Supply voltage type: DC Max. current at DC1: 8,0 A Power consumption AC: -Power consumption DC: -Height dimension: 98,0 mm Width dimension: 22,5 mm Depth dimension: 120,0 mm Height dimension (inches): 3.86" Width dimension (inches): 0.89" Depth dimension (inches): 4.72" Gross weight: 250 g Net weight: 190 g Ambient temperature in °C: -10 - 55 °C Terminal type: Screw terminal Terminal style: Plug-in Order number: 750126 http://www.pilz.co.uk/products/control_communication/safety_relay/f/pnozsigma/s/00514/index.jsp?itemId=750126 (1 of 2)24/02/2009 16:12:45 Two-hand relays Up to PL e of EN ISO 13849-1 PNOZ s6.1 Unit features Two-hand control device for safety circuits Approvals PNOZ s6.1 ‹ ‹ ` Positive-guided relay outputs: – 3 safety contacts (N/O), instantaneous – 1 auxiliary contact (N/C), instantaneous ` 1 semiconductor output ` Connection options for: – 2 operator elements (buttons) ` A connector can be used to connect 1 PNOZsigma contact expander module ` LED indicator for: – Supply voltage – Input status, channel 1 – Input status, channel 2 – Switch status, safety contacts – Feedback loop – Fault ` Plug-in connection terminals (either spring-loaded terminal or screw terminal) ` See order reference for unit types Unit description The two-hand control relay meets the requirements of EN 574 Type IIIA. It ‹ forces the operator to keep his hands outside the danger zone area during the hazardous movement. It is designed for use in two-hand circuits. CAUTION! The two-hand control relay may not be used on press controllers. It is only suitable for use where the risk analysis has established a low level of risk (e.g. EN 954-1 Cat. 1). Safety features The two-hand control relay meets the following safety requirements: ` The two-hand control relay prevents the plant from being enabled in the following cases: – Power supply failure – Component failure – Short circuit on an input circuit – Coil defect – Open circuit – Earth fault ` In each on-off cycle, the output relays on the safety device are tested to ensure they open and close correctly Block diagram )* = (~)* S13 S14 S23 S24 Input 13 23 33 41 Input K1 Interface expansion unit = ( A1 A2 Power K2 Feedback (Reset) S34 Y32 14 24 34 42 *only with UB = 48 – 240 VAC/DC Pilz GmbH & Co. KG, Felix-Wankel-Straße 2, 73760 Ostfildern, Germany Telephone: +49 711 3409-0, Telefax: +49 711 3409-133, E-Mail: pilz.gmbh@pilz.de NSG-D-2-405-2008-11 Two-hand relays Up to PL e of EN ISO 13849-1 PNOZ s6.1 Function description ing two buttons within 0.5 s. If one or both of the buttons are released, the unit interrupts the control command for the hazardous movement. ` The two-hand control relay must be activated by simultaneously press- ` Reactivation: The output relays will not re-energise until both operator elements have been released and then re-operated simultaneously. Timing diagram POWER Button 1 Button 2 Feedback loop Output safe Output aux. Out semi t0 t1 Key ` POWER: Supply voltage ` Button 1/Button 2: Input circuits S13-S14, S23-S24 ` Feedback loop: Feedback loop S34 ` Output safe: Safety outputs 13-14, 23-24, 33-34 t2 t3 t1 ` Output aux: Auxiliary contacts 4142 ` Out semi: Semiconductor output switch status Y32 ` t0: Recovery time after power on ` t1: Simultaneity, channel 1 and 2 t3 t1 ` t2: Operating cycle ended through button 1 or 2 ` t3: S34-S12 must be closed before before the button is operated (recovery time) Shaded area: Status irrelevant Wiring Please note: ` Information given in the “Technical details” must be followed. ` Outputs 13-14, 23-24, 33-34 are safety contacts, output 41-42 is an auxiliary contact (e.g. for display). ` To prevent contact welding, a fuse should be connected before the output contacts (see technical details). ` Calculation of the max. cable runs lmax in the input circuit: Imax = Rlmax Rl / km Rlmax = max. overall cable resistance (see technical details) Rl /km = cable resistance/km ` Use copper wire that can withstand 60/75 °C. ` Sufficient fuse protection must be provided on all output contacts with capacitive and inductive loads. Pilz GmbH & Co. KG, Felix-Wankel-Straße 2, 73760 Ostfildern, Germany Telephone: +49 711 3409-0, Telefax: +49 711 3409-133, E-Mail: pilz.gmbh@pilz.de NSG-D-2-405-2008-11 -2 Two-hand relays Up to PL e of EN ISO 13849-1 PNOZ s6.1 Preparing for operation ` Supply voltage Supply voltage AC DC S14 A1 L A2 N A1 L+ A2 L- ` Input circuit Input circuit Single-channel Dual-channel Two-hand button with detection of shorts across contacts S13 S1 S14 S23 S2 S24 ` Feedback loop Feedback loop Contacts from external contactors S24 S34 13 (23,33) 14 (24,34) K5 K6 K5 L1 N K6 ` Semiconductor output Y32 PLC Input S14 Gnd ` Key S1/S2 Two-hand button Pilz GmbH & Co. KG, Felix-Wankel-Straße 2, 73760 Ostfildern, Germany Telephone: +49 711 3409-0, Telefax: +49 711 3409-133, E-Mail: pilz.gmbh@pilz.de NSG-D-2-405-2008-11 Two-hand relays Up to PL e of EN ISO 13849-1 PNOZ s6.1 Terminal configuration Dimensions Install base unit without contact expander module: ` Ensure that the plug terminator is inserted at the side of the unit. Connect base unit and PNOZsigma contact expander module: ` Remove the plug terminator at the side of the base unit and at the contact expander module. ` Connect the base unit and the contact expander module to the supplied connector before mounting the units to the DIN rail. Installation in control cabinet ` The safety relay should be installed in a control cabinet with a protection type of at least IP54. ` Use the notch on the rear of the unit to attach it to a DIN rail. ` Ensure the unit is mounted securely on a vertical DIN rail (35 mm) by using a fixing element (e.g. retaining bracket or an end angle). ` Push the unit upwards or downwards before lifting it from the DIN rail. *with spring-loaded terminals 120 (4.72") Installation 98 (3.86") * 100 (3,94") Pilz GmbH & Co. KG, Felix-Wankel-Straße 2, 73760 Ostfildern, Germany Telephone: +49 711 3409-0, Telefax: +49 711 3409-133, E-Mail: pilz.gmbh@pilz.de 22,5 (0.88") NSG-D-2-405-2008-11 -4 Two-hand relays Up to PL e of EN ISO 13849-1 PNOZ s6.1 Service life graph This data sheet is only intended for use during configuration. For installation and operation, please refer to the operating instructions supplied with the unit. UB 24 VDC D GB F E I NL Nennbetriebstrom (A) Nominal operating current (A) Courant coupé (A) Corriente nominal de servicio (A) Corrente di esercizio nominale (A) Nominale bedrijfsstroom (A) NOTICE 10 1 DC1: 24 V DC13: 24 V 0.1 1000 100 D Schaltspielzahl x 103 GB Cycles x 103 F Nombre de manœuvres x 103 AC15: 230 V AC1: 230 V 10000 100000 E Número de ciclos x 103 I Numero dei cicli di commutazione x 103 NL Aantal schakelingen x 103 D GB F E I NL Nennbetriebstrom (A) Nominal operating current (A) Courant coupé (A) Corriente nominal de servicio (A) Corrente di esercizio nominale (A) Nominale bedrijfsstroom (A) UB 48-240 VAC/DC 10 AC15: 230 V AC1: 230 V DC1: 24 V DC13: 24 V 1 0.1 10 100 D Schaltspielzahl x 103 GB Cycles x 103 F Nombre de manœuvres x 103 1000 10000 E Número de ciclos x 103 I Numero dei cicli di commutazione x 103 NL Aantal schakelingen x 103 Technical details Electrical data Supply voltage Supply voltage UB DC Supply voltage UB AC/DC Voltage tolerance Power consumption at UB AC Power consumption at UB DC Frequency range AC Residual ripple DC Voltage and current at Input circuit DC: 24.0 V N/O contact Feedback loop DC: 24.0 V Number of output contacts Safety contacts (S) instantaneous: Auxiliary contacts (N/C): 24 V 48 - 240 V -15 %/+10 % 7.0 VA Order no.: 750156, 751156 3.5 W 50 - 60 Hz 20 % 20 mA 15.0 mA 3 1 Pilz GmbH & Co. KG, Felix-Wankel-Straße 2, 73760 Ostfildern, Germany Telephone: +49 711 3409-0, Telefax: +49 711 3409-133, E-Mail: pilz.gmbh@pilz.de NSG-D-2-405-2008-11 Two-hand relays Up to PL e of EN ISO 13849-1 PNOZ s6.1 Electrical data Type in accordance with EN 574 Utilisation category in accordance with EN 60947-4-1 Safety contacts: AC1 at 240 V Safety contacts: DC1 at 24 V Auxiliary contacts: AC1 at 240 V Auxiliary contacts: DC1 at 24 V Utilisation category in accordance with EN 60947-5-1 Safety contacts: AC15 at 230 V Safety contacts: DC13 at 24 V (6 cycles/min) Auxiliary contacts: AC15 at 230 V Auxiliary contacts: DC13 at 24 V (6 cycles/min) Contact material External contact fuse protection (IK = 1 kA) to EN 60947-5-1 Blow-out fuse, quick Safety contacts: Auxiliary contacts: Blow-out fuse, slow Safety contacts: Auxiliary contacts: Circuit breaker 24 VAC/DC, characteristic B/C Safety contacts: Auxiliary contacts: Semiconductor outputs (short circuit proof) Max. overall cable resistance Rlmax per input circuit Safety-related characteristic data Performance Level (PL)* of EN ISO 13849-1 Safety contacts, instantaneous SIL claim limit (SIL CL) in accordance with EN IEC 62061 Safety contacts, instantaneous Probability of dangerous failure per hour (PFHD) in accordance with EN IEC 62061 Safety contacts, instantaneous Mission time/Proof test interval in years III A Imin: 0.01 A , Imax: 6.0 A Order no.: 750156, 751156 8.0 A Order no.: 750126, 751126 Pmax: 1500 VA Order no.: 750156, 751156 2000 VA Order no.: 750126, 751126 Imin: 0.01 A , Imax: 6.0 A Order no.: 750156, 751156 8.0 A Order no.: 750126, 751126 Pmax: 150 W Order no.: 750156, 751156 200 W Order no.: 750126, 751126 Imin: 0.01 A , Imax: 6.0 A Order no.: 750156, 751156 8.0 A Order no.: 750126, 751126 Pmax: 1500 VA Order no.: 750156, 751156 2000 VA Order no.: 750126, 751126 Imin: 0.01 A , Imax: 6.0 A Order no.: 750156, 751156 8.0 A Order no.: 750126, 751126 Pmax: 150 W Order no.: 750156, 751156 200 W Order no.: 750126, 751126 Imax: 3.0 A Order no.: 750156, 751156 6.0 A Order no.: 750126, 751126 Imax: 4.0 A Order no.: 750156, 751156 5.0 A Order no.: 750126, 751126 Imax: 3.0 A Order no.: 750156, 751156 6.0 A Order no.: 750126, 751126 Imax: 4.0 A Order no.: 750156, 751156 5.0 A Order no.: 750126, 751126 AgCuNi + 0.2 µm Au 10 A Order no.: 750126, 751126 6 A Order no.: 750156, 751156 10 A Order no.: 750126, 751126 6 A Order no.: 750156, 751156 4 A Order no.: 750156, 751156 6 A Order no.: 750126, 751126 4 A Order no.: 750156, 751156 6 A Order no.: 750126, 751126 4 A Order no.: 750156, 751156 6 A Order no.: 750126, 751126 4 A Order no.: 750156, 751156 6 A Order no.: 750126, 751126 24.0 V DC,20 mA 30 Ohm e 3 2.44E-09 1/h 20 Pilz GmbH & Co. KG, Felix-Wankel-Straße 2, 73760 Ostfildern, Germany Telephone: +49 711 3409-0, Telefax: +49 711 3409-133, E-Mail: pilz.gmbh@pilz.de NSG-D-2-405-2008-11 -6 Two-hand relays Up to PL e of EN ISO 13849-1 PNOZ s6.1 Times Delay-on de-energisation (reaction time in accordance with EN 574) N/O contact N/C contact Recovery time Simultaneity, channel 1 and 2 Supply interruption before de-energisation Environmental data EMC Vibration to EN 60068-2-6 Frequency Amplitude Climatic suitability Airgap creepage in accordance with EN 60947-1 Pollution degree Rated insulation voltage Rated impulse withstand voltage Ambient temperature Storage temperature Protection type Mounting (e.g. cabinet) Housing Terminals Mechanical data Housing material Housing Front Cross section of external conductors with screw terminals 1 core flexible 2 core, same cross section, flexible: with crimp connectors, without insulating sleeve without crimp connectors or with TWIN crimp connectors Torque setting with screw terminals Cross section of external conductors with spring-loaded terminals: Flexible with/without crimp connectors Spring-loaded terminals: Terminal points per connection Stripping length Dimensions Height Width Depth Weight 40 ms 50 ms 250 ms 0.5 s 20 ms EN 60947-5-1, EN 61000-6-2, EN 61000-6-4 10 - 55 Hz 0.35 mm EN 60068-2-78 2 250 V 4.0 kV -10 - 55 °C -40 - 85 °C IP54 IP40 IP20 PC PC 0.25 - 2.50 mm² , 24 - 12 AWG Order no.: 750126, 750156 0.25 - 1.00 mm² , 24 - 16 AWG Order no.: 750126, 750156 0.20 - 1.50 mm² , 24 - 16 AWG Order no.: 750126, 750156 0.50 Nm Order no.: 750126, 750156 0.20 - 2.50 mm² , 24 - 12 AWG Order no.: 751126, 751156 2 Order no.: 751126, 751156 9 mm Order no.: 751126, 751156 100.0 mm Order no.: 751126, 751156 98.0 mm Order no.: 750126, 750156 22.5 mm 120.0 mm 190 g Order no.: 750126, 751126 210 g Order no.: 750156, 751156 *not within BG's scope of inspection The standards current on 2006-07 apply. Pilz GmbH & Co. KG, Felix-Wankel-Straße 2, 73760 Ostfildern, Germany Telephone: +49 711 3409-0, Telefax: +49 711 3409-133, E-Mail: pilz.gmbh@pilz.de NSG-D-2-405-2008-11 Two-hand relays Up to PL e of EN ISO 13849-1 PNOZ s6.1 Conventional thermal current Number of contacts 1 2 3 Ith (A) at UB DC 6.00 A Order no.: 750156, 751156 8.00 A Order no.: 750126, 751126 6.00 A Order no.: 750156, 751156 8.00 A Order no.: 750126, 751126 4.50 A Order no.: 750156, 751156 6.00 A Order no.: 750126, 751126 Ith (A) at UB AC 6.00 A Order no.: 750156, 751156 6.00 A Order no.: 750156, 751156 4.50 A Order no.: 750156, 751156 Order reference Type PNOZ s6.1 PNOZ s6.1 C PNOZ s6.1 PNOZ s6.1 C Features 24 VDC 24 VDC 48 – 240 VAC/DC 48 – 240 VAC/DC Pilz GmbH & Co. KG, Felix-Wankel-Straße 2, 73760 Ostfildern, Germany Telephone: +49 711 3409-0, Telefax: +49 711 3409-133, E-Mail: pilz.gmbh@pilz.de Terminals With screw terminals With spring-loaded terminals With screw terminals With spring-loaded terminals Order no. 750 126 751 126 750 156 751 156 NSG-D-2-405-2008-11 -8
750126 价格&库存
很抱歉,暂时无法提供与“750126”相匹配的价格&库存,您可以联系我们找货
