A1561
A1561
    HAKKO(日本白光)
    WIRE,CLEANING,FH-800
A1561 数据手册
Auto-soldering system Soldering iron Home Products Soldering iron Station type HAKKO FX-100 Soldering iron/Station type Station type Model name or Keyword HAKKO FM-2027/FM-2028 HAKKO FM-203 HAKKO FM-2030 HAKKO FM-2032 FX-100 provides the heat to the tip effectively by HAKKO FM-206 ‘Induction heater’ HAKKO FX-100 In addition, it allows more efficient heat supply with Model name or Keyword power assist of our unique technology. HAKKO FX-1002 No calibration is required. HAKKO FX-801 Selectable micro soldering iron as usage at your HAKKO FX-838 option. HAKKO FX-8801/FX-8805 HAKKO FX-888D Available in: HAKKO FX-889 HAKKO FX-950 HAKKO FX-951 HAKKO FX-952 Lead-Free Soldering ESD-SAFE products N2 system European RoHS Built-in solder feed type Ceramic heater type N2 system Part No. Name Specifications B5007 Sleeve green Nichrome heater type Battery-powered type 2018.07/02 - Best suited for electronic parts High quality for professional-use Excellent sharpness and durability Soldering pot/bath B5008 Sleeve gray Soldering related equipment and materials due to our unique heat-treatment Cutting pliers and pliers HAKKO HAND TOOLS Desoldering / Rework B2300 2018.07/02 Heat resistant pad - Precision tweezers for Smoke absorber electronic parts - Non-magnetic stainless-steel tweezers Precision Static Control tweezers HAKKO HAND TOOLS Tester / Meter FX1001-81 Soldering iron FX-1001 2018.01/23 Sealer / Glue Gun / Hot air A wide range of nozzles and blower Hobby shapes for any desoldering - Use FH800-81BY Iron holder blue of high thermal efficiency N61 series nozzles - A wide range of nozzles and shapes for secure desoldering - Equipped with high- B5006 Sleeve yellow precision temperature control function - Easy temperature control - Reduction of solder clogging by improved heating core A5038 Cleaning sponge yellow - Easy filter maintenace - Quick Change Nozzle System provides speed and safety - Includes simple iron holder - Power switch on grip - Includes carrying case A1561 Cleaning wire Portable desoldering tool HAKKO FR-301 Part No. Name Specifications FX1002-81 Soldering iron FX-1002 with Sleeve assembly yellow FX1002-82 HAKKO FX-1002 conversion kit with Sleeve assembly green, iron holder and heat resistant pad B5179 Sleeve assembly yellow, for FX-1002 B5180 Sleeve assembly green, for FX-1002 FH800-82BY Iron holder blue, for FX-1002 B3474 Rubber cleaner Home | Products | What's new | Support | Downloads | About Us | Contact Us This site uses cookies to gather information regarding site usage such as click counts. Accept Copyright (c) HAKKO Corporation. All Rights Reserved.
A1561 价格&库存
很抱歉,暂时无法提供与“A1561”相匹配的价格&库存,您可以联系我们找货
