750134
750134
    PILZ
750134 数据手册
PNOZsigma - Base units ● Sensors Control and Communication Electronic monitoring relays Safety Relays PNOZ X PNOZsigma PNOZelog ● Configurable control systems PNOZsigma - Base units Safe monitoring of E-STOP, safety gate, light grid and two-hand control PNOZ s4 48-240VACDC 3 n/o 1 n/c Order numbers: 750134 ● ● Programmable safety and control systems Industrial communication Motion Control Operating and Monitoring Login Back to overview PNOZmulti PNOZpower Register ● ● ● ● ● Software ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● Type: PNOZ s4 Application options: Safety gate monitor , Instantaneous E-STOP monitoring , Light barrer mon. Cat.4 , Light barrer mon. Cat.2 w/o tp , Light barrier mon. Cat.2 w/ tp , Limit switch Category in accordance with: EN 954-1 , EN ISO 13849-1 SIL value: -Standards: VDE 0113-1 , EN 954-1 , EN 62061 , EN 60204-1 Approvals: UL/cUL , GOST Russia , CCC , BG Operating modes: Dual-channel , Without detection of shorts across contacts , Monitored manual reset , Manual start , Single-channel , Automatic start , Self test , Detection of shorts across contacts , Start-up testing Selectable times: -Number of instantaneous safety contacts: 3 Number of delayed safety contacts: -Number of auxiliary contacts: 1 Number of delayed auxiliary contacts: -Number of semiconductor outputs: 1 Stop category: 0 Supply voltage [V]: -Supply voltage range: 48 - 240 V Supply voltage type: AC/DC Max. current at DC1: 6,0 A Power consumption AC: -Power consumption DC: -Height dimension: 96,0 mm Width dimension: 22,5 mm Depth dimension: 120,0 mm Height dimension (inches): 3.78" Width dimension (inches): 0.89" Depth dimension (inches): 4.72" Gross weight: 250 g Net weight: 210 g http://www.pilz.co.uk/products/control_communication/safety_relay/f/pnozsigma/s/00514/index.jsp?itemId=750134 (1 of 2)19/02/2009 11:47:57 E-STOP relays, safety gate monitors Up to PL e of EN ISO 13849-1 PNOZ s4 Safety relay for monitoring E-STOP pushbuttons, safety gates and light barriers. Approvals PNOZ s4 ‹ ‹ ‹ Unit features Unit description ` Positive-guided relay outputs: – 3 safety contacts (N/O), instantaneous – 1 auxiliary contact (N/C), instantaneous ` 1 semiconductor output ` Connection options for: – E-STOP pushbutton – Safety gate limit switch – Reset button – Light barriers – PSEN ` A connector can be used to connect 1 PNOZsigma contact expander module ` Operating modes can be set via rotary switch ` LED indicator for: – Supply voltage – Input status, channel 1 – Input status, channel 2 – Switch status, safety contacts – Reset circuit – Error ` Plug-in connection terminals (either spring-loaded terminal or screw terminal) The safety relay meets the requirements of EN 60947-5-1, EN 60204-1 and VDE 0113-1 and may be used in applications with ` E-STOP pushbuttons ` Safety gates ` Light barriers Safety features The relay meets the following safety requirements: ` The circuit is redundant with built-in self-monitoring. ` The safety function remains effective in the case of a component failure. ` The correct opening and closing of the safety function relays is tested automatically in each on-off cycle. ` The unit has an electronic fuse. Block diagram )* = (~)* S11 S12 S21 S22 Input 13 23 33 41 Input K1 Interface expansion unit = ( A1 A2 Power K2 Reset/ Start S34 Y32 14 24 34 42 * only when UB = 48 – 240 VAC/DC Pilz GmbH & Co. KG, Felix-Wankel-Straße 2, 73760 Ostfildern, Germany Telephone: +49 711 3409-0, Telefax: +49 711 3409-133, E-Mail: pilz.gmbh@pilz.de NSG-D-2-395-2008-11 E-STOP relays, safety gate monitors Up to PL e of EN ISO 13849-1 PNOZ s4 Function description ` Single-channel operation: no redundancy in the input circuit, earth faults in the reset and input circuit are detected. ` Dual-channel operation without detection of shorts across contacts: redundant input circuit, detects – earth faults in the reset and input circuit, – short circuits in the input circuit and, with a monitored reset, in the reset circuit too. ` Dual-channel operation with detection of shorts across contacts: redundant input circuit, detects – earth faults in the reset and input circuit, – short circuits in the input circuit and, with a monitored reset, in the reset circuit too, – shorts between contacts in the input circuit. ` Automatic start: Unit is active once the input circuit has been closed. ` Manual reset: Unit is active once the input circuit is closed and then the reset circuit is closed. ` Monitored reset with falling edge: Unit is active once – the input circuit is closed and then the reset circuit is closed and opened again. – the reset circuit is closed and then opened again once the in- put circuit is closed. ` Monitored reset with rising edge: Unit is active once the input circuit is closed and once the reset circuit is closed after the waiting period has elapsed (see technical details). ` Reset with start-up test: The unit checks whether safety gates that are closed are opened and then closed again when supply voltage is applied. ` Increase in the number of available instantaneous safety contacts by connecting contact expander modules or external contactors/relays; A connector can be used to connect 1 PNOZsigma contact expander module. Timing diagram 1 2 a 3 a b 4 a b b POWER Reset/Start Input Output safe Output aux. Out semi t1 t2 t1 t2 Key ` Power: Supply voltage ` Reset/start: Reset circuit S34 S34 ` Input: Input circuits S11-S12, S21S22 ` Output safe: Safety contacts 13-14, 23-24, 33-34 ` Output aux: Auxiliary contacts 4142 t1 t2 t1 t2 t3 t1 t2 ` Out semi: Semiconductor output Y32 ` c: Automatic reset ` d: Manual reset ` e: Monitored reset with rising edge ` f: Monitored reset with falling edge ` a: Input circuit closes before reset circuit t1 t2 t3 t4 t1 t2 t1 t2 ` b: Reset circuit closes before input circuit ` t1: Switch-on delay ` t2: Delay-on de-energisation ` t3: Waiting period ` t4: Waiting period reset circuit was closed Wiring Please note: ` Information given in the “Technical details” must be followed. ` Outputs 13-14, 23-24, 33-34 are safety contacts, output 41-42 is an auxiliary contact (e.g. for display). ` To prevent contact welding, a fuse should be connected before the output contacts (see technical details). ` Calculation of the max. cable runs lmax in the input circuit: Imax = Rlmax Rl / km Rlmax = max. overall cable resistance (see technical details) Rl /km = cable resistance/km ` Use copper wire that can withstand 60/75 °C. ` Sufficient fuse protection must be provided on all output contacts with capacitive and inductive loads. Pilz GmbH & Co. KG, Felix-Wankel-Straße 2, 73760 Ostfildern, Germany Telephone: +49 711 3409-0, Telefax: +49 711 3409-133, E-Mail: pilz.gmbh@pilz.de NSG-D-2-395-2008-11 -2 E-STOP relays, safety gate monitors Up to PL e of EN ISO 13849-1 PNOZ s4 Preparing for operation ` Supply voltage Supply voltage AC DC S21 A1 L A2 N A1 L+ A2 L- ` Input circuit Input circuit E-STOP without detection of shorts across contacts Single-channel Dual-channel S11 S1 S11 S1 S12 S12 S22 S22 E-STOP with detection of shorts across contacts S11 S1 S21 S22 S12 Safety gate without detection of shorts across contacts S11 S1 S11 S1 S12 S22 S2 S12 S22 Safety gate with detection of shorts across contacts S11 S12 S21 S22 Light beam device or safety switch with detection of shorts across contacts via ESPE (only when UB = 24 VDC) Pilz GmbH & Co. KG, Felix-Wankel-Straße 2, 73760 Ostfildern, Germany Telephone: +49 711 3409-0, Telefax: +49 711 3409-133, E-Mail: pilz.gmbh@pilz.de S1 S2 24 V DC A2 S12 S22 GND NSG-D-2-395-2008-11 E-STOP relays, safety gate monitors Up to PL e of EN ISO 13849-1 PNOZ s4 ` Reset circuit/feedback loop Reset circuit/feedback loop Reset circuit Feedback loop Automatic reset S12 S34 13 (23,33) 14 (24,34) S12 S34 Manual/monitored reset K5 K6 K5 L1 N K6 S3 S12 S12 S34 13 (23,33) 14 (24,34) S34 S3 K5 K6 K5 L1 N K6 ` Semiconductor output * Y32 PLC Input *Connect together the 0V connections on all the external power supplies ` Key S1/S2 S3 E-STOP/safety gate switch Reset button Switch operated Gate open Gate closed Pilz GmbH & Co. KG, Felix-Wankel-Straße 2, 73760 Ostfildern, Germany Telephone: +49 711 3409-0, Telefax: +49 711 3409-133, E-Mail: pilz.gmbh@pilz.de NSG-D-2-395-2008-11 -4 E-STOP relays, safety gate monitors Up to PL e of EN ISO 13849-1 PNOZ s4 Terminal configuration Dimensions Install base unit without contact expander module: ` Ensure that the plug terminator is inserted at the side of the unit. Connect base unit and PNOZsigma contact expander module: ` Remove the plug terminator at the side of the base unit and at the contact expander module. ` Connect the base unit and the contact expander module to the supplied connector before mounting the units to the DIN rail. Installation in control cabinet ` The safety relay should be installed in a control cabinet with a protection type of at least IP54. ` Use the notch on the rear of the unit to attach it to a DIN rail. ` Ensure the unit is mounted securely on a vertical DIN rail (35 mm) by using a fixing element (e.g. retaining bracket or an end angle). ` Push the unit upwards or downwards before lifting it from the DIN rail. *with spring-loaded terminals 120 (4.72") Installation 98 (3.86") * 100 (3,94") Pilz GmbH & Co. KG, Felix-Wankel-Straße 2, 73760 Ostfildern, Germany Telephone: +49 711 3409-0, Telefax: +49 711 3409-133, E-Mail: pilz.gmbh@pilz.de 22,5 (0.88") NSG-D-2-395-2008-11 E-STOP relays, safety gate monitors Up to PL e of EN ISO 13849-1 PNOZ s4 Service life graph This data sheet is only intended for use during configuration. For installation and operation, please refer to the operating instructions supplied with the unit. UB 24 VDC D GB F E I NL Nennbetriebstrom (A) Nominal operating current (A) Courant coupé (A) Corriente nominal de servicio (A) Corrente di esercizio nominale (A) Nominale bedrijfsstroom (A) Notice 10 1 DC1: 24 V DC13: 24 V 0.1 1000 100 D Schaltspielzahl x 103 GB Cycles x 103 F Nombre de manœuvres x 103 AC15: 230 V AC1: 230 V 10000 100000 E Número de ciclos x 103 I Numero dei cicli di commutazione x 103 NL Aantal schakelingen x 103 D GB F E I NL Nennbetriebstrom (A) Nominal operating current (A) Courant coupé (A) Corriente nominal de servicio (A) Corrente di esercizio nominale (A) Nominale bedrijfsstroom (A) UB 48-240 VAC/DC 10 AC15: 230 V AC1: 230 V DC1: 24 V DC13: 24 V 1 0.1 10 100 D Schaltspielzahl x 103 GB Cycles x 103 F Nombre de manœuvres x 103 1000 10000 E Número de ciclos x 103 I Numero dei cicli di commutazione x 103 NL Aantal schakelingen x 103 Technical details Electrical data Supply voltage Supply voltage UB DC Supply voltage UB AC/DC Voltage tolerance Power consumption at UB AC Power consumption at UB DC Frequency range AC Residual ripple DC Voltage and current at Input circuit DC: 24.0 V Reset circuit DC: 24.0 V Feedback loop DC: 24.0 V Number of output contacts Safety contacts (S) instantaneous: Auxiliary contacts (N/C): 24 V 48 - 240 V -15 %/+10 % 5.0 VA Order no.: 750134, 751134 2.5 W 50 - 60 Hz 20 %, 160 % 50.0 mA 50.0 mA 50.0 mA 3 1 Pilz GmbH & Co. KG, Felix-Wankel-Straße 2, 73760 Ostfildern, Germany Telephone: +49 711 3409-0, Telefax: +49 711 3409-133, E-Mail: pilz.gmbh@pilz.de NSG-D-2-395-2008-11 -6 E-STOP relays, safety gate monitors Up to PL e of EN ISO 13849-1 PNOZ s4 Electrical data Utilisation category in accordance with EN 60947-4-1 Safety contacts: AC1 at 240 V Safety contacts: DC1 at 24 V Auxiliary contacts: AC1 at 240 V Auxiliary contacts: DC1 at 24 V Utilisation category in accordance with EN 60947-5-1 Safety contacts: AC15 at 230 V Safety contacts: DC13 at 24 V (6 cycles/min) Auxiliary contacts: AC15 at 230 V Auxiliary contacts: DC13 at 24 V (6 cycles/min) Contact material External contact fuse protection (IK = 1 kA) to EN 60947-5-1 Blow-out fuse, quick Safety contacts: Auxiliary contacts: Blow-out fuse, slow Safety contacts: Auxiliary contacts: Circuit breaker 24 VAC/DC, characteristic B/C Safety contacts: Auxiliary contacts: Semiconductor outputs (short circuit proof) Max. overall cable resistance Rlmax input circuits, reset circuits single-channel at UB DC single-channel at UB AC dual-channel without detect. of shorts across contacts at UB DC dual-channel without detect. of shorts across contacts at UB AC dual-channel with detect. of shorts across contacts at UB DC dual-channel with detect. of shorts across contacts at UB AC Safety-related characteristic data Performance level (PL) in accordance with EN ISO 13849-1 Safety contacts, instantaneous Category of output contacts in accordance with EN 954-1, EN ISO 13849-1 Safety contacts (S) instantaneous: Imin: 0.01 A , Imax: 6.0 A Order no.: 750134, 751134 8.0 A Order no.: 750104, 751104 Pmax: 1500 VA Order no.: 750134, 751134 2000 VA Order no.: 750104, 751104 Imin: 0.01 A , Imax: 6.0 A Order no.: 750134, 751134 8.0 A Order no.: 750104, 751104 Pmax: 150 W Order no.: 750134, 751134 200 W Order no.: 750104, 751104 Imin: 0.01 A , Imax: 6.0 A Order no.: 750134, 751134 8.0 A Order no.: 750104, 751104 Pmax: 1500 VA Order no.: 750134, 751134 2000 VA Order no.: 750104, 751104 Imin: 0.01 A , Imax: 6.0 A Order no.: 750134, 751134 8.0 A Order no.: 750104, 751104 Pmax: 150 W Order no.: 750134, 751134 200 W Order no.: 750104, 751104 Imax: 3.0 A Order no.: 750134, 751134 6.0 A Order no.: 750104, 751104 Imax: 4.0 A Order no.: 750134, 751134 5.0 A Order no.: 750104, 751104 Imax: 3.0 A Order no.: 750134, 751134 6.0 A Order no.: 750104, 751104 Imax: 4.0 A Order no.: 750134, 751134 5.0 A Order no.: 750104, 751104 AgCuNi + 0.2 µm Au 10 A Order no.: 750104, 751104 6 A Order no.: 750134, 751134 10 A Order no.: 750104, 751104 6 A Order no.: 750134, 751134 4 A Order no.: 750134, 751134 6 A Order no.: 750104, 751104 4 A Order no.: 750134, 751134 6 A Order no.: 750104, 751104 4 A Order no.: 750134, 751134 6 A Order no.: 750104, 751104 4 A Order no.: 750134, 751134 6 A Order no.: 750104, 751104 24.0 V DC,20 mA 30 Ohm 30 Ohm Order no.: 750134, 751134 30 Ohm Order no.: 750134, 751134 60 Ohm Order no.: 750104, 751104 30 Ohm Order no.: 750134, 751134 30 Ohm 30 Ohm Order no.: 750134, 751134 e 4 Pilz GmbH & Co. KG, Felix-Wankel-Straße 2, 73760 Ostfildern, Germany Telephone: +49 711 3409-0, Telefax: +49 711 3409-133, E-Mail: pilz.gmbh@pilz.de NSG-D-2-395-2008-11 E-STOP relays, safety gate monitors Up to PL e of EN ISO 13849-1 PNOZ s4 Safety-related characteristic data SIL claim limit (SIL CL) in accordance with EN IEC 62061 Safety contacts, instantaneous Probability of dangerous failure per hour (PFHD) in accordance with EN IEC 62061 Safety contacts, instantaneous Mission time/Proof test interval in years Times Switch-on delay with automatic reset typ. with automatic reset max. with automatic reset after power on typ. with automatic reset after power on max. with manual reset typ. on monitored reset with rising edge typ. on monitored reset with rising edge max. on monitored reset with falling edge typ. on monitored reset with falling edge max. Delay-on de-energisation with E-STOP typ. with E-STOP max. with power failure typ. with power failure max. Recovery time at max. switching frequency 1/s after E-STOP after power failure Waiting period with a monitored reset with rising edge with falling edge Min. start pulse duration with a monitored reset with rising edge with falling edge Simultaneity, channel 1 and 2 Supply interruption before de-energisation Environmental data EMC Vibration to EN 60068-2-6 Frequency Amplitude Climatic suitability Airgap creepage in accordance with EN 60947-1 Pollution degree Rated insulation voltage Rated impulse withstand voltage Ambient temperature Storage temperature Protection type Mounting (e.g. cabinet) Housing Terminals Mechanical data Housing material Housing Front 3 2.31E-09 1/h 20 170 ms 300 ms 350 ms 600 ms 40 ms 35 ms 50 ms 55 ms 70 ms 10 ms 20 ms 40 ms 60 ms 50 ms 100 ms 120 ms 150 ms Order no.: 750134, 751134 250 ms Order no.: 750104, 751104 30 ms 100 ms ∞ 20 ms EN 60947-5-1, EN 61000-6-2, EN 61000-6-4 10 - 55 Hz 0.35 mm EN 60068-2-78 2 250 V 4.0 kV -10 - 55 °C -40 - 85 °C IP54 IP40 IP20 PC PC Pilz GmbH & Co. KG, Felix-Wankel-Straße 2, 73760 Ostfildern, Germany Telephone: +49 711 3409-0, Telefax: +49 711 3409-133, E-Mail: pilz.gmbh@pilz.de NSG-D-2-395-2008-11 -8 E-STOP relays, safety gate monitors Up to PL e of EN ISO 13849-1 PNOZ s4 Mechanical data Cross section of external conductors with screw terminals 1 core flexible 2 core, same cross section, flexible: with crimp connectors, without insulating sleeve without crimp connectors or with TWIN crimp connectors Torque setting with screw terminals Cross section of external conductors with spring-loaded terminals: Flexible with/without crimp connectors Spring-loaded terminals: Terminal points per connection Stripping length Dimensions Height Width Depth Weight 0.25 - 2.50 mm² , 24 - 12 AWG Order no.: 750104, 750134 0.25 - 1.00 mm² , 24 - 16 AWG Order no.: 750104, 750134 0.20 - 1.50 mm² , 24 - 16 AWG Order no.: 750104, 750134 0.50 Nm Order no.: 750104, 750134 0.20 - 2.50 mm² , 24 - 12 AWG Order no.: 751104, 751134 2 Order no.: 751104, 751134 9 mm Order no.: 751104, 751134 102.0 mm Order no.: 751104, 751134 96.0 mm Order no.: 750104, 750134 22.5 mm 120.0 mm 190 g Order no.: 750104, 751104 210 g Order no.: 750134, 751134 The standards current on 2006-04 apply. Conventional thermal current Number of contacts 1 2 3 Ith (A) at UB DC 6.00 A Order no.: 750134, 751134 8.00 A Order no.: 750104, 751104 6.00 A 4.50 A Order no.: 750134, 751134 5.00 A Order no.: 750104, 751104 Ith (A) at UB AC 6.00 A Order no.: 750134, 751134 6.00 A Order no.: 750134, 751134 4.50 A Order no.: 750134, 751134 Order reference Type PNOZ s4 PNOZ s4 C PNOZ s4 PNOZ s4 C Features 24 VDC 24 VDC 48 – 240 VAC/DC 48 – 240 VAC/DC Pilz GmbH & Co. KG, Felix-Wankel-Straße 2, 73760 Ostfildern, Germany Telephone: +49 711 3409-0, Telefax: +49 711 3409-133, E-Mail: pilz.gmbh@pilz.de Terminals With screw terminals With spring-loaded terminals With screw terminals With spring-loaded terminals Order no. 750 104 751 104 750 134 751 134 NSG-D-2-395-2008-11
750134 价格&库存
很抱歉,暂时无法提供与“750134”相匹配的价格&库存,您可以联系我们找货
