750101
750101
    PILZ
750101 数据手册
PNOZsigma - Base units ● Sensors Control and Communication Electronic monitoring relays Safety Relays PNOZ X PNOZsigma PNOZelog ● Back to overview PNOZsigma - Base units Safe monitoring of E-STOP, safety gate, light grid and two-hand control PNOZ s1 24VDC 2 n/o Order numbers: 750101 PNOZmulti PNOZpower Configurable control systems Programmable safety and control systems Industrial communication Motion Control Operating and Monitoring ● ● ● ● ● ● ● ● Software Register ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● Type: PNOZ s1 Application options: Safety gate monitor , Instantaneous E-STOP monitoring , Limit switch Category in accordance with: EN 954-1 , EN ISO 13849-1 SIL value: -Standards: EN 60204-1 , EN 62061 , VDE 0113-1 , EN 954-1 Approvals: BG , CCC , GOST Russia , UL/cUL Operating modes: Automatic start , Single-channel , Manual start Selectable times: -Number of instantaneous safety contacts: 2 Number of delayed safety contacts: -Number of auxiliary contacts: -Number of delayed auxiliary contacts: -Number of semiconductor outputs: 1 Stop category: 0 Supply voltage [V]: 24 Supply voltage range: -Supply voltage type: DC Max. current at DC1: 3,0 A Power consumption AC: -Power consumption DC: -Height dimension: 98,0 mm Width dimension: 12,5 mm Depth dimension: 120,0 mm Height dimension (inches): 3.86" Width dimension (inches): 0.49" Depth dimension (inches): 4.72" Gross weight: 150 g Net weight: 105 g Ambient temperature in °C: -10 - 55 °C Terminal type: Screw terminal Terminal style: Plug-in Order number: 750101 http://www.pilz.co.uk/products/control_communication/safety_relay/f/pnozsigma/s/00514/index.jsp?itemId=750101 (1 of 2)24/02/2009 16:13:56 Login E-STOP relays, safety gate monitors Up to PL c of EN ISO 13849-1 PNOZ s1 Unit features ` Relay outputs: – 2 safety contacts (N/O), instantaneous ` 1 semiconductor output ` Connection options for: – E-STOP pushbutton – Safety gate limit switch – Reset button ` A connector can be used to connect 1 PNOZsigma contact expander module ` LED indicator for: – Supply voltage – Input status, channel 1 – Input status, channel 2 – Switch status, safety contacts – Reset circuit – Error ` Plug-in connection terminals (either spring-loaded terminal or screw terminal) Safety relay for monitoring E-STOP pushbuttons and safety gates. Approvals PNOZ s1 ‹ ‹ Unit description ‹ The safety relay meets the requirements of EN 60947-5-1, EN 60204-1 and VDE 0113-1 and may be used in applications with ` E-STOP pushbuttons ` Safety gates Safety features The relay meets the following safety requirements: ` The circuit is redundant with built-in self-monitoring. ` The safety function remains effective in the case of a component failure. ` The correct opening and closing of the safety function relays is tested automatically in each on-off cycle. ` The unit has an electronic fuse. Block diagram A1 A2 = Input K1 Interface expansion unit = 13 23 Power K2 Reset/ Start S34 Y32 14 24 Pilz GmbH & Co. KG, Felix-Wankel-Straße 2, 73760 Ostfildern, Germany Telephone: +49 711 3409-0, Telefax: +49 711 3409-133, E-Mail: pilz.gmbh@pilz.de NSG-D-2-392-2008-11 E-STOP relays, safety gate monitors Up to PL c of EN ISO 13849-1 PNOZ s1 Function description ` Single-channel operation: no redundancy in the input circuit, earth faults in the reset and input circuit are detected. ` Automatic start: Unit is active once the input circuit has been closed. ` Manual reset: Unit is active once the input circuit is closed and then the reset circuit is closed. ` Increase in the number of available instantaneous safety contacts by connecting contact expander modules or external contactors/relays; A connector can be used to connect 1 PNOZsigma contact expander module. Timing diagram 1 2 a b POWER Reset/Start Input Output safe Semi t1 t2 t1 t2 t1 t1 t2 t2 t3 Key ` Power: Supply voltage ` Reset/Start: Reset circuit S34 ` Input: Input circuits A1-A2 ` Output safe: Safety contacts 13-14, 23-24 ` Semi: Semiconductor outputY32 ` c: Automatic reset ` d: Manual reset ` a: Input circuit closes before reset circuit ` b: Reset circuit closes before input circuit ` t1: Switch-on delay ` t2: Delay-on de-energisation ` t3: Recovery time Wiring Please note: ` Information given in the “Technical details” must be followed. ` Outputs 13-14, 23-24 are safety contacts. ` To prevent contact welding, a fuse should be connected before the output contacts (see technical details). ` Calculation of the max. cable runs lmax in the input circuit: Imax = Rlmax Rl / km Rlmax = max. overall cable resistance (see technical details) Rl /km = cable resistance/km ` Use copper wire that can withstand 60/75 °C. ` Sufficient fuse protection must be provided on all output contacts with capacitive and inductive loads. Pilz GmbH & Co. KG, Felix-Wankel-Straße 2, 73760 Ostfildern, Germany Telephone: +49 711 3409-0, Telefax: +49 711 3409-133, E-Mail: pilz.gmbh@pilz.de NSG-D-2-392-2008-11 -2 E-STOP relays, safety gate monitors Up to PL c of EN ISO 13849-1 PNOZ s1 Preparing for operation ` Supply voltage Supply voltage AC DC A1 S1 L+ L- A2 ` Input circuit Input circuit Single-channel E-STOP without detection of shorts across contacts Dual-channel A1 S1 Safety gate without detection of shorts across contacts L+ S1 A1 L+ ` Reset circuit Reset circuit Reset circuit Feedback loop Automatic reset A1 S34 13 (23) 14 (24) A1 S34 Manual reset K5 K6 K5 L1 N K6 S3 A1 A1 S34 13 (23) 14 (24) S34 S3 K5 K6 K5 L1 N K6 ` Semiconductor output * Y32 PLC Input *Connect together the 0V connections on all the external power supplies Pilz GmbH & Co. KG, Felix-Wankel-Straße 2, 73760 Ostfildern, Germany Telephone: +49 711 3409-0, Telefax: +49 711 3409-133, E-Mail: pilz.gmbh@pilz.de NSG-D-2-392-2008-11 E-STOP relays, safety gate monitors Up to PL c of EN ISO 13849-1 PNOZ s1 ` Key S1 E-STOP pushbutton S3 Reset button Switch operated Gate open Gate closed INFORMATION If a base unit and a contact expansion module from the PNOZsigma range are linked via the connector, no additional wiring is necessary. Pilz GmbH & Co. KG, Felix-Wankel-Straße 2, 73760 Ostfildern, Germany Telephone: +49 711 3409-0, Telefax: +49 711 3409-133, E-Mail: pilz.gmbh@pilz.de NSG-D-2-392-2008-11 -4 E-STOP relays, safety gate monitors Up to PL c of EN ISO 13849-1 PNOZ s1 Terminal configuration Install base unit without contact expander module: ` Ensure that the plug terminator is inserted at the side of the unit. Connect base unit and PNOZsigma contact expander module: ` Remove the plug terminator at the side of the base unit and at the contact expander module. ` Connect the base unit and the contact expander module to the supplied connector before mounting the units to the DIN rail. Installation in control cabinet ` The safety relay should be installed in a control cabinet with a protection type of at least IP54. ` Use the notch on the rear of the unit to attach it to a DIN rail. ` Ensure the unit is mounted securely on a vertical DIN rail (35 mm) by using a fixing element (e.g. retaining bracket or an end angle). ` Push the unit upwards or downwards before lifting it from the DIN rail. Dimensions 120 (4.72") Installation 98 (3.86") 12,5 (0.69") * 100 (3,94") Pilz GmbH & Co. KG, Felix-Wankel-Straße 2, 73760 Ostfildern, Germany Telephone: +49 711 3409-0, Telefax: +49 711 3409-133, E-Mail: pilz.gmbh@pilz.de NSG-D-2-392-2008-11 E-STOP relays, safety gate monitors Up to PL c of EN ISO 13849-1 PNOZ s1 NOTICE This data sheet is only intended for use during configuration. For installation and operation, please refer to the op- erating instructions supplied with the unit. Technical details Electrical data Supply voltage Supply voltage UB DC Voltage tolerance Power consumption at UB DC Residual ripple DC Voltage and current at Input circuit DC: 24.0 V Reset circuit DC: 24.0 V Feedback loop DC: 24.0 V Number of output contacts Safety contacts (S) instantaneous: Utilisation category in accordance with EN 60947-4-1 Safety contacts: AC1 at 240 V Safety contacts: DC1 at 24 V Utilisation category in accordance with EN 60947-5-1 Safety contacts: AC15 at 230 V Safety contacts: DC13 at 24 V (6 cycles/min) Contact material External contact fuse protection (IK = 1 kA) to EN 60947-5-1 Blow-out fuse, quick Safety contacts: Blow-out fuse, slow Safety contacts: Circuit breaker 24 VAC/DC, characteristic B/C Safety contacts: Semiconductor outputs (short circuit proof) Max. overall cable resistance Rlmax input circuits, reset circuits single-channel at UB DC Safety-related characteristic data Performance level (PL) in accordance with EN ISO 13849-1 Safety contacts, instantaneous Category of output contacts in accordance with EN 954-1, EN ISO 13849-1 Safety contacts (S) instantaneous: SIL claim limit (SIL CL) in accordance with EN IEC 62061 Safety contacts, instantaneous Probability of dangerous failure per hour (PFHD) in accordance with EN IEC 62061 Safety contacts, instantaneous Mission time/Proof test interval in years 24 V -15 %/+10 % 2.0 W 20 % 60.0 mA 20.0 mA 20.0 mA 2 Imin: 0.02 A , Imax: 3.0 A Pmax: 720 VA Imin: 0.02 A , Imax: 3.0 A Pmax: 72 W Imax: 1.5 A Imax: 1.5 A AgSnO2 4A 2A 2A 24.0 V DC,20 mA 30 Ohm c 2 2 2.00E-07 1/h 20 Pilz GmbH & Co. KG, Felix-Wankel-Straße 2, 73760 Ostfildern, Germany Telephone: +49 711 3409-0, Telefax: +49 711 3409-133, E-Mail: pilz.gmbh@pilz.de NSG-D-2-392-2008-11 -6 E-STOP relays, safety gate monitors Up to PL c of EN ISO 13849-1 PNOZ s1 Times Switch-on delay with automatic reset typ. with automatic reset max. with automatic reset after power on typ. with automatic reset after power on max. with manual reset typ. with manual reset max. Delay-on de-energisation with E-STOP typ. with E-STOP max. with power failure typ. with power failure max. Recovery time at max. switching frequency 1/s after E-STOP after power failure Supply interruption before de-energisation Environmental data EMC Vibration to EN 60068-2-6 Frequency Amplitude Climatic suitability Airgap creepage in accordance with EN 60947-1 Pollution degree Rated insulation voltage Rated impulse withstand voltage Ambient temperature Storage temperature Protection type Mounting (e.g. cabinet) Housing Terminals Mechanical data Housing material Housing Front Cross section of external conductors with screw terminals 1 core flexible 2 core, same cross section, flexible: with crimp connectors, without insulating sleeve without crimp connectors or with TWIN crimp connectors Torque setting with screw terminals Cross section of external conductors with spring-loaded terminals: Flexible with/without crimp connectors Spring-loaded terminals: Terminal points per connection Stripping length Dimensions Height Width Depth Weight 100 ms 150 ms 100 ms 150 ms 50 ms 60 ms 30 ms 40 ms 30 ms 40 ms 100 ms 100 ms 10 ms EN 60947-5-1, EN 61000-6-2, EN 61000-6-4 10 - 55 Hz 0.35 mm EN 60068-2-78 2 250 V 4.0 kV -10 - 55 °C -40 - 85 °C IP54 IP40 IP20 PC PC 0.25 - 2.50 mm² , 24 - 12 AWG Order no.: 750101 0.25 - 1.00 mm² , 24 - 16 AWG Order no.: 750101 0.20 - 1.50 mm² , 24 - 16 AWG Order no.: 750101 0.50 Nm Order no.: 750101 0.20 - 2.50 mm² , 24 - 12 AWG Order no.: 751101 2 Order no.: 751101 9 mm Order no.: 751101 100.0 mm Order no.: 751101 98.0 mm Order no.: 750101 12.5 mm 120.0 mm 105 g The standards current on 2006-04 apply. Pilz GmbH & Co. KG, Felix-Wankel-Straße 2, 73760 Ostfildern, Germany Telephone: +49 711 3409-0, Telefax: +49 711 3409-133, E-Mail: pilz.gmbh@pilz.de NSG-D-2-392-2008-11 E-STOP relays, safety gate monitors Up to PL c of EN ISO 13849-1 PNOZ s1 Conventional thermal current Ith (A) at UB DC 1 contact 2 contacts 3.00 A 3.00 A Order reference Type PNOZ s1 PNOZ s1 C Features 24 VDC 24 VDC Pilz GmbH & Co. KG, Felix-Wankel-Straße 2, 73760 Ostfildern, Germany Telephone: +49 711 3409-0, Telefax: +49 711 3409-133, E-Mail: pilz.gmbh@pilz.de Terminals With screw terminal With spring-loaded terminal Order no. 750 101 751 101 NSG-D-2-392-2008-11 -8
750101 价格&库存
很抱歉,暂时无法提供与“750101”相匹配的价格&库存,您可以联系我们找货
