G3-1601
G3-1601
    HAKKO(日本白光)
    BLADE,KNIFE,FT-8003
G3-1601 数据手册
Thermal strip gives great sharpness. FT-802 Due to the tweezers structure, the cutting edges are always aligned. Conventional wire stripper The blades can be securely fixed by making the frame with tweezers structure. Ragged edges Nick FT-802 can strip the insulation of AWG 38 wire with no nick. Conventional wire stripper could make ragged edges of insulation or damage strands. Blades are replaceable and a handpiece can be saved. Output setting by the unit of 5% Easy to set optimum output level as per material Material PVC PE PA PVDF ETFE SI PTFE Tweezers structure Output value (%) 10 10 20 30 40 45 55 No need to replace a handpiece when blades get worn out. Blades can be easily replaced by using the hex-wrench (included in the unit) and the blade removal plate. * The blades must be cool before replacement for safety. * The above values are for reference. User-friendly display Status of a handpiece at glance on the display. User-friendly design for reduction of stress during the work. Remove blades. A handpiece is correctly set in a holder. Put removed blades in the holder. Same as the output value. Ready to work immediately. Auto sleep function will activate after passing the set time. Optional Blades AWG 26 AWG 26 AWG 26 AWG 24 AWG 24 AWG 24 AWG 22 AWG 22 AWG 22 AWG 20 AWG 20 AWG 20 AWG 18 AWG 18 AWG 18 AWG 38 AWG AWG 38 38 AWG 36 AWG AWG 36 36 AWG 32 AWG AWG 32 32 AWG 30 AWG AWG 30 30 AWG 28 AWG AWG 28 28 AWG 26 AWG AWG 26 26 For FT-8003 (option) Φ5.2 AWG 28 AWG AWG 28 28 0.2 R1 5 For FT-8004 16 G3-1601 G4-1602 G4-1603 0.0.20. 22 RR R11155 5 Φ5.2 Φ5.2 Φ5.2 G4-1601 16 16 16 87 Tool for Lead and Wire Features
G3-1601 价格&库存
很抱歉,暂时无法提供与“G3-1601”相匹配的价格&库存,您可以联系我们找货
