511735
511735
    PAULSTRA
511735 数据手册
RADIAFLEX DESCRIPTION • Metalwork : Mild steel, plated. • Natural rubber, bonded, cylindrically shaped. • Welded fixings: 5 styles (single sided threaded stud, single sided threaded hole, double threaded stud, double threaded holes, combination fixing). In Europe, we often use different screw standards than our french standard. To better satisfy this need, Paulstra has created a new range TRadiaflex Europe. This range is available with the 4 usual welded fixings and with a new fixing : the threaded hole stop. CHARACTERISTICS The design of the RADIAFLEX mount gives the following basic characteristics : • Radial elasticity greater than axial elasticity. • The rubber works in : - compression (axial). - shear (radial). - compression/shear according to the fixing method. Advantages : • Simple to fix. • Simple and economical. • Extensive range : - 11 stud diameters. - Several heights for each diameter. - 5 methods of fixing. Recommendations : • Operation in shear is very useful for vibration isolation provided that the radial forces are not too great. 34 DIMENSIONS AND COMPRESSIVE LOADS SINGLE STUD FIXING DOUBLE STUDS FIXING ØA ØC B G B G ØA ØC See Vibrachoc elastomer range : Threaded studs New RADIAFLEX references ØA B G ØC mm mm mm 10 12.5 13.5 15 20 10 15 16 10 15 20 25 8.5 15 20 20 25 30 10 15 20 30 10 25.5 15 19 22 25 30 40 15 30 22 30 40 30 40 20 40 25 35 40 45 25 50 35 45 22 60 25 36 45 35 70 50 70 25 30 80 40 70 80 Compression Deflection Max. load mm daN M5 10 12 11 10 8 M4 10 20 M5 12 M6 16.5 M6 18 M8 20 M8 25 M8 20 M10 25 M10 25 M10 25 M10 25 45 35 M14 35 35 35 20 20 15 15 40 35 30 30 25 80 60 50 50 80 60 55 50 50 50 50 90 80 70 60 120 120 160 150 120 120 120 300 250 190 350 400 300 250 450 350 300 1100 950 600 500 450 2 2.5 3 3.5 2 3 2 3 4 5 1.5 4 5 5.5 7 2 3.5 5 8 2 3.5 4.5 5.5 6 8 10 3.5 6 8 9 7 10 5 6 8 10 11 6 9 11 3 6 9 11 9 12 14 6 8 10 17 19 Compression Shear* ØA B G Max. Max. ØC mm mm mm load Deflect load Deflect mm mm Ref. 511110 511128 511115 511125 511150 511151 511292 511294 511296 511298 511200 511215 511220 511225 511230 511158 511155 511159 511160 511265 511270 511251 511275 511280 511285 511290 511308 511310 511312 511314 511157 511161 511450 511401 511452 511454 511456 511525 511535 511545 513601 511625 511635 511645 511735 511750 511770 513801 511830 511840 511870 511880 8 8 10 12.5 15 20 10 15 16 10 15 20 25 8.5 15 20 20 25 30 10 15 20 30 25.5 10 15 22 25 30 40 15 30 22 30 40 30 40 20 40 28 35 40 45 25 50 35 45 25 60 36 45 35 70 50 70 40 30 80 30 40 70 80 40 100 55 80 10 12 Threaded hole fixing on request (except Ø 12.5). See current price list for availability of items. M3 M3 6 6 M5 10 M4 10 daN 10 12 12 10 8 20 20 20 15 15 40 35 M6 16.5 30 30 25 80 60 M6 18 50 50 80 60 50 M8 20 50 50 50 90 80 M8 25 70 60 150 M8 20 120 160 150 120 M10 25 120 120 300 M10 25 250 190 400 M10 25 300 250 450 M10 25 350 300 M12 28 600 45 950 35 950 600 M14 35 35 500 450 35 1100 M16 47 900 750 M5 12 1.6 1.2 2 3 3.5 1.5 3 1.5 3 4 5 0.6 3 4.5 5.5 7 1.5 2.5 2 7.5 1.5 2.5 4 5.5 7.5 10 3 5 8 9 6 10 4 6 8 10 11 6 8 11 5 8 11 8 11 14 9 7 7 9 17 19 8 12 19 daN 1.25 1.5 1.5 2.5 2.5 2.5 2.5 2.5 2.5 2 5 5 5 4.5 4.5 8 8 8 8 8 8 8 8 8 6.5 11 11 11 11 20 20 20 20 20 20 20 25 25 25 30 30 30 35 35 35 40 40 40 40 40 40 60 60 60 0.9 0.75 1.5 2 4 1.5 2 1.5 2 4 5 1 2.5 3.5 4.5 4.5 1.5 2.5 4 6 1.5 2.5 4 4.5 6 6 2.5 4 6 7.5 5.5 7.5 3 5.5 6.5 7.5 9 4.5 7 9 4.5 7 9 6.5 11 15 7 5 5 7 15 17 7 10 17 *The shear characteristics are measured under Axial Load. **See VIBRACHOC elastomer range : references E3RP. 35 Ref. ** ** 521293 521128 521295 521650 521651 521292 521294 521296 521298 521178 521249 521297 521299 521319 521655 521656 521652 521653 521340 521341 521251 521342 521343 521344 521308 521310 521312 521314 521181 521657 521450 521401 521452 521454 521456 521580 521581 521582 521601 521603 521641 521705 521710 521711 521658 521803 521840 521841 521842 521843 521908 521909 521910 COMBINATION FIXING THREADED HOLE FIXING ØA ØA ØC H H B B G ØC ØC Compression Shear* Ø A B Ø C G H Max. Max. Deflect. mm mm mm mm mm load Deflect. load mm mm daN 10 15 10 16 15 20 25 15 20 20 25 30 15 20 30 25.5 22 25 30 40 15 22 30 30 40 30 40 20 40 28 35 40 45 35 50 45 36 60 45 35 70 50 70 40 40 80 70 80 40 55 100 80 100 M4 10 2 M5 12 3 M6 16.5 4 M6 18 4 M8 20 6 M8 25 6 M8 20 6 M10 25 8 M10 25 8 M10 25 8 M10 25 9 M12 28 10 M14 35 12 M16 47 14 20 20 20 15 15 35 30 30 25 60 50 50 50 50 50 50 90 80 70 60 150 120 160 150 120 120 120 250 190 300 250 450 350 300 600 600 500 400 1100 900 750 600 Ref. daN 1.5 3 1.5 3 4 5 2.5 4.5 5.5 7 2.5 3.5 7.5 3.5 5 7.5 10 3 4.5 7.5 9 4.5 10 4 5 7.5 10 11 8 11 8 10 7.5 10 14 7 8 17 19 8 12 12 23 2.5 2.5 2.5 2.5 2 5 5 4.5 4.5 8 8 8 8 8 8 6 11 11 11 11 20 20 20 20 20 20 20 25 25 30 30 35 35 35 10 40 40 40 60 60 60 60 1.5 2.5 1.5 2 4 5 2.5 5 4.5 4.5 8.5 4 6 4 4.5 6 6 2.5 4 6 7.5 5.5 7.5 3 5.5 6.5 7.5 9 7 9 7 9 6.5 11 15 7 7 15 17 7 10 17 20 520053 520054 520010 520011 520012 520013 520015 520016 520017 520018 520052 520055 520057 520021 520022 520023 520024 520025 520026 520027 520028 520056 520058 520029 520030 520031 520032 520033 520035 520036 520038 520039 520040 520041 520042 520059 520044 520045 520046 520100 520101 520102 520103 Ø 16 mounts with threaded holes are fitted with RAPID nuts. Maximum torque 1.8 m.N. Compression Shear* Ø A B Ø C H Max. Max. Deflect. mm mm mm mm load Deflect. load mm mm 16 20 25.5 30 40 50 60 70 10 15 10 15 20 25 15 20 25 30 20 30 22 25 30 40 22 30 40 30 40 28 35 40 45 35 45 36 45 35 50 70 40 M4 2.5 M5 3 M6 4 M6 4 M8 6 M8 6 M8 6 M10 8 M10 8 M10 8 M10 9 M12 10 daN 20 20 20 20 15 15 35 30 30 25 50 50 50 50 50 50 80 70 60 150 120 150 120 120 120 250 190 300 250 450 350 300 120 1.5 3 1.5 3 4 5 2.5 4.5 5.5 7 3 7.5 3 4.5 7.5 10 4 7.5 9 4.5 10 4.5 7 10 11 7 10 7 9 7 9 14 10 daN 2.5 2.5 2.5 2.5 2.5 2 5 5 4.5 4.5 8 8 8 8 8 6 11 11 11 20 20 20 20 20 20 25 25 30 30 35 35 35 20 1.5 2 1.5 2 4 5 2.5 3.5 4.5 4.5 4 4.5 6 6 4 6 7.5 5.5 7.5 5.5 6.5 7.5 9 7 9 7 9 6.5 11 15 7.5 520550 520551 520500 520501 520502 520503 520505 520506 520507 520508 520554 520555 520511 520512 520513 520514 520516 520517 520518 520552 520553 520520 520521 520522 520523 520525 520526 520528 520529 520530 520531 520532 520556 7 15 17 7 10 10 12 17 20 520534 520535 520536 520541 520542 520545 520546 520543 520547 4 6 40 600 7 40 70 M14 12 500 17 40 80 450 19 40 40 1110 8 60 55 900 12 60 1100 8 180 100 60 M16 14 75 600 10 140 80 750 19 60 100 600 23 60 See current price list for availability of items. 80 Ref. * Shear characteristics are measured under axial load. ONE THREADED HOLE ØA ØA B H ØC mm mm mm ØC H ! 36 Ref. 16 10 15 M4 2,5 20 20 2 3 511152 511153 20 15 M6 4 35 4 511154 25,5 15 20 30 M6 4 60 55 50 3,5 5,5 8 511164 511162 511163 30 22 M8 6 80 6 511156 B w Ne Compression Max load Deflect. daN mm DIABOLO MOUNTS ØC G P F B S G (cm²) P ØC ØA Compression Shear* ØA B G S ØC M ax M ax Deflec mm mm mm cm² Load Deflec -tion Load -tion daN mm daN mm 12.5 20 40 57 57 60 80 95 14 19 28 44 44 60 70 76 M5 M6 M10 M8 M8 M10 M14 M16 10 0.3 16.5 1.6 25 3.1 20 5 20 9.5 25 19.5 35 38.5 45 50 3 12 30 40 75 150 300 400 1.4 2.5 5 5 5 8 9.5 9.5 0.5 3 2.5 7 12 30 55 70 1.2 5 4.5 5 6 10 9.5 8 Ref. 521300 521201 521403 521571 521572 521602 521801 521951 See current price list for availability of items. * Shear characteristics’ are measured under axial load. Also available with Ø 30 locators on each end, 3 mm thick allow M14 threaded holes : ØA B ØC mm mm 80 60 M14 Depth of thread mm 15.5 Compression Shear* S Max Deflec Max Deflec cm² Load -tion Load -tion daN mm daN mm 38.5 250 5 70 8 Ref. 521802 ASSEMBLY Compression/Shear Compression The fixing holes for the Radiaflex mounts should have a chamfer with a depth equal to the pitch of the thread. Ex. 521401 : M10 x 150 chamfer = 1.5 mm 521951 : M16 x 200 chamfer = 2 mm 37 Shear
511735 价格&库存
很抱歉,暂时无法提供与“511735”相匹配的价格&库存,您可以联系我们找货
