751101
751101
    PILZ
751101 数据手册
E-STOP relays, safety gate monitors Up to PL c of EN ISO 13849-1 PNOZ s1 ` E-STOP pushbuttons ` Safety gates Unit features ` Relay outputs: – 2 safety contacts (N/O), instantaneous ` 1 semiconductor output ` Connection options for: – E-STOP pushbutton – Safety gate limit switch – Reset button ` A connector can be used to connect 1 PNOZsigma contact expander module ` LED indicator for: – Supply voltage – Input status, channel 1 – Input status, channel 2 – Switch status, safety contacts – Reset circuit – Error ` Plug-in connection terminals (either spring-loaded terminal or screw terminal) Gertemerkmale Gertebild Safety relay for monitoring E-STOP pushbuttons and safety gates. ][Bildunterschrift Approvals PNOZ s1 ‹ SÜDDEUTSCHLAND ‹ Safety features The relay meets the following safety requirements: ` The circuit is redundant with built-in self-monitoring. ` The safety function remains effective in the case of a component failure. ` The correct opening and closing of the safety function relays is tested automatically in each on-off cycle. ` The unit has an electronic fuse. ][Sicherheitseigenschaften Schaltgerät_allgemeiner Teil Sicherheitseigenschaften Zusatz - Sicherung DC_PNOZ Unit description The safety relay meets the requirements of EN 60947-5-1, EN 60204-1 and VDE 0113-1 and may be used in applications with Bestimmung/Gertebeschreibung NOT-AUS, Schutz_PNOZ ‹ Zulassungen Block diagram il tb a h s k c lo B d A1 A2 = Input K1 Interface expansion unit = 13 23 Power K2 Reset/ Start S34 Y32 14 24 Pilz GmbH & Co. KG, Felix-Wankel-Straße 2, 73760 Ostfildern, Germany Telephone: +49 711 3409-0, Telefax: +49 711 3409-133, E-Mail: pilz.gmbh@pilz.de NSG-D-2-392-2010-10 E-STOP relays, safety gate monitors Up to PL c of EN ISO 13849-1 PNOZ s1 ` Automatic start: Unit is active once the input circuit has been closed. ` Manual reset: Unit is active once the input circuit is closed and then the reset circuit is closed. ` Increase in the number of available instantaneous safety contacts by Function description ` Single-channel operation: no redundancy in the input circuit, earth faults in the reset and input circuit are detected. ][Funktionen_einkanalig connecting contact expander modules or external contactors/relays; A connector can be used to connect 1 PNOZsigma contact expander module. ][Funktionen_manuStart ][Funktionen_Kontaktvervielfachung_PNOZsigma ][Funktionen_autoStart Timing diagram s n o u _ rm g a itd e ][Z 1 2 a b POWER Reset/Start Input Output safe Semi t1 t2 t1 t2 t1 t1 t2 t2 t3 Key ` Power: Supply voltage ` Reset/Start: Reset circuit S34 ` Input: Input circuits A1-A2 ` Output safe: Safety contacts 13-14, 23-24 ` Semi: Semiconductor outputY32 ` c: Automatic reset ` d: Manual reset ` a: Input circuit closes before reset circuit ` b: Reset circuit closes before input circuit ` t1: Switch-on delay ` t2: Delay-on de-energisation ` t3: Recovery time Wiring Please note: ` Information given in the “Technical details” must be followed. ` Outputs 13-14, 23-24 are safety contacts. ` To prevent contact welding, a fuse should be connected before the output contacts (see technical details). ` Calculation of the max. cable runs lmax in the input circuit: ][Verdrahtung_Si_unverz Imax = Rlmax Rl / km Rlmax = max. overall cable resistance (see technical details) Rl /km = cable resistance/km ` Use copper wire that can withstand 60/75 °C. ` Sufficient fuse protection must be provided on all output contacts with capacitive and inductive loads. Pilz GmbH & Co. KG, Felix-Wankel-Straße 2, 73760 Ostfildern, Germany Telephone: +49 711 3409-0, Telefax: +49 711 3409-133, E-Mail: pilz.gmbh@pilz.de NSG-D-2-392-2010-10 -2 E-STOP relays, safety gate monitors Up to PL c of EN ISO 13849-1 PNOZ s1 Preparing for operation Betriebsbereitschaft herstellen ` Supply voltage Supply voltage AC DC A1 S1 L+ L- A2 ` Input circuit Input circuit Single-channel E-STOP without detection of shorts across contacts Dual-channel A1 S1 Safety gate without detection of shorts across contacts L+ S1 A1 L+ ` Reset circuit Reset circuit Reset circuit Feedback circuit Automatic reset A1 S34 13 (23) 14 (24) A1 S34 Manual reset K5 K6 K5 L1 N K6 S3 A1 S34 Pilz GmbH & Co. KG, Felix-Wankel-Straße 2, 73760 Ostfildern, Germany Telephone: +49 711 3409-0, Telefax: +49 711 3409-133, E-Mail: pilz.gmbh@pilz.de A1 S34 13 (23) 14 (24) S3 K5 K6 K5 L1 N K6 NSG-D-2-392-2010-10 E-STOP relays, safety gate monitors Up to PL c of EN ISO 13849-1 PNOZ s1 ` Semiconductor output * Y32 PLC Input *Connect together the 0V connections on all the external power supplies ` Key S1 E-STOP pushbutton S3 Reset button Switch operated Gate open Gate closed INFORMATION If a base unit and a contact expansion module from the PNOZsigma range are linked via the connector, no additional wiring is necessary. ][Betriebsbereitschaft_herstellen_Info_Grundgert_DB Pilz GmbH & Co. KG, Felix-Wankel-Straße 2, 73760 Ostfildern, Germany Telephone: +49 711 3409-0, Telefax: +49 711 3409-133, E-Mail: pilz.gmbh@pilz.de NSG-D-2-392-2010-10 -4 E-STOP relays, safety gate monitors Up to PL c of EN ISO 13849-1 PNOZ s1 Terminal configuration u g b n m le K Installation Install base unit without contact expander module: ` Ensure that the plug terminator is inserted at the side of the unit. Connect base unit and PNOZsigma contact expander module: ` Remove the plug terminator at the side of the base unit and at the contact expander module. ` Connect the base unit and the contact expander module to the supplied connector before mounting the units to the DIN rail. Installation in control cabinet ` The safety relay should be installed in a control cabinet with a protection type of at least IP54. ` Use the notch on the rear of the unit to attach it to a DIN rail (35 mm). ` When installed vertically: Secure the unit by using a fixing element (e.g. retaining brakket or end angle). ` Push the unit upwards or downwards before lifting it from the DIN rail. Dimensions g n u s e m b A 120 (4.72") ][Montage_PNOZsigma 98 (3.86") 12,5 (0.69") * 100 (3,94") Pilz GmbH & Co. KG, Felix-Wankel-Straße 2, 73760 Ostfildern, Germany Telephone: +49 711 3409-0, Telefax: +49 711 3409-133, E-Mail: pilz.gmbh@pilz.de NSG-D-2-392-2010-10 E-STOP relays, safety gate monitors Up to PL c of EN ISO 13849-1 PNOZ s1 NOTICE This data sheet is only intended for use during configuration. For installation and operation, please refer to the operating instructions supplied with the unit. ][WICHTIG_PDB_alt Technical details PNOZsigma Technical details Electrical data Supply voltage Supply voltage UB DC Voltage tolerance Power consumption at UB DC Residual ripple DC Voltage and current at Input circuit DC: 24.0 V Reset circuit DC: 24.0 V Feedback loop DC: 24.0 V Number of output contacts Safety contacts (S) instantaneous: Utilisation category in accordance with EN 60947-4-1 Safety contacts: AC1 at 240 V Safety contacts: DC1 at 24 V Utilisation category in accordance with EN 60947-5-1 Safety contacts: AC15 at 230 V Safety contacts: DC13 at 24 V (6 cycles/min) Contact material External contact fuse protection (IK = 1 kA) to EN 60947-5-1 Blow-out fuse, quick Safety contacts: Blow-out fuse, slow Safety contacts: Circuit breaker 24 VAC/DC, characteristic B/C Safety contacts: Semiconductor outputs (short circuit proof) Max. overall cable resistance Rlmax input circuits, reset circuits single-channel at UB DC Safety-related characteristic data PL in accordance with EN ISO 13849-1 Category in accordance with EN 954-1 SIL CL in accordance with EN IEC 62061 PFH in accordance with EN IEC 62061 SIL in accordance with IEC 61511 PFD in accordance with IEC 61511 tM in years Times Switch-on delay with automatic reset typ. with automatic reset max. with automatic reset after power on typ. with automatic reset after power on max. with manual reset typ. with manual reset max. 24 V -15 %/+10 % 2.0 W 20 % 60.0 mA 20.0 mA 20.0 mA 2 Imin: 0.02 A , Imax: 3.0 A Pmax: 720 VA Imin: 0.02 A , Imax: 3.0 A Pmax: 72 W Imax: 1.5 A Imax: 1.5 A AgSnO2 4A 2A 2A 24.0 V DC, 20 mA 30 Ohm PL c (Cat. 3) Cat. 3 SIL CL 2 2.00E-07 SIL 2 5.95E-03 20 100 ms 150 ms 100 ms 150 ms 50 ms 60 ms Pilz GmbH & Co. KG, Felix-Wankel-Straße 2, 73760 Ostfildern, Germany Telephone: +49 711 3409-0, Telefax: +49 711 3409-133, E-Mail: pilz.gmbh@pilz.de NSG-D-2-392-2010-10 -6 E-STOP relays, safety gate monitors Up to PL c of EN ISO 13849-1 PNOZ s1 Times Delay-on de-energisation with E-STOP typ. with E-STOP max. with power failure typ. with power failure max. Recovery time at max. switching frequency 1/s after E-STOP after power failure Supply interruption before de-energisation Environmental data EMC Vibration to EN 60068-2-6 Frequency Amplitude Climatic suitability Airgap creepage in accordance with EN 60947-1 Pollution degree Overvoltage category Rated insulation voltage Rated impulse withstand voltage Ambient temperature Storage temperature Protection type Mounting (e.g. cabinet) Housing Terminals Mechanical data Housing material Housing Front Cross section of external conductors with screw terminals 1 core flexible 2 core, same cross section, flexible: with crimp connectors, without insulating sleeve without crimp connectors or with TWIN crimp connectors Torque setting with screw terminals Cross section of external conductors with spring-loaded terminals: Flexible with/without crimp connectors Spring-loaded terminals: Terminal points per connection Stripping length Dimensions Height Width Depth Weight 30 ms 40 ms 30 ms 40 ms 100 ms 100 ms 10 ms EN 60947-5-1, EN 61000-6-2, EN 61000-6-4 10 - 55 Hz 0.35 mm EN 60068-2-78 2 III 250 V 4.00 kV -10 - 55 °C -40 - 85 °C IP54 IP40 IP20 PC PC 0.25 - 2.50 mm² , 24 - 12 AWG No. 750101 0.25 - 1.00 mm² , 24 - 16 AWG No. 750101 0.20 - 1.50 mm² , 24 - 16 AWG No. 750101 0.50 Nm No. 750101 0.20 - 2.50 mm² , 24 - 12 AWG No. 751101 2 No. 751101 9 mm No. 751101 100.0 mm No. 751101 98.0 mm No. 750101 12.5 mm 120.0 mm 105 g Technische Daten_Satz No. No. stands for order number. Si_Kennzahlen_Erläuterung All the units used within a safety function must be considered when calculating the safety characteristic data. Technische Daten_Satz Normen The standards current on 2006-04 apply. ][Dauerstrom_DC Pilz GmbH & Co. KG, Felix-Wankel-Straße 2, 73760 Ostfildern, Germany Telephone: +49 711 3409-0, Telefax: +49 711 3409-133, E-Mail: pilz.gmbh@pilz.de NSG-D-2-392-2010-10 E-STOP relays, safety gate monitors Up to PL c of EN ISO 13849-1 PNOZ s1 Conventional thermal current Ith (A) at UB DC 1 contact 2 contacts 3.00 A 3.00 A Bestelldaten Order reference Type PNOZ s1 PNOZ s1 C Features 24 VDC 24 VDC Pilz GmbH & Co. KG, Felix-Wankel-Straße 2, 73760 Ostfildern, Germany Telephone: +49 711 3409-0, Telefax: +49 711 3409-133, E-Mail: pilz.gmbh@pilz.de Terminals With screw terminal With spring-loaded terminal Order no. 750 101 751 101 NSG-D-2-392-2010-10 -8
751101 价格&库存
很抱歉,暂时无法提供与“751101”相匹配的价格&库存,您可以联系我们找货
