530805-80
530805-80
    PAULSTRA
530805-80 数据手册
MINIFIX New range MINIFIX DESCRIPTION The MINIFIX mounting comprises an elastomer pad with an anti-slip ridged surface and a threaded stud allowing accurate height adjustment of equipment. Made in two hardnesses (50 and 80 Sh) the MINIFIX mounting is perfectly suited to a variety of applications and is delivered complete with fixing nuts and washers. MINIFIX mounting nuts and screws are made of steel or stainless steel. CHARACTERISTICS Reference Reference Stainl. steel Steel - 530801 - 530802* 530806 530805 - 530807 B C D ØA Hardness Colour 50 SBR 80 Nitrile 50 SBR 80 Nitrile 50 SBR 80 Nitrile 50 SBR 80 Nitrile grey black grey black grey black grey black * Threaded centre hole. See current price list for availability of items. ØA B C mm mm mm 32 46 46 70 D M8 stud M10 15 nut M10 15 38 stud M12 25.5 55.5 stud 15 38 Load range daN 5 - 30 15 - 70 10 - 80 25 - 200 10 - 40 25 - 100 50 - 120 100 - 350 1 kg . 1 daN APPLICATIONS Simple and economic, MINIFIX mountings are particularly suitable for the installation of equipment such as: • Electrical or electronic enclosures. • Packaging equipment. • Test and measuring equipment. • Equipment for the food industry. • Laboratory equipment. • Household appliances. 67
530805-80
物料型号: - 530801:不锈钢材质,硬度为50 SBR 80 Nitrile,颜色为灰黑色。 - 530802:钢材质,硬度为50 SBR 80 Nitrile,颜色为灰黑色,中心孔有螺纹。 - 530805:钢材质,硬度为50 SBR 80 Nitrile,颜色为灰黑色。 - 530806:不锈钢材质,硬度为50 SBR 80 Nitrile,颜色为灰黑色。 - 530807:不锈钢材质,硬度为50 SBR 80 Nitrile,颜色为灰黑色。
器件简介: - MINIFIX安装座由一个带有防滑脊面的橡胶垫和一个允许精确高度调节的螺纹螺柱组成。 - 该安装座有两种硬度(50和80 Sh),适合各种应用,并配有固定螺母和垫圈。
引脚分配: - 530801:M8螺柱,负载范围为5-30 daN。 - 530802:M10螺母,负载范围为10-80 daN。 - 530805:M10螺柱,负载范围为10-40 daN。 - 530806:M10螺柱,负载范围为25-100 daN。 - 530807:M12螺柱,负载范围为50-120 daN。
参数特性: - 硬度:50 SBR 80 Nitrile。 - 颜色:灰黑色。 - 尺寸:OA mm(外径)、B mm(高度)、C mm(螺纹直径)。
功能详解: - MINIFIX安装座适用于需要精确高度调节的设备安装。 - 适用于多种应用,如电气或电子外壳、包装设备、测试和测量设备、食品工业设备、实验室设备和家用电器。
应用信息: - MINIFIX安装座简单经济,特别适合安装如电气或电子外壳、包装设备、测试和测量设备、食品工业设备、实验室设备和家用电器等设备。
封装信息: - MINIFIX安装座螺母和螺钉由钢或不锈钢制成。
530805-80 价格&库存
很抱歉,暂时无法提供与“530805-80”相匹配的价格&库存,您可以联系我们找货
