777302
777302
    PILZ
777302 数据手册
PNOZ X2.8P 24-240VAC/DC 3n/o 1n/c 777302 Safety relay (standalone), inputs: 1/2-channel wiring with/without detection of shorts across contacts, outputs: 3 N/O, 1 N/C, automatic/manual start, UB 24 - 240 V AC/DC, width: 22.5 mm, plug-in screw terminals, monitoring of E-STOP, safety gates. Technical details General data Approval: CCC, CE, UKCA, cULus Listed, KOSHA, EAC (Eurasian), TÜV Technical data Electrical data Supply voltage (V): 24 - 240 V Type of supply voltage U1: AC/DC Power consumption AC: 4.5 VA Power consumption DC: 2W Inputs Number of inputs: 2 Semiconductor outputs Number of semicond. outputs: 0 Relay outputs Utilisation cat. AC/DC1 stand.: EN 60947-4-1 Voltage AC1 safety cont.: 240 V Max. current AC1 safety cont.: 6A Voltage DC1 safety cont.: 24 V Max. current DC1 safety cont.: 6A Utilisation cat. AC15/DC13sta.: EN 60947-5-1 Voltage AC15 safety cont.: 230 V Pilz GmbH & Co. KG, Felix-Wankel-Strasse 2, 73760 Ostfildern, Germany Page 1/3 Max. current AC15 safety cont.: 3A Voltage DC13 safety cont.: 24 V Safety contacts: AC at UL: 250 VAC G.U. (same polarity) Safety contacts: pilot duty: B300, R300 Relay contact material: AgCuNi Addit. contact details relay: + 0.2 µm Au Environmental data Climatic suitability to ...: EN 60068-2-78 Ambient temperature: -10 - 55 °C Humidity rating: 93 % r. h. at 40 °C Condensation permitted?: Not permitted EMC to standard ...: EN 60947-5-1, EN 61000-6-2, EN 61000-6-4, EN 61326-3-1 Vibration to standard ...: EN 60068-2-6 Clearance & creepage dist. to: EN 60947-1 Overvoltage category: III / II Pollution degree clear.&creep.: 2 Mechanical data Mounting position: any Housing material lower section: PPO UL 94 V0 Housing material front plate: ABS UL 94 V0 Housing material upper part: PPO UL 94 V0 Connection terminal: Screw terminal Terminal style: plug-in Flex. cond. c/s AWG info: 24 - 12 AWG Height dimension: 94 mm Width dimension: 22.5 mm Depth dimension: 121 mm Net weight: 210 g Gross weight: 220 g Pilz GmbH & Co. KG, Felix-Wankel-Strasse 2, 73760 Ostfildern, Germany Page 2/3 Environment RoHS directive: 2011/65/EU, 2015/863/EU RoHS conformity: yes RoHS exceptions: yes RoHS except.s acc. to direct.: 7a, 6c, 7c I REACh compliance: contains min. 1 SVHC-substance REACh included substances: Lead, Lead oxide %-part of the pollutant: > 0,1 CAS No.: 7439-92-1, 1317-36-8 WEEE classifikation (08/2018): 5 devices (feed size < 50cm) Commercial data ECLASS version: ECLASS-9.1 ECLASS Reference Feature: 27371819 ETIM Version: ETIM-7.0 ETIM Reference Group: EG000019 Optional accessories 374280 Pilz GmbH & Co. KG, Felix-Wankel-Strasse 2, 73760 Ostfildern, Germany PNOZ X Set plug in screw terminals P1+P2 Page 3/3
777302 价格&库存
很抱歉,暂时无法提供与“777302”相匹配的价格&库存,您可以联系我们找货
  • 1+1613.13460
库存:119
