772143
772143
    PILZ
    PILZ - 772143 - SAFETY RELAY, 24VDC, DIN RAIL
772143 数据手册
PNOZ m EF 4DI4DOR 772143 Configurable safe small controllers PNOZmulti 2, expansion module, 4 safe digital inputs, 4 safe relay outputs. Technical details General data Approval: CE, UKCA, cULus Listed, KOSHA, TÜV, EAC (Eurasian) Application range: Failsafe Technical data Electrical data Purpose of UINT1: Module supply Source of internal voltage: Via base unit Voltage type of UINT1: DC Permitted loads: Resistive, Inductive Inputs U input to EN 61131-2 Type 1: 24 V DC Potential isolation input: No Relay outputs Number of relay outputs: 4 Utilisation cat. AC/DC1 stand.: EN 60947-4-1 Voltage AC1 safety cont.: 250 V Max. current AC1 safety cont.: 6A Voltage DC1 safety cont.: 24 V Max. current DC1 safety cont.: 6A Utilisation cat. AC15/DC13sta.: EN 60947-5-1 Pilz GmbH & Co. KG, Felix-Wankel-Strasse 2, 73760 Ostfildern, Germany Page 1/4 Voltage AC15 safety cont.: 230 V Max. current AC15 safety cont.: 3A Voltage DC13 safety cont.: 24 V Safety contacts: AC at UL: 240 VAC G.U. Resistive Pilot duty R300 to UL: 24 V DC Relay contact material: AgCuNi Addit. contact details relay: + 0.2 µm Au Pot. isolation relay outputs: Yes Environmental data Ambient temperature standard: EN 60068-2-14 Ambient temperature: 0 - 60 °C Storage temperature standard: EN 60068-2-1/-2 Climatic suitability standard: EN 60068-2-30, EN 60068-2-78 Condensation permitted?: Not permitted Perm. operating height ASL: 2000 m EMC to standard ...: EN 61131-2 Vibration to standard ...: EN 60068-2-6 Acc. shock to standard1: 15g Clearance & creepage dist. to: EN 61131-2 Overvoltage category: II Pollution degree clear.&creep.: 2 Protection type standard: EN 60529 Potential separation Potential isolation 1 between: RL output and system voltage Type of potential isolation 1: Safe separation Mechanical data Mounting position: horizontal on top hat rail DIN-rail dimensions: 35 x 7.5 EN 50022 Housing material lower section: PC Pilz GmbH & Co. KG, Felix-Wankel-Strasse 2, 73760 Ostfildern, Germany Page 2/4 Housing material front plate: PC Housing material upper part: PC Connection terminal: Screw terminal, Spring-loaded terminal Terminal style: plug-in Flex. cond. c/s AWG info: 24 - 12 AWG Height dimension: 101.4 mm Width dimension: 22.5 mm Depth dimension: 120 mm Net weight: 190 g Gross weight: 205 g Environment RoHS directive: 2011/65/EU, 2015/863/EU RoHS conformity: yes RoHS exceptions: yes RoHS except.s acc. to direct.: 7c I REACh compliance: contains min. 1 SVHC-substance REACh included substances: Lead oxide %-part of the pollutant: > 0,1 CAS No.: 1317-36-8 WEEE classifikation (08/2018): 5 devices (feed size < 50cm) Commercial data ECLASS version: ECLASS-9.1 ECLASS Reference Feature: 27242204 ETIM Version: ETIM-7.0 ETIM Reference Group: EG000024 Pilz GmbH & Co. KG, Felix-Wankel-Strasse 2, 73760 Ostfildern, Germany Page 3/4 Obligatory accessories 793540 Screw terminals PNOZ mml2p 783540 Spring terminals PNOZ mml2p 793541 Screw terminals PNOZ mml2p 10 pcs. 783541 Spring terminals PNOZ mml2p 10 pcs. 779260 PNOZ mm0.xp connector left (10 pcs) Optional accessories Pilz GmbH & Co. KG, Felix-Wankel-Strasse 2, 73760 Ostfildern, Germany Page 4/4
772143 价格&库存
很抱歉,暂时无法提供与“772143”相匹配的价格&库存,您可以联系我们找货
