751105
751105
    PILZ
751105 数据手册
E-STOP relays, safety gate monitors Up to PL e of EN ISO 13849-1 PNOZ s5 Unit features  See order reference for unit types  Positive-guided relay outputs: – 2 safety contacts (N/O), instantaneous – 2 safety contacts (N/O), delay-on de-energisation  1 semiconductor output  Connection options for: – E-STOP pushbutton – Safety gate limit switch – Reset button – Light barriers – PSEN  A connector can be used to connect 1 PNOZsigma contact expander module  Delay-on de-energisation selectable  Operating modes and delay times can be selected via rotary switches  LED indicator for: – Supply voltage – Input status, channel 1 – Input status, channel 2 – Switch status channel 1/2 – Reset circuit – Error  Plug-in connection terminals (either spring-loaded terminal or screw terminal) Unit description Gertemerkmale Gertebild Safety relay for monitoring E-STOP pushbuttons, safety gates and light beam devices ][Bildunterschrift_NOT_Sch.tuer_Licht Approvals PNOZ s5    The safety relay meets the requirements of EN 60947-5-1, EN 60204-1 and VDE 0113-1 and may be used in applications with  E-STOP pushbuttons  Safety gates  Light beam devices Bestimmung/Gerätebeschreibung NOT-AUS, Schutzt, Lichtschr_PNOZ Safety features The relay meets the following safety requirements:  The circuit is redundant with built-in self-monitoring.  The safety function remains effective in the case of a component failure.  The correct opening and closing of the safety function relays is tested automatically in each on-off cycle.  The unit has an electronic fuse. ][Sicherheitseigenschaften Schaltgerät_allgemeiner Teil Sicherheitseigenschaften Zusatz - Sicherung DC_PNOZ ][Gertemerkmale_Zusatz_Datenblatt Zulassungen Block diagram il tb a h s k c lo B d ( S11 S12 S21 S22 13 23 37 47 = Input Input K3 Interface expansion unit = (~)* il tb a h s k c lo ][B T N S rW u *n _ d )* A1 A2 K1 K4 Power K2 Reset/ Start S34 Y32 14 24 38 48 *only with UB = 48 – 240 V AC/DC Pilz GmbH & Co. KG, Felix-Wankel-Straße 2, 73760 Ostfildern, Germany Telephone: +49 711 3409-0, Telefax: +49 711 3409-133, E-Mail: pilz.gmbh@pilz.de 1001972-EN-04-2012-05 E-STOP relays, safety gate monitors Up to PL e of EN ISO 13849-1 PNOZ s5 Function description  Single-channel operation: no redundancy in the input circuit, earth faults in the reset and input circuit are detected.  Dual-channel operation without detection of shorts across contacts: redundant input circuit, detects – earth faults in the reset and input circuit, – short circuits in the input circuit and, with a monitored reset, in the reset circuit too.  Dual-channel operation with detection of shorts across contacts: redundant input circuit, detects – earth faults in the reset and input circuit, – short circuits in the input circuit and, with a monitored reset, in the reset circuit too, – shorts between contacts in the input circuit.  Automatic start: Unit is active once the input circuit has been closed.  Manual reset: Unit is active once the input circuit is closed and then the reset circuit is closed.  Monitored reset with falling edge: Unit is active once – the input circuit is closed and then the reset circuit is closed and opened again. – the reset circuit is closed and then opened again once the input circuit is closed.  Monitored reset with rising edge: Unit is active once the input circuit is closed and once the reset circuit is closed after the waiting period has elapsed (see technical details).  Reset with start-up test: The unit checks whether safety gates that are closed are opened and then closed again when supply voltage is applied.  Ability to increase the number of contacts available on the – instantaneous safety contacts by using connectors to link to a PNOZsigma contact expansion module – delayed/instantaneous safety contacts by connecting contact expansion modules or external contactors ][Funktionen_einkanalig ][Funktionen_zweikanalig_ohne_quer ][Funktionen_zweikanalig_mit_quer_ber ][Funktionen_autoStart ][Funktionen_manuStart ][Funktionen_berStart_fall_Flanke ][Funktionen_berStart_steig_Flanke ][Funktionen_Start_Anlauftest Funktionsbeschreibung Pilz GmbH & Co. KG, Felix-Wankel-Straße 2, 73760 Ostfildern, Germany Telephone: +49 711 3409-0, Telefax: +49 711 3409-133, E-Mail: pilz.gmbh@pilz.de 1001972-EN-04-2012-05 -2 E-STOP relays, safety gate monitors Up to PL e of EN ISO 13849-1 PNOZ s5 Timing diagram f lA S 2 1 b n o u s O N P _ rm g a itd e ][Z 1 2 a b POWER Reset/Start Input Output safe Output safe del. Output semi t1 t2 t5 t1 t2 t5 t1 3 a a b t1 t2 t5 t2 t5 4 5 b POWER Reset/Start Input Output safe Output safe del. Output semi t3 t1 t2 Key  Power: Supply voltage  Reset/Start: Reset circuit S12-S34  Input: Input circuits S11-S12, S21S22  Output safe: Safety contacts 13-14, 23-24  Out semi: Semiconductor outputY32  : Automatic reset t1 t3 t4 t1 t2 t5 t1      : Manual reset : Monitored reset with rising edge : Monitored reset with falling edge : Reset with start-up test a: Input circuit closes before reset circuit  b: Reset circuit closes before input circuit t2 t5 t6 t1 t2 t6 t5 t1     t1: Switch-on delay t2: Delay-on de-energisation t3: Waiting period t4: Waiting period reset circuit was closed  t5: Delay time  t6: Minimum time safety gates open Wiring Please note:  Information given in the “Technical details” must be followed.  Outputs 13-14, 23-24 are instantaneous safety contacts, outputs 3738, 47-48 are delay-on de-energisation safety contacts.  To prevent contact welding, a fuse should be connected before the output contacts (see technical details).  Calculation of the max. cable runs lmax in the input circuit: ][Verdrahtung_Si_unverz_verz Imax = Rlmax Rl / km Rlmax = max. overall cable resistance (see technical details) Rl / km = cable resistance/km  Use copper wire that can withstand 60/75 °C.  Sufficient fuse protection must be provided on all output contacts with capacitive and inductive loads.  With UB 48 – 240 VAC/DC: Connect S21 to the protective earth system ][Verdrahtung_Zusatz_AC Pilz GmbH & Co. KG, Felix-Wankel-Straße 2, 73760 Ostfildern, Germany Telephone: +49 711 3409-0, Telefax: +49 711 3409-133, E-Mail: pilz.gmbh@pilz.de 1001972-EN-04-2012-05 E-STOP relays, safety gate monitors Up to PL e of EN ISO 13849-1 PNOZ s5 Preparing for operation Betriebsbereitschaft herstellen PNOZs  Supply voltage Supply voltage AC DC S21 A1 L A2 N A1 L+ A2 L-  Input circuit Input circuit E-STOP without detection of shorts across contacts Single-channel Dual-channel S11 S1 S11 S1 S12 S12 S22 S22 E-STOP with detection of shorts across contacts S11 S1 S21 S22 S12 Safety gate without detection of shorts across contacts S11 S1 S11 S12 S22 S1 S2 S12 S22 Safety gate with detection of shorts across contacts S11 S12 S21 S22 Light beam device or safety switch with detection of shorts across contacts via ESPE (only when UB = 24 VDC) Pilz GmbH & Co. KG, Felix-Wankel-Straße 2, 73760 Ostfildern, Germany Telephone: +49 711 3409-0, Telefax: +49 711 3409-133, E-Mail: pilz.gmbh@pilz.de S1 S2 24 V DC A2 S12 S22 GND 1001972-EN-04-2012-05 -4 E-STOP relays, safety gate monitors Up to PL e of EN ISO 13849-1 PNOZ s5  Reset circuit/feedback loop Reset circuit/feedback loop Reset circuit Feedback circuit Automatic reset S12 S34 13 (23,33,37,47) 14 (24,34,38,48) S12 S34 Manual/monitored reset K5 K6 K5 L1 N K6 S3 S12 S12 S34 13 (23,33,37,47) 14 (24,34,38,48) S34 S3 K5 K6 K5 L1 N K6  Semiconductor output UB 24 VDC UB 48 – 240 VAC/DC * Y32 PLC Input Y32 PLC Input S21 Gnd *Connect together the 0V connections on all the external power supplies  Key S1/S2 S3 E-STOP/safety gate switch Reset button Switch operated Gate open Gate closed Pilz GmbH & Co. KG, Felix-Wankel-Straße 2, 73760 Ostfildern, Germany Telephone: +49 711 3409-0, Telefax: +49 711 3409-133, E-Mail: pilz.gmbh@pilz.de 1001972-EN-04-2012-05 E-STOP relays, safety gate monitors Up to PL e of EN ISO 13849-1 PNOZ s5 Terminal configuration u g b n m le K Installation Dimensions Install base unit without contact expander module:  Ensure that the plug terminator is inserted at the side of the unit. Connect base unit and PNOZsigma contact expander module:  Remove the plug terminator at the side of the base unit and at the contact expander module.  Connect the base unit and the contact expander module to the supplied connector before mounting the units to the DIN rail. Installation in control cabinet  The safety relay should be installed in a control cabinet with a protection type of at least IP54.  Use the notch on the rear of the unit to attach it to a DIN rail (35 mm).  When installed vertically: Secure the unit by using a fixing element (e.g. retaining brakket or end angle).  Push the unit upwards or downwards before lifting it from the DIN rail. Abmessungen *with spring-loaded terminals 120 (4.72") ][Montage_PNOZsigma 98 (3.86") * 100 (3,94") Pilz GmbH & Co. KG, Felix-Wankel-Straße 2, 73760 Ostfildern, Germany Telephone: +49 711 3409-0, Telefax: +49 711 3409-133, E-Mail: pilz.gmbh@pilz.de 22,5 (0.88") 1001972-EN-04-2012-05 -6 E-STOP relays, safety gate monitors Up to PL e of EN ISO 13849-1 PNOZ s5 Notice This data sheet is only intended for use during configuration. Please refer to the operating manual for installation and operation. ][Wichtig_PDB Service life graph The service life graphs indicate the number of cycles from which failures due to wear must be expected. The wear is mainly caused by the electrical load; the mechanical load is negligible. Lebensdauerkurve_Relais_Text vor Kurve Example  Inductive load: 0,2 A  Utilisation category: AC15  Contact service life: 1,000,000 cycles Provided the application requires fewer than 1,000,000 cycles, the PFH value (see technical details) can be used in the calculation. Lebensdauerkurve_Relais_Text nach Kurve_SIS Bsp v rk u a d s n b e L To increase the service life, sufficient spark suppression must be provided on all output contacts. With capacitive loads, any power surges that occur must be noted. With contactors, use freewheel diodes for spark suppression. Technical details PNOZsigma Technical details Electrical data Supply voltage Supply voltage UB DC Supply voltage UB AC/DC Voltage tolerance Power consumption at UB AC Power consumption at UB DC Frequency range AC Residual ripple DC Voltage and current at Input circuit DC: 24.0 V Reset circuit DC: 24.0 V Feedback loop DC: 24.0 V 24 V 48 - 240 V -15 %/+10 % 8.0 VA No. 750135, 751135 4.0 W 50 - 60 Hz 160 % No. 750135, 751135 20 % No. 750105, 751105, 751185 40.0 mA 40.0 mA 40.0 mA Pilz GmbH & Co. KG, Felix-Wankel-Straße 2, 73760 Ostfildern, Germany Telephone: +49 711 3409-0, Telefax: +49 711 3409-133, E-Mail: pilz.gmbh@pilz.de 1001972-EN-04-2012-05 E-STOP relays, safety gate monitors Up to PL e of EN ISO 13849-1 PNOZ s5 Electrical data Number of output contacts Safety contacts (S) instantaneous: Safety contacts (N/O), delayed: Utilisation category in accordance with EN 60947-4-1 Safety contacts: AC1 at 240 V Safety contacts: DC1 at 24 V Safety contacts, delayed: AC1 at 240 V Safety contacts, delayed: DC1 at 24 V Utilisation category in accordance with EN 60947-5-1 Safety contacts: AC15 at 230 V Safety contacts: DC13 at 24 V (6 cycles/min) Safety contacts, delayed: AC15 at 230 V Safety contacts, delayed: DC13 at 24 V (6 cycles/min) Contact material External contact fuse protection (IK = 1 kA) to EN 60947-5-1 Blow-out fuse, quick Safety contacts: Safety contacts, delayed: Blow-out fuse, slow Safety contacts: Safety contacts, delayed: Circuit breaker 24 VAC/DC, characteristic B/C Safety contacts: Safety contacts, delayed: Semiconductor outputs (short circuit proof) Max. overall cable resistance Rlmax input circuits, reset circuits single-channel at UB DC single-channel at UB AC dual-channel without detect. of shorts across contacts at UB DC dual-channel without detect. of shorts across contacts at UB AC dual-channel with detect. of shorts across contacts at UB DC dual-channel with detect. of shorts across contacts at UB AC Min. input resistance when switching on Safety-related characteristic data PL in accordance with EN ISO 13849-1: 2006 Safety contacts, instantaneous Safety contacts, delayed Category in accordance with EN 954-1 Safety contacts, instantaneous Safety contacts, delayed SIL CL in accordance with EN IEC 62061 Safety contacts, instantaneous Safety contacts, delayed PFH in accordance with EN IEC 62061 Safety contacts, instantaneous Safety contacts, delayed SIL in accordance with IEC 61511 Safety contacts, instantaneous Safety contacts, delayed 2 2 Imin: 0.01 A , Imax: 6.0 A Pmax: 1500 VA Imin: 0.01 A , Imax: 6.0 A Pmax: 150 W Imin: 0.01 A , Imax: 6.0 A Pmax: 1500 VA Imin: 0.01 A , Imax: 6.0 A Pmax: 150 W Imax: 3.0 A Imax: 4.0 A Imax: 3.0 A Imax: 4.0 A AgCuNi + 0.2 µm Au 6A 6A 4A 4A 4A 4A 24.0 V DC, 20 mA 30 Ohm 30 Ohm No. 750135, 751135 30 Ohm 30 Ohm No. 750135, 751135 30 Ohm 30 Ohm No. 750135, 751135 110 Ohm PL e (Cat. 4) PL e (Cat. 4) Cat. 4 Cat. 4 SIL CL 3 SIL CL 3 2.31E-09 2.34E-09 SIL 3 SIL 3 Pilz GmbH & Co. KG, Felix-Wankel-Straße 2, 73760 Ostfildern, Germany Telephone: +49 711 3409-0, Telefax: +49 711 3409-133, E-Mail: pilz.gmbh@pilz.de 1001972-EN-04-2012-05 -8 E-STOP relays, safety gate monitors Up to PL e of EN ISO 13849-1 PNOZ s5 Safety-related characteristic data PFD in accordance with IEC 61511 Safety contacts, instantaneous Safety contacts, delayed TM [year] in accordance with EN ISO 13849-1: 2006 Times Switch-on delay with automatic reset typ. with automatic reset max. with automatic reset after power on typ. with automatic reset after power on max. with manual reset typ. with manual reset max. on monitored reset with rising edge typ. on monitored reset with rising edge max. on monitored reset with falling edge typ. on monitored reset with falling edge max. Delay-on de-energisation with E-STOP typ. with E-STOP max. with power failure typ. with power failure max. Recovery time at max. switching frequency 1/s after E-STOP after power failure Delay time tV: selectable Repetition accuracy Repetition accuracy in the case of a fault Time accuracy Waiting period with a monitored reset with rising edge with falling edge Min. start pulse duration with a monitored reset with rising edge with falling edge Simultaneity, channel 1 and 2 Supply interruption before de-energisation Environmental data EMC Vibration to EN 60068-2-6 Frequency Amplitude Climatic suitability Airgap creepage in accordance with EN 60947-1 Pollution degree Overvoltage category Rated insulation voltage Rated impulse withstand voltage Ambient temperature Storage temperature 2.03E-06 2.75E-05 20 180 ms 400 ms 1,430 ms 2,000 ms 45 ms 85 ms 45 ms 130 ms 60 ms 150 ms 15 ms 20 ms 75 ms 110 ms 150 ms +tv 200 ms 0,00 s; 0,10 s; 0,20 s; 0,30 s; 0,40 s; 0,50 s; 0,60 s; 0,70 s; 0,80 s; 1,00 s; 1,50 s; 2,00 s; 2,50 s; 3,00 s; 3,50 s; 4,00 s; 5,00 s; 6,00 s; 7,00 s; 8,00 s; 10,00 s; 12,00 s; 14,00 s; 15,00 s; 16,00 s; 20,00 s; 25,00 s; 30,00 s; 35,00 s; 40,00 s; 50,00 s; 60,00 s; 70,00 s; 80,00 s; 90,00 s; 100,00 s; 120,00 s; 140,00 s; 150,00 s; 160,00 s; 180,00 s; 200,00 s; 210,00 s; 240,00 s; 300,00 s +/-1 % + +/-20 ms +/-15 % + +/-20 ms +/-1 % + +/-20 ms 150 ms 240 ms 30 ms 70 ms ∞ 20 ms EN 60947-5-1, EN 61000-6-2, EN 61000-6-4 10.0 - 55.0 Hz 0.35 mm EN 60068-2-78 2 III / II 250 V 4.00 kV -10 - 55 °C -40 - 85 °C Pilz GmbH & Co. KG, Felix-Wankel-Straße 2, 73760 Ostfildern, Germany Telephone: +49 711 3409-0, Telefax: +49 711 3409-133, E-Mail: pilz.gmbh@pilz.de 1001972-EN-04-2012-05 E-STOP relays, safety gate monitors Up to PL e of EN ISO 13849-1 PNOZ s5 Environmental data Protection type Mounting (e.g. cabinet) Housing Terminals Mechanical data Housing material Housing Front Cross section of external conductors with screw terminals 1 core flexible 2 core, same cross section, flexible: with crimp connectors, without insulating sleeve without crimp connectors or with TWIN crimp connectors Torque setting with screw terminals Cross section of external conductors with spring-loaded terminals: Flexible with/without crimp connectors Spring-loaded terminals: Terminal points per connection Stripping length Dimensions Height Width Depth Weight IP54 IP40 IP20 PC PC 0.25 - 2.50 mm² , 24 - 12 AWG No. 750105, 750135 0.25 - 1.00 mm² , 24 - 16 AWG No. 750105, 750135 0.20 - 1.50 mm² , 24 - 16 AWG No. 750105, 750135 0.50 Nm No. 750105, 750135 0.20 - 2.50 mm² , 24 - 12 AWG No. 751105, 751135, 751185 2 No. 751105, 751135, 751185 9 mm No. 751105, 751135, 751185 100.0 mm No. 751105, 751135, 751185 98.0 mm No. 750105, 750135 22.5 mm 120.0 mm 235 g No. 750105, 751105, 751185 260 g No. 750135, 751135 Technische Daten_Satz No. No. stands for order number. It is essential to consider the relay's service life graphs. The relay outputs' safety-related characteristic data is only valid if the values in the service life graphs are met. Si-Kennzahlen_Zusatz_Relais_Lebensdauer_PDB The PFH value depends on the switching frequency and the load on the relay output. If the service life graphs are not accessible, the stated PFH value can be used irrespective of the switching frequency and the load, as the PFH value already considers the relay's B10d value as well as the failure rates of the other components. Si_Kennzahlen_Erläuterung_1 All the units used within a safety function must be considered when calculating the safety characteristic data. INFORMATION A safety function's SIL/PL values are not identical to the SIL/PL values of the units that are used and may be different. We recommend that you use the PAScal software tool to calculate the safety function's SIL/PL values. Si_Kennzahlen_Erläuterung_2 Technische Daten_Satz Normen The standards current on 2009-12 apply. ][Dauerstrom_ACDC Conventional thermal current while loading several contacts Number of contacts 1 2 3 4 Ith per contact at UB DC 6.00 A 6.00 A 6.00 A 6.00 A Ith at UB AC 6.00 A No. 750135, 751135 6.00 A No. 750135, 751135 6.00 A No. 750135, 751135 6.00 A No. 750135, 751135 Bestelldaten Pilz GmbH & Co. KG, Felix-Wankel-Straße 2, 73760 Ostfildern, Germany Telephone: +49 711 3409-0, Telefax: +49 711 3409-133, E-Mail: pilz.gmbh@pilz.de 1001972-EN-04-2012-05 -10 E-STOP relays, safety gate monitors Up to PL e of EN ISO 13849-1 PNOZ s5 Order reference Type PNOZ s5 PNOZ s5 C PNOZ s5 C (coated version) PNOZ s5 PNOZ s5 C Features 48 – 240 VAC 48 – 240 VAC 24 VDC 24 VDC 24 VDC Terminals With screw terminals With spring-loaded terminals With spring-loaded terminals Order no. 750 105 751 105 751 185 48 – 240 VDC 48 – 240 VDC With screw terminals With spring-loaded terminals 750 135 751 135 Pilz GmbH & Co. KG, Felix-Wankel-Straße 2, 73760 Ostfildern, Germany Telephone: +49 711 3409-0, Telefax: +49 711 3409-133, E-Mail: pilz.gmbh@pilz.de 1001972-EN-04-2012-05
751105 价格&库存
很抱歉,暂时无法提供与“751105”相匹配的价格&库存,您可以联系我们找货
