1.13/01
1.13/01
    GEDORE
    BATTERY-TERMINAL PULLER 3-ARM PA
1.13/01 数据手册
Baldur_9_GB.mif Seite 315 Freitag, 18. Juli 2003 10:15 10 1.04 Puller 2-arm pattern The new model for the safe and fast removal of pulleys, wheels, ball bearings, etc. Due to the bending-moment reinforcement on its back face, the energy-saving design of the cross piece means even stronger and safer pulling work. With the newly-developed cantilever hook design, it is possible to use these higher forces without losses over the whole width of the cross piece. The high-speed adjustment feature supports the energy-saving and fast operation. The spindle possesses an interchangeable tip, meaning that a ball tip may also be employed if necessary. Spindle may be exchanged for hydraulic pressure spindle (see table). Code No. 1307703 1.04/1A 1307827 1.04/2A 1307940 1.04/3A a1 a2 min a2 max b A 130 200 350 70 110 150 170 260 420 100 150 200 M 14x1,5 x 140 G 1/2 x 210 G 3/4 x 280 Hydraulic spindle $ c d e max. t 0 1.06/HSP1 1.06/HSP2 17 22 27 22 30 36 15 25 33 3,0 4,5 6,0 3,0 5,0 7,5 1.2 3.3 9.9 Hydraulic spindle $ c d e max. t 0 1.06/HSP1 1.06/HSP1 1.06/HSP2 1.06/HSP2 1.06/HSP3 1.06/HSP3 17 17 22 22 27 27 36 36 22 22 30 30 36 36 36 50 12 12 18 18 28 28 28 33 3,0 3,0 3,5 3,5 6,5 6,5 6,5 10,0 3,0 3,0 5,0 5,0 7,5 7,5 10,0 18,0 1.1 1.3 3.2 3.6 7.8 9.2 15.2 23.5 1.06 Universal puller 2-arm pattern The reliable model for the fast and safe removal of pulleys, wheels, ball bearings, etc. Strong drop forged design. Reversible hooks permit use as an internal or external puller. Available extras are replaceable hooks for various clamping reaches. Spindle may be exchanged for hydraulic pressure spindle (see table). Code No. 8000230 8000310 8000580 8000660 8000740 8000820 8000900 8112970 1.06/1 1.06/1A 1.06/2 1.06/2A 1.06/3 1.06/3A 1.06/4 1.06/5 a1 a2 min a2 max b A 90 130 160 200 250 350 520 640 60 70 80 90 125 125 185 230 140 180 220 260 330 420 600 715 100 100 150 150 200 200 200 225 M 14x1,5 x 140 M 14x1,5 x 140 G 1/2 x 210 G 1/2 x 210 G 3/4 x 280 G 3/4 x 280 G 1 x 310 G 1 x 310 1.06 Universal puller 2-arm pattern, with extended hooks As universal puller No. 1.06/1 to 1.06/4, but with extended pulling hooks. Spindle may be exchanged for hydraulic pressure spindle (see table). Code No. 8108350 8108430 8108510 8108780 8001200 8108860 8108940 8109080 8109160 8109240 8109320 8112380 8112460 1.06/1-2 1.06/1A-2 1.06/2-3 1.06/2A-3 1.06/3-3 1.06/3A-3 1.06/4-3 1.06/3-4 1.06/3A-4 1.06/4-4 1.06/3-5 1.06/3A-5 1.06/4-5 a1 a2 min a2 max b A 90 130 160 200 250 350 520 250 350 520 250 350 520 60 70 80 90 125 125 185 125 125 185 125 125 185 140 180 220 260 330 420 600 330 420 600 330 420 600 200 200 300 300 300 300 300 400 400 400 500 500 500 M 14x1,5 x 140 M 14x1,5 x 140 G 1/2 x 210 G 1/2 x 210 G 3/4 x 280 G 3/4 x 280 G 1 x 310 G 3/4 x 280 G 3/4 x 280 G 1 x 310 G 3/4 x 280 G 3/4 x 280 G 1 x 310 Hydraulic spindle $ c d e max. t 0 1.06/HSP1 1.06/HSP1 1.06/HSP2 1.06/HSP2 1.06/HSP3 1.06/HSP2 1.06/HSP2 1.06/HSP3 1.06/HSP2 1.06/HSP2 1.06/HSP3 17 17 22 22 27 27 36 27 27 36 27 27 36 22 22 30 30 36 36 36 36 36 36 36 36 36 12 12 18 18 28 28 28 28 28 28 28 28 28 3,0 3,0 3,5 3,5 6,5 6,5 6,5 6,5 6,5 6,5 6,5 6,5 6,5 3,0 3,0 5,0 5,0 7,5 7,5 10,0 7,5 7,5 10,0 7,5 7,5 10,0 1.5 1.8 4.4 4.8 9.1 10.5 16.5 10.4 11.8 17.8 11.6 13.0 19.0 315 Baldur_9_GB.mif Seite 316 Freitag, 18. Juli 2003 10:15 10 1.06 Universal puller 2-arm pattern, with rigid hooks Design as universal puller No. 1.06/1 to 1.06/4, but with rigid pulling hooks. For greater ease in setting the clamping spread. The hooks clamp automically when under tension. The hooks may be reversed to convert the puller from an external one to an internal one. Spindle may be exchanged for hydraulic pressure spindle (see table). Code No. 8001470 8001040 8001550 8001120 8001630 8001390 8109400 1.06/11 1.06/1A1 1.06/21 1.06/2A1 1.06/31 1.06/3A1 1.06/41 a1 a2 min a2 max b A 100 140 170 210 250 340 520 50 60 80 90 125 125 185 140 180 220 260 340 430 610 100 100 150 150 200 200 200 M 14x1,5 x 140 M 14x1,5 x 140 G 1/2 x 210 G 1/2 x 210 G 3/4 x 280 G 3/4 x 280 G 1 x 310 Hydraulic spindle $ c d e max. t 0 1.06/HSP1 1.06/HSP1 1.06/HSP2 1.06/HSP2 1.06/HSP3 17 17 22 22 27 27 36 22 22 30 30 36 36 36 15 15 24 24 32 32 32 4,0 4,0 3,5 3,5 5,0 5,0 5,0 3,0 3,0 5,0 5,0 7,5 7,5 10,0 0.8 1.2 2.7 3.1 6.6 8.0 14.0 1.06 Universal puller 2-arm pattern, with slim hooks The feet of the hooks are very slim and particularly suitable for barely-accessible places. Code No. 8113510 8113780 8114830 8114910 1.06/S1 1.06/S1A 1.06/S2 1.06/S2A a b A $ c d e f max. t 0 100 140 160 200 100 100 150 150 M 14x1,5 x 140 M 14x1,5 x 140 G 1/2 x 210 G 1/2 x 210 17 17 22 22 27 27 40 40 6 6 8 8 3,6 3,6 5,0 5,0 13 13 17 17 2,5 2,5 5,0 5,0 1.0 1.2 3.0 3.2 1.06 Fast clamping puller 2-arm pattern, with fast-clamp adjustment The tried and tested model for the safe and fast removal of pulleys, wheels, ball bearings, etc. Strong drop forged pattern. By reversing the hooks, this tool may be used as an internal or external puller. Exchangeable hooks for several clamping reaches available as accessories. With the innovative high-speed clamps, fast and uncomplicated setting-up and readjustment is child's play. Spindle may be exchanged for hydraulic pressure spindle (see table). Code No. 1213830 1215140 1216570 1217720 1218980 1220160 1.06/1-E 1.06/1A-E 1.06/2-E 1.06/2A-E 1.06/3-E 1.06/3A-E 316 a1 a2 min a2 max b A 90 130 160 200 250 350 60 70 80 90 125 125 140 180 220 260 330 420 100 100 150 150 200 200 M 14x1,5 x 140 M 14x1,5 x 140 G 1/2 x 210 G 1/2 x 210 G 3/4 x 280 G 3/4 x 280 Hydraulic spindle $ c d e max. t 0 1.06/HSP1 1.06/HSP1 1.06/HSP2 1.06/HSP2 17 17 22 22 27 27 22 22 30 30 36 36 12 12 18 18 28 28 3,0 3,0 3,5 3,5 6,5 6,5 3,0 3,0 5,0 5,0 7,5 7,5 1.1 1.3 3.2 3.6 7.8 9.2 Baldur_9_GB.mif Seite 317 Freitag, 18. Juli 2003 10:15 10 1.06 HSP Universal puller hydraulic, 2-arm pattern The tried and tested model for the safe and fast removal of pulleys, wheels, ball bearings, etc. Drop forged pattern. By reversing the hooks, this tool may be used as an internal or external puller. With the hydraulic spindle, a controlled and safe pulling action is possible at all times. Code No. 8000150 8002870 8003170 8003920 8004060 8004730 1.06/2-HSP1 1.06/2A-HSP1 1.06/3-HSP2 1.06/3A-HSP2 1.06/4-HSP3 1.06/5-HSP3 a1 a2 b Spindle c d e max. t 0 160 200 250 350 520 640 220 260 330 420 600 715 75 75 125 125 90 110 1.06/HSP1 1.06/HSP1 1.06/HSP2 1.06/HSP2 1.06/HSP3 1.06/HSP3 30 30 36 36 36 50 18 18 28 28 28 33 3,5 3,5 6,5 6,5 6,5 10,0 5,0 5,0 7,5 7,5 10,0 18,0 3.6 4.0 8.2 9.6 16.5 24.5 1.06 HSP Universal puller hydraulic, 2-arm pattern, with extended hooks For the highest requirements. With the hydraulic spindle, a controlled and safe pulling action is possible at all times. Code No. 8005700 8005890 8005970 8006940 8007240 8007670 8007750 8007830 8007910 8008480 8008560 1.06/2-3-HSP1 1.06/2A-3-HSP1 1.06/3-3-HSP2 1.06/3A-3-HSP2 1.06/4-3-HSP3 1.06/3-4-HSP2 1.06/3A-4-HSP2 1.06/4-4-HSP3 1.06/3-5-HSP2 1.06/3A-5-HSP2 1.06/4-5-HSP3 a1 a2 b Spindle c d e max. t 0 160 200 250 350 520 250 350 520 250 350 520 220 260 330 420 600 330 420 600 330 420 600 225 225 225 225 190 325 325 290 425 425 390 1.06/HSP1 1.06/HSP1 1.06/HSP2 1.06/HSP2 1.06/HSP3 1.06/HSP2 1.06/HSP2 1.06/HSP3 1.06/HSP2 1.06/HSP2 1.06/HSP3 30 30 36 36 36 36 36 36 36 36 36 18 18 28 28 28 28 28 28 28 28 28 3,5 3,5 6,5 6,5 6,5 6,5 6,5 6,5 6,5 6,5 6,5 5,0 5,0 7,5 7,5 10,0 7,5 7,5 10,0 7,5 7,5 10,0 4.8 5.2 9.5 11.4 18.4 10.4 11.3 19.4 12.4 13.4 20.4 1.06 HSP Universal puller hydraulic, 2-arm pattern, with rigid hooks With pulling hooks in one piece, drop forged pattern. By reversing the hooks, this tool may be used as an internal or external puller. With the hydraulic spindle, a controlled and safe pulling action is possible at all times. Code No. 8008640 8008720 8008800 8008990 8009370 1.06/21-HSP1 1.06/2A1-HSP1 1.06/31-HSP2 1.06/3A1-HSP2 1.06/41-HSP3 a1 a2 b Spindle c d e max. t 0 170 210 250 340 520 220 260 340 430 610 75 75 115 115 80 1.06/HSP1 1.06/HSP1 1.06/HSP2 1.06/HSP2 1.06/HSP3 30 30 36 36 36 24 24 32 32 32 3,5 3,5 5,0 5,0 5,0 5,0 5,0 7,5 7,5 10,0 3.7 3.8 7.0 8.8 14.8 317 Baldur_9_GB.mif Seite 318 Freitag, 18. Juli 2003 10:15 10 1.06 HSP Fast clamping puller hydraulic, 2-arm pattern With the hydraulic spindle, a controlled and safe pulling action is possible at all times. With the innovative high-speed clamps, fast and uncomplicated setting-up and readjustment is child's play. Code No. 1221256 1221450 1221639 1221760 1.06/2-E-HSP1 1.06/2A-E-HSP1 1.06/3-E-HSP2 1.06/3A-E-HSP2 a1 a2 b Spindle c d e max. t 0 160 200 250 350 220 260 330 420 75 75 125 125 1.06/HSP1 1.06/HSP1 1.06/HSP2 1.06/HSP2 30 30 36 36 18 18 28 28 3,5 3,5 6,5 6,5 5,0 5,0 7,5 7,5 3.7 4.1 7.6 8.8 1.06 HSP Hydraulic pressure spindle These grease-hydraulic pressure spindle has been designed for controlled and safe pulling work, and is set up for a pressure of up to 15 t. Preparation for use: 1. Before using, check whether the pressure spindle is screwed far enough out of the cap, so that the pressure pad is in the initial position in the hydraulic cylinder. 2. Unscrew the cap from the spindle body. For this purpose, first slacken off the grup screw. 3. Screw the spindle body from beneath into the cross piece of the puller until the body protrudes approx. 60 mm from the cross piece. 4. Screw the cap onto the spindle body until the stop, and then fix it in position by turning in the grub screw. Use and operation: e.g. HSP3 5. Place the puller into position and pre-tension the spindle body using a size 41 mm wrench. 6. Screw the pressure spindle size 17 mm into the cap. The hydraulic effect will come into use. The stroke of the pressure pad in the hydraulic cylinder is max. 12 mm. The workpiece that has been loosened by the hydraulic force may be pulled off completely by turning the spindle body with the cap size 41 mm. 7. Following its use, the pressure spindle (size 17 mm) is turned back into its initial position and the pressure pad pushed into the hydraulic cylinder. Code No. 8116100 1.06/HSP1 8116290 1.06/HSP2 8116370 1.06/HSP3 a b c d e 1/2" 3/4" 1" 55 80 125 135 205 165 350 420 465 12 12 17 f Stroke mm max. t 32 36 41 12 12 12 12 12 15 0 1.1 1.8 3.6 1.06 Extension for pullers DGBM The one-piece drop forged extensions enable the clamping reach to be extended indefinitely. The extensions may be used together with all hooks of the 1.06 range. (Delivery in pairs). DGBM = German Federal Utility Patent Code No. 8036500 1.06/V100 8036690 1.06/V150 8036770 1.06/V200 318 B for 1.06/A and 1.06/100 for 1.06/B and 1.06/150 for 1.06/C and 1.06/200 b 0 100 150 200 0.4 1.2 2.6 Baldur_9_GB.mif Seite 319 Freitag, 18. Juli 2003 10:15 10 1.06 Pulling hooks set of 2 pieces Pulling hooks (1 pair including clamping parts), in standard and special lengths. Code No. B 8035020 8035100 8035290 8114400 8035370 8035450 8035530 8035610 8035880 8112700 8112890 8113860 1.06/A 1.06/B 1.06/C 1.06/D 1.06/AV 1.06/BV 1.06/CV 1.06/DV 1.06/EV 1.06/D-300 1.06/D-400 1.06/D-500 1.06/1 1.06/2 1.06/3 1.06/5 1.06/1 1.06/2 1.06/3 1.06/3 1.06/3 1.06/5 1.06/5 1.06/5 /1A /2A /3A /4 /1A /2A /3A /4 /3A /4 /3A /4 b c d e 0 100 150 200 225 200 300 300 400 500 320 420 520 22 30 36 50 22 30 36 36 36 50 50 50 12 18 28 35 12 18 28 28 28 35 35 35 3,0 3,5 6,5 11,0 3,0 3,5 6,5 6,5 6,5 11,0 11,0 11,0 0.6 1.6 3.5 3.5 1.1 2.8 5.0 6.3 7.5 5.7 6.4 8.4 1.06 Pulling hooks set of 2 pieces, rigid pattern Code No. B 8036260 1.06/100 1.06/11 1.06/1A1 8111490 1.06/150 1.06/21 1.06/2A1 8036420 1.06/200 1.06/31 1.06/3A1 1.06/41 b c d e 0 100 150 200 22 30 36 15 24 32 3,0 3,5 5,0 0.4 1.1 2.4 1.06 Pulling hooks set of 2 pieces, slim pattern The forged hook feet are very shallow and thus particularly suitable for barely-accessible places. Code No. B 1175513 1175548 1175556 1554840 1554859 1554867 1175564 1175572 1175580 1.06/S100 1.06/S200 1.06/S250 1.06/S100S 1.06/S200S 1.06/S250S 1.06/S150 1.06/S220 1.06/S300 1.06/S1 1.06/S1 1.06/S1 1.06/S1 1.06/S1 1.06/S1 1.06/S2 1.06/S2 1.06/S2 1.06/S1A 1.06/S1A 1.06/S1A 1.06/S1A 1.06/S1A 1.06/S1A 1.06/S2A 1.06/S2A 1.06/S2A b c d e f 0 100 200 250 100 200 250 150 220 300 27 27 27 27 27 27 40 40 40 6 6 6 6 6 6 8 8 8 3,6 3,6 3,6 2,3 2,3 2,3 5,0 5,0 5,0 13 13 13 13 13 13 17 17 17 0.5 1.0 1.2 0.5 1.0 1.2 1.3 1.7 2.2 1.06 Fast clamping pulling hooks set of 2 pieces With the innovative high-speed clamps, fast and uncomplicated setting-up and readjustment is child's play. Code No. 1221213 1.06/A-E 1221221 1.06/B-E 1221248 1.06/C-E B 1.06/1-E 1.06/1A-E 1.06/2-E 1.06/2A-E 1.06/3-E 1.06/3A-E b c d e 0 100 150 200 22 30 36 12 18 28 3,0 3,5 6,5 0.6 1,6 3.5 319 Baldur_9_GB.mif Seite 320 Freitag, 18. Juli 2003 10:15 10 1.06 AS Puller set 2-arm pattern with 6 slim hooks With very slim forged hooks, thus particularly suitable for barely-accessible places. Code No. 8001710 1.06/AS Contents 2 each 0 1.06/S100 S200 S250 3.3 1.06 Puller set with display stand Code B No. 8111570 1.06/ST 8111650 1.06/ST1 1322745 1.06/ST-E 0 1.06/1 /1A /2 /2A /3 1.06/11 /1A1 /21 /2A1 /31 1.06/1-E /1A-E /2-E /2A-E /3-E 17.5 15.0 20.0 1.07 Universal puller 3-arm pattern For use as internal or external puller. The even load distribution on the three pulling hooks guarantees secure grip and central pulling. Hooks in special lengths available. Hooks 1.07/AV (clamping reach 200 mm) for 1.07/1 and 1.07/1A, and hooks 1.07/BV (clamping reach 300 mm) for 1.07/2 and 1.07/2A. Spindle may be exchanged for hydraulic pressure spindle (see table). Code No. 8113940 8114080 8114160 8114240 1541757 1.07/1 1.07/1A 1.07/2 1.07/2A 1.07/3 320 a1 a2 min a2 max b A 90 130 160 200 250 70 80 100 100 100 140 180 220 260 400 100 100 150 150 200 M 14x1,5 x 140 M 14x1,5 x 140 G 1/2 x 210 G 1/2 x 210 G 3/4 x 280 Hydraulic spindle $ c d e max. t 0 1.06/HSP1 1.06/HSP1 1.06/HSP2 17 17 22 22 27 22 22 30 30 36 12 12 18 18 28 3,0 3,0 3,5 3,5 6,5 3,0 3,0 5,0 5,0 7,5 1.4 1.6 3.6 4.0 9.0 Baldur_9_GB.mif Seite 321 Freitag, 18. Juli 2003 10:15 10 1.07/4 Universal puller 3-arm pattern Just like our standard model No. 1.06, this puller is designed for all branches of industry, but particularly for the construction of electric motors. It is also suitable for removing heavy, multistage pulley wheels, flywheels, gear wheels, etc. Pins are used to lock the arms at 120° to each other on the hub. The clamping reach may be extended to 490 mm by using extensions No. 1.07/CV, 1.07/DV and 1.07/EV. Spindle may be exchanged for hydraulic pressure spindle (see table). This puller may also be used with the hydraulic aid 1.50 without requiring any reduction bushing. Code No. 8002440 1.07/4 a1 a2 b A Hydraulic spindle $ c d e max. t 0 450 530 200 G 1 x 360 1.06/HSP3 36 36 28 6,5 10 19.0 1.07 Universal puller 3-arm pattern, with slim hooks The feet of the hooks are very slim and particularly suitable for barely-accessible places. a A $ Code No. 8116450 8116530 8116610 8116880 1.07/S1 90 100 M 14x1,5 x 140 1.07/S1A 130 100 M 14x1,5 x 140 1.07/S2 160 150 G 1/2 x 210 1.07/S2A 200 150 G 1/2 x 210 b 17 17 22 22 c d e 27 27 40 40 6 6 8 8 3,6 3,6 5,0 5,0 f max. t 0 13 13 17 17 2,5 2,5 5,0 5,0 1.3 1.4 3.6 4.0 1.07 Universal puller 3-arm pattern, with rigid hooks Design as universal puller No. 1.07/1 to 1.07/3, but with rigid pulling hooks. For greater ease in setting the clamping spread. The hooks clamp automatically when under tension. The hooks may be reversed to convert the puller from an external one to an internal one. Spindle may be exchanged for hydraulic pressure spindle (see table). Code No. 1305549 1306022 1306154 1306278 1554778 1.07/11 1.07/1A1 1.07/21 1.07/2A1 1.07/31 a1 a2 min a2 max b A 90 130 160 200 250 70 80 100 100 100 140 180 220 260 400 100 100 150 150 200 M 14x1,5 x 140 M 14x1,5 x 140 G 1/2 x 210 G 1/2 x 210 G 3/4 x 280 Hydraulic spindle $ c d e max. t 0 1.06/HSP1 1.06/HSP1 1.06/HSP2 17 17 22 22 27 22 22 30 30 36 15 15 24 24 28 4,0 4,0 3,5 3,5 6,5 3,0 3,0 5,0 5,0 7,5 1.3 1.5 3.0 3.2 9.0 321 Baldur_9_GB.mif Seite 322 Freitag, 18. Juli 2003 10:15 10 1.07 Fast clamping puller 3-arm pattern, with fast-clamp adjustment May be used as an internal or external puller. The even distribution of the loading over the three hooks results in secure grip and centered pulling action. With the innovative high-speed clamps, fast and uncomplicated setting-up and readjustment is child's play. Spindle may be exchanged for hydraulic pressure spindle (see table). Code No. 1222902 1225901 1227335 1227459 1554751 1.07/1-E 1.07/1A-E 1.07/2-E 1.07/2A-E 1.07/3-E a1 a2 min a2 max b A 90 130 160 200 250 70 80 100 100 100 140 180 220 260 400 100 100 150 150 200 M 14x1,5 x 140 M 14x1,5 x 140 G 1/2 x 210 G 1/2 x 210 G 3/4 x 280 Hydraulic spindle $ c d e max. t 0 1.06/HSP1 1.06/HSP1 1.06/HSP2 17 17 22 22 27 22 22 30 30 36 12 12 18 18 28 3,0 3,0 3,5 3,5 6,5 3,0 3,0 5,0 5,0 7,5 1.4 1.6 3.6 4.0 9.0 1.07 HSP Universal puller hydraulic, 3-arm pattern The tried and tested model for the removal of pulleys, wheels, ball bearings, etc. Drop forged pattern. By reversing the hooks, this tool may be used as an internal or external puller. With the hydraulic spindle, a controlled and safe pulling action is possible at all times. Code No. 8009960 8010970 1554816 8012400 1.07/2-HSP1 1.07/2A-HSP1 1.07/3-HSP2 1.07/4-HSP3 a1 a2 b Spindle c d 160 200 250 450 220 260 100 530 75 75 80 80 1.06/HSP1 1.06/HSP1 1.06/HSP2 1.06/HSP3 30 30 36 36 18 18 28 28 e max. t 3,5 3,5 6,5 6,5 0 5,0 4.4 5,0 4.8 7,5 9.3 10,0 19.4 1.07 HSP Fast clamping puller hydraulic, 3-arm pattern With the hydraulic spindle, a controlled and safe pulling action is possible at all times. With the innovative high-speed clamps, fast and uncomplicated setting-up and readjustment is child's play. Code No. 1221922 1.07/2-E-HSP1 1222554 1.07/2A-E-HSP1 1554824 1.07/3-E-HSP2 322 a2 b 160 220 200 260 250 400 a1 75 75 80 Spindle c d e max. t 0 1.06/HSP1 30 18 3,5 1.06/HSP1 30 18 3,5 1.06/HSP2 36 28 6,5 5,0 5,0 7,5 4.5 4.7 9.3 Baldur_9_GB.mif Seite 323 Freitag, 18. Juli 2003 10:15 10 1.07 Extension for pullers set of 3 pieces The one-piece drop forged extensions enable the clamping reach to be extended. The extensions may be used together with all hooks of the 1.07 range. Code B No. 1307576 1.07/V100 1307584 1.07/V150 1307592 1.07/V200 for 1.07/A and 1.07/100 for 1.07/B and 1.07/150 for 1.07/C and 1.07/200 b 0 100 150 200 0.4 1.6 2.6 1.07/A 1.07/A-E 1.07 Pulling hooks set of 3 pieces Code No. B 1307401 1307428 1307436 1307452 1307460 1307479 1307487 1307495 1307509 1307517 1307525 1.07/A 1.07/B 1.07/C 1.07/A-E 1.07/B-E 1.07/C-E 1.07/AV 1.07/BV 1.07/CV 1.07/DV 1.07/EV 1.07/1 1.07/2 1.07/3 1.07/1 1.07/2 1.07/3 1.07/1 1.07/2 1.07/3 1.07/3 1.07/3 1.07/1A 1.07/2A 1.07/4 1.07/1A 1.07/2A 1.07/4 1.07/1A 1.07/2A 1.07/4 1.07/4 1.07/4 b c d e 0 100 150 200 100 150 200 200 300 300 400 500 22 30 36 22 30 36 22 30 36 36 36 12 118 28 12 18 28 12 18 28 28 28 3,0 3,5 6,5 3,0 3,5 6,5 3,0 3,5 6,5 6,5 6,5 0.9 2.4 5.2 0.9 0.9 8.0 1.6 4.2 7.5 9.4 11.2 1.07/AV 1.07 Pulling hooks set of 3 pieces, rigid pattern for 3-arm pullers. Code No. 1307533 1.07/100 1307541 1.07/150 1307568 1.07/200 B 1.07/11 1.07/1A1 1.07/21 1.07/2A1 1.07/3 1.07/4 b c d e 0 100 150 200 22 30 36 15 24 32 3,0 3,5 5,0 0.6 1.6 3.7 1.07 Pulling hooks set of 3 pieces, slim pattern The feet of the hooks are very slim and thus particularly suitable for barely-accessible places. Code No. B 1307606 1307622 1307630 1554786 1554794 1554808 1307649 1307657 1307665 1.07/S100 1.07/S200 1.07/S250 1.07/S100S 1.07/S200S 1.07/S250S 1.07/S150 1.07/S220 1.07/S300 1.07/S1 1.07/S1 1.07/S1 1.07/S1 1.07/S1 1.07/S1 1.07/S2 1.07/S2 1.07/S2 1.07/S1A 1.07/S1A 1.07/S1A 1.07/S1A 1.07/S1A 1.07/S1A 1.07/S2A 1.07/S2A 1.07/S2A b c d e f 0 100 200 250 100 200 250 150 220 300 27 27 27 27 27 27 40 40 40 6 6 6 6 6 6 8 8 8 3,6 3,6 3,6 2,3 2,3 2,3 5,0 5,0 5,0 13 13 13 13 13 13 17 17 17 1.2 2.4 3.0 0.8 1.6 2.0 2.7 3.4 5.0 323 Baldur_9_GB.mif Seite 324 Freitag, 18. Juli 2003 10:15 10 1.07 AS Puller set 3-arm pattern with 9 slim hooks The feet of the hooks are very slim and thus particularly suitable for barely-accessible places. Code No. 8117260 1.07/AS Contents 3 each 0 1.07/S100 S200 S250 4.3 1.07/KSE Puller set Contents: case, spindle, 1 cross piece each 2-arm and 3-arm pattern and 3 puller hooks length 100 mm. Code 0 No. 1438484 1.07/K-1-SE 2.1 1.07 K Puller set with 9 hooks, in plastic case Contents: case, spindle, 1 cross piece each 2-arm and 3-arm pattern and 9 puller hooks in length 100, 200, 250 mm. Code No. 8117340 1.07/K amax b1 b2 120 100 200 A $ b3 250 M 14x1,5 x 140 c 17 27 d e 0 6 3,6 5.0 1.07 Puller set in plastic case With three quick-clamping hooks and hydraulic spindle. Suitable for internal and external pulling work, 2-arm or 3-arm, with powerful hydraulic spindle and quick-clamping hooks. The right puller for the job - and ready in a second. The best equipment for the professional for everyday heavy duty work. For industrial or car and truck repairs - set of two. Your price advantage: 1 spindle and 2 hooks saved. Hydraulic spindle HSP1 (max. 12 t force). Three quick-clamping hooks for internal and external use. Heavy duty cross pieces for 2-arm or 3-arm use. And everything stored safely in a handy case. Contents: case, spindle, 1 cross piece each 2-arm and 3-arm, 3 puller hooks. Code No. 1438492 1.07/K-2-E-HSP1 324 a1 a2 b 160 220 75 A $ 1.06/HSP1 30 c d e 0 18 3 5 2.1 Baldur_9_GB.mif Seite 325 Freitag, 18. Juli 2003 10:15 10 1.08 Universal puller 2-arm pattern, with fast spindle adjustment Twice as fast and twice as simple. With the fast spindle adjustment feature, the spindle can be set the desired range in a moment. When the clamping yoke is released, the 4-part internal thread closes, and takes the full working pressure. Code No. 8019090 1.08/1A 8000070 1.08/2A 8018950 1.08/3A a1 a2 min a2 max b A $ c d e max. t 0 130 200 350 80 110 130 180 260 420 100 150 200 M 14x1,5 x 140 G 1/2 x 210 G 3/4 x 280 17 22 27 22 30 36 12 18 28 3,0 3,5 6,5 3,0 5,0 7,5 1.4 3.8 10.2 1.10 Puller 2-arm pattern The reliable, heavy duty model for the removal of pulleys, wheels, ball bearings, etc. The double hook ends, wide or narrow, grip automatically. The wide hook ends of the puller 1.10/2 and 1.11/2 possess 8 mm slots, so that pulleys or gears may also be pulled off using 8 mm bolts. Code No. amax 8002600 1.10/1 8002790 1.10/2 b A $ c1 90 80 M 14x1,5 x 125 160 130 M 18x1,5 x 170 17 19 17 24 c2 d 10 7 20 13 e max. t 0 2 3 2 0.7 5 2.0 1.11 Puller 3-arm pattern The reliable, heavy-duty model for the removal of pulleys, wheels, ball bearings, etc. The double hook ends, wide or narrow, grip automatically. The wide hook ends of the puller 1.10/2 and 1.11/2 possess 8 mm slots, so that pulleys or gears may also be pulled off using 8 mm bolts. Code No. 8002950 1.11/1 8003090 1.11/2 amax b A $ 90 80 M 14x1,5 x 125 160 130 M 18x1,5 x 170 17 19 c1 c2 17 24 10 7 20 13 d e max. t 0 2 3 3,0 7,5 0.9 2.7 325 Baldur_9_GB.mif Seite 326 Freitag, 18. Juli 2003 10:15 10 1.12 Puller 2-arm pattern Handy robust model for the removal of pulleys, wheels, ball bearings, etc. Inexpensive economy model. The hook tips grip automatically. Code No. 8003250 8003330 8003410 8003680 1.12/0 1.12/1 1.12/2 1.12/3 amax 70 90 130 180 A $ b 80 M 12x1,5 x 110 120 M 14x1,5 x 155 160 M 18x1,5 x 200 200 G 1/2 x 250 14 17 19 22 c d e max. t 0 14 18 25 32 8 11 14 20 2,0 2,5 3,0 3,5 1 2 5 8 0.4 0.7 1.9 3.7 e max. t 0 1.13 Puller 3-arm pattern Handy robust model for the removal of pulleys, wheels, ball bearings, etc. Inexpensive economy model. The hook tips grip automatically. Code No. 8004140 8004220 8004300 8004490 1.13/0 1.13/1 1.13/2 1.13/3 amax A $ b 70 80 M 12x1,5 x 110 90 120 M 14x1,5 x 155 130 160 M 18x1,5 x 200 180 200 G 1/2 x 250 c 14 17 19 22 d 14 8 2,0 18 11 2,5 25 14 3,0 32 20 3,5 1,5 3,0 7,5 12,0 0.5 1.0 2.6 5.1 1.12 Battery-terminal puller 2-arm pattern The perfect tool for removing small parts such as battery terminals, pulleys, wheels, ball bearings, etc. The hook tips grip automatically. Code No. 8003760 1.12/01 8003840 1.12/02 326 amax b A c d e max. t / 60 60 60 40 M 10x1,5 x 80 M 10x1,5 x 60 10 10 5 5 2 2 0,5 0,5 160 120 Baldur_9_GB.mif Seite 327 Freitag, 18. Juli 2003 10:15 10 1.13 Battery-terminal puller 3-arm pattern The perfect tool for removing small parts such as battery terminals, pulleys, wheels, ball bearings, etc. The hook tips grip automatically. Code No. amax b A c d e max. t / 60 60 60 40 M 10x1,5 x 80 M 10x1,5 x 60 10 10 5 5 2 2 0,75 0,75 200 150 8004570 1.13/01 8004650 1.13/02 1.14 Puller 2-arm pattern The reliable, extra-strong model for the removal of pulleys, wheels, ball bearings, etc. With technical and economical benefits due to the variable clamping reach and automatic grip of the hooks. Especially suited to removing V-belt pulley wheels and flywheels mounted on longer shafts. Spindle may be exchanged for hydraulic pressure spindle (see table). Code No. 8004810 8005030 8005380 8005460 8005540 8005620 1.14/0 1.14/1 1.14/2 1.14/3 1.14/4 1.14/5 amax b A 90 130 200 250 280 420 100 140 210 260 390 480 M 12x1,5 x 110 M 14x1,5 x 140 M 18x1,5 x 200 G 1/2 x 250 G 1/2 x 250 G 1/2 x 350 Hydraulic spindle $ c d e max. t / 1.06/HSP1 1.06/HSP1 1.06/HSP1 14 17 19 24 24 24 14 18 25 32 32 32 9 11 16 18 20 20 2,0 2,0 3,0 3,5 3,5 3,5 1 2 5 8 8 8 500 800 2100 4300 5100 5800 1.14 HSP Puller hydraulic, 2-arm pattern The reliable, extra-strong model for the removal of pulleys, wheels, ball bearings, etc. With technical and economical benefits due to the variable clamping reach and automatic grip of the hooks. Especially suited to removing V-belt pulley wheels and flywheels mounted on longer shafts. With the hydraulic spindle, a controlled and safe pulling action is possible at all times. Code No. amax b 1392883 1.14/3-HSP1 1392913 1.14/4-HSP1 250 280 260 390 A $ 1.06/HSP1 1.06/HSP1 22 22 c 32 32 d e max. t 0 18 3,5 20 3,5 8 8 4.3 5.1 327 Baldur_9_GB.mif Seite 328 Freitag, 18. Juli 2003 10:15 10 1.15 Puller 3-arm pattern The reliable, extra-strong model for the removal of pulleys, wheels, ball bearings, etc. With technical and economical benefits due to the variable clamping reach and automatic grip of the hooks. Especially suited to removing V-belt pulley wheels and flywheels mounted on longer shafts. Spindle may be exchanged for hydraulic pressure spindle (see table). Code No. 8006000 8006190 8006350 8006430 8006510 8006780 1.15/0 1.15/1 1.15/2 1.15/3 1.15/4 1.15/5 amax b A 90 130 200 250 280 420 100 140 210 260 390 480 M 12x1,5 x 110 M 14x1,5 x 140 M 18x1,5 x 200 G 1/2 x 250 G 1/2 x 250 G 1/2 x 350 Hydraulic spindle $ c d e max. t / 1.06/HSP1 1.06/HSP1 1.06/HSP1 14 17 19 24 24 24 14 18 25 32 32 32 9 11 16 18 20 20 2,0 2,0 3,0 3,5 3,5 3,5 2 3 8 12 12 12 650 1100 2900 6100 7100 8200 1.15 HSP Puller hydraulic, 3-arm pattern The reliable, extra-strong model for the removal of pulleys, wheels, ball bearings, etc. With technical and economical benefits due to the variable clamping reach and automatic grip of the hooks. Especially suited to removing V-belt pulley wheels and flywheels mounted on longer shafts. With the hydraulic spindle, a controlled and safe pulling action is possible at all times. Code No. amax 1392956 1.15/3-HSP1 1392980 1.15/4-HSP1 b 250 260 280 390 A $ 1.06/HSP1 1.06/HSP1 22 22 c 32 32 d e max. t 18 3,5 20 3,5 12 12 0 6.1 7.1 1.14 L Fan puller 2-arm pattern The especially-slender hooks reach through the slots the collar of the fan. Due to their slender hooks and the three adjustment positions of its clamping reach, these pullers are also particularly suitable for the dismantling of gear arrangements. Hooks grip automatically. Code No. 8005110 1.14/1L 328 amax 150 b A $ 200 M 14x1,5 x 155 17 c d e max. t 0 10 6 2 0.9 2 Baldur_9_GB.mif Seite 329 Freitag, 18. Juli 2003 10:15 10 1.15 L Fan puller 3-arm pattern The especially-slender hooks reach through the slots the collar of the fan. Due to their slender hooks and the three adjustment positions of its clamping reach, these pullers are also particularly suitable for the dismantling of gear arrangements. Hooks grip automatically. Code No. 8006270 1.15/1L amax A $ b 150 200 M 14x1,5 x 155 17 c d e max. t 0 10 6 2 1.3 3 1.16 Puller 2-arm pattern Very strong type. Especially suitable for industrial purposes and for heavy agricultural and construction machines. Hooks grip automatically. Spindle may be exchanged for hydraulic pressure spindle (see table). Code No. 8007080 1.16/1 8007160 1.16/2 amax b A Hydraulic spindle $ c d e max. t 0 280 420 300 420 G 1 x 360 G 1 x 500 1.06/HSP3 1.06/HSP3 36 36 32 32 19 22 3 3 8 8 8.0 10 1.16 HSP Puller hydraulic, 2-arm pattern Very strong type. Especially suitable for industrial purposes and for heavy agricultural and construction machines. Hooks grip automatically. With the hydraulic spindle, a controlled and safe pulling action is possible at all times. Code No. 8012590 1.16/1-HSP3 8012670 1.16/2-HSP3 amax b A $ 280 190 1.06/HSP3 420 310 1.06/HSP3 c d 36 32 36 32 19 22 e max. t 3 3 0 8 9.3 8 11.3 329 Baldur_9_GB.mif Seite 330 Freitag, 18. Juli 2003 10:15 10 1.17 Puller 3-arm pattern Very strong type. Especially suitable for industrial purposes and for heavy agricultural and construction machines. Hooks grip automatically. Spindle may be exchanged for hydraulic pressure spindle (see table). Code No. 8007320 1.17/1 8007400 1.17/2 amax b A Hydraulic spindle $ c d e max. t 0 300 425 300 425 G 1 x 360 G 1 x 500 1.06/HSP3 1.06/HSP3 36 36 32 32 19 22 3 3 12 12 9.7 13.2 1.17 HSP Puller hydraulic, 3-arm pattern Very strong type. Especially suitable for industrial purposes and for heavy agricultural and construction machines. Hooks grip automatically. With the hydraulic spindle, a controlled and safe pulling action is possible at all times. Code No. amax b 8014290 1.17/1-HSP3 8014370 1.17/2-HSP3 300 425 190 315 A $ 1.06/HSP3 1.06/HSP3 36 36 c d 32 32 19 22 e max. t 3 3 0 12 11 12 14.5 1.18 Puller ECO 2-arm pattern The tried and tested range for economical bearing removal. Code No. 1464965 1.18/1 1464973 1.18/2 1464981 1.18/3 330 amax 110 160 200 b A $ 110 M 14x1,5 x 163 140 M 18x1,5 x 215 200 G 1/2 x 282 c d e max. t 17 17 18 5,0 19 21 20 6,5 22 22 22 7,5 2 3 5 0 1.0 1.9 2.3 Baldur_9_GB.mif Seite 331 Freitag, 18. Juli 2003 10:15 10 1.19 Puller ECO 3-arm pattern The tried and tested range for economical bearing removal. Code No. 1465007 1.19/1 1465015 1.19/2 1465023 1.19/3 amax 110 160 200 b A $ 110 M 14x1,5 x 163 140 M 18x1,5 x 215 200 G 1/2 x 282 c d e max. t 17 17 18 5,0 19 21 20 6,5 22 22 22 7,5 2 3 5 0 1.3 2.5 4.0 1.20 Puller with clamping yoke These pullers are mainly employed for removing car and truck steering arms. The clamping yoke presses the hooks firmly behind the part to be removed and prevents the puller from slipping out of position. Code No. 8008050 1.20/1 8008130 1.20/2 8008210 1.20/3 amax b A $ 90 85 M 18x1,5 x 130 90 100 M 18x1,5 x 130 150 140 G 1/2 x 175 c d 19 22 19 24 22 30 12 15 18 e max. t 3,0 3,0 3,5 5,0 5,0 7,5 0 1.2 1.8 3.3 1.22 Puller with clamping yoke Due to its double-ended hooks, this tool is particularly suitable for separating and removing flush-seated parts, such as axle bearings, pinions, etc. Especially economical, this is a multi-functional tool to cover a range of sizes. Code No. 8009020 1.22/1 8009100 1.22/2 8009290 1.22/3 amax 110 160 160 b A $ 170 M 18x1,5 x 200 260 G 1/2 x 350 325 G 1/2 x 350 19 22 22 c 25 25 25 d e max. t 14 3,5 14 3,5 14 3,5 5,0 7,5 7,5 0 2.1 4.1 4.5 331 Baldur_9_GB.mif Seite 332 Freitag, 18. Juli 2003 10:15 10 1.23 Puller with slim hooks For removing bearings in confined spaces. The scissor-pattern hook design means that the hooks are pressed firmly onto the part during the removal procedure. Code No. 8084580 8084310 8084660 8084740 1.23/1S 1.23/1 1.23/2 1.23/3 amax A $ b 80 85 M 10 x 105 80 85 M 10 x 105 120 120 M 14x1,5 x 130 120 150 M 14x1,5 x 205 12 12 17 17 c d 11 23 31 31 4,5 4,5 5,0 5,0 e max. t 2,5 2,5 3,5 3,5 1,5 2,0 3,5 3,5 0 0.4 0.4 0.8 1.0 1.26 Nut splitter For splitting jammed or stripped nuts without damaging the bolt thread. Suitable for nuts up to property class 6. Code No. 8009880 1.26/1 8009610 1.26/2 8010030 1.26/3 for nuts up to A $ 0 SW 17, M 10 SW 24, M 16 SW 36, M 24 M 14x1,5 x 37 M 14x1,5 x 37 M 22x1,5 x 70 17 17 24 0.2 0.3 1.0 1.26/12 Nut splitter set In plastic wallet. Code No. 8010110 1.26/12 Contents 1 each 0 1.26/1 1.26/2 0.5 1.26 HYD Nut splitter hydraulic With strong chisel, additionally induction hardened at the cutting edge for breakage resistance. The chamfer at the chisel's edge improves the splitting effect and prevents breakage. With smooth chisel function. Channel walls rolled, thus mirror-smooth and wear resistant. No force necessary when turning back the chisel. For nuts up to property class 10. Code No. 8009450 1.26/1 HYD 8009530 1.26/2 HYD for nuts up to max. t 0 5 13 0.7 3.8 SW 7 - SW 22, M 4 - M 14 SW 22 - SW 36, M 14 - M 24 1.28 Stud extractor For inserting and removing studs. These tools will reliably grip even extremely short stud ends. Slim pattern. Code No. 8010620 1.28/1 8010700 1.28/2 8010890 1.28/3 u-Stud $ / 6-13 8-19 19-25 19 19 19 230 300 390 1.28/4 Stud extractor For inserting and removing studs. These tools will reliably grip even extremely short stud ends. Code No. 1465031 1.28/4 332 u-Stud $ / 5-26 19 390 Baldur_9_GB.mif Seite 333 Freitag, 18. Juli 2003 10:15 10 1.29 Ball bearing extractor These special extractors have been developed for removing ball bearings that are both on a shaft and in a housing. These hooks selected using the table are inserted into the ball race, evenly distributed in the outer ring according to the number of balls. The support rings supplied for the ball bearings to be removed are placed on the bearings’ inner races. The bridge with spindle is then placed on the centering depression of the shaft and the spindle put under tension with the hooks. Code No. 8011000 8011190 8011270 8011350 8011430 1.29/1 1.29/2 1.29/3 1.29/4 1.29/5 A $ / M 10 x 160 M 12 x 195 M 14 x 210 M 18 x 230 M 20 x 235 14 14 17 19 22 150 280 420 750 1100 Tool inventory at the professional fire brigade in Bochum. 1.29 Pulling hooks set of 4 pieces * Support rings are used for pulling these bearings. y for bridge - for ball bearing No. / 8011510 1.29/10 8011780 1.29/15 8011860 1.29/20 145 145 177 1.29/1 - 6000 6001 6002 1.29/1 - 6003 6004 6005 6200 6201 6202 80 100 200 8011940 1.29/25 177 8012080 1.29/30 185 8012160 1.29/35 8012240 1.29/40 187 235 8110250 1.29/45 236 Code No. 1.29/2 - 6006 6203 1.29/2 - 6007 6008 6009 6010 6204 6205 6300 6301 6302 1.29/2 - 6303 6304 1.29/3 - 6011 6012 1.29/3 - 6206 6207 6208 6305 1.29/4 - 6209 6210 1.29/4 - 6211 6212 6308* 6404 6405 1.29/5 - 6309* 6310* 6311* 6406* 200 300 400 600 800 1.29 K Ball bearing extractor set In sheet metal case, dimensions: 285 x 190 x 75 mm. Code No. 8110330 1.29/1K 8012320 1.29/3K Contents 3 hubs with spindle 1.29/1 - 1.29/3 6 sets hooks 1.29/10 - 1.29/35 1 plug-in handle 1.29/0 5 hubs with spindle 1.29/1 - 1.29/5 6 sets hooks 1.29/10 - 1.29/45 1 plug-in handle 1.29/0 and 4 support rings 0 4.7 8.0 333 Baldur_9_GB.mif Seite 334 Freitag, 18. Juli 2003 10:15 10 1.92 Ball bearing extractor PLUS Using the new BALDUR ball bearing extractor, the removal of shaft-mounted ball bearings in a housing is now possible without any problems. Due to its great degree of functionality combined with the simplified handling, this novel design makes a PLUS in effectiveness and productivity possible. This tool is distinguished by its extreme user-friendliness. The hooks are fixed in the slot. The self-locking arrangement means that the force applied is 100% utilised. Secure at all times against slipping off - and a straight pulling force for precise working. Suitable for more than 40 standard ball bearings up to 6311. * with supporting ring 6309 ** with supporting ring 6310 *** with supporting ring 6311 Code No. 1553534 1.92/1 1553542 1.92/2 1553550 1.92/12 334 Bearing Hook Head size 6000 6001 6002 6003 6200 6201 6202 6203 6004 6005 6006 6300 6301 6302 6007 6008 6204 6009 6010 6205 6303 6304 6011 6012 6206 6207 6305 6403 6306 6307 6208 6209 6210 6211 6407* 6404 6405 6406 6308 6309 6212 6310** 6311*** Contents of set 1.92/1 and 1.92/2 10 10 10 10 10 20 20 20 20 20 20 30 30 30 40 40 40 40 40 40 40 40 50 50 50 50 50 60 60 60 60 60 60 60 60 70 70 70 70 70 70 70 70 1-7 1-4 1-3 1-4 1-4 1-7 1-4 1-4 1-3 1-3 1-3 1-3 1-3 1-7 1-3 1-3 1-4 1-3 1-3 1-3 1-7 1-7 2-3 2-3 2-3 2-3 2-7 2-3 2-4 2-4 2-3 2-3 2-3 2-3 2-3 2-7 2-7 2-7 2-4 2-4 2-3 2-4 2-4 Baldur_9_GB.mif Seite 335 Freitag, 18. Juli 2003 10:15 10 1.30 Internal extractor For extremely-tightly-packed ball bearings, bearing races, bushings, and oil seals®. Operation: The internal extractor is inserted into the bearing and the spindle screwed in. The sharp turned-out shoulders of the pulling shell jaws will press outwards behind the part to be extracted. The counter-support brace is then added. Both feet must be aligned parallel to the spindle to ensure rigidity. Code No. p 8012750 8012830 8012910 8013130 8013480 8013560 8013640 8013720 8013800 8013990 8014020 1.30/0 1.30/1 1.30/2 1.30/3 1.30/4 1.30/4A 1.30/5 1.30/6 1.30/7 1.30/8 1.30/9 M 10 M 10 M 10 M 10 M 10 M 10 M 10 M 14x1,5 M 14x1,5 M 14x1,5 M 14x1,5 C $ / 5-8 8-12 12-15 15-19 19-25 25-30 30-35 35-45 45-55 55-70 70-100 10 10 10 14 14 14 14 17 17 19 27 150 160 170 170 200 300 350 650 800 1400 2900 1.30/0-9 1.30/2N 1.30 N Internal extractor with reinforced shoulder Especially suitable for the safe and trouble-free extraction of needle roller bearings, ball bearings and brass sleeves from crankshafts. Note: The soulder of the shell jaw must be applied behind the bearing. Code No. 8013050 1.30/2N 8013210 1.30/3N p C $ / M 10 M 10 12-14 14-19 10 14 170 170 1.30/10 Internal extractor Suitable for removing large ball bearings and bearing outer races. Operation: The extraction jaws are spread by turning the nut. The newly-developed spreading system enables a simple, step-free and time-saving adjustment to the desired diameter to be made. The sharp-edged sections of the extraction jaws seat flush beneath when spread. Code No. 8014100 1.30/10 p G 1/2" C $ / 60-160 36 2450 1.35/2 1.35 Impact bearing puller Suited for the removal of small ball bearings since there is often not enough room for support braces. Code No. 8016070 1.35/1 8039010 1.35/2 for internal extractor with adaptor p 1.30/1 - 1.30/2 1.30/0 - 1.30/7 M 10 M 10 M 14 x 1,5 $ / 1.35/1 17 550 24 3200 335 Baldur_9_GB.mif Seite 336 Freitag, 18. Juli 2003 10:15 10 1.36 Support brace For internal extractors Nos. 1.30/0 – 1.30/9. Operation: The support brace is placed on the housing and the spindle screwed onto the spindle of the internal extractor. The toggle is held firmly, and the bearing extracted by tightening the nut. Code 1.36/1-3 No. 8016580 1.36/1 8016660 1.36/2 8016740 1.36/3 for internal extractor p 1.30/1 - 1.30/5 1.30/6 - 1.30/8 1.30/9 M 10 M 14x1,5 M 14x1,5 $ / 27 32 32 600 1400 3000 1.36/4 Support brace For internal extractor No. 1.30/10. Operation see No. 1.36 1.36/4 Code No. 8016820 1.36/4 for internal extractor p 1.30/10 G 1/2" $ / 36 7700 1.31 Internal extractor set The handy sheet metal case contains the most used extractor sizes for the removal of ball bearings, bearing races, bushings, oil seals®, etc. Code No. 8014450 1.31/0N 8014530 1.31/0 8014610 1.31/1 8014880 1.31/2 0 Contents 4 internal extractors 12-30 mm 1 support brace 1.36/1 4 internal extractors 12-30 mm 1 support brace 1.36/1 6 internal extractors 12-46 mm 2 support braces 1.36/1 - 2 8 internal extractors 12-70 mm 2 support braces 1.36/1 - 2 1.30/2 -3 -4 -4A 2.4 1.30/2N -3N -4 -4A 2.4 1.30/2 - 6 1.30/2 - 8 5.9 10.0 1.32/1 1.32 Set of internal and external extractors In a handy sheet metal case. Sets comprise internal extractors, support braces, pulling chucks, external extractors and stud extractors. Code No. 8015260 1.32/1 8015340 1.32/2 1.32/2 336 Contents 6 internal extractors 12-46 mm 1.30/2 - 6 2 support braces 1.36/1 - 2 1 pulling chuck 1.44 1 battery-terminal puller 1.12/02 1 puller, 2-arm pattern 1.06/1 8 internal extractors 12-70 mm 1.30/2 - 8 2 support braces 1.36/1 - 2 1 pulling chuck 1.44 1 battery-terminal puller 1.12/02 2 pullers, 2-arm pattern 1.06/1 - 2 1 stud extractor 1.28/1 0 10.0 19.0 Baldur_9_GB.mif Seite 337 Freitag, 18. Juli 2003 10:15 10 1.37 Cylinder liner puller complete with support brace Wet heavy-vehicle (e.g. Daimler Benz, MAN) cylinder liners, automobile and stationary-engine liners, and other parts may be extracted using this puller. Operation: The spindle of the support brace is screwed into the clamping nut of the puller, and the puller inserted into the liner. The support brace is placed on to the cylinder block. Due to the newly-developed spreading system, when the spindle is turned, all three jaws spread quickly and without difficulty, until they are firmly seated beneath the edge of the liner. Then the nut of the support brace is tightened. Code No. 8017200 1.37/2 p G 1/2" C $ / 60-160 36 6800 1.38 Separator puller These separator pullers are used together with the bearing separators No. 1.40. The tension bolts are screwed into the threaded holes in the bearing separators. Code No. for separator 8017550 8017630 8017710 8017980 8018010 8018280 1.38/0 1.38/1 1.38/2 1.38/3 1.38/4 1.38/5 1.40/0 1.40/1 1.40/2 1.40/3 1.40/4 1.40/5 a b A $ p / p top 40-120 60-165 70-215 90-300 125-380 140-440 160 230 250 270 350 400 M 14 x 120 M 18 x 170 G 1/2 x 210 G 3/4 x 280 G 1 x 310 G 1 x 360 17 19 22 27 36 36 M 10 / M 12x1,5 M 10 / M 14x1,5 M 14x1,5 / M 16x1,5 M 18x1,5 / M 20x1,5 M 22x1,5 / M 24x1,5 M 24x1,5 / M 26x1,5 Hydraulic spindle 0 1.06/HSP1 1.06/HSP2 1.06/HSP3 1.06/HSP3 1.0 2.4 3.8 7.2 11.3 16.3 1.38 V Extension rod For separator puller No. 1.38. Code No. for separator p 8018440 8018520 8018600 8018790 8018870 1.38/AV 1.38/CV 1.38/DV 1.38/EV 1.38/FV 1.38/0 1.38/1 1.38/2 1.38/3 1.38/4 1.38/5 M 10 M 14 x 1,5 M 18 x 1,5 M 22 x 1,5 M 24 x 1,5 y 0 100 100 100 200 200 0.2 0.5 0.6 2.1 2.7 337 Baldur_9_GB.mif Seite 338 Freitag, 18. Juli 2003 10:15 10 1.38 HSP Separator puller hydraulic, for separating blades These pullers are used together with the separating blades No. 1.40. The tension bolts are screwed into the threaded bores of the separating blades. Code No. for separator 8014960 8015180 8015420 8015500 1.38/2-HSP1 1.38/3-HSP2 1.38/4-HSP3 1.38/5-HSP3 1.40/2 1.40/3 1.40/4 1.40/5 a b p 0 70-215 90-300 125-380 140-440 175 195 240 290 M 14 x 1,5 M 18 x 1,5 M 22 x 1,5 M 24 x 1,5 4.0 6.8 11.8 16.6 1.40 Bearing separator For removing taper roller and ball bearings, inner bearing races, and other tightly-seated or thin-walled parts. Operation: To remove tightly-seated parts, the sharp edges of the separator blades are pressed behind the part and it is then withdrawn using the correct puller No. 1.38. To avoid damage to delicate parts, the flat surfaces of the separator blades are used. This produces a large support surface that prevents deformation. Code No. for puller p 8019680 8019760 8019840 8019920 8020180 8020260 1.40/0 1.40/1 1.40/2 1.40/3 1.40/4 1.40/5 1.38/0 1.38/1 1.38/2 1.38/3 1.38/4 1.38/5 M 10 M 10 M 14 x 1,5 M 18 x 1,5 M 22 x 1,5 M 24 x 1,5 O 0 5-60 12-75 22-115 30-155 30-200 30-250 0.4 1.0 2.3 4.4 8.9 15.3 1.41 Separator and puller set Set in sheet metal case, comprising separator, puller, and extension rods. Dimensions: 420 x 320 x 80 mm. Code No. Contents 8109750 8109830 8109910 8110090 8110170 1.41/0 1.41/1 1.41/2 1.41/3 1.41/4 1.38/0 1.38/1 1.38/2 1.38/3 1.38/4 0 1.38/AV 1.38/AV 1.38/CV 1.38/DV 1.38/EV 1.40/0 1.40/1 1.40/2 1.40/3 1.40/4 2.8 4.1 9.1 16.1 28.6 1.40/15 Drive shaft bearing puller Operation: The separator blades are placed evenly behind the bearing and the pulling arms aligned parallel to the axle and spindle. Code No. 8010380 1.40/15 1.40/16A Aperture y A $ 0 45-75 750 G 1/2 x 160 22 11.8 1.40/16 Set of hooks 2 pieces These hooks, together with the crossbeam and separator blades of No. 1.40/15, are used for mounting drive-shaft bearings. Operation: The separator blades are placed with the flat side behind the bearing, and the hooks inserted behind the clamping bolt of the separator blades. When the spindle is tightened, the bearing is pulled against the axle flange. 1.40/15 1.40/16 Code No. 8010460 1.40/16 8010540 1.40/16A 338 Description 0 1 pair hooks as illustrated Crossbeam with spindle 1.4 2.2 Baldur_9_GB.mif Seite 339 Freitag, 18. Juli 2003 10:15 10 1.44 Pulling chuck For removing the inner races of dynamos, magnetos, motors, and other machine parts. Simple operation by tightening the cap nut. Code No. 8022040 1.44/1 Clamping range mm Clamping reach mm 0 5-32 125 1.4 Forging of the heavy-duty puller crossbeams in the BALDUR works in Remscheid. 1.50 Hydraulic pump and cylinder set This hydraulic set, consisting of hand pump 1.50/1 and hydraulic cylinder 1.51, is suitable for pressing, straightening, lifting, bending, and pulling. Code No. 8110410 1.50/10 8110680 1.50/11 0 consisting of: Hydraulic hand pump 1.50/1 Hydraulic cylinder 1.51/10 Hydraulic hand pump 1.50/1 Hydraulic cylinder 1.51/11 11.0 13.0 1.50/1 Hydraulic hand pump Supplied complete with 1.50 m high-pressure hose, to fit hydraulic cylinder 1.51. Code No. 8022710 1.50/1 for hydraulic cylinder 0 1.51/10 1.51/11 7.0 1.51 Hydraulic cylinder Code No. 8023440 1.51/10 8110760 1.51/11 Stroke height mm 140 200 max. t 0 10 10 4.0 6.0 339 Baldur_9_GB.mif Seite 340 Freitag, 18. Juli 2003 10:15 10 1.06 Puller for hydraulic implement 1.50 For the fast and damage-free removal of pulleys, wheels, ball bearings, etc. Robust pattern, designed for rigidity and heavy duty use. By reversing the hooks, this tool may be used as an internal or external puller. The reach may be increased both by using pulling hooks in special lengths, and by using extensions. Code No. 8112620 1.06/40 8113000 1.06/50 a1 a2 min a2 max b c 520 640 185 230 600 715 200 225 36 50 d e 28 6,5 33 10,0 max. t 0 10 11.0 18 24.0 1.15 H Puller for hydraulic implement 1.50 Heavy duty pattern for the removal of gear wheels, spoked wheels, pulleys, etc. The hook tips grip automatically. The hooks may be moved to use this tool as a 2-arm puller. The adjustable reach means that this puller is very versatile. Code No. 8006860 1.15/30 8109590 1.15/40 amax b c d e max. t 0 250 280 260 390 32 32 18 20 3,5 3,5 12 12 9.0 9.5 1.17 H Puller for hydraulic implement 1.50 Heavy duty pattern for the removal of gear wheels, spoked wheels, pulleys, etc. The hook tips grip automatically. Code No. 8007590 1.17/10 8109670 1.17/20 340 amax b c d e max. t 0 300 425 300 425 36 36 19 22 3,5 3,5 12 12 11.4 12.3 Baldur_9_GB.mif Seite 341 Freitag, 18. Juli 2003 10:15 10 1.55 Hydraulic press This piece of auxiliary equipment considerably increases the capability of the standard pressure spindle. Operation: With pressure released, the press is placed between the pressure spindle and the end of the shaft. The pressure spindle is then tightened firmly. Care must be taken that the centreline of the shaft, the hydraulic press, and the pressure spindle are exactly in alignment. Then the hydraulic spindle is screwed inwards. Important note: Release the hydraulic press after use. Code No. Stroke height mm Installed height mm 8024090 1.55/1 8024170 1.55/2 10 15 75 90 max. t 0 8 15 0.7 1.3 1.60/3 1.60 Wheel-hub puller For cars and trucks with wheel stud circles up to 225 mm. Easy to use. With wheel stud protection using rotating nut apertures that always lie flat to the hub. Spindle may be exchanged for hydraulic pressure spindle (see table). Code No. No. of hooks A Hydraulic spindle 0 8024840 8110840 8024920 8110920 1.60/3 1.60/5 1.60/4 1.60/H 3 4 5 1 G 3/4 x 200 G 3/4 x 200 G 3/4 x 200 spare hook 1.06/HSP2 1.06/HSP2 1.06/HSP2 4.0 4.5 5.0 0.5 1.60/H 1.60 HSP Wheel-hub puller hydraulic For cars and trucks with wheel stud circles up to 225 mm. Easy to use. With wheel stud protection using rotating nut apertures that always lie flat to the hub. Code No. 8015690 1.60/3-HSP2 8015770 1.60/4-HSP2 8015850 1.60/5-HSP2 No. of hooks A 0 3 4 5 1.06/HSP2 1.06/HSP2 1.06/HSP2 4.6 5.1 5.6 1.60/5-HSP2 1.61 Wheel-hub puller For cars and trucks with wheel stud circles up to 250 mm. Simple use. Just place the plate with the spindle on the centremarking of the axle and fold back the hooks onto the plate. With swivelling nut holders always lying flat on the hub to prevent wheel-stud damage. Spindle may be exchanged for hydraulic pressure spindle (see table). Code No. No. of hooks A Hydraulic spindle 0 8111060 8111140 8025300 8111220 1.61/3 1.61/4 1.61/5 1.61/H 3 4 5 1 G 3/4 x 200 G 3/4 x 200 G 3/4 x 200 spare hook 1.06/HSP2 1.06/HSP2 1.06/HSP2 5.0 5.6 6.2 0.6 1.61/5 341 Baldur_9_GB.mif Seite 342 Freitag, 18. Juli 2003 10:15 10 1.61 HSP Wheel-hub puller hydraulic For cars and trucks with wheel stud circles up to 250 mm. Easy to use. With wheel stud protection using rotating nut apertures that always lie flat to the hub. Code No. 8015930 1.61/3-HSP2 8016150 1.61/4-HSP2 8016230 1.61/5-HSP2 No. of hooks Hydraulic spindle 0 3 4 5 1.06/HSP2 1.06/HSP2 1.06/HSP2 5.6 6.2 6.8 1.62 Wheel-hub puller For trucks with wheel stud circles up to 350 mm. Easy to use. With wheel stud protection using rotating nut apertures that always lie flat to the hub. This tool may also be used with the hydraulic aid without requiring a reduction bushing. Code No. 8026030 1.62/8 8111220 1.61/H No. of hooks A Hydraulic spindle 8 1 G 1 x 310 spare hook 1.06/HSP3 0 10.5 0.6 1.62 HSP Wheel-hub puller 1.62/8 hydraulic For trucks with wheel stud circles up to 350 mm. Easy to use. With wheel stud protection using rotating nut apertures that always lie flat to the hub. Code No. 8016310 1.62/8-HSP3 No. of hooks A 8 1.06/HSP3 0 11.9 1.64 Drive shaft puller Suitable for drive shafts with 4 or 5 apertures. For wheel stud circles 100-180 mm. Operation: The puller is attached to the drive shaft flange using the nuts of the wheel bolts. By striking the spindle head with the sliding hammer, the shaft may be removed easily and without damage. Code No. 8026700 1.64/1 p 0 max. M14 3.8 1.65 Pulling flange The flange possesses slots for hole pitches of 180, 120, and 90 degrees. Additional holes may be drilled to render the flange suitable for other pitches and aperture diameters. A very sturdy model for heavy parts and the highest requirements. Spindle may be exchanged for hydraulic pressure spindle (see table). Code No. 8027000 1.65/1 342 Stud , up to 16 A Hydraulic spindle 0 G 1 x 270 1.06/HSP3 16.3 Baldur_9_GB.mif Seite 343 Freitag, 18. Juli 2003 10:15 10 1.66 Pulling flange For wheels and discs with tapped holes up to M10. The flange is fitted with slots for hole pitches of 180 and 120 degrees, and using one pair each of long and short hooks and a protective cap for the thread of the steering column, this tool is suitable as a steering wheel puller. Code No. Stud , A $ 0 8027510 1.66/1 up to 10 with hooks in length 85 + 135 mm, 8027780 1.66/11 1 pair each M 12 x 110 14 0.7 M 12 x 110 14 1.0 1.67 Steering-wheel puller Steering-wheel puller for cars. The puller includes one pair of short hooks, one pair of long hooks, and a protective cap for the thread of the steering column. Code No. 8028240 1.67/1 A $ Clamping reach Hook length up to 35-90 135 M 14x1,5 x 150 17 0 0.6 1.68 Steering-wheel puller Steering-wheel puller featuring one pulling ring each with 100 mm and 150 mm diameter for 3-spoke and 4-spoke steering wheels. To protect the steering-wheels, the pulling rings are fitted with sliding rubber sleeves. Code No. 8028750 1.68/1 A $ 0 M 18 x 170 19 2.0 Hook length mm 120 1.70 Dismantling and assembly fork The wedge-shaped fork end makes the fast removal of track rod and push rod ends, steering arms, and other steering parts possible. Also suitable for removing shock absorbers and other separating and dismantling work. The forks are suitable for use in the most confined spaces. Hammer blows on the handle ends are used to separate the parts. Code No. A mm B mm C mm 0 8029210 8029480 8029560 8029640 8085040 1.70/1 1.70/2 1.70/3 1.70/4 1.70/5 18 23 29 40 45 340 340 350 350 355 80 80 90 90 95 0.8 0.8 1.0 1.1 1.2 343 Baldur_9_GB.mif Seite 344 Freitag, 18. Juli 2003 10:15 10 1.72 Ball joint puller For the simple and damage-free removal of ball pins on track rods and push rods. Code No. a b c A $ 0 8030300 8030490 8030570 8030650 1.72/1 1.72/2 1.72/3 1.72/4 18 23 27 37 35 45 56 78 40 50 60 75 M 14x1,5 x 50 M 14x1,5 x 50 M 18x1,5 x 80 G 1/2 x 110 17 17 19 22 0.3 0.5 0.7 1.5 1.73 Universal ball joint puller For removing ball joints on cars and trucks. Code O Clamping height No. 8030810 1.73/1 8033240 1.73/3 23 32 65 85 Fork depth 0 24 28 0.7 2.4 1.74 Universal ball joint puller For removing the ball joint journals on track rods, stabilizers, etc. Simple operation due to slender lower part and two-stage lever position. Code No. 8085200 1.74/1 8085390 1.74/2 O Clamping height Fork depth 0 20 20 12-50 50-80 35 35 1.0 1.4 1.75 Oil filter hook 3-arm pattern For removing firmly seated oil filters. Code No. 8117420 1.75/1 O Drive 0 60-120 without adaptor G 3/8, with adaptor 17 mm external, G 1/2 internal 0.6 1.76 Cartridge spanner 3-arm pattern For removing firmly seated granulate cartridges. Code No. 1523651 1.76/1 344 O Drive 0 80-150 1/2" 0.6 Baldur_9_GB.mif Seite 345 Freitag, 18. Juli 2003 10:15 10 d 1.78 S Safety coil spring compressor Safety coil spring compressor for the safe installation and removal of coil springs with a diameter of 110–180 mm. The spindles (M18) have 13 mm hexagon drive nut, so that when compressing the springs, they turn downwards, thus preventing damage to bodywork above the springs. Safety note: When the spindles are tightened evenly, the clamping heads grip the coils tightly, rendering sideways slip impossible. VPA-GS-tested safety. Code No. 8031110 1.78/S1 8031380 1.78/S2 8031460 1.78/S3 Clamping reach mm 0 180 280 380 2.2 2.5 2.8 d 1.78/P1 1.78 P Universal coil spring compressor A coil spring compressor for MacPherson suspension strut and transverse link axles with spring diameters of 110-180 mm. Shock absorbers may be replaced without removing the suspension struts. The safety holder renders slipping impossible. VPA-GS-tested safety. The hooks are drop forged. The wide support rests are matched to the coil spring pitch. Code No. 8111300 1.78/P1 8031030 1.78/PK1 Clamping reach mm 240 240 max. t 0 3,5 3,5 3.5 3.5 1.78/PK1 1.79 Spring spreader This has been especially designed for VAG exhaust installations, where the pipe is not held by bolts to the exhaust manifold, but clamped on using springs. Code No. 8112540 1.79/1 0 0.4 345 Baldur_9_GB.mif Seite 346 Freitag, 18. Juli 2003 10:15 10 1.80/1 Spindle pressure pads for axle bores (hollow shafts) The BALDUR pressure pads are used for the removal of such parts as bearings and gear wheels that are mounted on hollow shafts or in housings. Here, the spindle pressure pad serves as a counter-axis to the BALDUR puller, where the spindle now transfers the force to the pressure pad. Code No. 1120697 1.80/1 Plate , Holder , 0 25 28 32 35 41 44 48 50 54 60 64 19 22 25 28 32 35 38 41 44 48 50 2.2 1.80/2 Spindle pressure pads for axle bores (hollow shafts) See No. 1.80/1 for description. Code No. 1120700 1.80/2 Plate , Holder , 0 67 70 73 78 83 90 54 57 60 64 70 76 2.3 1.80/3 Spindle pressure pads for axle bores (hollow shafts) See No. 1.80/1 for description. Code No. 1120719 1.80/3 Plate , Holder , 0 41 44 48 50 54 60 64 67 70 73 78 83 90 32 35 38 41 44 48 50 54 57 60 64 70 76 4.2 1.81/1 Threaded inserts The BALDUR threaded inserts make the removal of threaded caps, for example, possible, when these possess one threaded hole. For slide hammers 1.35/1, 1.35/2, threaded support 1.36/1. Code No. 1120727 1.81/1 Connecting / Insert thread / M 10 - M 4 M 10 - M 5 M 10 - M 6 M 10 - M 8 M 10 - M 10 M 10 - M 12 200 1.81/2 Threaded inserts See No. 1.81/1 for description. For slide hammers 1.35/2, 1.36/2, threaded support 1.36/3. Code No. 1120743 1.81/2 346 Connecting / Insert thread / M 14x1,5 - M 8 M 14x1,5 - M 10 M 14x1,5 - M 12 M 14x1,5 - M 14 M 14x1,5 - M 16 M 14x1,5 - M 18 470 Baldur_9_GB.mif Seite 347 Freitag, 18. Juli 2003 10:15 10 1.81/10 Threaded inserts for 1-hole and 2-hole uses, 2 each The BALDUR threaded inserts make the removal of threaded caps, for example, possible, when these possess one or two threaded holes. For separator puller 1.38/0, 1.38/1. Code No. 1120735 1.81/10 Connecting / Insert thread / M 10 - M 4 M 10 - M 5 M 10 - M 6 M 10 - M 8 M 10 - M 10 M 10 - M 12 Adaptor 460 1.81/20 Threaded inserts for 1-hole and 2-hole uses, 2 each See No. 1.81/10 for description. For separator puller 1.38/2. Code No. 1120751 1.81/20 Connecting / Insert thread M 14x1,5 - M 8 M 14x1,5 - M 10 M 14x1,5 - M 12 M 14x1,5 - M 14 M 14x1,5 - M 16 M 14x1,5 - M 18 Adaptor / 1010 Adaptor Threaded insert 1.85/1 Professional plastic bearing installation set This sturdy plastic bearing installation set combines the advantages of the usual models in metal with the advantages of plastic. The impact-resistant plastic is handily light, but just as robust as the metal variants. Using this bearing installation set, which consists of 33 impact rings, more than 200 types of bearings may be re-installed effortlessly and without damage. The set is completed with three aluminium impact sleeves and a recoil-free bodywork hammer with nylon heads, all in a strong plastic case. This set guarantees that the installed bearings will suffer no damage that might have happened when working "metal to metal". No deformations of the bearing housings, sealing rings, or shafts. Code No. 1120778 1.85/1 Contents 0 Impact rings 10-50 mm, for external Ø 26-110 mm, hammer 1,2 kg, case dimensions 450 x 360 x 140 mm 4.6 1.91 Tyre removing tool For breaking the adhesion between truck tyres and wheel rims. Code No. 8032270 1.91 y 0 300 1.8 347 Baldur_9_GB.mif Seite 348 Freitag, 18. Juli 2003 10:15 10 2.10 Automobile workshop set Add-on system Clearly arranged module system, everything at hand on perforated wall-board. Code No. 0 Contents 1088696 2.10 as below stated Code No. Description Qty. 1076469 1076981 1120514 1175343 8003840 8009610 8010700 8029480 8030810 8117420 1120638 1081616 1081624 1081632 106/103 107/103 106/A 106/S100 1.12/02 1.26/2 1.28/2 1.70/2 1.73/1 1.75/1 71010 1500 H 1 1500 H 2 1500 H 3 Cross piece, 2-arm pattern, 140 mm Cross piece, 3-arm pattern, 140 mm Pulling hook, 100 mm Pulling hook, slim pattern, 100 mm Battery-terminal puller, 2-arm pattern Nut splitter Stud extractor Dismantling and assembly fork Universal ball joint puller Oil filter hook Perforated board Hook Spring clamp Spring clamp 1 1 3 3 1 1 1 1 1 1 1 4 9 5 11.5 2.20 Truck workshop set Add-on system Clearly arranged module system, everything at hand on perforated wall-board. Code No. 0 Contents 1088718 2.20 as below stated Code No. Description Qty. 1076612 1077023 1120530 1175475 1123947 1084593 8116100 8019840 1120638 1081616 1081632 106/2A03 107/2A03 106/B 106/S220 106/BV 1.2106210 1.06/HSP1 1.40/2 71010 1500 H 1 1500 H 3 Cross piece, 2-arm pattern, 260 mm Cross piece, 3-arm pattern, 260 mm Pulling hook, 100 mm Pulling hook, slim pattern, 220 mm Pulling hook, 300 mm Spindle Hydraulic pressure spindle Bearing separator Perforated board Hook Spring clamp 1 1 3 3 3 1 1 1 1 10 5 14.0 2.30 Industrial pulling set Add-on system For the assembly of the tried and tested 1.06 and 1.07 versions. Using this set, you will be able to assemble more than 12 of the usual versions with high-speed clamping hooks, including hydraulic spindle, in seconds. Code 348 No. 0 Contents 1393014 2.30 as below stated Code No. Description Qty. 1076469 1076485 1076590 1076612 1076981 1077007 1077015 1077023 1084488 1084593 8116100 1178199 1178253 1120638 1081616 1081624 1081632 106/103 106/1A03 106/203 106/2A03 107/103 107/1A03 107/203 107/2A03 1.1406140 1.2106210 1.06/HSP1 106/A-E 106/B-E 71010 1500 H 1 1500 H 2 1500 H 3 Cross piece, 2-arm pattern, 140 mm Cross piece, 2-arm pattern, 180 mm Cross piece, 2-arm pattern, 220 mm Cross piece, 2-arm pattern, 260 mm Cross piece, 3-arm pattern, 140 mm Cross piece, 3-arm pattern, 180 mm Cross piece, 3-arm pattern, 220 mm Cross piece, 3-arm pattern, 260 mm Spindle Spindle Hydraulic pressure spindle Pulling hook Pulling hook Perforated board Hook Spring clamp Spring clamp 1 1 1 1 1 1 1 1 1 1 1 3 3 1 12 4 6 17.5 Baldur_9_GB.mif Seite 349 Freitag, 18. Juli 2003 10:15 10 2.40 Pulling set for construction machines Add-on system For the assembly of the robust and handy strap-pattern pulling tools 1.14 and 1.15. With this set, you will be able to assemble 10 of the usual flexible strap-pattern pulling tools from the range 1.14/1.15, including the new hydraulic spindle. Code No. 0 Contents 1393030 2.40 as below stated Code No. Description Qty. 1077856 1077910 1078054 1078070 1084569 1084631 8116100 1077821 1077899 1077953 1077872 1077937 1120638 1081616 1081624 1081632 114/204 114/304 115/204 115/304 1.1806200 1.2106250 1.06/HSP1 114/201 114/301 114/401 114/208 114/308 71010 1500 H 1 1500 H 2 1500 H 3 Head Head Head Head Spindle Spindle Hydraulic pressure spindle Pulling hook, 210 mm Pulling hook, 260 mm Pulling hook, 390 mm Strap Strap Perforated board Hook Spring clamp Spring clamp 1 1 1 1 1 1 1 3 3 3 6 6 1 6 2 20 Code Accessories No. Qty. 1075225 1075144 1074946 1074954 1074431 1074458 Hexagon bolt M10 Hexagon bolt M12 Hexagon nut M10 Hexagon nut M12 Spring washer M10 Spring washer M12 6 12 6 12 6 12 24.5 Dump truck at work. 3.01 Track alignment gauge For inside measurement. Suitable for all vehicle types. With simple, telescopic length adjustment. Immediate track-difference readings may be taken from the milimetre scale. Extensive measurement range from 835 to 1500 mm, and with extensions up to 2100 mm. Track difference measurable from 0–35 mm. Notes on Use: The vehicle to be tested must be standing on level ground. The front wheels must be set for running straight ahead and have the same tyre pressure. The play in the steering linkage must be removed by pressing the front wheels apart. The track alignment gauge must be set roughly at the axle centreline between the front tyres in such a manner that the two chain ends contact the ground. The scale is set a “0“. The car is allowed to roll forward approx. one half turn of the wheel, until the chain ends again contact the ground. The track difference may then be read off on the scale. Code No. 8033080 3.01 8033160 3.01/V Description Track alignment gauge Extension for track alignment gauge Measurement range 0 835-1500 1500-2100 2.0 0.4 349
1.13/01 价格&库存
很抱歉,暂时无法提供与“1.13/01”相匹配的价格&库存,您可以联系我们找货
