774-300 PNOZ/X1/24V
774-300 PNOZ/X1/24V
    PILZ
    PILZ - 774-300 PNOZ/X1/24V - Safety Relay, 24 V, 3PST-NO, PNOZ X1, DIN Rail, 8 A, Screw
774-300 PNOZ/X1/24V 数据手册
E-STOP relays up to Category 2, EN 954-1 PNOZ X1 Safety relay for monitoring E-STOP pushbuttons. Unit features Safety features ` Positive-guided relay outputs: – 3 safety contacts (N/O), instantaneous – 1 auxiliary contact (N/C), instantaneous ` Safe separation of safety contacts 13-14, 23-24, 33-34 from input circuits A1-A2, feedback loop Y1-Y2 and auxiliary contact 41-42. ` Connection options for: – E-STOP pushbutton – Reset button ` LED indicator for: – Switch status channel 1/2 – Supply voltage The relay meets the following safety requirements: ` The circuit is redundant with built-in self-monitoring. ` The safety function remains effective in the case of a component failure. ` The correct opening and closing of the safety function relays is tested automatically in each on-off cycle. Approvals Unit description PNOZ X1 The safety relay meets the requirements of EN 60204-1 and IEC 602041 and may be used in applications with ` E-STOP pushbuttons The safety relay is not suitable for noncontact barriers because ` a dynamic start is not possible ` the unit can be started during the delay-on de-energisation time. ‹ ‹ ‹ Block diagram * Safe separation in accordance with EN 60947-1, 6 kV (see unit features) A1 A2 ~ = * Y1 Y2 Input 13 23 33 41 Reset/ Start K1 Power K2 14 24 34 42 Pilz GmbH & Co. KG, Sichere Automation, Felix-Wankel-Straße 2, 73760 Ostfildern, Germany Telephone: +49 711 3409-0, Telefax: +49 711 3409-133, E-Mail: pilz.gmbh@pilz.de NSG-D-2-069-2006-09 E-STOP relays up to Category 2, EN 954-1 PNOZ X1 Function description ` Single-channel operation: no redundancy in the input circuit, earth faults in the reset circuit are detected. ` Increase in the number of available contacts by connecting contact expander modules or external contactors/relays. ` Automatic start: Unit is active once the input circuit has been closed. ` Manual reset: Unit is active once the input circuit is closed and then the reset circuit is closed. Timing diagram 1 2 a b POWER Reset/Start Input Output safe Output aux. t1 Key ` Power: Supply voltage ` Reset/start: Reset circuit Y1-Y2 ` Input: Input circuits A1-L+ ` Output safe: Safety contacts 13-14, 23-24, 33-34 t2 t1 t2 t1 ` Output aux: Auxiliary contacts 4142 ` c: Automatic reset ` d: Manual reset ` a: Input circuit closes before reset circuit t1 t2 t2 ` b: Reset circuit closes before input circuit ` t1: Switch-on delay ` t2: Delay-on de-energisation Wiring Please note: ` Information given in the “Technical details” must be followed. ` Outputs 13-14, 23-24, 33-34 are safety contacts, output 41-42 is an auxiliary contact (e.g. for display). ` To prevent contact welding, a fuse should be connected before the output contacts (see technical details). ` Calculation of the max. cable runs lmax in the input circuit: Imax = Rlmax Rl / km Rlmax = max. overall cable resistance (see technical details) Rl /km = cable resistance/km ` Use copper wire that can withstand 60/75 °C. ` Sufficient fuse protection must be provided on all output contacts with capacitive and inductive loads. Pilz GmbH & Co. KG, Sichere Automation, Felix-Wankel-Straße 2, 73760 Ostfildern, Germany Telephone: +49 711 3409-0, Telefax: +49 711 3409-133, E-Mail: pilz.gmbh@pilz.de NSG-D-2-069-2006-09 -2 E-STOP relays up to Category 2, EN 954-1 PNOZ X1 Preparing for operation ` Supply voltage Supply voltage AC DC A1 S1 A2 L1 A1 N A2 S1 L+ L- ` Input circuit Input circuit Single-channel E-STOP without detection of shorts across contacts Dual-channel A1 S1 L+ ` Reset circuit Reset circuit E-STOP wiring (single-channel) Automatic reset E-STOP wiring (dual-channel) Y1 Y2 Manual reset S3 Y1 Y2 ` Feedback loop Feedback loop Contacts from external contactors Automatic reset Manual reset Y1 Y2 13 (23, 33) 14 (24, 34) K5 K5 S3 Y1 K6 L1 N K6 Y2 13 (23, 33) 14 (24 ,34) K5 K6 K5 L1 N K6 ` Key S1 E-STOP pushbutton S3 Reset button Pilz GmbH & Co. KG, Sichere Automation, Felix-Wankel-Straße 2, 73760 Ostfildern, Germany Telephone: +49 711 3409-0, Telefax: +49 711 3409-133, E-Mail: pilz.gmbh@pilz.de NSG-D-2-069-2006-09 E-STOP relays up to Category 2, EN 954-1 PNOZ X1 Terminal configuration 13 A1 23 33 Y1 Y2 PNOZ X1 POWER CH.1 CH.2 13 23 33 41 14 24 34 42 42 A2 14 24 34 19068 41 Installation Dimensions 121 (4.8") ` The safety relay should be installed in a control cabinet with a protection type of at least IP54. ` Use the notch on the rear of the unit to attach it to a DIN rail. ` Ensure the unit is mounted securely on a vertical DIN rail (35 mm) by using a fixing element (e.g. retaining bracket or an end angle). 75 (2.95") 87 (3.42") Pilz GmbH & Co. KG, Sichere Automation, Felix-Wankel-Straße 2, 73760 Ostfildern, Germany Telephone: +49 711 3409-0, Telefax: +49 711 3409-133, E-Mail: pilz.gmbh@pilz.de 22,5 (0,89") NSG-D-2-069-2006-09 -4 E-STOP relays up to Category 2, EN 954-1 PNOZ X1 D GB F E I NL This data sheet is only intended for use during configuration. For installation and operation, please refer to the operating instructions supplied with the unit. Service life graph Nennbetriebstrom (A) Nominal operating current (A) Courant coupé (A) Corriente nominal de servicio (A) Corrente di esercizio nominale (A) Nominale bedrijfsstroom (A) Notice 10 1 DC13: 24 V 0.1 1000 100 D Schaltspielzahl x 103 GB Cycles x 103 F Nombre de manœvres x 103 DC1: 24 V AC15: 230 V AC1: 230 V 10000 100000 E Número de ciclos x 103 I Numero dei cicli di commutazione x 103 NL Aantal schakelingen x 103 Technical details Electrical data Supply voltage Supply voltage UB AC/DC Voltage tolerance Power consumption at UB AC Power consumption at UB DC Frequency range AC Residual ripple DC Voltage and current at Input circuit DC: 24.0 V Reset circuit DC: 24.0 V Feedback loop DC: 24.0 V Number of output contacts Safety contacts (S) instantaneous: Auxiliary contacts (N/C): Category of output contacts in accordance with EN 954-1 Safety contacts (S) instantaneous: Utilisation category in accordance with EN 60947-4-1 Safety contacts: AC1 at 240 V Safety contacts: DC1 at 24 V Auxiliary contacts: AC1 at 240 V Auxiliary contacts: DC1 at 24 V Utilisation category in accordance with EN 60947-5-1 Safety contacts: AC15 at 230 V Safety contacts: DC13 at24 V (6 cycles/min) Auxiliary contacts: AC15 at 230 V Auxiliary contacts: DC13 at24 V (6 cycles/min) Contact material 24 V -15 %/+10 % 4.0 VA 2.0 W 50 - 60 Hz 160 % 65.0 mA 40.0 mA 40.0 mA 3 1 2 Imin: 0.01 A , Imax: 8.0 A Pmax: 2000 VA Imin: 0.01 A , Imax: 8.0 A Pmax: 200 W Imin: 0.01 A , Imax: 8.0 A Pmax: 2000 VA Imin: 0.01 A , Imax: 8.0 A Pmax: 200 W Imax: 6.0 A Imax: 5.0 A Imax: 6.0 A Imax: 5.0 A AgCuNi + 0.2 µm Au Pilz GmbH & Co. KG, Sichere Automation, Felix-Wankel-Straße 2, 73760 Ostfildern, Germany Telephone: +49 711 3409-0, Telefax: +49 711 3409-133, E-Mail: pilz.gmbh@pilz.de NSG-D-2-069-2006-09 E-STOP relays up to Category 2, EN 954-1 PNOZ X1 Electrical data External contact fuse protection (IK = 1 kA) to EN 60947-5-1 Blow-out fuse, quick Safety contacts: Auxiliary contacts: Blow-out fuse, slow Safety contacts: Auxiliary contacts: Circuit breaker 24 VAC/DC, characteristic B/C Safety contacts: Auxiliary contacts: Max. overall cable resistance Rlmax input circuits, reset circuits single-channel at UB DC single-channel at UB AC Times Switch-on delay with automatic reset typ. with automatic reset max. with manual reset typ. with manual reset max. Delay-on de-energisation with E-STOP typ. with E-STOP max. with power failure typ. with power failure max. Recovery time at max. switching frequency 1/s after E-STOP after power failure Supply interruption before de-energisation Environmental data EMC Vibration to EN 60068-2-6 Frequency Amplitude Climatic suitability Airgap creepage Rated insulation voltage Rated impulse withstand voltage Ambient temperature Storage temperature Protection type Mounting (e.g. cabinet) Housing Terminals Mechanical data Housing material Housing Front Max. cross section of external conductors with screw terminals 1 core flexible 2 core, same cross section, flexible: with crimp connectors, without insulating sleeve without crimp connectors or with TWIN crimp connectors Torque setting with screw terminals 10 A 10 A 6A 6A 6A 6A 30 Ohm 30 Ohm 60 ms 120 ms 50 ms 120 ms 55 ms 90 ms 55 ms 90 ms 100 ms 100 ms 20 ms EN 60947-5-1, EN 61000-6-2 10 - 55 Hz 0.35 mm EN 60068-2-78 EN 60947-1 250 V 6.0 kV -10 - 55 °C -40 - 85 °C IP54 IP40 IP20 PPO UL 94 V0 ABS UL 94 V0 0.20 - 4.00 mm² , 24 - 10 AWG 0.20 - 2.50 mm² , 24 - 14 AWG 0.20 - 2.50 mm² , 24 - 14 AWG 0.60 Nm Pilz GmbH & Co. KG, Sichere Automation, Felix-Wankel-Straße 2, 73760 Ostfildern, Germany Telephone: +49 711 3409-0, Telefax: +49 711 3409-133, E-Mail: pilz.gmbh@pilz.de NSG-D-2-069-2006-09 -6 E-STOP relays up to Category 2, EN 954-1 PNOZ X1 Mechanical data Dimensions Height Width Depth Weight 87.0 mm 22.5 mm 121.0 mm 180 g The standards current on 2004-09 apply. Conventional thermal current Number of contacts 1 2 3 Ith (A) at UB DC 8.00 A 7.00 A 6.00 A Ith (A) at UB AC 8.00 A 7.00 A 6.00 A Order reference Type PNOZ X1 Features 24 VAC 24 VDC Terminals Screw terminals Pilz GmbH & Co. KG, Sichere Automation, Felix-Wankel-Straße 2, 73760 Ostfildern, Germany Telephone: +49 711 3409-0, Telefax: +49 711 3409-133, E-Mail: pilz.gmbh@pilz.de Order no. 774 300 NSG-D-2-069-2006-09
774-300 PNOZ/X1/24V
PDF文档中包含以下信息:
物料型号:STM32F103RCT6 器件简介:STM32F103RCT6是一款基于ARM Cortex-M3内核的32位微控制器,适用于多种嵌入式系统应用。
引脚分配:该芯片共有100个引脚,包括电源引脚、地引脚、I/O引脚等。
参数特性:工作电压2.0V至3.6V,工作频率72MHz,内置512KB Flash和64KB SRAM。
功能详解:包含多种外设如ADC、DAC、定时器等,支持多种通信接口如UART、SPI、I2C等。
应用信息:适用于工业自动化、医疗设备、智能家居等领域。
封装信息:LQFP封装,共有100个引脚。
774-300 PNOZ/X1/24V 价格&库存
很抱歉,暂时无法提供与“774-300 PNOZ/X1/24V”相匹配的价格&库存,您可以联系我们找货
