PNOZ s4 C 24VDC 3 n/o 1 n/c
751104
PNOZsigma safety relay (standalone), inputs: 1/2-channel wiring with/
without detection of shorts across contacts, manual/automatic start,
outputs: 3 N/O, 1 N/C, 1 SC, UB 24 V DC, width: 22.5 mm, plug-in springloaded terminals, monitoring of E-STOP, safety gates, lightguard.
Technical details
General data
Approval:
CCC, CE, cULus Listed, KOSHA, EAC (Eurasian), TÜV
Technical data
Electrical data
Supply voltage (V):
24 - 24 V
Type of supply voltage U1:
DC
Power consumption DC:
2.5 W
Inputs
Number of inputs:
2
Semiconductor outputs
Number of semicond. outputs:
1
Utilisation cat. to EN 60947-1:
DC-12
Relay outputs
Utilisation cat. AC/DC1 stand.:
EN 60947-4-1
Voltage AC1 safety cont.:
240 V
Max. current AC1 safety cont.:
6A
Voltage DC1 safety cont.:
24 V
Max. current DC1 safety cont.:
6A
Utilisation cat. AC15/DC13sta.:
EN 60947-5-1
Voltage AC15 safety cont.:
230 V
Pilz GmbH & Co. KG, Felix-Wankel-Strasse 2, 73760 Ostfildern, Germany
Page 1/3
Max. current AC15 safety cont.:
5A
Voltage DC13 safety cont.:
24 V
Safety contacts: AC at UL:
240 VAC G.U. (same polarity)
Relay contact material:
AgCuNi
Addit. contact details relay:
+ 0.2 µm Au
Environmental data
Climatic suitability to ...:
EN 60068-2-78
Ambient temperature:
-10 - 55 °C
Humidity rating:
93 % r. h. at 40 °C
Condensation permitted?:
Not permitted
EMC to standard ...:
EN 60947-5-1, EN 61000-6-2, EN 61000-6-4, EN 61326-3-1
Vibration to standard ...:
EN 60068-2-6
Clearance & creepage dist. to:
EN 60947-1
Overvoltage category:
III / II
Pollution degree clear.&creep.:
2
Mechanical data
Mounting position:
any
Housing material lower section:
PC
Housing material front plate:
PC
Housing material upper part:
PC
Connection terminal:
Spring-loaded terminal
Terminal style:
plug-in
Height dimension:
100 mm
Width dimension:
22.5 mm
Depth dimension:
120 mm
Net weight:
185 g
Gross weight:
195 g
Environment
RoHS directive:
2011/65/EU, 2015/863/EU
Page 2/3
RoHS conformity:
yes
RoHS exceptions:
yes
RoHS except.s acc. to direct.:
34, 7a, 6c, 7c I
REACh compliance:
contains min. 1 SVHC-substance
REACh included substances:
Lead, Lead oxide
%-part of the pollutant:
> 0,1
CAS No.:
7439-92-1, 1317-36-8
WEEE classifikation (08/2018):
5 devices (feed size < 50cm)
Commercial data
ECLASS version:
ECLASS-9.1
ECLASS Reference Feature:
27371819
ETIM Version:
ETIM-7.0
ETIM Reference Group:
EG000019
Optional accessories
750010
PNOZ s terminator plug ( 10 pieces)
750910
PNOZ s nIE
750900
PNOZ s pIE
751004
PNOZ s Setspring loaded terminals 22,5mm
Page 3/3
很抱歉,暂时无法提供与“751104”相匹配的价格&库存,您可以联系我们找货
