29W0-100UA0-30
29W0-100UA0-30
    SIFAM
29W0-100UA0-30 数据手册
Key features ◆ Flexible styling – 4 sizes each in four styles ◆ High quality modular construction ◆ Taut band core magnet movements Presentor Meter types 19, 29, 39, 49 The Presentor range of analogue moving coil instruments is available in four sizes each in four styles. The modern flexible styling meets today’s stringent design and economic requirements. Features and benefits Calibration ◆ Choice of four styles available in each size - Simple back of panel mounting - Back of panel mounting with accompanying bezel - Front of panel mounting with lower mask - Front of panel mounting with full bezel For vertical use unless otherwise specified. ◆ Constructed with transparent acrylic front and high impact translucent rear body moulding. Masks and bezels, available in black or grey, are moulded in ABS. ◆ Taut band core magnet movement incorporated as standard within a compact 26mm diameter barrel. There is no calibration effect when mounted on a ferrous panel Pointers and dials Pointers and dial markings are normally in accordance with the current BS3693 requirements. Other types of pointer and/or custom dial markings together with company logos, including colour printing can be provided to suit individual requirements. Centre or righthand zero scales are available if required. Mirror dials can be supplied (except for type 19). Accuracy All SIFAM meters are normally supplied/designed to meet the requirements of current BS89, IEC 51, EN60 051 and ANSI C39.1 standards. Zero adjuster Normally positioned on the front of surface mounted styles and on the rear of behind panel styles. Reverse options to these may be specified. Certified drawings Available on request. Operating Temperature -25°C to +55°C. Audio level indicators All of the Presentor meters are available in this version (except type 49). Please refer to SIFAM for specific information. Illumination Comprehensive options are available. Please refer to back page for more information. Terminals 6mm tabs are supplied as standard but threaded studs or flying leads are available. Please refer to back page for more information. Presentor Style W A For back of panel mounting with only the scale and pointer visible. L CUT-OUT N B M CUT-OUT Types: 19W, 29W, 39W, 49W P K METER Meter barrel cut out 27.0mm/1.06” Fixing studs M2.5x10.0mm/0.39” (except type 19: M2) 6.00mm/0.24” hole required when optional front zero is specified Presentor Style WF A For back of panel mounting with bezel and with only the scale and pointer visible. Types: 19WF, 29WF, 39WF, 49WF N B BEZEL K METER P Max panel thickness 4.0mm/0.16” (except type 19: 3.0mm/0.12”) Meter barrel cut out 27.0mm/1.06” Fixing studs M2.5x10.0mm/0.39” (except type 19: M2) 6.00mm/0.24” hole required when optional front zero is specified Presentor Style M For front of panel mounting with lower mask. A Types: 19M, 29M, 39M, 49M B METER Max panel thickness 6.0mm/0.24” Meter barrel cut out 27.0mm/1.06” Fixing studs M2.5x10.0mm/0.39” (except type 19: M2) Presentor Style B For front of panel mounting with full bezel. A Types: 19B, 29B, 39B, 49B B METER Max panel thickness 6.0mm/0.24” Meter barrel cut out 27.0mm/1.06” Fixing studs M2.5x10.0mm/0.39” (except type 19: M2) M CUT-OUT L CUT-OUT 19W D F E A B C D E F G H J K L M N P J C G METER 39W 49W inches mm inches mm inches mm inches 43.9 21.0 11.5 37.2 1.50 32.0 4.70 1.73 0.82 0.45 1.46 0.06 1.26 0.18 76.1 33.3 11.5 38.7 1.80 47.8 15.0 9.70 38.0 58.8 73.66 32.26 3.90 16.1 2.99 1.31 0.45 1.52 0.07 1.88 0.59 0.38 1.50 2.32 2.90 1.27 0.15 0.63 94.0 41.9 11.5 39.2 2.00 57.2 20.9 8.60 48.5 72.4 91.50 40.50 5.70 20.4 3.70 1.65 0.45 1.54 0.08 2.25 0.82 0.34 1.91 2.85 3.60 1.59 0.22 0.80 124.0 57.1 11.5 40.3 2.10 92.0 26.9 4.88 2.25 0.45 1.59 0.08 3.62 1.06 Fixing studs in same horizontal plane above C/L 7.0mm/0.28” 37.9 42.4 20.20 2.0 9.90 1.49 1.66 0.79 0.08 0.39 Fixing studs in same horizontal plane above C/L 7.0mm/0.28” 93.0 121.00 55.50 10.6 21.5 3.66 4.76 2.19 0.42 0.85 H BARREL 29W mm Ø26.0 1.02" 19WF C D E R F BEZEL G J METER H BARREL Ø26.0 1.02" 29WF E F J D 49WF inches mm inches mm inches mm inches A B C D E F G H J 49.2 27.0 11.5 40.8 1.50 32.0 6.10 1.94 1.06 0.45 1.61 0.06 1.26 0.24 82.8 41.6 11.5 42.9 1.50 47.8 16.7 9.70 38.0 3.26 1.64 0.45 1.69 0.06 1.88 0.66 0.38 1.50 101.0 50.5 11.5 43.4 1.6 57.2 22.7 8.60 48.5 3.98 1.99 0.45 1.71 0.06 2.25 0.89 0.34 1.91 131.0 65.6 11.5 44.5 1.70 92.0 28.7 5.16 2.58 0.45 1.75 0.07 3.62 1.13 K L M N P Q R 40.6 47.0 24.0 5.20 8.00 58.5 6.80 1.60 1.85 0.94 0.20 0.31 2.30 0.27 62.2 80.0 37.0 8.10 13.7 90.6 10.3 2.45 3.15 1.46 0.32 0.54 3.57 0.41 76.1 98.0 46.0 10.2 17.7 108.6 12.8 2.99 3.86 1.81 0.40 0.70 4.28 0.50 96.5 128.0 61.0 15.1 18.8 139.7 15.4 mm inches mm inches mm inches mm inches 43.9 38.8 11.5 31.2 7.50 32.0 4.20 1.73 1.53 0.45 1.23 0.30 1.26 0.17 76.1 60.3 11.5 30.5 10.0 47.8 14.2 9.70 38.0 2.99 2.37 0.45 1.20 0.39 1.88 0.56 0.38 1.50 94.0 74.0 11.5 30.2 11.0 57.2 20.0 8.60 48.5 3.70 2.91 0.45 1.19 0.43 2.25 0.79 0.34 1.91 124.0 94.6 11.5 30.2 12.2 92.0 26.1 4.88 3.72 0.45 1.19 0.48 3.62 1.03 Fixing studs in same horizontal plane above C/L 7.0mm/0.28” 19M C 39WF mm Q A B C D E F G H J Fixing studs in same horizontal plane above C/L 7.0mm/0.28” 29M Fixing studs in same horizontal plane above C/L 7.0mm/0.28” 39M 3.80 5.04 2.40 0.59 0.74 5.50 0.61 49M Fixing studs in same horizontal plane above C/L 7.0mm/0.28” G METER H BARREL Ø26.0 1.02" 19B E J F METER G D BARREL H C Ø26.0 1.02" A B C D E F G H J 29B 39B 49B mm inches mm inches mm inches mm inches 46.0 40.0 11.5 31.2 7.50 32.0 4.8 1.81 1.57 0.45 1.23 0.30 1.26 0.19 79.5 61.9 11.5 30.5 10.0 47.8 15.0 9.70 38.0 3.13 2.44 0.45 1.20 0.39 1.88 0.59 0.38 1.50 97.5 76.4 11.5 30.2 11.0 57.2 20.8 8.60 48.5 3.84 3.01 0.45 1.19 0.43 2.25 0.82 0.34 1.91 127.7 96.6 11.5 30.2 12.2 92.0 26.9 5.03 3.80 0.45 1.19 0.48 3.62 1.06 Fixing studs in same horizontal plane above C/L 7.0mm/0.28” Fixing studs in same horizontal plane above C/L 7.0mm/0.28” Presentor Terminals Standard ranges If the required range is not indicated by a symbol please enquire as it may be possible to supply to your special requirements Bent tabs option 4.5 mm 0.18" DC Range V 0-1 µA ●* AC mA A V ● ● ● ● ● µA mA A ● ■ 0-1.5 0-2 ● ◆ 0-2.5 Screw terminals option All types/styles M2.5 terminals 0-3 ● ● ◆ ● 0-5 ● ● ◆ ● ● ■ 0-10 ● ● ◆ ● ● ■ ● ● ▲ ● ● ■ ■ 0-12 6.0 mm 0.24" 10.3 mm 0.41" 12.0 mm 0.47" 0-15 ● 0-20 ▲ 0-25 Flying leads option Also available with reduced barrel depth - special order only 0-30 ● ● ▲ ● ● 0-40 ● ● ▲ ● ● 0-50 ● ● ● ▲ ● ● ● ■ 0-100 ● ● ● ▲ ● ● ● ■ ■ Type Barrel Depth 0-120 ● 19 29.2mm/1.15* 0-150 ● 29 28.5mm/1.12* 0-200 ● ● ● ▲ ● ● 39 28.2mm/1.11* 0-250 ● ● ● ▲ ● ● 49 28.3mm/1.11* 0-300 ● ● Overhead Available for types 19W, 19WF, 29W, 29WF, 39W, 39WF Unit contains Ø6mm festoon style lamp available in 6V, 12V, or 24V Illumination bracket assembly ■ ● 0-500 This is available in either of the two forms shown below and should be specified at the time of ordering meters. Please contact the sales office for full information and drawings. ● ▲ 0-400 Illumination ● ● ● ▲ ● 0-1000 ✔ ▲ ✔ 0-1500 ✔ ▲ ✔ 0-2000 ✔ ▲ ● Self contained. ◆ Complete with external tag board. ▲ 75mV - external shunt required. ■ ✔ Complete with external resistance box. * Millivoltmeters can be supplied on request. ■ Complete with external transformer. Terminal resistance Range Tolerance ± 15% Range Tolerance ± 15% 50µA 2000Ω 250µA 255Ω 100µA 1000Ω 500µA 155Ω 200µA 365Ω 1mA 50Ω Accuracy Light Box Available for all styles of types 29, 39 which require translucent dials. The meter fixing studs occupy different positions and rectangular panel cut-outs are required for styles M, B. Unit is available with either festoon style or T1 3/4 flanged lamps in 6V, 12V, 24V. T1 3/4 flanged LEDs are also available in either 12V or 24V. Scale length DC AC Rectifier 19 34.0mm/1.34” ±2.5% ±2.5% 29 60.0mm/2.36” ±1.5% ±2.5% 39 78.0mm/3.07” ±1.5% ±2.5% 49 100.0mm/3.94” ±1.5% ±1.5% Weight Type Nett Weight Type Nett Weight 19 40g/1.4oz 39 90g/2.8oz 29 65g/2.3oz 49 130g/4.6oz As part of our policy of continuous product improvement we reserve the right to change specifications at any time. Certificate No. 851037 SIFAM LIMITED WOODLAND ROAD TORQUAY DEVON TQ2 7AY ENGLAND TEL: 01803 407733 FAX: 01803 407740 Sifam_ComponentsUK@compuserve.com www.sifam.com SIFAM – The plastics and measurement technology group As part of our policy of continuous product improvement we reserve the right to change specifications at any time. Produced in the UK by SLS Communications 2500UK/02/99 Panel Type
29W0-100UA0-30 价格&库存
很抱歉,暂时无法提供与“29W0-100UA0-30”相匹配的价格&库存,您可以联系我们找货
