DREMOTEST E12 2288311
    GEDORE
    GEDORE - DREMOTEST E12 2288311 - Torque Tester, Calibration Analyser, +/- 1% Accuracy, Clockwise, 0....
DREMOTEST E12 2288311 数据手册
TORQUE TOOLS Torque calibration analysers 8612 ELECTRONIC TORQUE TESTER DREMOTEST E 0.2-3150 N·m / 1.8 lbf·in - 2323 lbf·ft ››For verifying and setting clockwise torque wrenches and torque screwdrivers ››Simple, electronic torque tester with integrated torque transducer (DMS) ››5 models in the range from 0.2 to 3150 N·m ››With fixed hexagon female drive 1/4", 10, 17, 36, 46 mm or 1.1/2" square drive adaptor (model dependent) ››With 1/4", 3/8", 1/2", 3/4", 1" square drive adaptor or bit adaptor (model dependent) ››High measurement accuracy: +/- 1 % tolerance of reading, +/- 1 digit ››Break-Point-measurement (1st peak) ››Autoreset ››Can be switched from N·m to lbf·ft ››Serial interface RS232 ››Optionally available: adaptor for cigarette lighter socket (12 V), no. 8612-390 Scope of delivery: ››Electronic torque tester ››RS232 cable ››Power supply unit ››100 - 240 V, 50 - 60 Hz, max. 500 mA (see type plate) ››2 sockets (size and drive model-dependent) ››Adaptor for 8612-3150 ››Operating instructions ››Packaging 8612-3150 8612-300 N·m 0,2-12 0,9-55 9-320 90-1100 500-3150 lbf·in 1,8-106 OPTIONAL ACCESSORIES: Description Adaptor for cigarette lighter socket lbf·ft 0,7-40,6 7-236 66-811 369-2323 6.3 10.0 17.0 36.0 Resolution 0,001 0,01 0,1 1 1 Adaptor Q 1/4", 3/8" 1/4", 3/8" 3/8", 1/2" 1/2", 3/4" 1" 0 3.0 3.0 3.0 10.0 26.0 0 0.150 Code 2288311 1947699 1856111 1947702 2529858 Code 1878719 No. 8612-012 8612-050 8612-300 8612-1000 8612-3150 No. 8612-390 314 315 Torsion test device E-tp ETP ELECTRONIC TORSION TEST DEVICE ››For testing, and verifying clockwise and anti-clockwise torque wrenches ››5 models in the range of 0.5 to 3150 N·m ››Vertical and horizontal testing according to DIN EN ISO 6789 ››Electronic torque tester integrated with measurement electronics ››Robust housing from aluminium cast with separate or detachable operating display ››Serial interface RS232 for PC ››Traceable to national standards ››ETP 15 with integrated overload protection and tool for manual resetting after unintended overload ››Torque reading precision +/- 1 %, +/- 1 digit from reading figure ››Factory certificate based on VDI 2646 ››Optional certificate as per DAkkS-DKD-R 3-8 ››A large LC graphic display ››Wide measuring range in N·m, can be switched to cN·m, lbf·ft or lbf·in (model dependant) ››Power supply unit with EURO plug (UK, US, AUS-adaptor on request) ››Accessories: Operating display, display holder incl. cable, software incl. connection cable for PC Q" 1/4 1/2 3/4 3/4 1.1/2 Q 6.3 12.5 20.0 20.0 40.0 N·m 0,5-15 4-100 20-500 50-1000 300-3150 lbf·ft 0,4-11 3-74 14,8-369 36,9-737,6 221-2323 Resolution 0,001 N·m 0,01 N·m 0,1 N·m 0,1 N·m 1,0 N·m Adaptor 1/4", 3/8" 3/8", 1/2" 3/8", 1/2" 3/4", 1" Code 2795663 2795701 2795728 2795868 2795884 0 4.8 10.0 10.3 10.3 26.8 No. ETP 15 ETP 100 ETP 500 ETP 1000 ETP 3150 ETPG BASIC HOUSING ››From aluminium cast (except ETP3150) ››Serial interface RS232 for PC ››Traceable to national standards with factory certificate ››High measurement accuracy: +/- 1 % tolerance of reading, +/- 1 digit ››ETPG 15 with integrated overload protection and tool for manual resetting after unintended overload ››Wide measuring range in N·m, can be switched to cN·m, lbf·ft or lbf·in ››Power supply unit with EURO plug (UK, US, AUS-adaptor on request) Q" 1/4 1/2 3/4 3/4 1.1/2 Q 6.3 12.5 20.0 20.0 40.0 N·m 0,5-15 4-100 20-500 50-1000 300-3150 lbf·ft 0,4-11 3-74 14,8-369 36,9-737,6 221-2323 Resolution 0,001 N·m 0,01 N·m 0,1 N·m 0,1 N·m 1,0 N·m Adaptor 1/4", 3/8" 3/8", 1/2" 3/8", 1/2" 3/4", 1" 0 4.0 9.2 9.5 9.5 26.0 Code 2795892 2795906 2795914 2795930 2795957 No. ETPG 15 ETPG 100 ETPG 500 ETPG 1000 ETPG 3150 TORQUE TOOLS Torque angle indicator TORQUE ANGLE INDICATOR 8200 ››When using torque angle indicator no. 8200, please note: The maximum output of the torque wrenches must not be passed. Please ensure that the maximum load capacity of the square drive including the values achieved by angle-regulated tightening is not exceeded: ››1/2" max. approx. 390 N·m ››3/4" max. approx. 1330 N·m 8200 TORQUE ANGLE INDICATOR Use: ››Additional angle-regulated tightening for controlled torque and angle activation Features: ››Torque angle indicator with 1/2" or 3/4" square drive ››For additional precise angle tightening (0 - 360°) ››1/2" square drive with ball locking device or 3/4" square drive with pin locking device ››No. 8200-01/-02 models with sliding magnetic and gripping arm ››No. 8200-11 only with magnetic arm - simple design ››To operate with a suitable torque wrench ››The maximum output of the torque wrench must not be passed Scope of delivery: ››Torque angle indicator ››Delivered in a strong plastic case (no. 8200-01/-02), model no. 8200-11 in sturdy hard cardboard packaging 8200-01 8200-02 8200-11 a" 1/2 1/2 3/4 Q" 1/2 1/2 3/4 , 80 82 120 A° 0-360 0-360 0-360 0 0.330 0.330 0.530 Code 1195980 7718480 7716510 No. 8200-01 8200-11 8200-02 316 317 Accessories End fittings 16 Z 8791 (MM) OPEN END FITTING 16 Z ››For accessing bolts in cramped and hard-to-reach locations, easy to change ››Forged ››Chrome-vanadium steel, matt chrome-plated ››With eject-pin for unlocking ! 7 8 9 10 11 12 13 14 15 16 17 18 19 Ø 16 16 16 16 16 16 16 16 16 16 16 16 16 4 5 5 5 7 7 7 8 8 8 9 9 9 10 r 20.5 20.5 20.5 29.0 29.0 29.0 34.5 34.5 34.5 41.5 41.5 41.5 45.0 Depth gauge 32 32 32 32 32 32 32 32 32 32 32 32 32 0 0.080 0.080 0.080 0.090 0.090 0.090 0.120 0.120 0.120 0.160 0.160 0.160 0.180 Code 7774470 7774550 7774630 7710070 7710150 7676890 7710230 7710310 7710580 7710660 7710740 7676970 7710820 No. 8791-07 8791-08 8791-09 8791-10 8791-11 8791-12 8791-13 8791-14 8791-15 8791-16 8791-17 8791-18 8791-19 ! 20 21 22 23 24 25 26 27 28 29 30 32 36 Ø 16 16 16 16 16 16 16 16 16 16 16 16 16 No. 8791-1/4AF 8791-5/16AF 8791-3/8AF 8791-7/16AF 8791-1/2AF 8791-9/16AF 8791-5/8AF 8791-11/16AF 8791-3/4AF 8791-13/16AF 8791-7/8AF 8791-15/16AF " 1 1.1/16 1.1/8 1.3/16 1.1/4 1.5/16 Ø 16 16 16 16 16 16 4 10 10 11 11 11 11 11 12 12 12 12 12 12 r 45.0 45.0 56.0 56.0 56.0 56.0 56.0 60.5 68.0 68.0 68.0 68.0 68.0 Depth gauge 32 32 32 32 32 32 32 32 32 32 32 32 32 0 0.180 0.180 0.220 0.220 0.220 0.220 0.220 0.260 0.300 0.300 0.300 0.300 0.300 Code 7710900 7677000 7711040 1977164 7711120 1552279 1552287 7711200 1207008 1552309 7774710 7774980 1552317 No. 8791-20 8791-21 8791-22 8791-23 8791-24 8791-25 8791-26 8791-27 8791-28 8791-29 8791-30 8791-32 8791-36 8791 (AF) OPEN END FITTING 16 Z ››For accessing bolts in cramped and hard-to-reach locations, easy to change ››Forged ››Chrome-vanadium steel, matt chrome-plated ››With eject-pin for unlocking " 1/4 5/16 3/8 7/16 1/2 9/16 5/8 11/16 3/4 13/16 7/8 15/16 Ø 16 16 16 16 16 16 16 16 16 16 16 16 4 5 5 7 7 8 8 9 9 10 10 11 11 r 20.5 20.5 29.0 29.0 34.5 34.5 41.5 41.5 45.0 45.0 56.0 56.0 Depth gauge 32 32 32 32 32 32 32 32 32 32 32 32 0 0.090 0.080 0.090 0.090 0.090 0.120 0.160 0.160 0.180 0.090 0.220 0.220 Code 1211421 7720030 1211447 7720110 7720380 7720460 7720540 7720620 7720700 1211439 7720890 7720970 4 11 12 12 12 12 12 r 56.0 60.5 68.0 68.0 68.0 68.0 Depth gauge 32 32 32 32 32 32 0 0.220 0.260 0.300 0.300 0.300 0.300 Code 7721000 7721190 7721270 7776170 7776250 7776330 No. 8791-1AF 8791-1.1/16AF 8791-1.1/8AF 8791-1.3/16AF 8791-1.1/4AF 8791-1.5/16AF TORQUE TOOLS 8792 (MM) RING END FITTING 16 Z ››For accessing bolts in cramped and hard-to-reach locations, easy to change ››Forged ››Chrome-vanadium steel, matt chrome-plated ››With eject-pin for unlocking ! 7 8 9 10 11 12 13 14 15 16 Ø 16 16 16 16 16 16 16 16 16 16 4 8 8 8 10 10 10 12 12 12 13 r 15.0 15.0 15.0 19.5 19.5 19.5 23.5 23.5 23.5 28.5 Depth gauge 32 32 32 32 32 32 32 32 32 32 0 0.090 0.090 0.090 0.100 0.100 0.100 0.140 0.140 0.140 0.180 Code 7775010 7775280 7775360 7712600 7712790 7677190 7712870 7712950 7713090 7713170 No. 8792-07 8792-08 8792-09 8792-10 8792-11 8792-12 8792-13 8792-14 8792-15 8792-16 ! 17 18 19 20 21 22 23 24 27 Ø 16 16 16 16 16 16 16 16 16 No. 8792-1/4AF 8792-5/16AF 8792-3/8AF 8792-7/16AF 8792-1/2AF 8792-9/16AF 8792-5/8AF " 11/16 3/4 13/16 7/8 15/16 1 1.1/16 Ø 16 16 16 16 16 16 16 4 13 13 14 14 14 15 15 15 16 r 28.5 28.5 31.5 31.5 31.5 39.5 39.5 39.5 41.5 Depth gauge 32 32 32 32 32 32 32 32 32 0 0.180 0.180 0.210 0.210 0.210 0.260 0.270 0.260 0.300 Code 7713250 7677270 7713330 7713410 7677350 7713680 1211471 7713760 7713840 No. 8792-17 8792-18 8792-19 8792-20 8792-21 8792-22 8792-23 8792-24 8792-27 8792 (AF) RING END FITTING 16 Z ››For accessing bolts in cramped and hard-to-reach locations, easy to change ››Forged ››Chrome-vanadium steel, matt chrome-plated ››With eject-pin for unlocking " 1/4 5/16 3/8 7/16 1/2 9/16 5/8 Ø 16 16 16 16 16 16 16 4 8 8 10 10 12 12 13 r 15.0 15.0 19.5 19.5 23.5 23.5 28.5 Depth gauge 32 32 32 32 32 32 32 0 0.100 0.090 0.100 0.100 0.100 0.140 0.140 Code 1211455 7721350 1211498 7721430 7721510 7721780 7721860 4 13 14 14 15 15 15 16 r 28.5 31.5 31.5 39.5 39.5 39.5 41.5 Depth gauge 32 32 32 32 32 32 32 0 0.180 0.210 0.100 0.260 0.260 0.300 0.300 Code 7721940 7722080 1211463 7722160 7722240 7722320 7722400 No. 8792-11/16AF 8792-3/4AF 8792-13/16AF 8792-7/8AF 8792-15/16AF 8792-1AF 8792-1.1/16AF 8797 FLARED END FITTING 16 Z ››For accessing bolts in cramped and hard-to-reach locations, easy to change ››Forged ››Chrome-vanadium steel, matt chrome-plated ››With eject-pin for unlocking ! 7 8 9 10 11 12 13 14 15 Ø 16 16 16 16 16 16 16 16 16 4 8 8 8 10 10 10 12 12 12 r 15.0 15.0 15.0 19.5 19.5 19.5 23.5 23.5 23.5 7.0 6.5 5.5 26.0 19.0 13.0 34.0 24.0 18.0 c1 5.5 6.0 6.5 7.0 8.5 9.0 10.0 11.2 12.0 32 32 32 32 32 32 32 32 32 0 0.090 0.090 0.090 0.100 0.100 0.120 0.140 0.140 0.140 Code 1211587 1211595 1211609 1211625 1211633 1211641 1211668 7664290 1211684 No. 8797-07 8797-08 8797-09 8797-10 8797-11 8797-12 8797-13 8797-14 8797-15 ! 16 17 18 19 20 21 22 24 27 Ø 16 16 16 16 16 16 16 16 16 4 13 13 13 14 14 14 15 15 16 r 28.5 28.5 28.5 31.5 31.5 31.5 39.5 39.5 41.5 66.0 56.0 45.0 80.0 60.0 43.0 172.0 118.0 76.0 c1 13.0 14.0 14.5 15.0 16.0 16.5 17.0 18.0 20.0 32 32 32 32 32 32 32 32 32 0 0.180 0.180 0.200 0.210 0.210 0.210 0.260 0.260 0.300 Code 1211692 1211706 1211714 1211722 1211731 1211749 1211757 1211773 1211781 No. 8797-16 8797-17 8797-18 8797-19 8797-20 8797-21 8797-22 8797-24 8797-27 318 319 8754 RATCHET HEAD 16 Z ››For accessing bolts in cramped and hard-to-reach locations, easy to change ››Forged ››Chrome-vanadium steel, matt chrome-plated ››With eject pin for unlocking ››Max. continuous load of ratchet according to DIN EN ISO 6789:2003 and/or maximum load of cavity 8754-01 8754-02 a" 3/8 1/2 a 10.0 12.5 Ø 16 16 Type 2 2 Depth gauge 32 32 Continuous load 3/8" = 135 N·m 1/2" = 340 N·m 0 0.170 0.270 Code 7711980 7712010 No. 8754-01 8754-02 8756 END FITTING IN-HEX 8790 - 8793 FIXED SQUARE HEAD 16 Z 16 Z ››For accessing bolts in cramped and hard-to-reach ››For accessing bolts in cramped and hard-to-reach locations, easy to change ››Forged ››Chrome-vanadium steel, matt chrome-plated ››With eject pin for unlocking ››Max. continuous load of ratchet according to DIN EN ISO 6789:2003 and/or maximum load of cavity locations, easy to change ››Forged ››Chrome-vanadium steel, matt chrome-plated ››With eject-pin for unlocking $ 3 4 5 6 8 Ø 16 16 16 16 16 Depth gauge 32 32 32 32 36 0 0.100 0.100 0.100 0.100 0.110 Code 7773740 7773820 7773900 7774040 7774120 No. 8756-03 8756-04 8756-05 8756-06 8756-08 Ø a" a 3/8 10.0 16 1/2 12.5 16 Type 5 5 Depth gauge Continuous load 32 3/8" = 135 N·m 32 1/2" = 340 N·m 0 Code 0.350 7709490 0.380 7709570 No. 8790-00 8793-00 TORQUE TOOLS End fittings 22 Z 8794-00 FIXED SQUARE HEAD 22 Z ››For accessing bolts in cramped and hard-to-reach locations, easy to change ››Forged ››Chrome-vanadium steel, matt chrome-plated a" 3/4 Ø 22 a 20 Type 5 Depth gauge 56 Continuous load 3/4" = 850 N·m Code 7708840 0 0.610 No. 8794-00 8795 OPEN END FITTING 22 Z ››For accessing bolts in cramped and hard-to-reach locations, easy to change ››Forged ››Chrome-vanadium steel, matt chrome-plated ››With eject-pin for unlocking ! 22 24 27 30 32 Ø 22 22 22 22 22 4 11 11 12 12 12 r 52.0 52.0 64.0 64.0 75.5 Depth gauge 56 56 56 56 56 0 0.330 0.320 0.380 0.370 0.450 Code 7707010 7707280 7707360 7707440 7707520 No. 8795-22 8795-24 8795-27 8795-30 8795-32 ! 34 36 41 46 Ø 22 22 22 22 4 12 12 12 12 r 75.5 75.5 94.0 94.0 Depth gauge 56 56 56 56 0 0.430 0.430 0.580 0.530 Code 7677430 7707600 7707790 7707870 No. 8795-34 8795-36 8795-41 8795-46 No. 8796-22 8796-24 8796-27 8796-30 8796-32 ! 34 36 41 46 Ø 22 22 22 22 4 20 20 22 22 r 54.0 54.0 68.0 68.0 Depth gauge 56 56 56 56 0 0.420 0.390 0.560 0.520 Code 7677510 7708410 7708680 7708760 No. 8796-34 8796-36 8796-41 8796-46 8796 RING END FITTING 22 Z ››For accessing bolts in cramped and hard-to-reach locations, easy to change ››Forged ››Chrome-vanadium steel, matt chrome-plated ››With eject-pin for unlocking ! 22 24 27 30 32 Ø 22 22 22 22 22 4 15 15 17 17 20 r 38.0 38.0 46.5 46.5 54.0 Depth gauge 56 56 56 56 56 0 0.350 0.330 0.370 0.350 0.420 Code 7707950 7708090 7708170 7708250 7708330 320 321 8794-02 - 8794-03 RATCHET HEAD 22 Z 8794-02 ››For accessing bolts in cramped and hard-to-reach locations, easy to change ››Forged ››Chrome-vanadium steel, matt chrome-plated ››With eject-pin for unlocking a" 3/4 3/4 Ø 22 22 a 20 20 8794-03 8794-02 Type 2 2 Depth gauge 56 56 8794-03 Continuous load 3/4" = 850 N·m 3/4" = 850 N·m 0 1.011 0.950 Code 2961385 1427318 No. 8794-02 8794-03 ! 60 65 70 75 Ø 28 28 28 28 4 24.5 28.0 30.0 31.5 r 129.5 140.5 151.0 163.0 Depth gauge 75 75 75 100 0 2.1 2.4 2.9 4.0 Code 1565397 1565400 1565419 1565427 No. 8798-60 8798-65 8798-70 8798-75 ! 60 65 70 75 80 Ø 28 28 28 28 28 4 26.0 29.0 32.5 34.0 35.0 r 94 101 110 117 123 Depth gauge 75 75 75 100 100 0 2.5 2.9 2.0 4.5 4.8 Code 1565540 1565559 1565567 1565575 1565583 No. 8799-60 8799-65 8799-70 8799-75 8799-80 End fittings 28 Z 8798 OPEN END FITTING 28 Z ››For accessing bolts in cramped and hard-to- reach locations, easy to change ››Chrome-vanadium steel, matt chrome-plated ! 36 41 46 50 55 Ø 28 28 28 28 28 4 18.0 19.5 20.0 21.5 24.5 ››With catch retention ››Special sizes available on request Depth gauge 75 75 75 75 75 r 77.5 89.0 99.0 108.0 118.5 0 1.9 1.9 1.9 1.9 2.1 Code 1565346 1565354 1565362 1565370 1565389 No. 8798-36 8798-41 8798-46 8798-50 8798-55 8799 RING END FITTING 28 Z ››For accessing bolts in cramped and hard-to- reach locations, easy to change ››Chrome-vanadium steel, matt chrome-plated ! 36 41 46 50 55 Ø 28 28 28 28 28 4 19.5 20.5 22.5 23.5 25.0 r 60 66 75 80 88 ››With catch retention ››Special sizes available on request Depth gauge 75 75 75 75 75 0 1.6 1.8 2.1 2.2 2.4 Code 1565494 1565508 1565516 1565524 1565532 No. 8799-36 8799-41 8799-46 8799-50 8799-55 8794 RATCHET HEAD 28 Z ››For accessing bolts in cramped and hard-to- reach locations, easy to change ››Chrome-vanadium steel, matt chrome-plated ››With catch retention ››Max. continuous load of coupler according to DIN EN ISO 6789:2003 and/or maximum support load: 1000 N·m a" 3/4 a 20 Ø 28 Type 2 Depth gauge 0 75 1.8 Code 1566032 No. 8794-05 TORQUE TOOLS End fittings 9x12 SE 7112 RECTANGULAR OPEN END FITTING 9x12 ››For accessing bolts in cramped and hard-to-reach locations, easy to change ››Forged ››Chrome-vanadium steel, matt chrome-plated ››With eject-pin for unlocking ! 7 8 9 10 11 12 13 14 : 9 x 12 9 x 12 9 x 12 9 x 12 9 x 12 9 x 12 9 x 12 9 x 12 4 5.5 5.5 5.5 5.5 5.5 5.5 5.5 7.5 r 20.0 21.5 23.0 24.5 26.0 27.5 29.0 31.0 Depth gauge 17.5 17.5 17.5 17.5 17.5 17.5 17.5 20.0 0 0.035 0.035 0.035 0.040 0.030 0.035 0.035 0.040 Code 7688390 7688550 7679050 7688630 7688980 7679560 7689010 7689360 No. 7112-07 7112-08 7112-09 7112-10 7112-11 7112-12 7112-13 7112-14 ! 15 16 17 18 19 : 9 x 12 9 x 12 9 x 12 9 x 12 9 x 12 4 7.5 7.5 7.5 7.5 7.5 : 9 x 12 9 x 12 9 x 12 9 x 12 9 x 12 9 x 12 9 x 12 4 12 13 13 13 13 15 15 r 33.0 35.0 37.0 39.0 41.0 Depth gauge 20.0 20.0 20.0 20.0 20.0 0 0.040 0.045 0.050 0.060 0.060 Code 7689440 7679990 7689600 7684560 7689790 No. 7112-15 7112-16 7112-17 7112-18 7112-19 7212 RECTANGULAR RING END FITTING 9x12 ››For accessing bolts in cramped and hard-to-reach locations, easy to change ››Forged ››Chrome-vanadium steel, matt chrome-plated ››With eject-pin for unlocking ! 7 8 10 11 12 13 14 : 9 x 12 9 x 12 9 x 12 9 x 12 9 x 12 9 x 12 9 x 12 4 8 8 8 8 12 12 12 r 13.0 14.2 17.2 18.6 20.0 21.5 23.0 Depth gauge 17.5 17.5 17.5 17.5 17.5 17.5 17.5 0 0.030 0.030 0.030 0.030 0.035 0.035 0.040 Code 7691340 7691420 7691690 7691770 7677940 7691930 7692230 No. 7212-07 7212-08 7212-10 7212-11 7212-12 7212-13 7212-14 ! 15 16 17 18 19 21 22 r 24.0 26.0 27.0 28.5 30.5 33.0 34.5 Depth gauge 17.5 17.5 17.5 17.5 17.5 17.5 17.5 0 0.040 0.040 0.040 0.040 0.040 0.050 0.050 Code 7692580 7678080 7692740 7678160 7692820 7678240 7693040 No. 7212-15 7212-16 7212-17 7212-18 7212-19 7212-21 7212-22 7312 RECTANGULAR FLARED END FITTING 9x12 ››For accessing bolts in cramped and hard-to-reach locations, easy to change ››Forged ››Chrome-vanadium steel, matt chrome-plated ››With eject-pin for unlocking ! 10 11 12 13 14 : 9 x 12 9 x 12 9 x 12 9 x 12 9 x 12 4 12 12 12 12 13 r 21.0 22.5 24.0 25.0 27.0 Opening width 7.3 8.7 9.0 10.0 11.0 Depth gaugea 17.5 17.5 17.5 17.5 17.5 0 0.040 0.040 0.040 0.040 0.050 Code 7685290 7685370 7699590 7679210 7679480 No. 7312-10 7312-11 7312-12 7312-13 7312-14 ! 17 18 19 22 : 9 x 12 9 x 12 9 x 12 9 x 12 4 13 15 15 15 r 31.5 33.0 34.5 39.0 Opening width 14.0 14.7 15.3 17.0 Depth gaugea 17.5 17.5 17.5 17.5 0 0.065 0.065 0.065 0.065 Code 7685880 7679640 7686260 7679720 No. 7312-17 7312-18 7312-19 7312-22 322 323 7412 RECTANGULAR REVERSIBLE RATCHET HEAD 9x12 ››For accessing bolts in cramped and hard-to-reach locations, easy to change ››Forged ››Chrome-vanadium steel, matt chrome-plated ››With eject-pin for unlocking ››Fine-toothed ››Return angle 5 degrees ››Max. continuous load of ratchet according to DIN EN ISO 6789:2003 and/or maximum load of cavity a" 1/4 3/8 1/2 a 6.3 10.0 12.5 : 9 x 12 9 x 12 9 x 12 A° 5 5 5 4 16.6 23.2 24.2 r 25 34 34 Depth gauge 17.5 17.5 17.5 Continuous load 1/4" = 30 N·m 3/8" = 135 N·m 1/2" = 150 N·m 0 0.060 0.140 0.150 Code 7672710 7686500 7687230 No. 7412-00 7412-01 7412-02 7612 RECTANGULAR FIXED SQUARE HEAD 9x12 ››For accessing bolts in cramped and hard-to-reach locations, easy to change ››Forged ››Chrome-vanadium steel, matt chrome-plated ››With eject-pin for unlocking ››Max. continuous load of ratchet according to DIN EN ISO 6789:2003 and/or maximum load of cavity a" 1/4 3/8 1/2 : 9 x 12 9 x 12 9 x 12 a 6.3 10.0 12.5 4 14 14 14 r 20 20 20 Depth gauge 17.5 17.5 17.5 Continuous load 1/4"/30 N·m 3/8"/135 N·m 1/2"/150 N·m 0 0.070 0.070 0.080 Code 7672630 7679800 7687900 No. 7612-00 7612-01 7612-02 7812 RECTANGULAR BIT HOLDER 9x12 ››For accessing bolts in cramped and hard-to-reach locations, easy to change ››Forged ››Chrome-vanadium steel, matt chrome-plated ››With eject-pin for unlocking k" 1/4 5/16 k 6.3 8.0 : 9 x 12 9 x 12 4 10.0 12.5 r 14 16 Depth gauge 17.5 17.5 0 0.040 0.040 Code 2101645 7697970 No. 7812-10 7812-00 TORQUE TOOLS 7912 RECTANGULAR WELD-ON FITTING 9x12 ››For accessing bolts in cramped and hard-to-reach locations, easy to change ››Bear the depth gauges in mind y 14 : 9 x 12 4 14.5 Depth gauge 8 r 19 Code 7698190 0 0.030 No. 7912-00 SUKSE RECTANGULAR RING RATCHET SPANNER, REVERSIBLE 9x12 ››9x12 mm rectangular cavity with pin-locking ››Flat ring ratchet with UD-profile, fine-toothed ››With recessed lever change ››For loosening or fast tightening with high torque transfer ››Non-glare look thanks to matt chrome-plating, locking insert and pawl manganese-phosphated ››GEDORE vanadium steel 31CrV3, forged ››To operate with a 9x12 mm torque wrench or rectangular handle 9x12 mm ! 10 13 17 19 : 9 x 12 9 x 12 9 x 12 9 x 12 h 7.7 9.0 10.6 11.7 A° 7 7 6 6 b 21.0 25.7 33.6 36.3 Depth gauge 40 42 45 52 Code 2827735 2827743 2827751 2827778 0 0.070 0.090 0.130 0.150 No. SUKSE9 10 SUKSE9 13 SUKSE9 17 SUKSE9 19 AGSE9 RECTANGULAR HANDLE SE 9x12 ››To operate with rectangular end fittings 9x12 ››For removing bolts or nuts, especially in confined spaces ››Without torque function ››GEDORE vanadium steel 31CrV3, matt chrome-plated : 9 x 12 L 267 ››Non-slip 2-component handle with hanging hole ››Max. continuous load of cavity according to DIN EN ISO 6789:2003 and/or maximum support load : 150 N·m h 18.5 b 22 0 0.320 Code 2827786 No. AGSE9 324 325 End fittings 14x18 SE 7118 RECTANGULAR OPEN END FITTING 14x18 ››For accessing bolts in cramped and hard-to-reach locations, easy to change ››Forged ››Chrome-vanadium steel, matt chrome-plated ››With eject-pin for unlocking ! 13 14 15 16 17 18 19 21 22 : 14 x 18 14 x 18 14 x 18 14 x 18 14 x 18 14 x 18 14 x 18 14 x 18 14 x 18 4 7 7 7 9 9 9 9 11 11 r 30.0 32.0 34.0 35.5 37.0 39.0 41.0 45.0 47.0 Depth gauge 25.0 25.0 25.0 25.0 25.0 25.0 25.0 25.0 25.0 0 0.120 0.120 0.120 0.125 0.130 0.130 0.130 0.155 0.150 Code 7689870 7690020 7690100 7685610 7690370 7686180 7690450 7686420 7690610 No. 7118-13 7118-14 7118-15 7118-16 7118-17 7118-18 7118-19 7118-21 7118-22 ! 24 27 29 30 32 34 36 41 : 14 x 18 14 x 18 14 x 18 14 x 18 14 x 18 14 x 18 14 x 18 14 x 18 4 11 13 13 13 13 15 15 15 r 51.0 58.5 63.0 67.5 67.5 74.0 78.0 82.0 : 14 x 18 14 x 18 14 x 18 14 x 18 14 x 18 14 x 18 4 17.5 17.5 17.5 19.0 19.0 19.0 r 41.5 45.0 47.5 50.5 53.0 59.0 Depth gauge 25.0 32.5 32.5 32.5 32.5 33.5 36.0 40.0 0 0.170 0.185 0.220 0.220 0.220 0.255 0.257 0.261 Code 7690880 7690960 2212285 7691260 7687740 1963708 1963716 1963724 No. 7118-24 7118-27 7118-29 7118-30 7118-32 7118-34 7118-36 7118-41 Code 7694440 7694790 7695920 7679130 7696220 7696300 No. 7218-27 7218-30 7218-32 7218-34 7218-36 7218-41 7218 RECTANGULAR RING END FITTING 14x18 ››For accessing bolts in cramped and hard-to-reach locations, easy to change ››Forged ››Chrome-vanadium steel, matt chrome-plated ››With eject-pin for unlocking ! 13 14 15 16 17 18 19 21 22 24 : 14 x 18 14 x 18 14 x 18 14 x 18 14 x 18 14 x 18 14 x 18 14 x 18 14 x 18 14 x 18 4 12.0 12.0 12.0 12.0 12.0 12.0 12.0 15.0 15.0 15.0 r 21.5 23.0 24.2 25.7 27.2 28.5 30.5 33.0 34.5 37.5 Depth gauge 25 25 25 25 25 25 25 25 25 25 0 0.120 0.120 0.115 0.125 0.125 0.125 0.125 0.140 0.140 0.140 Code 7693120 7693390 7693470 7678320 7693630 7678830 7693710 7678910 7693980 7694280 No. 7218-13 7218-14 7218-15 7218-16 7218-17 7218-18 7218-19 7218-21 7218-22 7218-24 ! 27 30 32 34 36 41 Depth gauge 31 31 31 31 31 31 0 0.150 0.160 0.165 0.195 0.195 0.225 TORQUE TOOLS 7418 RECTANGULAR REVERSIBLE RATCHET HEAD 14x18 ››For accessing bolts in cramped and hard-to-reach locations, easy to change ››Forged ››Chrome-vanadium steel, matt chrome-plated ››With eject-pin for unlocking ››Fine-toothed ››Return angle 7 degrees ››Max. continuous load of ratchet according to DIN EN ISO 6789:2003 and/or maximum load of cavity a" 1/2 3/4 a 12.5 20.0 : 14 x 18 14 x 18 A° 7,2 7,2 4 28.8 35.5 Depth gauge 25 33 r 47 64 Continuous load 1/2" = 340 N·m 3/4" = 400 N·m 0 0.350 0.780 Code 7687580 7687660 No. 7418-02 7418-04 7618 RECTANGULAR FIXED SQUARE HEAD 14x18 ››For accessing bolts in cramped and hard-to-reach locations, easy to change ››Forged ››Chrome-vanadium steel, matt chrome-plated ››With eject pin for unlocking ››Max. continuous load of ratchet according to DIN EN ISO 6789:2003 and/or maximum load of cavity a" 1/2 3/4 a 12.5 20.0 : 14 x 18 14 x 18 4 18 25 r 27 40 Depth gauge 25 25 Continuous load 1/2" = 340 N·m 3/4" = 400 N·m 0 0.200 0.390 Code 7688040 7688200 No. 7618-02 7618-04 7818 RECTANGULAR BIT HOLDER 7918 RECTANGULAR WELD-ON FITTING 14x18 14x18 ››For accessing bolts in cramped and hard-to-reach locations, easy to change ››Forged ››Chrome-vanadium steel, matt chrome-plated ››With eject-pin for unlocking ››For accessing bolts in cramped and hard-to-reach locations, easy to change ››Bear the depth gauges in mind k" 5/16 k 8 : 14 x 18 4 r 12.5 16 Depth gauge 0 25 0.100 Code 7698000 No. 7818-00 y 25 : 14 x 18 4 r Depth gauge 0 21.5 26 12 0.100 Code 7698430 No. 7918-00 326 327 Empty standard packaging MODULE SYSTEMS - FLEXIBILITY WITH FLAIR ››The module system adapts itself exactly to your wishes and requirements. At last, you can assemble ››Your set is flexibly alterable and extendible at all times. Just replace or add modules. The modules PLASTIC CASSETTES EMPTY FOR DREMOMETER MINI + AM SHEET METAL CASE EMPTY FOR DREMOMETER A-F your sets completely individually. Exactly and only using the tools you actually need. For every need, our system provides you with the perfect solution. Whether you chose a standard or an individual solution, your DREMASTER®/TORCOFIX torque wrenches with or without accessories, are always stored and transported professionally by virtue of the modular system design. Use: themselves are delivered with dummy plugs. Simply remove the plugs from the cavities you wish to load with your tools or accessory units. The remaining cavities remain closed - that's what we call neat. ››You tell us which tools you would like to combine into a set and we will then take care of the rest and you will get your desired set without delay. Finished and ready! Use: ››Standard packaging for sets of the torque wrench series DREMOMETER MINI and AM ››Robust and solid, best for storage and transport ››Standard packaging for sets of the torque wrench series DREMOMETER A-F ››Robust and solid, best for storage and transport ››With foam rubber inlay and nest-holes for the accessories ››With integrated metal-flight and nest-holes for the accessories ››Hinges, locks and hand grip made of steel ››GEDORE blue powder-coated Features: Features: Scope of delivery: ››Empty black plastic cassettes with foam inlay ››Delivery in sturdy cardboard packaging Description Plastic cassette + foam inlay for DREMO MINI Plastic cassette + foam insert for DREMO AM Scope of delivery: ››Sheet metal case, emtpy ››Delivery in sturdy cardboard packaging L 275 W 150 H 42 0 Code 0.296 1986805 No. 753-88 275 150 42 0.310 7620910 8554-99 Description Sheet metal case for DREMO A Sheet metal case for DREMO B Sheet metal case for DREMO BC/C Sheet metal case for DREMO D/DS Sheet metal case for DREMO DR/DX Sheet metal case for DREMO E / EK Sheet metal case for DREMO F L 370 485 630 830 830 945 1040 W 115 115 115 165 165 270 175 H 50 52 52 73 73 100 100 0 1.200 1.698 1.950 3.713 3.656 10.300 6.700 Code 7621050 7621130 7621210 7621480 7622100 7621560 1742876 No. 8560-90 8561-90 8562-90 8563-90 8571-90 8564-90 8572-90
DREMOTEST E12 2288311 价格&库存
很抱歉,暂时无法提供与“DREMOTEST E12 2288311”相匹配的价格&库存,您可以联系我们找货
