191-212
191-212
    HAKKO(日本白光)
    SENSOR,SET OF 10,LEAD FREE SOLDE
191-212 数据手册
Auto-soldering system Soldering iron Home Products Tester / Meter Thermometer / soldering tester HAKKO FG-100 Tester / Meter/Thermometer / soldering tester Soldering pot/bath Model name or Keyword Soldering related equipment and materials Desoldering / Rework Tip thermometer providing reliable temperature control Smoke absorber of soldering iron tips Model name or Keyword Compact design saves your workspace and allows Static Control you to easily carry it around Tester / Meter Extremely fine sensor with high temperature reactivity is incorporated Thermometer / soldering tester HAKKO FG-100 Available in: HAKKO FG-101 HAKKO FG-102 Static level meter Lead-Free Soldering Tester for wrist strap ESD-SAFE products Tester for antistatic shoes European RoHS N2 system Sealer / Glue Gun / Hot air blower Hobby Part No. Name Specifications 191-212 Sensor (qty 10) lead-free 2018.07/02 - Best suited for electronic parts High quality for professional-use Excellent sharpness and durability due to our unique heat-treatment Change-out rate of sensor Cutting pliers and pliers HAKKO The sensor replacement period is about 50 times per single sensor in general, but this changes depending on the temperature used and the components in the solder and flux. If you use lead-free solder, the sensor needs to be replaced more frequently. If the sensor degrades because it is being eaten away by the solder, it will register a low temperature. Even if the sensor is not broken, replace it after about 50 measurements. HAND TOOLS 2018.07/02 - Precision tweezers for electronic parts - Non-magnetic Even if the soldering tip has degraded, the temperature will register extremely low. Keep these points in mind and decide on the sensor replacement period. Caution: The sensor is extremely thin and may break if pushed with force. stainless-steel tweezers Precision tweezers HAKKO HAND TOOLS 2018.01/23 A wide range of nozzles and shapes for any desoldering - Use Part No. Name Specifications of high thermal efficiency N61 series nozzles - A wide range of nozzles and shapes for secure A1310 Temperature probe for soldering bath & pot desoldering - Equipped with highprecision temperature control function - Easy temperature control - Reduction of solder C1541 Temperature probe hot air clogging by improved heating core - Easy filter maintenace - Quick Change Nozzle System provides speed and safety - Includes A1556 Sensor A simple iron holder - Power switch on grip - Includes carrying case Portable desoldering tool HAKKO FR-301 A1557 Sensor B A1310 C1541 Home | Products | What's new | Support | Downloads | About Us | Contact Us This site uses cookies to gather information regarding site usage such as click counts. Accept Copyright (c) HAKKO Corporation. All Rights Reserved.
191-212 价格&库存
很抱歉,暂时无法提供与“191-212”相匹配的价格&库存,您可以联系我们找货
