775600
775600
    PILZ
775600 数据手册
E-STOP relays, safety gate monitors Up to Category 3, EN 954-1 PNOZ 1 Unit features Safety features  Positive-guided relay outputs: – 3 safety contacts (N/O), instantaneous – 1 auxiliary contact (N/C), instantaneous  Connection options for: – E-STOP pushbutton – Safety gate limit switch – Reset button  LED indicator for: – Switch status channel 1/2 – Supply voltage  See order reference for unit types Gertemerkmale Gertebild Safety relay for monitoring E-STOP pushbuttons and safety gates. ][Bildunterschrift The relay meets the following safety requirements:  The circuit is redundant with built-in self-monitoring.  The safety function remains effective in the case of a component failure.  The correct opening and closing of the safety function relays is tested automatically in each on-off cycle.  The tranformer is short circuitproof. An electronic fuse is used on a DC supply. ][Sicherheitseigenschaften Schaltgerät_allgemeiner Teil Sicherheitseigenschaften Zusatz - AC/DC-Gerte_PNOZ Unit description Approvals The safety relay meets the requirements of EN 60947-5-1, EN 60204-1 and VDE 0113-1 and may be used in applications with  E-STOP pushbuttons  Safety gates Bestimmung/Gerätebeschreibung NOT-AUS, Schutz_PNOZ PNOZ 1    Zulassungen Block diagram il tb a h s k c lo B d A1 A2 = = T11 T12 T12 T22 Input Input 13 23 33 41 14 24 34 42 K1 K2 Power Feedback Reset/ Start X1 X2 T33 T34 Pilz GmbH & Co. KG, Felix-Wankel-Straße 2, 73760 Ostfildern, Germany Telephone: +49 711 3409-0, Telefax: +49 711 3409-133, E-Mail: pilz.gmbh@pilz.de 1002105-EN-03-2012-01 E-STOP relays, safety gate monitors Up to Category 3, EN 954-1 PNOZ 1 Function description  Single-channel operation: no redundancy in the input circuit, earth faults in the reset and input circuit are detected.  Dual-channel operation without detection of shorts across contacts: redundant input circuit, detects ][Funktionen_einkanalig ][Funktionen_zweikanalig_ohne_quer  Manual reset: Unit is active once the input circuit is closed and then the reset circuit is closed.  Increase in the number of available instantaneous safety contacts by connecting contact expansion modules or external contactors. – earth faults in the reset and input circuit, – short circuits in the input circuit and, with a monitored reset, in the reset circuit too.  Automatic start: Unit is active once the input circuit has been closed. ][Funktionen_Kontaktvervielfachung ][Funktionen_autoStart ][Funktionen_manuStart Timing diagram x n o u _ rm g a itd e ][Z 1 2 a b POWER Reset/Start Input Output safe Output aux. t1 Key  Power: Supply voltage  Reset/start: Reset circuit  Input: Input circuits T12-T22, T11T22  Output safe: Safety contacts 13-14, 23-24, 33-34 t2 t1 t2 t1  Output aux: Auxiliary contacts 4142  : Automatic reset  : Manual reset  a: Input circuit closes before reset circuit t2 t1 t2  b: Reset circuit closes before input circuit  t1: Switch-on delay  t2: Delay-on de-energisation Wiring Please note:  Information given in the “Technical details” must be followed.  Outputs 13-14, 23-24, 33-34 are safety contacts, outputs 41-42 are auxiliary contacts (e.g. for display).  To prevent contact welding, a fuse should be connected before the output contacts (see technical details).  Calculation of the max. cabling runs lmax in the input circuit: ][Verdrahtung_Si_Hi_unverz Verdrahtung Imax = Rlmax Rl / km Rlmax = max. overall cable resistance (see technical details) Rl /km = cable resistance/km  Use copper wire that can withstand 60/75 °C.  Sufficient fuse protection must be provided on all output contacts with capacitive and inductive loads. Pilz GmbH & Co. KG, Felix-Wankel-Straße 2, 73760 Ostfildern, Germany Telephone: +49 711 3409-0, Telefax: +49 711 3409-133, E-Mail: pilz.gmbh@pilz.de 1002105-EN-03-2012-01 -2 E-STOP relays, safety gate monitors Up to Category 3, EN 954-1 PNOZ 1 Preparing for operation Betriebsbereitschaft herstellen  Supply voltage Supply voltage AC/DC A1 L1/L+ A2 N/L-  Input circuit Input circuit E-STOP without detection of shorts across contacts Single-channel Dual-channel T11 S1 T11 S1 T12 T12 T22 T22 E-STOP with detection of shorts across contacts Safety gate without detection of shorts across contacts T11 S1 T11 T12 T22 S1 S2 T12 T22 Safety gate with detection of shorts across contacts Pilz GmbH & Co. KG, Felix-Wankel-Straße 2, 73760 Ostfildern, Germany Telephone: +49 711 3409-0, Telefax: +49 711 3409-133, E-Mail: pilz.gmbh@pilz.de 1002105-EN-03-2012-01 E-STOP relays, safety gate monitors Up to Category 3, EN 954-1 PNOZ 1  Reset circuit Reset circuit Safety gate (dual-channel) E-STOP wiring (single-channel, dual-channel) Safety gate (single-channel) Automatic reset T33 T34 Manual reset S3 S3 T33 T33 T34 T34  Feedback loop Feedback loop Link or contacts from external contactors Without feedback loop With feedback loop X1 X2 X1 X2 13 (23, 33) 14 (24, 34) K5 K6 K5 L1 N K6  Key S1 E-STOP pushbutton Switch operated Gate open Gate closed Pilz GmbH & Co. KG, Felix-Wankel-Straße 2, 73760 Ostfildern, Germany Telephone: +49 711 3409-0, Telefax: +49 711 3409-133, E-Mail: pilz.gmbh@pilz.de 1002105-EN-03-2012-01 -4 E-STOP relays, safety gate monitors Up to Category 3, EN 954-1 PNOZ 1 Terminal configuration u g b n m le K Installation Dimensions  The safety relay should be installed in a control cabinet with a protection type of at least IP54.  Use the notch on the rear of the unit to attach it to a DIN rail.  Ensure the unit is mounted securely on a vertical DIN rail (35 mm) by using a fixing element (e.g. retaining bracket or an end angle). g n u s e m b A 121 (4.76") Montage_PNOZ_X 75 (2.95") 87 (3.42") Pilz GmbH & Co. KG, Felix-Wankel-Straße 2, 73760 Ostfildern, Germany Telephone: +49 711 3409-0, Telefax: +49 711 3409-133, E-Mail: pilz.gmbh@pilz.de 90 (3.54") 1002105-EN-03-2012-01 E-STOP relays, safety gate monitors Up to Category 3, EN 954-1 PNOZ 1 Notice This data sheet is only intended for use during configuration. Please refer to the operating manual for installation and operation. ][Wichtig_PDB Service life graph The service life graphs indicate the number of cycles from which failures due to wear must be expected. The wear is mainly caused by the electrical load; the mechanical load is negligible. Lebensdauerkurve_Relais_Text vor Kurve Example  Inductive load: 0,2 A  Utilisation category: AC15  Contact service life: 4,000,000 cycles Provided the application requires fewer than 4,000,000 cycles, the PFH value (see technical details) can be used in the calculation. Lebensdauerkurve_Relais_Text nach Kurve_SIR_SLR Bsp v rk u a d s n b e L To increase the service life, sufficient spark suppression must be provided on all output contacts. With capacitive loads, any power surges that occur must be noted. With contactors, use freewheel diodes for spark suppression. ][Technische Daten PNOZ Technical details Electrical data Supply voltage Supply voltage UB AC Supply voltage UB DC Voltage tolerance Power consumption at UB AC Power consumption at UB DC Frequency range AC Residual ripple DC Voltage and current at Input circuit DC: 24.0 V Reset circuit DC: 24.0 V Feedback loop DC: 24.0 V 24 V, 48 V, 110 - 120 V, 230 - 240 V 24 V -15 %/+10 % 5.5 VA No. 775600, 775620, 775630, 775650 2.5 W No. 775695 50 - 60 Hz 160 % 30.0 mA No. 775600, 775620, 775630, 775650 40.0 mA No. 775695 50.0 mA 50.0 mA Pilz GmbH & Co. KG, Felix-Wankel-Straße 2, 73760 Ostfildern, Germany Telephone: +49 711 3409-0, Telefax: +49 711 3409-133, E-Mail: pilz.gmbh@pilz.de 1002105-EN-03-2012-01 -6 E-STOP relays, safety gate monitors Up to Category 3, EN 954-1 PNOZ 1 Electrical data Number of output contacts Safety contacts (S) instantaneous: Auxiliary contacts (N/C): Utilisation category in accordance with EN 60947-4-1 Safety contacts: AC1 at 240 V Safety contacts: AC1 at 400 V Safety contacts: DC1 at 24 V Auxiliary contacts: AC1 at 240 V Auxiliary contacts: DC1 at 24 V Utilisation category in accordance with EN 60947-5-1 Safety contacts: AC15 at 230 V Safety contacts: DC13 at 24 V (6 cycles/min) Auxiliary contacts: AC15 at 230 V Auxiliary contacts: DC13 at 24 V (6 cycles/min) Conventional thermal current Contact material External contact fuse protection (IK = 1 kA) to EN 60947-5-1 Blow-out fuse, quick Safety contacts: Auxiliary contacts: Blow-out fuse, slow Safety contacts: Auxiliary contacts: Circuit breaker 24 VAC/DC, characteristic B/C Safety contacts: Auxiliary contacts: Max. overall cable resistance Rlmax input circuits, reset circuits single-channel at UB DC single-channel at UB AC dual-channel without detect. of shorts across contacts at UB DC dual-channel without detect. of shorts across contacts at UB AC Times Switch-on delay with automatic reset typ. with automatic reset max. with automatic reset after power on typ. with automatic reset after power on max. with manual reset typ. with manual reset max. Delay-on de-energisation with E-STOP typ. with E-STOP max. with power failure max. Recovery time at max. switching frequency 1/s after E-STOP after power failure 3 1 Imin: 0.01 A , Imax: 8.0 A Pmax: 2000 VA Imin: 0.01 A , Imax: 5.00 A Pmax: 2000 VA Imin: 0.01 A , Imax: 8.0 A Pmax: 200 W Imin: 0.01 A , Imax: 8.0 A Pmax: 2000 VA Imin: 0.01 A , Imax: 8.0 A Pmax: 200 W Imax: 5.0 A Imax: 7.0 A Imax: 5.0 A Imax: 7.0 A 8.0 A AgSnO2 + 0.2 µm Au 10 A 10 A 6A 6A 6A 6A 150 Ohm No. 775695 200 Ohm No. 775600, 775620, 775630, 775650 250 Ohm No. 775695 350 Ohm No. 775600, 775620, 775630, 775650 190 ms 250 ms No. 775695 270 ms No. 775600, 775620, 775630, 775650 190 ms No. 775695 215 ms No. 775600, 775620, 775630, 775650 250 ms No. 775695 320 ms No. 775600, 775620, 775630, 775650 190 ms 250 ms No. 775695 270 ms No. 775600, 775620, 775630, 775650 15 ms 30 ms 80 ms 300 ms 350 ms Pilz GmbH & Co. KG, Felix-Wankel-Straße 2, 73760 Ostfildern, Germany Telephone: +49 711 3409-0, Telefax: +49 711 3409-133, E-Mail: pilz.gmbh@pilz.de 1002105-EN-03-2012-01 E-STOP relays, safety gate monitors Up to Category 3, EN 954-1 PNOZ 1 Times Simultaneity, channel 1 and 2 Supply interruption before de-energisation Environmental data EMC Vibration to EN 60068-2-6 Frequency Amplitude Climatic suitability Airgap creepage in accordance with EN 60947-1 Pollution degree Overvoltage category Rated insulation voltage Rated impulse withstand voltage Ambient temperature Storage temperature Protection type Mounting (e.g. cabinet) Housing Terminals Mechanical data Housing material Housing Front Cross section of external conductors with screw terminals 1 core flexible 2 core, same cross section, flexible: with crimp connectors, without insulating sleeve without crimp connectors or with TWIN crimp connectors Torque setting with screw terminals Dimensions Height Width Depth Weight 140 ms 35 ms EN 60947-5-1, EN 61000-6-2 10 - 55 Hz 0.35 mm EN 60068-2-78 2 III 400 V 4.00 kV -10 - 55 °C -40 - 85 °C IP54 IP40 IP20 PPO UL 94 V0 ABS UL 94 V0 0.20 - 4.00 mm² , 24 - 10 AWG 0.20 - 2.50 mm² , 24 - 14 AWG 0.20 - 2.50 mm² , 24 - 14 AWG 0.60 Nm 87.0 mm 90.0 mm 121.0 mm 400 g No. 775695 500 g No. 775600, 775620, 775630, 775650 Technische Daten_Satz No. No. stands for order number. Technische Daten_Satz Normen The standards current on 2005-10 apply. Bestelldaten Order reference Type PNOZ 1 PNOZ 1 PNOZ 1 PNOZ 1 PNOZ 1 Features 24 VAC 48 VAC 110 – 120 VAC 230 – 240 VAC 24 VDC Pilz GmbH & Co. KG, Felix-Wankel-Straße 2, 73760 Ostfildern, Germany Telephone: +49 711 3409-0, Telefax: +49 711 3409-133, E-Mail: pilz.gmbh@pilz.de Terminals With screw terminals With screw terminals With screw terminals With screw terminals With screw terminals Order no. 775 600 775 620 775 630 775 650 775 695 1002105-EN-03-2012-01 -8
775600 价格&库存
很抱歉,暂时无法提供与“775600”相匹配的价格&库存,您可以联系我们找货
