540320
540320
    PILZ
    PILZ - 540320 - Sensor Cable, M12 Receptacle, Free End, 8 Positions, 5 m, 16.4 ft
540320 数据手册
PSEN cable axial M12 8-pole 5m 540320 Connection cable, PUR, yellow RAL1003, suitable for drag chains, 8pin,socket straight M12, on open line end, A-coded, cable length: 5m Technical details General data Approval: CE, UKCA, cULus Listed Technical data Electrical data Rated current: 2A Typ. conductor resistance K1: 79 Ohm/km Specific contact resistance K1: >= 7E+15 Ohm*cm Specific conductor capacity K1: 64.6pF/m Environmental data Ambient temperature: -25 - 80 °C Overvoltage category: II Pollution degree clear.&creep.: 3 Mechanical data Connector type 1: 8-pin M12 female connector Shape of connector type 1: straight Coding of M12 connector 1: A coded Matl threaded ring conn 1: CuZn nickel-plated Contact surfaces material 1: Au Material of sockets: CuSn Cable material K1: Cu Pilz GmbH & Co. KG, Felix-Wankel-Strasse 2, 73760 Ostfildern, Germany Page 1/3 Insulation material cable K1: PP (9Y) Cable type K1: LiF9Y11Y Length cable: 5m Colour cable insulation 1: Yellow, similar to RAL 1003 Housing colour: Black Material of cable insulation 1: TPU / TPE-U, PUR Trailing capability of cable 1: yes Bend radius (when laying) K1: 5xØ Max. outside diameter cable K1: 6.1 - 6.1 mm Conductor cross section: 0.25 - 0.25 mm² Cable cross section AWG K1: 24 Stranding K1: 8 cores round plastic filler Shielding K1: no Number of conductors: 8 Approvals for cable K1: UL AWM-Style 20233, UL/CSA Approvals for connector 1: UL94 V-0 Halogen-free: yes Oil resistance: resistant Flame resistance: UL VW1, FT1 Housing material: PUR Net weight: 250 g Gross weight: 260 g Environment RoHS directive: 2011/65/EU, 2015/863/EU RoHS conformity: yes RoHS exceptions: yes RoHS except.s acc. to direct.: 6c REACh compliance: contains min. 1 SVHC-substance REACh included substances: Lead Pilz GmbH & Co. KG, Felix-Wankel-Strasse 2, 73760 Ostfildern, Germany Page 2/3 %-part of the pollutant: > 0,1 CAS No.: 7439-92-1 WEEE classifikation (08/2018): 5 devices (feed size < 50cm) Commercial data ECLASS version: ECLASS-9.1 ECLASS Reference Feature: 27060311 ETIM Version: ETIM-7.0 ETIM Reference Group: EG000026 Pilz GmbH & Co. KG, Felix-Wankel-Strasse 2, 73760 Ostfildern, Germany Page 3/3
540320 价格&库存
很抱歉,暂时无法提供与“540320”相匹配的价格&库存,您可以联系我们找货
  • 1+339.751521+43.99090
  • 5+335.126095+43.39200
