4549-05
4549-05
    GEDORE
4549-05 数据手册
258 259 Torque Tools DREMOMETER AM-F, A+S 268 Accessories DREMOMETER 281 DREMOMETER MINI / T-FS 282 DREMOMETER Z / SE, A+S 283 DREMASTER ® K / UK / Z / SE 288 TORCOFIX K / Z / SE / FS 294 Torque Screwdrivers 299 Other Mechanical Torque Wrenches 304 Electronic Torque Wrenches TorcoTronic 312 Torque calibration analyser DREMOTEST E 314 Electronic torsion test device E-TP 315 Accessories End fittings 317 Torque Multipliers DREMOPLUS ALU 329 Detailed information on calibration and repair 636 Torque Tools Torque CoMpeTenCe FroM 0.02 To 54,000 N·M Maximum production depth from a single source › Use of the very best steel grades, state-of-the-art machinery and environmentally-friendly production processes › Top-grade industrial quality for the hardest of development Precise adherence to stringent testing and measuring specifications are proof of maximum product quality. Large selection of mechanical and electronic torque wrenches, test equipment, torque multipliers and accessories Available individually or in practical sets Tailored service packages through to development of special customised tools › Torque tools are measuring equipment. Over › Our tool experts guarantee precision-like processing and permanent › › › › controlled screw tightening reliable and safe for more than 50 years continuous uses the long term, the high accuracy can only be assured in the form of regular tests (recalibration, recommended once a year or after 5000 load cycles) Maximum control during production guarantees a constantly high level. › All parts incorporated in the production process - from steel to the › › smallest spring - are controlled while all manufacturing and work steps are subject to stringent quality controls. After assembly, adjustment and calibration, torque tools are tested for accuracy in the end control stage and given a serial number (unique product identification) and factory test certificate in accordance with the applicable DIN EN ISO standard. Within the framework of regular continuous tests, processing quality, repeat accuracy and durability are tested. The results of these tests are integrated directly in optimising the production process. Top-level authorised calibration and competent control our all-round service - qualified and customised › Own accredited DAkkS calibration laboratory for torques with We offer you a wide range of services, which can be matched quite individually to your requirements. Your problems are our challenges. We can offer you qualified tailormade support in the following areas: › › In-house calibration according to DIN EN ISO 6789:2003 › DAkkS calibration in our own accredited DAkkS calibration laboratory › Repair service for our own brands › Demonstration/hire tools at favourable prices › Competent advice via our service telephone › Problem solving with the aid of our technical field service › Product training (internal and external) › Product presentations (internal and external) › Involvement in your in-house fairs › Special solutions in the engineering field/GEDORE SOLUTIONS › › (licence for testing in acc. with DAkkS guidelines DKD 3-7/3-8/DIN EN ISO 6789:2003) the registration number: D-K-15200-01-00 National co-operation partner to the German Calibration Service (DAkkS) since accreditation (DIN EN ISO/IEC 17025) and authorisation by PTB in 2000 Official examination of all test and measuring equipment once a year in the DAkkS laboratory by the Physikalisch-Technische Bundesanstalt in Braunschweig (PTB) Internal precision testing of all test and measuring equipment at least once every 3 months 260 261 Certified precision GEDORE Werkzeugfabrik GmbH & Co. KG Remscheider Straße 149 42899 Remscheid · GERMANY Vertrieb DEUTSCHLAND Fon +49 2191 596-900 Fax +49 2191 596-999 zentrale@gedore.com Sales INTERNATIONAL Fon +49 2191 596-910 Fax +49 2191 596-911 www.gedore.com Traceable safety ››DAkkS calibration in our own accredited, independent DAkkS calibration laboratory ››In-house calibration according to DIN EN ISO 6789:2003 2995832 01/16 PTB National Standard Basis of all lower-order standards DAkkS Calibration Standard (1) Highest calibration in one place Usage Standard (2) For testing measuring devices Customer Test Equipment Measuring devices for monitoring torque wrenches INFO Products Measuring tools (torque wrenches) which check and tighten bolts safely   636 More information on the topics calibration types, certificates and repair service DAkkS-calibration Scope of services offered by DAkkS Laboratory (1) Type Measuring range Measuring process Minimum measurement inaccuracy indicated Electr. torque wrench 0,2 N·m – 3.000 N·m DAkkS – DKD – R 3 – 7:2003 0,2 % Calibration equipment torque wrench (test devices) 0,2 N·m – 3.000 N·m DAkkS – DKD – R 3 – 8:2003 0,2 % Hand-operated torque wrench 0,2 N·m – 1.000 N·m DIN EN ISO 6789:2003 1 % Type Measuring range Measuring process Minimum measurement inaccuracy indicated Electr. torque wrench 0,2 N·m – 3.000 N·m DIN EN ISO 6789:2003 1% Calibration equipment torque wrench (test devices) 0,2 N·m – 3.000 N·m based on DAkkS-DKD 3-8:2003 0,5 % Hand-operated torque wrench 0,2 N·m – 1.000 N·m DIN EN ISO 6789:2003 1 % Electr. torque/rotary angle wrench 5 N·m – 300 N·m VDI 2647 0,3° based on VDI 2648 0,5° Homologation acc. OEM 0,3° Factory calibration (2) Torque Tools Overview of GEDORE torque tools Page Series/Type Precision +/- Drive Ratchet Scale Operation length independent Release types 0,4 – 3.000 N·m  Mechanische Drehmomentschlüssel 282 Dremometer Mini 3 % b 268 Dremometer AM - F 3 % b 283 Dremometer Z 3 % 284 Dremometer SE 3% }~ 1 282 Dremometer FS 6% b 1 290 Dremometer DMK 3% d 291 Dremometer DMUK 3% d 1 292 Dremometer DMZ 3% jk 1 293 Dremometer DMSE 3% } ~ 1 295 Torcofix K 3% b 1 296 Torcofix Z 3% jk 1 297 Torofix SE 3% } ~ 1 298 Torcofix FS 3% } ~ 1 305 TSN Slipper 4% 3 308 TBN Knicker 4 %, 6% b b j} 306 TSP Slipper 6% b 3 306 TSC Slipper 6% b 310 Typ 83 4% b 309 Typ 88 4% e k 2 1 g 1 1 e e d 1 2 3 f 0,04 – 13,6 N·m  Torque screwdriver 301 Typ 755 FS 6% i 3 302 Typ 756 S 6% i 3 303 Typ 757 S 6% i 3 303 Typ 758 SP 6% i 2 – 1.000 N·m  Electr. torque wrench 312 E-Torc II 1% b 313 Torcotronic III 1% d 0,2 – 3.150 N·m  Torque testers 314 Dremotest E 1% b g 315 E-TP 1% b g 262 263 Different Torque Tool Mechanisms Range N·m 0 5 10 15 20 40 60 80 100 150 200 300 400 500 750 1000 1500 2000   1 Click Tools Overtightening Possible Mech. torque wrench 2,5 – 12 N·m When the preset torque value is reached the operator will hear a click, feel an impulse and there will be approximately 3° of tool movement. Resetting takes place when the hand pressure is released. Work can then immediately continue. These tools are generally length dependent (exception DREMOMETER models AM - F), the position of the hand on the tool alters the torque produced. Continued application of force after the 3° of movement will cause the torque applied to increase above the required preset limit. Torque 6 – 3.000 N·m 8 – 1.000 N·m Preset Torque Value 8 – 400 N·m °m o ve me nt 5 – 12 N·m ap p ro x. 3 20 – 850 N·m 20 – 300 N·m Applied Force 20 – 850 N·m Overtightening Possible 20 – 400 N·m 1 – 850 N·m 2 – 850 N·m   2 Breaking Tools Overtightening Unlikely 2 – 400 N·m 2 – 200 N·m When the preset torque value is reached, these tools break at a specific point along the tool’s length - usually at a pivot point near the tool’s head. In most cases the movement is approximately 20°. The tool is automatically reset by allowing the handle to return to its in line position. These tools are length dependent, the position of the hand on the tool alters the torque produced. Continued application of force after 20° of tool movement will increase the torque applied above the preset limit but with the greater angle of tool movement this is less likely. Torque 5 – 125 N·m Preset Torque 0,4 – 135 N·m Value 1 – 10 N·m 1 – 10 N·m 0,8 – 2.000 N·m a ro pp x. 20 ° v mo em en t Applied Force 100 – 1.500 N·m Overtightening Unlikely Torque screwdriver 0,04 – 13,6 N·m 0,08 – 9 N·m 0,2 – 9 N·m   3 Slipping Tools Overtightening Impossible 0,1 – 5,0 N·m When the preset torque value is reached, a mechanism in the tool causes the application of torque to cease and the tool slips free for a short time until resetting occurs. Even if the application of force is repeated, the preset torque value will not be exceeded, therefore making it impossible to overtighten a fastener. These tools are not length dependent. Torque Electr. torque wrench 2 – 1.000 N·m Preset Torque 10 – 350 N·m Value Torque testers 0,2 – 3.150 N·m 0,5 – 3.150 N·m Applied Force Overtightening Impossible Torque Tools DreMoMeTer PErMANENT PrEcISIoN Torque wrench made of high-strength aluminium alloy Drive in accordance with application DREMOMETERS are available for a large variety of applications in controlled screw tightening. The single square drive for controlled clockwise tightening or the double square drive (L) for controlled bi-directional tightening. Special utilisation areas for DREMOMETER with spigot end (Z) and rectangular cavity (SE) particularly for hard-to-access locations and where space is tight. Almost all DREMOMETER models have separate ratchet heads, and there are good reasons for that: It is possible to work with or without the ratchet head function as desired. Robust and unsusceptible The full-metal construction of the DREMOMETER makes it particularly unsusceptible to grime and rough handling on construction sites, in workshops and in industry. Model Classified to DIN EN ISO 6789:2003 Type II Class A, with a factory certificate allowing for operations to be traced back. Calibrated to a permitted +/3 % deviation and better. The specifications of the standard (+/- 4 %) are exceeded. Automatic resetting The DREMOMETER gives operator an audible signal and tactile impulse and is back in operation in an instant. Working principle s b-g 6-3000 N·m tL b-f Z 6-2000 N·m 8-1000 N·m SE } ~ 8-400 N·m The quality lever chain produced in the company's own drop forge reduces the strain on the mechanics to a minimum. The proportioning of the individual levers, which are optimally attuned to each other, gives the DREMOMETER its unique precision and its long tool life. 1 Position of the lever chain without impact of force (in starting position). 2 Position of the lever chain with impact of force before the set torque is achieved. The force is transferred from the primary lever to the intermediary and final lever until the final lever slips past the so-called release lever through the sliding back of the angle-lever body. 3 Position of the lever chain when the force impacts after the torque setting is achieved. Immediate position after the clear tactile impulse and audible signal "click". On relief, the lever chain moves back into the starting position (1). 1 2 3 264 265 Maximum precision Extended tool life and long life-cycle even if used intensely. Lightweight and pleasant The aluminium housing and the ergonomically designed handgrip enable simple and safe operation over wide tightening ranges. Scale Clear dual scale N·m and lbf·in/lbf·ft on every DREMOMETER (apart from models E / EL / EK / EKL / F). › Serial number on the wrench and on the certificate for unambiguous product identification, traceable via in-house DAkkS laboratory to national standards DreMoMeTer operable without inaccuracies Regardless of where you apply the force, at the center of the handgrip or another part of the DREMOMETER, with both hands or using an extension tube, your torque setting will always be attained, without shifts in value. Due to its unique single-axis location of the centre of rotation and the output square drive, the DREMOMETER is a tool that can be operated free from errors. In contrast to conventional torque wrenches, this single lever enables tightening without shifts in the measured value and without interference caused by activation outside of the handgrip. Features Setting of the torque value to N·m or alternatively to lbf·in / lbf·ft by the non-losable hexagon key in the handgrip. The smooth-running mechanism enables the setting to be made quickly without significant force needing to be applied. 2 1 3 However, value shifts are possible when activating the DREMOMETER with special wrenches or when using wrenches with different depth gauges. A+S All DREMOMETERS are also available with locking and safely device (A+S). Pre-set value locking and safety device (A+S) eliminates the possibility of unintentional or manipulated adjustment, thereby representing more process reliability of the user Torque Tools DreMoMeTer THE orIgINAL Lightweight and sturdy, very workshop-friendly Maximum precision even when subjected to extreme continuous use. Drive Range N·m 0 5 10 15 20 40 60 80 100 150 200 300 400 500 600 700 800 1000 1250 1500 1750 2000 3000 6 – 30 N·m s t AM / AML 8 – 40 N·m s t A / AL 25 – 120 N·m Type B, BC, C with push-button release s t B / BL 40 – 200 N·m s t BC / BCL 60 – 300 N·m s t C / CL 80 – 360 N·m s t CD / CDL 110 – 550 N·m s t DS / DSL 155 – 760 N·m s t D / DL s t DR / DRL 520 – 1.000 N·m s t DX / DXL 600 – 1.500 N·m s t EK / EKL 750 – 2.000 N·m s t E / EL s t F 1.500 – 3.000 N·m 266 267 All the benefits at a single glance Type N·m lbf·in lbf·ft Scale Tube Code No. Square drive ››In the DREMOMETER, the output square drive and the pivot point of the primary lever are situated on a single axis. ››Advantage: The absolute accuracy always remains unchanged in every case. Even if the tool is operated outside of the handgrip or with an extension tube. ››This ensures a high degree of user safety; can be extended to reduce the user's working load. s AM 6 – 30 50 – 270 – 1 N·m / 10 lbf·in – 7775440 8554-01 t AML 6 – 30 50 – 270 – 1 N·m / 10 lbf·in – 7775870 8559-01 s A 8 – 40 70 – 350 – 5 N·m / 50 lbf·in – 7682000 8560-01 t AL 8 – 40 70 – 350 – 5 N·m / 50 lbf·in – 7682190 8565-01 s B 25 – 120 – 18 – 90 5 N·m / 5 lbf·in – 7683320 8561-01 t BL 25 – 120 – 18 – 90 5 N·m / 5 lbf·in – 7683400 8566-01 s BC 40 – 200 – 30 – 150 5 N·m / 5 lbf·in – 7685530 8573-01 t BCL 40 – 200 – 30 – 150 5 N·m / 5 lbf·in – 7683670 8578-00 s C 60 – 300 – 45– 220 5 N·m / 5 lbf·in – 7685450 8562-10 t CL 60 – 300 – 45– 220 5 N·m / 5 lbf·in – 7685960 8567-10 s CD 80 – 360 – 60 – 260 5 N·m / 5 lbf·in – 7688470 8570-10 t CDL 80 – 360 – 60 – 260 5 N·m / 5 lbf·in – 7688710 8575-10 s DS 110 – 550 – 80 – 400 10 N·m / 10 lbf·in – 1427156 8574-10 t DSL 110 – 550 – 80 – 400 10 N·m / 10 lbf·in – 1427121 8579-10 s D 155 – 760 – 115 – 560 10 N·m / 10 lbf·in – 7691500 8563-10 t DL 155 – 760 – 115 – 560 10 N·m / 10 lbf·in – 7691850 8568-10 s DR 155 – 760 – 115 – 560 10 N·m / 10 lbf·in 8571-80 7670180 8563-01 t DRL 155 – 760 – 115 – 560 10 N·m / 10 lbf·in 8571-80 7670500 8568-01 s DX 520 – 1.000 – 380 – 730 10 N·m / 10 lbf·in 8571-80 7694010 8571-01 t DXL 520 – 1.000 – 380 – 730 10 N·m / 10 lbf·in 8571-80 7694360 8576-01 ››All DREMOMETER models include a test certificate s EK 600 – 1.500 – – 25 N·m 8564-92 2311267 8581-01 ››Advantage: Guaranteed accuracy +/-3 % of the adjusted t EKL 600 – 1.500 – – 25 N·m 8564-92 2311291 8586-01 s E 750 – 2.000 – – 50 N·m 8564-92 / 8572-74 7695250 8564-01 t EL 750 – 2.000 – – 50 N·m 8564-92 / 8572-74 7695410 8569-01 s F 1.500 – 3.000– – 50 N·m 8564-92 / 8572-74 7717160 8572-01 Lever chain ››The integrated lever chain reduces the strain on the measuring mechanics to a minimum which means that the measuring mechanics can thus be constructed with much greater sensitivity. ››Advantage: High accuracy and a long life cycle. ››Extremely low wear Double square drive ››DREMOMETER models (except model F) having a double square drive are available on request. Apart from that, separate ratchet heads are available for almost all models (except model F). ››Advantage: Controlled counter-clockwise tightening and work in very narrow spaces are possible without any problems. Scale ››Two scales on each DREMOMETER indicate N·m and the common US unit of torque measurement (apart from types E - F). ››Advantage: Exact reading even for lbf·in or lbf·ft. ››Easy operation - fast and safe torque tightening Handgrip ››The nice-to-hold handgrip enables safe work and less operator fatigue. The full-metal construction makes DREMOMETER models particularly robust. ››Advantage: A high level of dependability even following tough long term work. Test certificate according to DIN EN ISO 6789:2003. scale value. The specification of the standard (+/- 4 %) is exceeded. GEDORE Werkzeugfabrik GmbH & Co. KG Remscheider Straße 149 42899 Remscheid · GERMANY Vertrieb DEUTSCHLAND Fon +49 2191 596-900 Fax +49 2191 596-999 zentrale@gedore.com Sales INTERNATIONAL Fon +49 2191 596-910 Fax +49 2191 596-911 www.gedore.com 2995832 01/16 Torque Tools Torque Tools 8554 AM - 8559 AML Torque wrench DREMOMETER 6-30 N·m / 50-270 lbf·in Use: Technical advantage/Function: ››Controlled screw tightening in the range 6-30 N·m / 50-270 lbf·in ››For use in almost all industrial manufacturing areas ››Lightweight and robust (as housing is made of an aluminium alloy), very workshop-friendly Features: ››Classified to DIN EN ISO 6789:2003 Type II Class A, with a factory certificate. Working accuracy: +/- 3 % tolerance of scale set torque. The specification of the standard (+/- 4 %) is exceeded. ››1/4" square drive with ball locking device DIN 3120 - A 6.3 ISO 1174 ››Automatic short-path actuation with tactile impulse and audible signal ››Dual scale with a scale graduation of 1 N·m and 10 lbf·in ››No inaccuracies whether used with both hands or held away from the handle (as for standard torque wrenches). Both the square drive and fulcrum are on an axis which ensures a high degree of user safety; can be extended to reduce the user's working load. ››Extremely low wear attributable to reduced forces in a unique lever mechanism ››Forged lever chain from our own quality forge ››Maximum precision even when subjected to extreme continuous use ››Long life cycles and tool lives ››Easy operation - fast and safe torque tightening ››Easy adjustment thanks to attractive adjusting button secured against loss at the end of the handle ››Single- and double-square drive for controlled bi-directional tightening AML AM 8554-03 Type s AM s AM s AM a" 1/4 1/4 1/4 a 6.3 6.3 6.3 s AM 1/4 6.3 t AML t AML t AML 1/4 1/4 1/4 6.3 6.3 6.3 t AML 1/4 6.3 Contents ! in plastic box ' in plastic cassette # Set mm 1 8 9 10 11 12 13 14 ; 3 ? 5.5 5 4 5 6 8 7 T20 T27 T30 & 754-00 ' 55 + 97 mm # Set INCH 1 9/32 5/16 11/32 3/8 7/16 1/2 9/16 ; 3 ? 5.5 5 4 5 6 8 7 T20 T27 T30 & 754-00 ' 55 + 97 mm ! in plastic box ' in plastic cassette # Set mm 1 8 9 10 11 12 13 14 ; 3 ? 5.5 5 4 5 6 8 7 T20 T27 T30 & 754-00 ' 55 + 97 mm # Set INCH 1 9/32 5/16 11/32 3/8 7/16 1/2 9/16 ; 3 ? 5.5 5 4 5 6 8 7 T20 T27 T30 & 754-00 ' 55 + 97 mm N·m 6-30 6-30 6-30 lbf·in 50-270 50-270 50-270 lw 206 206 206 a 30 30 30 b 15 15 15 c 268 268 268 9 1 N·m / 10 lbf·in 1 N·m / 10 lbf·in 1 N·m / 10 lbf·in 0 0.580 0.910 1.300 Code 7775440 7674090 7674170 No. 8554-01 8554-02 8554-03 6-30 50-270 206 30 15 268 1 N·m/ 10 lbf·in 1.300 7674410 8554-04 6-30 6-30 6-30 50-270 50-270 50-270 206 206 206 30 30 30 15 15 15 268 268 268 1 N·m / 10 lbf·in 1 N·m / 10 lbf·in 1 N·m / 10 lbf·in 0.580 0.910 1.300 7775870 7673790 7675060 8559-01 8559-02 8559-03 6-30 50-270 206 30 15 268 1 N·m / 10 lbf·in 1.300 7675140 8559-04 268 269 8560 A - 8565 AL Torque wrench DREMOMETER 8-40 N·m / 70-350 lbf·in Use: Technical advantage/Function: ››Lightweight and robust (as housing is made of an aluminium alloy), very workshop-friendly ››No inaccuracies whether used with both hands or held away from the handle (as for standard torque wrenches). Both the square drive and fulcrum are on an axis which ensures a high degree of user safety; can be extended to reduce the user's working load. ››Extremely low wear attributable to reduced forces in a unique lever mechanism ››Forged lever chain from our own quality forge ››Maximum precision even when subjected to extreme continuous use ››Long life cycles and tool lives ››Easy operation - fast and safe torque tightening ››Easy adjustment thanks to attractive adjusting button secured against loss at the end of the handle ››Single- and double-square drive for controlled bi-directional tightening ››Controlled screw tightening in the range 8-40 N·m / 70-350 lbf·in ››For use in almost all industrial manufacturing areas Features: ››Classified to DIN EN ISO 6789:2003 Type II Class A, with a factory certificate. Working accuracy: +/- 3 % tolerance of scale set torque. The specification of the standard (+/- 4 %) is exceeded. ››3/8" square drive with ball locking device DIN 3120 - A 10, ISO 1174 ››Automatic short-path actuation with tactile impulse and audible signal ››Dual scale with a scale graduation of 5 N·m and 50 lbf·in AL A 8560-03 Type sA sA sA a" 3/8 3/8 3/8 a 10 10 10 sA 3/8 10 t AL t AL t AL 3/8 3/8 3/8 10 10 10 t AL 3/8 10 Contents ! in plastic box " in a sheet-metal case # Set mm 1 8 10 11 13 14 15 17 19 54 5 6 8 & 754-01 ' 125 + 250 mm # Set INCH 2 3/8 7/16 1/2 9/16 19/32 5/8 11/16 5 1/4 5/16 3/8 & 754-01 ' 125 + 250 mm ! in plastic box " in a sheet-metal case # Set mm 1 8 10 11 13 14 15 17 19 54 5 6 8 & 754-01 ' 125 + 250 mm # Set INCH 2 3/8 7/16 1/2 9/16 19/32 5/8 11/16 5 1/4 5/16 3/8 & 754-01 ' 125 + 250 mm N·m 8-40 8-40 8-40 lbf·in 70-350 70-350 70-350 lw 262 262 262 a 30 30 30 b 17.5 17.5 17.5 c 338 338 338 9 5 N·m / 50 lbf·in 5 N·m / 50 lbf·in 5 N·m / 50 lbf·in 0 1.0 2.2 3.1 Code 7682000 7682270 7682430 No. 8560-01 8560-02 8560-03 8-40 70-350 262 30 17.5 338 5 N·m / 50 lbf·in 3.0 7683160 8560-04 8-40 8-40 8-40 70-350 70-350 70-350 262 262 262 30 30 30 17.5 17.5 17.5 338 338 338 5 N·m / 50 lbf·in 5 N·m / 50 lbf·in 5 N·m / 50 lbf·in 1.0 2.2 3.1 7682190 7682350 7682940 8565-01 8565-02 8565-03 8-40 70-350 262 30 17.5 338 5 N·m / 50 lbf·in 3.0 7683240 8565-04 Torque Tools 8561 B - 8566 BL Torque wrench DREMOMETER 25-120 N·m / 18-90 lbf·ft Use: Technical advantage/Function: ››Lightweight and robust (as housing is made of an aluminium alloy), very workshop-friendly ››No inaccuracies whether used with both hands or held away from the handle (as for standard torque wrenches). Both the square drive and fulcrum are on an axis which ensures a high degree of user safety; can be extended to reduce the user's working load. ››Extremely low wear attributable to reduced forces in a unique lever mechanism ››Forged lever chain from our own quality forge ››Maximum precision even when subjected to extreme continuous use ››Long life cycles and tool lives ››Easy operation - fast and safe torque tightening ››Easy adjustment thanks to attractive adjusting button secured against loss at the end of the handle ››Single- and double-square drive for controlled bi-directional tightening ››Controlled screw tightening in the range 25-120 N·m / 18-90 lbf·ft ››For use in almost all industrial manufacturing areas Features: ››Classified to DIN EN ISO 6789:2003 Type II Class A, with a factory certificate. Working accuracy: +/- 3 % tolerance of scale set torque. The specification of the standard (+/- 4 %) is exceeded. ››1/2" square drive with ball locking device DIN 3120 - A 12.5, ISO 1174 ››Automatic short-path actuation with tactile impulse and audible signal ››Dual scale with a scale graduation of 5 N·m and 5 lbf·ft ››With push-button release BL B BR 8561-03 Type a" s BR 1/2 a 12.5 sB sB sB 1/2 1/2 1/2 12.5 12.5 12.5 sB 1/2 12.5 t BL t BL t BL 1/2 1/2 1/2 12.5 12.5 12.5 t BL 1/2 12.5 Contents ! in plastic box with ALU extension tube ! in plastic box " in a sheet-metal case # Set mm 1 11 13 14 17 19 22 24 5 6 8 10 12 & 754-02 ' 76 + 125 + 250 mm # Set INCH 2 7/16 1/2 9/16 19/32 5/8 11/16 3/4 25/32 13/16 7/8 15/16 1" 5 5/16 3/8 1/2" & 754-02 ' 76 + 125 + 250 mm ! in plastic box " in a sheet-metal case # Set mm 1 11 13 14 17 19 22 24 5 6 8 10 12 & 754-02 ' 76 + 125 + 250 mm # Set INCH 2 7/16 1/2 9/16 19/32 5/8 11/16 3/4 25/32 13/16 7/8 15/16 1" 5 5/16 3/8 1/2" & 754-02 ' 76 + 125 + 250 mm N·m 25-120 lbf·ft 18-90 lw 373 a 30 b 17.5 c 462 Tube 9 8577-350 5 N·m / 5 lbf·ft 0 2.2 Code 2926989 No. 8561-001 25-120 25-120 25-120 18-90 18-90 18-90 373 373 373 30 30 30 17.5 17.5 17.5 462 462 462 – – – 5 N·m / 5 lbf·ft 5 N·m / 5 lbf·ft 5 N·m / 5 lbf·ft 1.5 2.8 4.7 7683320 7683830 7684480 8561-01 8561-02 8561-03 25-120 18-90 373 30 17.5 462 – 5 N·m / 5 lbf·ft 5.3 7684990 8561-04 25-120 25-120 25-120 18-90 18-90 18-90 373 373 373 30 30 30 17.5 17.5 17.5 462 462 462 – – – 5 N·m / 5 lbf·ft 5 N·m / 5 lbf·ft 5 N·m / 5 lbf·ft 1.5 2.8 4.7 7683400 7684130 7684640 8566-01 8566-02 8566-03 25-120 18-90 373 30 17.5 462 – 5 N·m / 5 lbf·ft 5.3 7685100 8566-04 270 271 8573 BC - 8578 BCL Torque wrench DREMOMETER 40-200 N·m / 30-150 lbf·ft Use: Technical advantage/Function: ››Controlled screw tightening in the range 40-200 N·m / 30-150 lbf·ft ››For use in almost all industrial manufacturing areas ››Lightweight and robust (as housing is made of an aluminium alloy), very workshop-friendly ››No inaccuracies whether used with both hands or held away from the handle Features: ››Classified to DIN EN ISO 6789:2003 Type II Class A, with a factory certificate. Working accuracy: +/- 3 % tolerance of scale set torque. The specification of the standard (+/- 4 %) is exceeded. ››1/2" square drive with ball locking device DIN 3120 - A 12.5, ISO 1174 ››Automatic short-path actuation with tactile impulse and audible signal ››Dual scale with a scale graduation of 5 N·m and 5 lbf·ft ››With push-button release (as for standard torque wrenches). Both the square drive and fulcrum are on an axis which ensures a high degree of user safety; can be extended to reduce the user's working load. ››Extremely low wear attributable to reduced forces in a unique lever mechanism ››Forged lever chain from our own quality forge ››Maximum precision even when subjected to extreme continuous use ››Long life cycles and tool lives ››Easy operation - fast and safe torque tightening ››Easy adjustment thanks to attractive adjusting button secured against loss at the end of the handle ››Single- and double-square drive for controlled bi-directional tightening BCL BC 8573-03 Type s BC s BC s BC a" 1/2 1/2 1/2 a 12.5 12.5 12.5 s BC 1/2 12.5 t BCL t BCL t BCL 1/2 1/2 1/2 12.5 12.5 12.5 t BCL 1/2 12.5 Contents ! in plastic box " in a sheet-metal case # Set mm 1 11 13 14 17 19 21 22 24 27 5 6 8 10 12 & 754-02 ' 125 + 250 mm # Set INCH 2 1/2 9/16 5/8 11/16 3/4 13/16 7/8" 5 5/16 3/8 1/2 9/16" & 754-02 ' 125 + 250 mm ! in plastic box " in a sheet-metal case # Set mm 1 11 13 14 17 19 21 22 24 27 5 6 8 10 12 & 754-02 ' 125 + 250 mm # Set INCH 2 1/2 9/16 5/8 11/16 3/4 13/16 7/8" 5 5/16 3/8 1/2 9/16" & 754-02 ' 125 + 250 mm N·m 40-200 40-200 40-200 lbf·ft 30-150 30-150 30-150 lw 463 463 463 a 30 30 30 b 17.5 17.5 17.5 c 551 551 551 9 5 N·m / 5 lbf·ft 5 N·m / 5 lbf·ft 5 N·m / 5 lbf·ft 0 1.4 3.5 5.1 Code 7685530 7683590 7683910 No. 8573-00 8573-02 8573-03 40-200 30-150 463 30 17.5 551 5 N·m / 5 lbf·ft 4.9 7684720 8573-04 40-200 40-200 40-200 30-150 30-150 30-150 463 463 463 30 30 30 17.5 17.5 17.5 551 551 551 5 N·m / 5 lbf·ft 5 N·m / 5 lbf·ft 5 N·m / 5 lbf·ft 1.3 3.5 5.1 7683670 7683750 7684050 8578-00 8578-02 8578-03 40-200 30-150 463 30 17.5 551 5 N·m / 5 lbf·ft 4.9 7684210 8578-04 Torque Tools 8562 C - 8567 CL Torque wrench DREMOMETER 60-300 N·m / 45-220 lbf·ft Use: Technical advantage/Function: ››Controlled screw tightening in the range 60-300 N·m / 45-220 lbf·ft ››For use in almost all industrial manufacturing areas ››Lightweight and robust (as housing is made of an aluminium alloy), very workshop-friendly ››No inaccuracies whether used with both hands or held away from the handle Features: ››Classified to DIN EN ISO 6789:2003 Type II Class A, with a factory certificate. Working accuracy: +/- 3 % tolerance of scale set torque. The specification of the standard (+/- 4 %) is exceeded. ››1/2" square drive with ball locking device DIN 3120 - A 12.5, ISO 1174 ››Automatic short-path actuation with tactile impulse and audible signal ››Dual scale with a scale graduation of 5 N·m and 5 lbf·ft ››With push-button release (as for standard torque wrenches). Both the square drive and fulcrum are on an axis which ensures a high degree of user safety; can be extended to reduce the user's working load. ››Extremely low wear attributable to reduced forces in a unique lever mechanism ››Forged lever chain from our own quality forge ››Maximum precision even when subjected to extreme continuous use ››Long life cycles and tool lives ››Easy operation - fast and safe torque tightening ››Easy adjustment thanks to attractive adjusting button secured against loss at the end of the handle ››Single- and double-square drive for controlled bi-directional tightening CL C 8562-30 Type a" s CR 1/2 a 12.5 sC sC sC 1/2 1/2 1/2 12.5 12.5 12.5 sC 1/2 12.5 t CL t CL t CL 1/2 1/2 1/2 12.5 12.5 12.5 t CL 1/2 12.5 Contents ! in plastic box with ALU extension tube ! in plastic box " in a sheet-metal case # Set mm 1 17 19 22 24 27 30 32 5 8 10 12 14 & 754-02 ' 76 + 125 + 250 mm # Set INCH 2 3/4 25/32 13/16 7/8 15/16 1" 1.1/16 1.1/8 1.1/4" 5 3/8 1/2 9/16 5/8" & 754-02 ' 76 + 125 + 250 mm ! in plastic box " in a sheet-metal case # Set mm 1 17 19 22 24 27 30 32 5 8 10 12 14 & 754-02 ' 76 + 125 + 250 mm # Set INCH 2 3/4 25/32 13/16 7/8 15/16 1" 1.1/16 1.1/8 1.1/4" 5 3/8 1/2 9/16 5/8" & 754-02 ' 76 + 125 + 250 mm CR N·m 60-300 lbf·ft 45-220 lw 529 a 30 b 17.5 c 617 Tube 9 8577-700 5 N·m / 5 lbf·ft 0 2.7 Code 2926997 No. 8562-001 60-300 60-300 60-300 45-220 45-220 45-220 529 529 529 30 30 30 17.5 17.5 17.5 617 617 617 – – – 5 N·m / 5 lbf·ft 5 N·m / 5 lbf·ft 5 N·m / 5 lbf·ft 2.0 3.6 6.0 7685450 7686340 7687070 8562-10 8562-20 8562-30 60-300 45-220 529 30 17.5 617 – 5 N·m / 5 lbf·ft 6.2 7687820 8562-40 60-300 60-300 60-300 45-220 45-220 45-220 529 529 529 30 30 30 17.5 17.5 17.5 617 617 617 – – – 5 N·m / 5 lbf·ft 5 N·m / 5 lbf·ft 5 N·m / 5 lbf·ft 2.0 3.6 6.0 7685960 7686690 7687310 8567-10 8567-20 8567-30 60-300 45-220 529 30 17.5 617 – 5 N·m / 5 lbf·ft 6.2 7688120 8567-40 272 273 8570 CD - 8575 CDL Torque wrench DREMOMETER 80-360 N·m / 60-260 lbf·ft Use: Technical advantage/Function: ››Controlled screw tightening in the range 80-360 N·m / 60-260 lbf·ft ››For use in almost all industrial manufacturing areas ››Lightweight and robust (as housing is made of an aluminium alloy), very workshop-friendly ››No inaccuracies whether used with both hands or held away from the handle Features: ››Classified to DIN EN ISO 6789:2003 Type II Class A, with a factory certificate. Working accuracy: +/- 3 % tolerance of scale set torque. The specification of the standard (+/- 4 %) is exceeded. ››3/4" square drive with pin-locking mechanism as per DIN 3120 - B 20, ISO 1174 ››Automatic short-path actuation with tactile impulse and audible signal ››Dual scale with a scale graduation of 5 N·m and 5 lbf·ft (as for standard torque wrenches). Both the square drive and fulcrum are on an axis which ensures a high degree of user safety; can be extended to reduce the user's working load. ››Extremely low wear attributable to reduced forces in a unique lever mechanism ››Forged lever chain from our own quality forge ››Maximum precision even when subjected to extreme continuous use ››Long life cycles and tool lives ››Easy operation - fast and safe torque tightening ››Easy adjustment thanks to attractive adjusting button secured against loss at the end of the handle ››Single- and double-square drive for controlled bi-directional tightening CDL CD 8570-30 Type a" s CDR 3/4 a 20 s CD s CD s CD 3/4 3/4 3/4 20 20 20 s CD 3/4 20 t CDL t CDL t CDL 3/4 3/4 3/4 20 20 20 t CDL 3/4 20 Contents ! in plastic box with ALU extension tube ! in plastic box " in a sheet-metal case # Set mm 1 19 22 24 27 30 32 & 754-04 ' 200 + 400 mm # Set INCH 2 7/8 15/16 1" 1.1/8 1.1/4 1.3/8 1.1/2 1.5/8" & 754-04 ' 200 + 400 mm ! in plastic box " in a sheet-metal case # Set mm 1 19 22 24 27 30 32 & 754-04 ' 200 + 400 mm # Set INCH 2 7/8 15/16 1" 1.1/8 1.1/4 1.3/8 1.1/2 1.5/8" & 754-04 ' 200 + 400 mm CDR N·m 80-360 lbf·ft 60-260 lw 624 a 30 b 22.5 c 717 Tube 9 8577-700 5 N·m / 5 lbf·ft 0 3.1 Code 2927004 No. 8570-001 80-360 80-360 80-360 60-260 60-260 60-260 624 624 624 30 30 30 22.5 22.5 22.5 717 717 717 – – – 5 N·m / 5 lbf·ft 5 N·m / 5 lbf·ft 5 N·m / 5 lbf·ft 2.4 6.2 11.0 7688470 7689280 7689950 8570-10 8570-20 8570-30 80-360 60-260 624 30 22.5 717 – 5 N·m / 5 lbf·ft 11.3 7690530 8570-40 80-360 80-360 80-360 60-260 60-260 60-260 624 624 624 30 30 30 22.5 22.5 22.5 717 717 717 – – – 5 N·m / 5 lbf·ft 5 N·m / 5 lbf·ft 5 N·m / 5 lbf·ft 2.4 6.2 11.0 7688710 7689520 7690290 8575-10 8575-20 8575-30 80-360 60-260 624 30 22.5 717 – 5 N·m / 5 lbf·ft 11.3 7691180 8575-40 Torque Tools 8574 DS - 8579 DSL Torque wrench DREMOMETER 110-550 N·m / 80-400 lbf·ft Use: Technical advantage/Function: ››Controlled screw tightening in the range 110-550 N·m / 80-400 lbf·ft ››For use in almost all industrial manufacturing areas ››Lightweight and robust (as housing is made of an aluminium alloy), very workshop-friendly Features: ››Classified to DIN EN ISO 6789:2003 Type II Class A, with a factory certificate. Working accuracy: +/- 3 % tolerance of scale set torque. The specification of the standard (+/- 4 %) is exceeded. ››3/4" square drive with pin-locking mechanism DIN 3120 - B 20, ISO 1174 ››Automatic short-path actuation with tactile impulse and audible signal ››Dual scale with a scale graduation of 10 N·m and 10 lbf·ft ››No inaccuracies whether used with both hands or held away from the handle (as for standard torque wrenches). Both the square drive and fulcrum are on an axis which ensures a high degree of user safety; can be extended to reduce the user's working load. ››Extremely low wear attributable to reduced forces in a unique lever mechanism ››Forged lever chain from our own quality forge ››Maximum precision even when subjected to extreme continuous use ››Long life cycles and tool lives ››Easy operation - fast and safe torque tightening ››Easy adjustment thanks to attractive adjusting button secured against loss at the end of the handle ››Single- and double-square drive for controlled bi-directional tightening DSL DS Type s DS s DS t DSL t DSL a" 3/4 3/4 3/4 3/4 a 20 20 20 20 920 / 922 Contents ! in plastic box " in a sheet-metal case ! in plastic box " in a sheet-metal case N·m 110-550 110-550 110-550 110-550   5 65 lbf·ft 80-400 80-400 80-400 80-400 754 lw 719 719 719 719 a 35 35 35 35 b 22.5 22.5 22.5 22.5 c 812 812 812 812   2 81 9 10 N·m / 10 lbf·ft 10 N·m / 10 lbf·ft 10 N·m / 10 lbf·ft 10 N·m / 10 lbf·ft 0 2.9 6.7 2.9 6.7 DVV-40ZRS Code 1427156 1436112 1427121 1436120 No. 8574-10 8574-20 8579-10 8579-20   3 35 274 275 8563 D - 8568 DL Torque wrench DREMOMETER 155-760 N·m / 115-560 lbf·ft Use: Technical advantage/Function: ››Controlled screw tightening in the range 155-760 N·m / 115-560 lbf·ft ››For use in almost all industrial manufacturing areas ››Lightweight and robust (as housing is made of an aluminium alloy), very workshop-friendly Features: ››Classified to DIN EN ISO 6789:2003 Type II Class A, with a factory certificate. Working accuracy: +/- 3 % tolerance of scale set torque. The specification of the standard (+/- 4 %) is exceeded. ››3/4" square drive with pin-locking mechanism DIN 3120 - B 20, ISO 1174 ››Automatic short-path actuation with tactile impulse and audible signal ››Dual scale with a scale graduation of 10 N·m and 10 lbf·ft ››No inaccuracies whether used with both hands or held away from the handle (as for standard torque wrenches). Both the square drive and fulcrum are on an axis which ensures a high degree of user safety; can be extended to reduce the user's working load. ››Extremely low wear attributable to reduced forces in a unique lever mechanism ››Forged lever chain from our own quality forge ››Maximum precision even when subjected to extreme continuous use ››Long life cycles and tool lives ››Easy operation - fast and safe torque tightening ››Easy adjustment thanks to attractive adjusting button secured against loss at the end of the handle ››Single- and double-square drive for controlled bi-directional tightening DL D 8563-30 Type sD sD sD a" 3/4 3/4 3/4 a 20 20 20 sD 3/4 20 t DL t DL t DL 3/4 3/4 3/4 20 20 20 t DL 3/4 20 Contents ! in plastic box " in a sheet-metal case # Set mm 1 22 24 27 30 32 36 41 46 & 754-04 ' 200 + 400 mm # Set INCH 2 1" 1.1/8 1.1/4 1.5/16 1.3/8 1.7/16 1.1/2 1.5/8 1.3/4 1.13/16 1.7/8 2" & 754-04 ' 200 + 400 mm ! in plastic box " in a sheet-metal case # Set mm 1 22 24 27 30 32 36 41 46 & 754-04 ' 200 + 400 mm # Set INCH 2 1" 1.1/8 1.1/4 1.5/16 1.3/8 1.7/16 1.1/2 1.5/8 1.3/4 1.13/16 1.7/8 2" & 754-04 ' 200 + 400 mm N·m 155-760 155-760 155-760 lbf·ft 115-560 115-560 115-560 lw 719 719 719 a 35 35 35 b 22.5 22.5 22.5 c 812 812 812 9 10 N·m / 10 lbf·ft 10 N·m / 10 lbf·ft 10 N·m / 10 lbf·ft 0 3.2 7.7 13.6 Code 7691500 7692070 7692660 No. 8563-10 8563-20 8563-30 155-760 115-560 719 35 22.5 812 10 N·m / 10 lbf·ft 13.3 7693200 8563-40 155-760 155-760 155-760 115-560 115-560 115-560 719 719 719 35 35 35 22.5 22.5 22.5 812 812 812 10 N·m / 10 lbf·ft 10 N·m / 10 lbf·ft 10 N·m / 10 lbf·ft 3.2 7.7 13.6 7691850 7692310 7692900 8568-10 8568-20 8568-30 155-760 115-560 719 35 22.5 812 10 N·m / 10 lbf·ft 13.3 7693550 8568-40 Torque Tools 8563 DR - 8568 DRL Torque wrench DREMOMETER 155-760 N·m / 115-560 lbf·ft Use: ››Controlled screw tightening in the range 155-760 N·m / 115-560 lbf·ft ››For use in almost all industrial manufacturing areas Features: ››Classified to DIN EN ISO 6789:2003 Type II Class A, with a factory certificate. Working accuracy: +/- 3 % tolerance of scale set torque. The specification of the standard (+/- 4 %) is exceeded. ››3/4" square drive with pin-locking mechanism DIN 3120 - B 20, ISO 1174 ››Automatic short-path actuation with tactile impulse and audible signal ››Dual scale with a scale graduation of 10 N·m and 10 lbf·ft Technical advantage/Function: ››Lightweight and robust (as housing is made of an aluminium alloy), very workshop-friendly ››No inaccuracies whether used with both hands or held away from the handle (as for standard torque wrenches). Both the square drive and fulcrum are on an axis which ensures a high degree of user safety; can be extended to reduce the user's working load. ››Extremely low wear attributable to reduced forces in a unique lever mechanism ››Forged lever chain from our own quality forge ››Maximum precision even when subjected to extreme continuous use ››Long life cycles and tool lives ››Easy operation - fast and safe torque tightening ››Easy adjustment thanks to attractive adjusting button secured against loss at the end of the handle ››Single- and double-square drive for controlled bi-directional tightening DRL DR 8563-03 DR-LKW Type s DR s DR s DR s DR t DRL t DRL t DRL t DRL t DRLKW a " a Contents 3/4 20 ! in plastic box with extension tube 3/4 20 " in a sheet-metal case with extension tube 3/4 20 # Set mm 1 22 24 27 30 32 36 41 46 & 754-04 ' 200 + 400 mm 3/4 20 # Set INCH 2 1" 1.1/8 1.1/4 1.5/16 1.3/8 1.7/16 1.1/2 1.5/8 1.3/4 1.13/16 1.7/8 2" & 754-04 ' 200 + 400 mm 3/4 20 ! in plastic box with extension tube 3/4 20 " in a sheet-metal case with extension tube 3/4 20 # Set mm 1 22 24 27 30 32 36 41 46 & 754-04 ' 200 + 400 mm 3/4 20 # Set INCH 2 1" 1.1/8 1.1/4 1.5/16 1.3/8 1.7/16 1.1/2 1.5/8 1.3/4 1.13/16 1.7/8 2" & 754-04 ' 200 + 400 mm 3/4 20 # Set mm 1 27 30 32 & 754-04 ' 400 mm N·m lbf·ft lw 155-760 115-560 1,290.5 a 35 b 22.5 c 812 d 1403 e 762 Tube 9 8571-80 10 N·m / 10 lbf·ft No. 0 Code 5.0 7670180 8563-01 155-760 115-560 1,290.5 35 22.5 812 1403 762 8571-80 10 N·m / 10 lbf·ft 8.8 155-760 115-560 1,290.5 35 22.5 812 1403 762 8571-80 10 N·m / 10 lbf·ft 14.4 7670340 8563-03 155-760 115-560 1,290.5 35 22.5 812 1403 762 8571-80 10 N·m / 10 lbf·ft 16.7 7670420 8563-04 155-760 115-560 1,290.5 35 22.5 812 1403 762 8571-80 10 N·m / 10 lbf·ft 5.0 7670500 8568-01 155-760 115-560 1,290.5 35 22.5 812 1403 762 8571-80 10 N·m / 10 lbf·ft 8.8 7670690 8568-02 155-760 115-560 1,290.5 35 22.5 812 1403 762 8571-80 10 N·m / 10 lbf·ft 14.4 7670770 8568-03 155-760 115-560 1,290.5 35 22.5 812 1403 762 8571-80 10 N·m / 10 lbf·ft 16.7 7670850 8568-04 155-760 115-560 1,290.5 35 22.5 812 1403 762 8571-80 10 N·m / 10 lbf·ft 12.3 7670930 8568-35 7670260 8563-02 276 277 8571 DX - 8576 DXL Torque wrench DREMOMETER 520-1000 N·m / 380-730 lbf·ft Use: Technical advantage/Function: ››Controlled screw tightening in the range 520-1000 N·m / 380-730 lbf·ft ››For use in almost all industrial manufacturing areas ››Lightweight and robust (as housing is made of an aluminium alloy), very workshop-friendly ››No inaccuracies whether used with both hands or held away from the handle Features: ››Classified to DIN EN ISO 6789:2003 Type II Class A, with a factory certificate. Working accuracy: +/- 3 % tolerance of scale set torque. The specification of the standard (+/- 4 %) is exceeded. ››3/4" square drive with pin-locking mechanism DIN 3120 - B 20, ISO 1174 ››Automatic short-path actuation with tactile impulse and audible signal ››Dual scale with a scale graduation of 10 N·m and 10 lbf·ft (as for standard torque wrenches). Both the square drive and fulcrum are on an axis which ensures a high degree of user safety; can be extended to reduce the user's working load. ››Extremely low wear attributable to reduced forces in a unique lever mechanism ››Forged lever chain from our own quality forge ››Maximum precision even when subjected to extreme continuous use ››Long life cycles and tool lives ››Easy operation - fast and safe torque tightening ››Easy adjustment thanks to attractive adjusting button secured against loss at the end of the handle ››Single- and double-square drive for controlled bi-directional tightening DXL DX 8571-03 Type a " a Contents s DX 3/4 20 ! in plastic box with ALU extension tube s DX 3/4 20 " in a sheet-metal case with ALU extension tube s DX 3/4 20 # Set mm 1 30 32 36 41 46 50 & 754-04 ' 200 + 400 mmm s DX 3/4 20 # Set INCH 2 1.1/8 1.1/4 1.3/8 1.1/2 1.3/4 1.7/8" & 754-04 ' 200 + 400 mm t DXL 3/4 20 ! in plastic box with ALU extension tube t DXL 3/4 20 " in a sheet-metal case with ALU extension tube t DXL 3/4 20 # Set mm 1 30 32 36 41 46 50 & 754-04 ' 200 + 400 mm t DXL 3/4 20 # Set INCH 2 1.1/8 1.1/4 1.3/8 1.1/2 1.3/4 1.7/8" & 754-04 ' 200 + 400 mm N·m 520-1000 lbf·ft lw 380-730 1,290.5 a 35 b 22.5 c 812 d 1403 e 762 Tube 8571-80 9 10 N·m / 10 lbf·ft 0 Code 5.6 7694010 No. 8571-01 520-1000 380-730 1,290.5 35 22.5 812 1403 762 8571-80 10 N·m / 10 lbf·ft 10.0 7694520 8571-02 520-1000 380-730 1,290.5 35 22.5 812 1403 762 8571-80 10 N·m / 10 lbf·ft 16.8 7694870 8571-03 520-1000 380-730 1,290.5 35 22.5 812 1403 762 8571-80 10 N·m / 10 lbf·ft 16.0 7695170 8571-04 520-1000 380-730 1,290.5 35 22.5 812 1403 762 8571-80 10 N·m / 10 lbf·ft 5.6 7694360 8576-01 520-1000 380-730 1,290.5 35 22.5 812 1403 762 8571-80 10 N·m / 10 lbf·ft 10.0 7694600 8576-02 520-1000 380-730 1,290.5 35 22.5 812 1403 762 8571-80 10 N·m / 10 lbf·ft 16.8 7694950 8576-03 520-1000 380-730 1,290.5 35 22.5 812 1403 762 8571-80 10 N·m / 10 lbf·ft 16.0 7695330 8576-04 Torque Tools 8581 EK - 8586 EKL Torque wrench DREMOMETER 600-1500 N·m Use: Technical advantage/Function: ››Controlled screw tightening in the range 600-1500 N·m ››For use in almost all industrial manufacturing areas ››Lightweight and robust (as housing is made of an aluminium alloy), very workshop-friendly ››No inaccuracies whether used with both hands or held away from the handle Features: ››Classified to DIN EN ISO 6789:2003 Type II Class A, with a factory certificate. Working accuracy: +/- 3 % tolerance of scale set torque. The specification of the standard (+/- 4 %) is exceeded. ››1" square drive with pin-locking mechanism DIN 3120 - B25, ISO 1174 ››Automatic short-path actuation with tactile impulse and audible signal ››Single scale with a scale graduation of 25 N·m (as for standard torque wrenches). Both the square drive and fulcrum are on an axis which ensures a high degree of user safety; can be extended to reduce the user's working load. ››Extremely low wear attributable to reduced forces in a unique lever mechanism ››Forged lever chain from our own quality forge ››Maximum precision even when subjected to extreme continuous use ››Long life cycles and tool lives ››Easy operation - fast and safe torque tightening ››Easy adjustment thanks to attractive adjusting button secured against loss at the end of the handle ››Single- and double-square drive for controlled bi-directional tightening EKL EK 8581-02 Type s EK a" a 1 25 s EK 1 25 s EK 1 25 t EKL 1 25 t EKL 1 25 t EKL 1 25 Contents ! with 1 extension tube " in sheet-metal case with 1 extension tube # Set mm 2 36 41 46 50 55 60 65 70 & 754-06 ' 200 + 400 mm ! with 1 extension tube " in sheet-metal case with 1 extension tube # Set mm 2 36 41 46 50 55 60 65 70 & 754-06 ' 200 + 400 mm N·m 600-1500 lw 1473 a 40 b 30 c 932 d 1608 e 925 Tube 8564-92 9 0 25 N·m 10.8 Code 2311267 No. 8581-01 600-1500 1473 40 30 932 1608 925 8564-92 25 N·m 24.3 2311275 8581-02 600-1500 1473 40 30 932 1608 925 8564-92 25 N·m 42.4 2311283 8581-03 600-1500 1473 40 30 932 1608 925 8564-92 25 N·m 10.8 2311291 8586-01 600-1500 1473 40 30 932 1608 925 8564-92 25 N·m 24.3 2311305 8586-02 600-1500 1473 40 30 932 1608 925 8564-92 25 N·m 42.4 2311313 8586-03 278 279 8564 E - 8569 EL Torque wrench DREMOMETER 750-2000 N·m Use: Technical advantage/Function: ››Controlled screw tightening in the range 750-2000 N·m ››For use in almost all industrial manufacturing areas ››Lightweight and robust (as housing is made of an aluminium alloy), very workshop-friendly ››No inaccuracies whether used with both hands or held away from the handle Features: ››Classified to DIN EN ISO 6789:2003 Type II Class A, with a factory certificate. Working accuracy: +/- 3 % tolerance of scale set torque. The specification of the standard (+/- 4 %) is exceeded. ››1" square drive with pin-locking mechanism DIN 3120 - B25, ISO 1174 ››Automatic short-path actuation with tactile impulse and audible signal ››Single scale with a scale graduation of 50 N·m (as for standard torque wrenches). Both the square drive and fulcrum are on an axis which ensures a high degree of user safety; can be extended to reduce the user's working load. ››Extremely low wear attributable to reduced forces in a unique lever mechanism ››Forged lever chain from our own quality forge ››Maximum precision even when subjected to extreme continuous use ››Long life cycles and tool lives ››Easy operation - fast and safe torque tightening ››Easy adjustment thanks to attractive adjusting button secured against loss at the end of the handle ››Single- and double-square drive for controlled bi-directional tightening EL E 8564-02 Type a " sE 1 a 25 sE 1 25 sE 1 25 t EL 1 25 t EL 1 25 t EL 1 25 Contents ! with 2 extension tubes " in sheet-metal case with 2 extension tubes # Set mm 2 36 41 46 50 55 60 65 70 & 754-06 ' 200 + 400 mm ! with 2 extension tubes " in sheet-metal case with 2 extension tubes # Set mm 2 36 41 46 50 55 60 65 70 & 754-06 ' 200 + 400 mm N·m 750-2000 lw 2213 a 40 b 30.0 c 932 d 2353 e 925 f 745 Tube 8564-92 / 8572-74 9 0 Code 50 N·m 12.0 7695250 No. 8564-01 750-2000 2213 40 30.0 932 2353 925 745 8564-92 / 8572-74 50 N·m 21.2 7695680 8564-02 750-2000 2213 40 30.0 932 2353 925 745 8564-92 / 8572-74 50 N·m 42.4 7696060 8564-03 750-2000 2213 40 30.0 932 2353 925 745 8564-92 / 8572-74 50 N·m 12.0 7695410 8569-01 750-2000 2213 40 30.0 932 2353 925 745 8564-92 / 8572-74 50 N·m 21.4 7695840 8569-02 750-2000 2213 40 30.0 932 2353 925 745 8564-92 / 8572-74 50 N·m 42.4 7696140 8569-03 Torque Tools 8572 F Torque wrench DREMOMETER 1500-3000 N·m Use: Technical advantage/Function: ››Controlled screw tightening in the range 1500-3000 N·m ››For use in almost all industrial manufacturing areas ››Lightweight and robust (as housing is made of an aluminium alloy), very workshop-friendly ››No inaccuracies whether used with both hands or held away from the handle Features: ››Classified to DIN EN ISO 6789:2003 Type II Class A, with a factory certificate. Working accuracy: +/- 3 % tolerance of scale set torque. The specification of the standard (+/- 4 %) is exceeded. ››1.1/2" square drive with pin-locking mechanism DIN 3121 - F 40, ISO 1174 ››Automatic short-path actuation with tactile impulse and audible signal ››Single scale with scale graduation 50 N·m (as for standard torque wrenches). Both the square drive and fulcrum are on an axis which ensures a high degree of user safety; can be extended to reduce the user's working load. ››Extremely low wear attributable to reduced forces in a unique lever mechanism ››Forged lever chain from our own quality forge ››Maximum precision even when subjected to extreme continuous use ››Long life cycles and tool lives ››Easy operation - fast and safe torque tightening ››Easy adjustment thanks to attractive adjusting button secured against loss at the end of the handle ››Single square drive for controlled clockwise tightening F 8572-02 Type a " s F 1.1/2 a 40 s F 1.1/2 40 Contents ! with 2 extension tubes " in sheet-metal case with 2 extension tubes N·m 1500-3000 lw 2309 a 40 b 35.0 c 1037 d 2454 e 925 f 745 Tube 8564-92 / 8572-74 9 50 N·m 0 15.0 Code 7717160 No. 8572-01 1500-3000 2309 40 35.0 1037 2454 925 745 8564-92 / 8572-74 50 N·m 21.2 7717240 8572-02 Technical information After being used, torque wrenches should where possible be turned back to the minimum scale value. This helps to preserve the springs and ensures a longer product life cycle with high precision. O n request, all torque wrenches can be factory pre-set -at extra chargeWhen ordering, please specify the N·m value 280 281 Accessories DREMOMETER Ratchet heads DREMOMETER 754 ››Ratchet head no. 754 can only be used in combination with the DREMOMETER. Please note the right direction of rotation by the ratchet head when ordering. There are separate models for clockwise or counter-clockwise rotation. Ratchet head nos. 754-11 to 754-16 (counter-clockwise) can only be used with the DREMOMETER with double square drive. 754 Ratchet head DREMOMETER Use: ››Enables controlled torque tightening in combination with a DREMOMETER torque wrench (Type MINI - E) Features: ››Fine-pitched, sturdy ratchet head ››With 1/4", 3/8", 1/2", 3/4" or 1" output square drive ››Clockwise models (no. 754-00 to -06) ››Anti-clockwise models (no. 754-11 to -16) ››Made of chrome-vanadium steel Scope of delivery: ››Ratchet head ››Single packed in poly-bag 1/4" 3/8" 1/2" 3/4" 1" * Max. continuous load of ratchet according to DIN EN ISO 6789:2003 and/or maximum load of cavity Q" 1/4 3/8 1/2 3/4 1 3/8 1/2 3/4 1 H 20 28 36 56 62 28 36 56 62 a" 1/4 3/8 1/2 3/4 1 3/8 1/2 3/4 1 , 24 35 46 65 73 35 46 65 73 A° 18,0 20,0 7,5 10,0 10,0 20,0 7,5 10,0 10,0 Use MINI, AM A B, BC, C CD, DS, D, DR, DX E / EK AL BL, BCL, CL CDL, DSL, DL, DRL, DXL EL / EKL Execution clockwise clockwise clockwise clockwise clockwise counter-clockwise counter-clockwise counter-clockwise counter-clockwise 8564 - 8572 Extension tubes for DREMOMETER E - F Use: ››Spare extension tube for torque wrench series DREMOMETER E - F ››To enable high torque values by means of extending the lever arm Features: ››Guarantees proof connection to the Continuous load* 1/4" = 30 N·m 3/8" = 135 N·m 1/2" = 340 N·m 3/4" = 1000 N·m 1" = 2000 N·m 3/8" = 135 N·m 1/2" = 340 N·m 3/4" = 1000 N·m 1" = 2000 N·m Code 7680490 7680570 7680650 7680730 7680810 7686770 7686850 7686930 7687150 0 0.054 0.150 0.350 1.000 1.800 0.150 0.350 1.000 1.800 8571 - 8577 Extension tubes ALU for DREMOMETER A - CD DREMOMETER ››Ideal for extending the lever arm ››Made from high-grade, galvanised steel Scope of delivery: ››Extension tube ››Single packed in poly-bag Use: ››Spare extension tube for torque wrench series DREMOMETER A - CD, DR, DX ››To enable high torque values by means of extending the lever arm Features: ››Guarantees proof connection to the DREMOMETER No. 754-00 754-01 754-02 754-04 754-06 754-11 754-12 754-14 754-16 neW ››Ideal for extending the lever arm ››Made from high-grade aluminium with anodised locknut - extremely lightweight Scope of delivery: ››Extension tube ››Single packed in poly-bag 8577-350 8572-74 8577-700 8564-92 8571-80 Use DREMOMETER E/F DREMOMETER E/EK/F Execution extension only with locknut y 0 745 3.550 925 3.490 Code 7622020 7621720 No. 8572-74 8564-92 Use DREMOMETER A-CD DREMOMETER A-CD DREMOMETER DR/DX y 350 700 762 0 0.400 0.850 0.750 Code 2880164 2880032 1686313 No. 8577-350 8577-700 8571-80 Torque Tools DREMOMETER MINI / T-FS 753 Torque wrench DREMOMETER MINI 2.5-12 N·m / 22-106 lbf·in Use: ››Additional micrometre scale for setting interim values with N·m, Features: ››Window with a magnifying-glass effect ››Locking button enables reliable locking of the torque setting ››Controlled screw tightening in the range 2.5 - 12 N·m / 22.5 - 106 lbf·in ››For use in almost all industrial manufacturing areas graduations of 0.05 N·m ››Classified to DIN EN ISO 6789:2003 Type II Class A, with a factory certificate. Working accuracy: +/- Scope of delivery: 3% tolerance of scale set torque. The specification of the standard (+/- 4%) is exceeded. ››Torque wrench with 1/4" square drive with ball locking device DIN 3120 - A 6.3, similar to ISO 1174, for controlled clockwise tightening ››Automatic short-path actuation with tactile impulse and audible signal ››Lightweight plastic casing, made from high-grade, glass-fibre reinforced polyamide, with soft-grip handle ››Dual scale with a scale graduation of 0.5 N·m and 5 lbf·in ››Torque wrench type MINI ››With certificate acc. to DIN EN ISO 6789:2003, traceable via in-house Type MINI MINI MINI a" 1/4 1/4 1/4 a 6.3 6.3 6.3 MINI 1/4 6.3 Contents ) in plastic box ' in plastic cassette ( Set mm 1 4 5 5,5 6 7 8 9 10 ; 1 2 3 ? 4 5.5 6.5 5 3 4 5 6 7 T20 T27 T30 & 754-00 ' 55 + 97 mm 2098 ( Set INCH 1 3/16 7/32 1/4 9/32 5/16 11/32 3/8 7/16" ; 1 2 3 ? 4 5.5 6.5 5 3 4 5 6 7 T20 T27 T30 & 754-00 ' 55 + 97 mm 2098 DAkkS laboratory to national standards N·m 2,5-12 2,5-12 2,5-12 lbf·in 22,5-106 22,5-106 22,5-106 lw 130 130 130 a 28 28 28 b 14 14 14 c 211 211 211 9 0,5 N·m / 5 lbf·in + 0,05 N·m 0,5 N·m / 5 lbf·in + 0,05 N·m 0,5 N·m / 5 lbf·in + 0,05 N·m 0 0.320 0.628 0.968 Code 1957694 1957708 1957724 No. 753-11 753-12 753-13 2,5-12 22,5-106 130 28 14 211 0,5 N·m / 5 lbf·in + 0,05 N·m 0.968 1957732 753-14 763 Torque wrench DREMOMETER T-FS pre-set, 5-12 N·m Use: ››Power-saving application for torques which are usually in the range of torque screwdrivers ››E.g. securing modules on solar power systems, tool supports etc.; wherever the torques are too large for classic torque screwdrivers Features: ››Torque wrench series with 8 pre-set models for serial production ››For controlled clockwise tightening ››Working accuracy in accordance with DIN EN ISO 6789:2003 Type II Class E (+/- 6 %) ››Lightweight and robust - housing made of a high-quality aluminium alloy ››With certificate acc. to DIN EN ISO 6789:2003, traceable via in-house DAkkS laboratory to national standards Special ranges are available on request a" 1/4 1/4 1/4 1/4 1/4 1/4 1/4 1/4 a 6.3 6.3 6.3 6.3 6.3 6.3 6.3 6.3 pre-set value 5 N·m 6 N·m 7 N·m 8 N·m 9 N·m 10 N·m 11 N·m 12 N·m 0 0.241 0.241 0.241 0.241 0.241 0.241 0.241 0.241 Code 1947958 1947966 1947974 1947990 1948008 1948016 1948024 1948032 No. 763-05 763-06 763-07 763-08 763-09 763-10 763-11 763-12 282 283 DREMOMETER Z Technical information Z ››The large cross-section of the spigot end transfers a maximum torque. "Quick-change system" with a locking pin mechanism guarantees that work takes place flexibly and rapidly. ››Ideal for bolted connections in cramped and hard-to-access locations. Depending on how the torque wrench Z is used, it is possible to work both in the forward direction and also to the side. For anti-clockwise tightening, simply turn the torque wrench through 180° 8460 Z - 8471 Z Torque wrench DREMOMETER Z with quick-fitting change 8-1000 N·m / 70 lbf·in - 730 lbf·ft ››Classified to DIN EN ISO 6789:2003 Type II Class A, with a factory certificate. Working accuracy: +/- 3 % tolerance of scale set torque. The specification of the standard (+/- 4 %) is exceeded. ››Lightweight yet robust (as the housing is made of an aluminium alloy) and resilient, very workshopfriendly ››Depending on the application, access is possible from the front (e.g. open-end fitting) or side (e.g. reversible ratchet and socket) ››Force to be applied in the middle of the handgrip only - do not use an extension tube as otherwise, inaccuracies can evolve (except for model DXZ where the DREMOMETER has been calibrated and adjusted using the extension tube) ››Operation only with end fittings with standardised depth gauges, otherwise inaccuracies can arise. Keep the depth gauges on the certificate in mind. Only use original GEDORE accessories. ››Large drive cross-section transfers maximum torques ››Extremely low wear attributable to reduced forces in the lever mechanism ››Forged lever chain from our own quality forge ››Maximum precision even when subjected to extreme continuous use ››Long life cycles and tool lives ››Easy operation - fast and safe torque tightening ››Easy adjustment thanks to attractive adjusting button secured against loss at the end of the handle ››With certificate acc. to DIN EN ISO 6789, traceable via in-house DAkkS laboratory to national standards AZ DXZ CZ Type AZ BZ CZ DZ DXZ Ø 16 16 16 22 28 N·m 8-40 25-120 80-400 140-620 520-1000 lbf·in 70-350 – – – – lbf·ft – 18-90 60-300 100-450 380-730 9 5 N·m / 50 lbf·in 5 N·m / 5 lbf·ft 5 N·m / 5 lbf·ft 10 N·m / 10 lbf·ft 10 N·m / 10 lbf·ft lwZ 300.0 411.5 567.0 767.5 1,221.0 lcZ 32 32 32 56 75 a 35 35 35 45 45 b 38 38 38 49 57 c 16.5 16.5 16.5 17.5 17.5 d 366 489 645 846 1319 0 1.000 1.450 2.000 3.000 5.500 Code 7703610 7704260 7704340 7703020 1251341 No. 8460-01 8461-01 8462-01 8463-10 8471-01 Torque Tools DREMOMETER SE Technical information Quick-fitting change O n request, all torque wrenches can be factory pre-set -at extra charge-. When ordering, please specify the N·m value. ››Quick-change system with pin locking guarantees flexible and swift working methods. Ideal for installations in confined and poorly accessible spaces. Depending on the application for the DREMOMETER SE, access is possible from the front and side. 8480 SE - 8482 SE Torque wrench DREMOMETER SE with quick-fitting change 8-400 N·m / 70 lbf·in - 300 lbf·ft ››Classified to DIN EN ISO 6789:2003 Type II Class A, with a factory certificate. Working accuracy: +/- 3% tolerance of scale set torque. The specification of the standard (+/- 4%) is exceeded. ››Lightweight yet robust (as the housing is made of an aluminium alloy) and resilient, very workshop-friendly ››Drive offers extensive range of accessories ››Depending on the application, access is possible from the front (e.g. rectangular open-end fitting) or side (e.g. reversible ratchet and socket) ››Force to be applied in the middle of the handgrip only - do not use an extension tube as otherwise, inaccuracies can arise ››Operation only with end fittings otherwise inaccuracies can arise. Keep the depth gauges on the certificate in mind. Only use original GEDORE accessories. ››Extremely low wear attributable to reduced forces in the lever mechanism ››Forged lever chain from our own quality forge ››Maximum precision even when subjected to extreme continuous use ››Long life cycles and tool lives ››Easy operation - fast and safe torque tightening ››Easy adjustment thanks to attractive adjusting button secured against loss at the end of the handle ››With certificate acc. to DIN EN ISO 6789, traceable via in-house DAkkS laboratory to national standards A-SE B-SE C-SE Type A-SE B-SE C-SE : 9 x 12 9 x 12 14 x 18 N·m 8-40 25-120 80-400 lbf·in 70-350 – – lbf·ft – 18-90 60-300 9 5 N·m / 50 lbf·in 5 N·m / 5 lbf·ft 5 N·m / 5 lbf·ft lwSE 302.0 413.5 582.0 lcSE 17.5 17.5 25.0 a 35 35 35 b 40 40 53 c 16.5 16.5 16.5 d 361 484 653 0 0.950 1.250 1.700 Code 7714060 7714140 7714220 No. 8480-01 8481-01 8482-01 284 285 DREMOMETER A+S 7554 AM A+S - 7572 F A+S Torque wrench DREMOMETER A+S with pre-set value locking and safety device (A+S) Technical advantage/function: Features: ››Pre-set value locking and safety device (A+S) eliminates the possibility of unintentional ››With certificate acc. to DIN EN ISO 6789, traceable via in-house ››Classified to DIN EN ISO 6789:2003 Type II Class A, with a factory certificate. Working accuracy: ››Automatic short-path actuation with tactile impulse and audible signal ››Dual scale with corresponding scale graduation (see table) ››Type B, BC, C with push-button release ››Pre-set DREMOMETER for serial production wherever or manipulated adjustment, thereby representing more process reliability of the user +/- 3 % tolerance of scale set torque. The specification of the standard (+/- 4 %) is exceeded. ››Lightweight and robust (as housing is made of an aluminium alloy), very workshop-friendly ››No inaccuracies whether used with both hands or held away from the handle (as for standard torque wrenches). Both the square drive and fulcrum are on an axis which ensures a high degree of user safety; can be extended to reduce the user's working load. ››Extremely low wear attributable to reduced forces in a unique lever mechanism ››Forged lever chain from our own quality forge ››Maximum precision even when subjected to extreme continuous use ››Long life cycles and tool lives ››Easy operation - fast and safe torque tightening ››Single- and double-square drive for controlled bi-directional tightening Use: ››Controlled screw tightening in the range 6 - 3000 N·m ››For use in almost all industrial manufacturing areas DAkkS laboratory to national standards the same value always needs to be applied ››The pre-setting can be made at the factory or by the user on suitable torque testers ››If ordering, please specify the N·m value - if a fixed factory pre-setting is desired (price on request) A B Type s AM A+S t AML A+S s A A+S t AL A+S s B A+S t BL A+S s BC A+S t BCL A+S s C A+S t CL A+S s CD A+S t CDL A+S s DS A+S t DSL A+S s D A+S t DL A+S s DR A+S t DRL A+S s DX A+S t DXL A+S s EK A+S t EKL A+S s E A+S t EL A+S s F A+S a" 1/4 1/4 3/8 3/8 1/2 1/2 1/2 1/2 1/2 1/2 3/4 3/4 3/4 3/4 3/4 3/4 3/4 3/4 3/4 3/4 1 1 1 1 1.1/2 a 6.3 6.3 10.0 10.0 12.5 12.5 12.5 12.5 12.5 12.5 20.0 20.0 20.0 20.0 20.0 20.0 20.0 20.0 20.0 20.0 25.0 25.0 25.0 25.0 40.0 N·m 6-30 6-30 8-40 8-40 25-120 25-120 40-200 40-200 60-300 60-300 80-360 80-360 110-550 110-550 155-760 155-760 155-760 155-760 520-1000 520-1000 600-1500 600-1500 750-2000 750-2000 1500-3000 lbf·in 50-270 50-270 70-350 70-350 – – – – – – – – – – – – – – – – – – – – – lbf·ft – – – – 18-90 18-90 30-150 30-150 45-220 45-220 60-260 60-260 80-400 80-400 115-560 115-560 115-560 115-560 380-730 380-730 – – – – – 9 1 N·m / 10 lbf·in 1 N·m / 10 lbf·in 5 N·m / 50 lbf·in 5 N·m / 50 lbf·in 5 N·m / 5 lbf·ft 5 N·m / 5 lbf·ft 5 N·m / 5 lbf·ft 5 N·m / 5 lbf·ft 5 N·m / 5 lbf·ft 5 N·m / 5 lbf·ft 5 N·m / 5 lbf·ft 5 N·m / 5 lbf·ft 10 N·m / 10 lbf·ft 10 N·m / 10 lbf·ft 10 N·m / 10 lbf·ft 10 N·m / 10 lbf·ft 10 N·m / 10 lbf·ft 10 N·m / 10 lbf·ft 10 N·m / 10 lbf·ft 10 N·m / 10 lbf·ft 25 N·m 25 N·m 50 N·m 50 N·m 50 N·m lw 206.0 206.0 262.0 262.0 373.0 373.0 463.0 463.0 529.0 529.0 624.0 624.0 719.0 719.0 719.0 719.0 1,290.5 1,290.5 1,290.5 1,290.5 1,473.0 1,473.0 2,213.0 2,213.0 2,309.0 a 30 30 30 30 30 30 30 30 30 30 30 30 35 35 35 35 35 35 35 35 40 40 40 40 40 b 15.0 15.0 17.5 17.5 17.5 17.5 17.5 17.5 17.5 17.5 22.5 22.5 22.5 22.5 22.5 22.5 22.5 22.5 22.5 22.5 30.0 30.0 30.0 30.0 35.0 c 256.0 256.0 326.5 326.5 450.0 450.0 539.0 539.0 605.0 605.0 705.5 705.5 800.0 800.0 800.0 800.0 800.0 800.0 800.0 800.0 920.0 920.0 920.0 920.0 1,025.0 d – – – – – – – – – – – – – – – – 1403 1403 1403 1403 1608 1608 2353 2353 2454 e – – – – – – – – – – – – – – – – 762 762 762 762 925 925 925 925 925 f – – – – – – – – – – – – – – – – – – – – – – 745 745 745 0 0.580 0.580 1.000 1.000 1.500 1.500 1.400 1.300 2.000 2.000 2.400 2.400 2.900 2.900 3.200 3.200 5.000 5.000 5.600 5.600 10.800 10.800 11.600 11.600 13.200 Code 1210891 1210904 7708920 1210939 7709060 1210947 1211013 1427113 7709650 1210955 1210998 1211021 1427164 1427148 1210921 1210971 1210912 1210963 1211005 1211048 2311321 2311348 1547232 1547240 1547259 No. 7554-01 7559-01 7560-01 7565-01 7561-01 7566-01 7573-00 7578-00 7562-10 7567-10 7570-10 7575-10 7574-10 7579-10 7563-10 7568-10 7563-01 7568-01 7571-01 7576-01 7581-01 7586-01 7564-01 7569-01 7572-01 Torque Tools 7460 Z - 7471 Z Torque wrench DREMOMETER Z A+S with pre-set value locking and safety device (A+S) Technical advantage/function: ››Pre-set value locking and safety device (A+S) eliminates the possibility of unintentional or manipulated adjustment, thereby representing more process reliability of the user ››Classified to DIN EN ISO 6789:2003 Type II Class A, with a factory certificate. Working accuracy: +/- 3 % tolerance of scale set torque. The specification of the standard (+/- 4 %) is exceeded. ››Lightweight yet robust (as the housing is made of an aluminium alloy) and resilient, very secured against loss at the end of the handle workshop-friendly ››Depending on the application, access is possible from the front (e.g. open-end fitting) or side (e.g. reversible ratchet and socket) ››Force to be applied in the middle of the handgrip only - do not use an extension tube as otherwise, inaccuracies can evolve (except for model DXZ where the DREMOMETER has been calibrated and adjusted using the extension tube) ››Operation only with end fittings with standardised depth gauges, otherwise inaccuracies can arise. Keep the depth gauges on the certificate in mind. Only use original GEDORE accessories. ››Large drive cross-section transfers maximum torques ››Extremely low wear attributable to reduced forces in the lever mechanism Type AZ A+S BZ A+S CZ A+S DZ A+S DXZ A+S Ø 16 16 16 22 28 N·m 8-40 25-120 80-400 140-620 520-1000 8791 - 8798 lbf·in 70-350 – – – – lbf·ft – 18-90 60-300 105-450 380-730 9 5 N·m / 50 lbf·in 5 N·m / 5 lbf·ft 5 N·m / 5 lbf·ft 10 N·m / 10 lbf·ft 10 N·m / 10 lbf·ft ››Forged lever chain from our own quality forge ››Maximum precision even when subjected to extreme continuous use ››Long life cycles and tool lives ››Easy operation - fast and safe torque tightening ››Easy adjustment thanks to attractive adjusting button lwZ 300.0 411.5 567.0 767.5 1,221.0 ››With certificate acc. to DIN EN ISO 6789, traceable via in-house DAkkS laboratory to national standards ››Pre-set DREMOMETER for serial production wherever the same value always needs to be applied ››The pre-setting can be made at the factory or by the user on suitable torque testers ››If ordering, please specify the N·m value - if a fixed factory pre-setting is desired (price on request) lcZ 32 32 32 56 75 a 35 35 35 45 45 b 38 38 38 49 57 c 16.5 16.5 16.5 17.5 17.5 d 354.0 477.5 633.0 834.5 1,319.0 0 1.000 1.450 2.000 3.000 5.500 Code 1427067 1427075 1225669 1427083 1521977 No. 7460-01 7461-01 7462-01 7463-10 7471-01   3 17 – 321 286 287 7480 SE - 7482 SE Torque wrench DREMOMETER SE A+S with pre-set value locking and safety device (A+S) Technical advantage/function: ››Pre-set value locking and safety device (A+S) eliminates the possibility of unintentional or manipulated adjustment, thereby representing more process reliability of the user ››Classified to DIN EN ISO 6789:2003 Type II Class A, with a factory certificate. Working accuracy: +/- 3% tolerance of scale set torque. The specification of the standard (+/- 4%) is exceeded. ››Lightweight yet robust (as the housing is made of an aluminium alloy) and resilient, secured against loss at the end of the handle very workshop-friendly ››Drive offers extensive range of accessories ››Depending on the application, access is possible from the front (e.g. rectangular open-end fitting) or side (e.g. reversible ratchet and socket) ››Force to be applied in the middle of the handgrip only - do not use an extension tube as otherwise, inaccuracies can arise ››Operation only with end fittings otherwise inaccuracies can arise. Keep the depth gauges on the certificate in mind. Only use original GEDORE accessories. ››Extremely low wear attributable to reduced forces in the lever mechanism Type A-SE A+S B-SE A+S C-SE A+S : 9 x 12 9 x 12 14 x 18 N·m 8-40 25-120 80-400 7112 - 7918 lbf·in 70-350 – – lbf·ft – 18-90 60-300 9 5 N·m / 50 lbf·in 5 N·m / 5 lbf·ft 5 N·m / 5 lbf·ft ››Forged lever chain from our own quality forge ››Maximum precision even when subjected to extreme continuous use ››Long life cycles and tool lives ››Easy operation - fast and safe torque tightening ››Easy adjustment thanks to attractive adjusting button lwSE 302.0 413.5 582.0 ››With certificate acc. to DIN EN ISO 6789, traceable via in-house DAkkS laboratory to national standards ››Pre-set DREMOMETER for serial production wherever the same value always needs to be applied ››The pre-setting can be made at the factory or by the user on suitable torque testers ››If ordering, please specify the N·m value - if a fixed factory pre-setting is desired (price on request) lcSE 17.5 17.5 25.0 a 35 35 35 b 40 40 53 c 16.5 16.5 16.5 d 350 474 642 0 0.950 1.250 1.700 Code 1427059 1427091 1427105 No. 7480-01 7481-01 7482-01   3 22 – 326 TORQUE TOOLS DREMASTER ® DMK Robust torque wrench with square drive and integrated ratchet-head function for controlled bi-directional tightening and interchangeable mushroom head with push-button release. Zinc-plated ratchet head All 1/2" square drives of the DREMASTER® DMK-series have a black plastic cap - also referred to as a mushroom head. This mushroom head prevents an unintentional pulling out of the whole square drive when changing the nut socket. Automatic actuation The DREMASTER® DMK actuates with a clear tactile impulse and audible signal and is immediately ready for operation again. Robust steel tube With high corrosion protection, chrome-plated, satin powdercoated. Classified to DIN EN ISO 6789:2003 Type II Class A, with a factory certificate allowing for operations to be traced back. Calibrated to a permitted +/- 3 % deviation and better. The specifications of the standard (+/- 4 %) are exceeded. Technical information Anti-loss attachment Function 1 In order to change the turning direction of the DREMASTER® DMK: Press on the push-button with your thumb and take out the mushroom head, turn the wrench and re-insert the square drive. 2 3 180° All the benefits at a single glance › Additional protection of the serial number › Concealed setting drill hole › Engaging adjusting button with locking reference (lock symbol) › Rapid adjustment provision using a separate hexagon allen key › Mushroom head with release button › Plastic grip with a user aid GEDORE Werkzeugfabrik GmbH & Co. KG Remscheider Straße 149 42899 Remscheid · GERMANY Vertrieb DEUTSCHLAND Fon +49 2191 596-900 Fax +49 2191 596-999 zentrale@gedore.com Sales INTERNATIONAL Fon +49 2191 596-910 Fax +49 2191 596-911 www.gedore.com › Dual scale (main unit with vernier) › Change-over switch for selecting the unit › At all times only one unit in the viewing area (N·m or lbf·ft) › Controlled safety via in-house DAkkS test laboratory 2995832 01/16 288 289 Additional protection of the serial number Concealed setting drill hole = secured adjusting/ setting system Serial number on the wrench and on the certificate for unambiguous product identification, traceable via in-house DAkkS laboratory to national standards Handgrip with a user aid Grey plastic handgrip, new ergonomically enhanced shape, with an indentation in the middle of the handgrip. User aid and reference points for calibration. Nonius Model-dependent intervals of 1 or 0.5 N·m allow very accurate settings. Ligthweight and reliable Locking button enables reliable locking of the torque setting. "Torque adjustable" reference by means of opened lock symbol. Provision for rapid setting from the separate hexagon allen key fixture. Dual scale with main and alternative unit (N·m/Ibf·ft). Main unit N·m with vernier. At all times only one unit in the viewing area = avoids any reading errors. Change-over switch next to the scale for straightforward unit selection. DREMASTER ® DMUK Features Robust tubular steel With high corrosion protection, satin powder-coated, with zinc-plated ratchet head Torque wrench with square drive and integrated ratchet-function for controlled clockwise tightening With 1/2" square drive and integrated lever-change reversible ratchet function for controlled clockwise tightening   2 90 DMK d-e Switch the lever of the reversible ratchet to correspond with the desired direction, clockwise or anti-clockwise.   2 91 20-850 N·m DMUK d   2 92 20-300 N·m DMZ jk   2 93 20-850 N·m DMSE } ~ 20-400 N·m Torque Tools DMK Torque wrench DREMASTER® K 20-850 N·m Use: ››Sturdy, varnished tubular steel construction, with zinc-plated ratchet head and (guide for screws M7-10.9 to M24-8.8, M30-5.6) ››Adjustable, releasing and sturdy tubular torque wrench with integrated ratchet and with square drive for industry and the trades Features: ››Classified to DIN EN ISO 6789:2003 Type II Class A, with a factory certificate allowing for operations to be traced back. Calibrated to a permitted +/- 3 % deviation and better. The specifications of the standard (+/- 4 %) are exceeded. ››For controlled bi-directional tightening. DMUK only for controlled clockwise-tightening ››Models DMK: 1/2" mushroom head interchangeable square with push-button releasing and a ball-locking mechanism. From Model No. DMK 400 with 3/4" push-through square and a pin-locking mechanism ››Ergonomically shaped plastic grip with calibration aid ››Change-over between N·m main scale and lbf·ft ancillary scale to avoid reading ››Controlled screw tightening in the most common range of 20 - 850 N·m / 15 - 630 lbf·ft a" 1/2 1/2 1/2 3/4 3/4 3/4 3/4 a 12.5 12.5 12.5 20.0 20.0 20.0 20.0 N·m 20-100 40-200 60-300 80-400 110-550 150-750 250-850 lbf·ft 15-75 30-150 45-220 60-300 80-405 110-550 185-630 9 5 N·m 10 N·m 10 N·m 10 N·m 10 N·m 10 N·m 10 N·m Scale ring 0,5 N·m 1 N·m 1 N·m 1 N·m 1 N·m 1 N·m 1 N·m top-grade plastic parts L 423.5 514.5 606.4 714.8 953.2 1,228.2 1,375.2 errors when setting the torque wanted ››With micrometre scale for main N·m scale for setting interim values ››Release system triggers a tactile and audible signal ››Ergonomic system for torque adjustment with reference symbol ››Provision for rapid setting with hexagon allen key, not included ››Secured adjusting/setting system lw 329.2 420.2 511.1 608.9 846.4 1,121.4 1,268.4 c 35 35 35 46 52 327 474 h 38.5 38.5 38.5 38.0 38.0 38.0 38.0 b 44 44 46 67 69 69 69 0 1.250 1.400 1.431 2.488 3.940 5.020 5.325 Code 2641232 2641240 2641259 2641267 2641275 2641283 2641291 No. DMK 100 DMK 200 DMK 300 DMK 400 DMK 550 DMK 750 DMK 850 GDMK Torque wrench set DREMASTER® K ››The DREMASTER® DMK as a practical tool set ››Most-widely-used tools in a robust sheet-metal case ››Clearly organised - everything always easily accessible ››With foam-material inlay modules (on request, these can be customised or extended individually) a" 1/2 a 12.5 N·m 20-100 lbf·ft 15-75 1/2 12.5 40-200 30-150 1/2 12.5 60-300 45-220 3/4 20.0 80-400 60-300 Contents " No. DMK 100 in sheet-metal case 1 10 13 17 19 24 ' 125 mm and 1/2" square drive " No. DMK 200 in sheet-metal case 1 10 13 17 19 24 ' 125 mm and 1/2" square drive " No. DMK 300 in sheet-metal case 1 17 19 24 27 ' 125 mm and 1/2" square drive " No. DMK 400 in sheet-metal case 1 18 19 24 27 ' 200 mm and 3/4" square drive 0 4.4 Code 2641593 No. GDMK 100 5.7 2641607 GDMK 200 5.8 2641615 GDMK 300 6.5 2641623 GDMK 400 290 291 DMUK Torque wrench DREMASTER® UK 20-300 N·m / 15-220 lbf·ft Use: ››Change-over between N·m main scale and lbf·ft ancillary scale to avoid reading (guide for screws M7-10.9 to M24-8.8, M30-5.6) ››Adjustable, releasing and sturdy tubular torque wrench with integrated ratchet and with square drive for industry and the trades Features: ››Classified to DIN EN ISO 6789:2003 Type II Class A, with a factory certificate. Working accuracy: +/- 3 % tolerance of scale set torque. The specification of the standard (+/- 4 %) is exceeded. ››For controlled clockwise tightening ››Models DMUK: With 1/2" reversible ratchet ››Sturdy, varnished tubular steel construction, with zinc-plated ratchet head and top-grade plastic parts ››Ergonomically shaped plastic grip with calibration aid ››With micrometre scale for main N·m scale for setting interim values ››Release system triggers a tactile and audible signal ››Ergonomic system for torque adjustment with reference symbol ››Provision for rapid setting with hexagon allen key, not included ››Secured adjusting/setting system ››Controlled screw tightening in the most common range of 20 - 300 N·m / 15 - 220 lbf·ft errors when setting the torque wanted h l lw b c a" 1/2 1/2 1/2 a 12.5 12.5 12.5 N·m 20-100 40-200 60-300 lbf·ft 15-75 30-150 45-220 9 5 N·m 10 N·m 10 N·m Scale ring 0,5 N·m 1 N·m 1 N·m L 437.7 529.7 619.6 1 3 c 50 50 50 h 22.0 22.0 22.0 b 42.5 42.5 42.5 0 1.232 1.400 1.623 Code 2641305 2641313 2641348 No. DMUK 100 DMUK 200 DMUK 300 DMKPK Mushroom head DREMASTER® DMK Function In order to change the turning direction of the TORCOFIX K: ››Press on the protruding square drive with your thumb and take out the mushroom head, turn the wrench and re-insert the square drive. lw 344.2 435.2 526.1 2 180 ››With 1/2" output square drive with ball locking device and release button ››Made of chrome-vanadium steel, zinc-plated ››With blue mushroom head made of polypropylene 3294 Coupler 3/4" ››Acc. to DIN 3122, ISO 3315 ››For hand-operated sockets with square drive as per DIN 3120, ISO 1174, with locking pin ››Chrome-vanadium steel, chrome-plated a" 3/4 a 20 y 51.5 0 0.133 Code 6279090 No. 3294 a" 1/2 a 12.5 Q" 1/2 Q 12.5 0 0.064 Code 2551829 No. DMKPK 7 Torque Tools DMZ Torque wrench DREMASTER® Z 20-850 N·m / 15-630 lbf·ft Use: ››Controlled screw tightening in the most common range of 20 - 850 N·m / 15 - 630 lbf·ft (guide for screws M7-10.9 to M24-8.8, M30-5.6) ››Adjustable, releasing and sturdy tubular torque wrench with spigot end for industry and the trades Features: ››Classified to DIN EN ISO 6789:2003 Type II Class A, with a factory certificate allowing for operations to be traced back. Calibrated to a permitted +/- 3 % deviation and better. The specifications of the standard (+/- 4 %) are exceeded. ››For controlled bi-directional tightening ››Sturdy, varnished tubular steel construction, with phosphated spigot end (Ø 16 mm or Ø 22 mm) and high-grade plastic parts ››Ergonomically shaped plastic grip with calibration aid ››Change-over between N·m main scale and lbf·ft ancillary scale to avoid reading errors when setting the torque wanted. Ø 16 16 16 16 22 22 22 N·m 20-100 40-200 60-300 80-400 110-550 150-750 250-850 lbf·ft 15-75 30-150 45-220 60-300 80-405 110-550 185-630 9 5 N·m 10 N·m 10 N·m 10 N·m 10 N·m 10 N·m 10 N·m Scale ring 0,5 N·m 1 N·m 1 N·m 1 N·m 1 N·m 1 N·m 1 N·m L 405.5 496.5 587.4 677.2 912.7 1,193.7 1,340.7 ››With micrometre scale for main N·m scale for setting interim values ››Release system triggers a tactile and audible signal ››Ergonomic system for torque adjustment with reference symbol ››Provision for rapid setting with hexagon allen key, not included ››Secured adjusting/setting system ››Factory depth gauge: 32 mm (Ø 16 mm) or 56 mm (Ø 22 mm) ››Operation only with end fittings with standardised depth gauge - otherwise inaccuracies may arise. ››Depending on the application, access is possible from the front (e.g. open-end lwZ 326.2 417.2 508.1 597.9 831.4 1,121.7 1,259.4 fitting) or side (e.g. reversible ratchet and socket) lcZ 32 32 32 32 56 56 56 b 27.5 27.5 27.5 35.0 36.5 38.5 38.5 c 32 32 32 32 37 318 465 0 0.998 1.100 1.300 1.790 3.280 4.380 5.000 Code 2641518 2641526 2641534 2641542 2641550 2641569 2641577 GDMZ Torque wrench set DREMASTER® Z ››The DREMASTER® DMZ as a practical tool set ››Most-widely-used tools in a robust sheet-metal case ››Clearly organised - everything always easily accessible ››With foam-material inlay modules (on request, these can be customised or extended individually) Ø 16 N·m 20-100 lbf·ft 15-75 16 40-200 30-150 16 60-300 45-220 16 80-400 60-300 Contents " No. DMZ 100 in sheet-metal case 1 17 19 24 4 17 19 24 and 1/2" ratchet head " No. DMZ 200 in sheet-metal case 1 17 19 24 4 17 19 24 and 1/2" ratchet head " No. DMZ 300 in sheet-metal case 1 24 27 30 32 4 24 27 and 1/2" ratchet head " No. DMZ 400 in sheet-metal case 1 24 27 30 32 4 24 27 and 1/2" ratchet head 0 4.5 Code 2641704 No. GDMZ 100 5.8 2641712 GDMZ 200 6.5 2641720 GDMZ 300 7.4 2641739 GDMZ 400 No. DMZ 100 DMZ 200 DMZ 300 DMZ 400 DMZ 550 DMZ 750 DMZ 850 292 293 DMSE Torque wrench DREMASTER® SE 20-400 N·m / 15-300 lbf·ft Use: ››Controlled screw tightening in the most common range of 20 - 400 N·m / 15 - 300 lbf·ft (guide for screws M7-10.9 to M20-6.9) ››Adjustable, releasing and sturdy tubular torque wrench with rectangular cavity for industry and the trades Features: ››Classified to DIN EN ISO 6789:2003 Type II Class A, with a factory certificate allowing for operations to be traced back. Calibrated to a permitted +/- 3 % deviation and better. The specifications of the standard (+/- 4 %) are exceeded. ››For controlled bi-directional tightening ››Sturdy, varnished tubular steel construction, with zinc-plated rectangular cavity (9x12 mm or 14x18mm) and high-grade plastic parts ››Ergonomically shaped plastic grip with calibration aid ››Change-over between N·m main scale and lbf·ft ancillary scale to avoid reading errors when setting the torque wanted. : 9 x 12 9 x 12 14 x 18 14 x 18 14 x 18 N·m 20-100 30-150 40-200 60-300 80-400 lbf·ft 15-75 22-110 30-150 45-220 60-300 9 5 N·m 10 N·m 10 N·m 10 N·m 10 N·m Scale ring 0,5 N·m 1 N·m 1 N·m 1 N·m 1 N·m L 398.5 489.5 499.5 590.4 677.2 lwSE 326.2 417.2 427.2 518.1 604.9 ››With micrometre scale for main N·m scale for setting interim values ››Release system triggers a tactile and audible signal ››Ergonomic system for torque adjustment with reference symbol ››Provision for rapid setting with hexagon allen key, not included ››Secured adjusting/setting system ››Factory depth gauge: 17.5 mm (9x12 mm) or 25 mm (14x18 mm) ››Operation only with end fittings with standardised depth gauges, otherwise inaccuracies can arise ››Depending on the application, access is possible from the front (e.g. open-end fitting) or side (e.g. reversible ratchet and socket) lcSE 17.5 17.5 25.0 25.0 25.0 b 27.5 27.5 27.5 27.5 33.0 c 32 32 42 42 42 Contents " No. DMSE 100 in sheet-metal case 1 13 17 19 4 13 17 19 and 1/2" ratchet head " No. DMSE 150 in sheet-metal case 1 13 17 19 4 13 17 19 and 1/2" ratchet head " No. DMSE 200 in sheet-metal case 1 17 19 24 4 17 19 24 and 1/2" ratchet head " No. DMSE 300 in sheet-metal case 1 24 30 32 4 24 30 32 36 and 1/2" ratchet head " No. DMSE 400 in sheet-metal case 1 24 30 32 4 24 30 32 36 and 1/2" ratchet head 0 3.9 Code 2641658 No. GDMSE 100 5.6 2643731 GDMSE 150 6.3 2641666 GDMSE 200 6.5 2641674 GDMSE 300 7.0 2641690 GDMSE 400 0 1.000 1.160 1.250 1.400 2.000 Code 2641445 2641453 2641461 2641488 2641496 No. DMSE 100 DMSE 150 DMSE 200 DMSE 300 DMSE 400 GDMSE Torque wrench set DREMASTER® SE ››The DREMASTER® DMSE as a practical tool set ››Most-widely-used tools in a robust sheet-metal case ››Clearly organised - everything always easily accessible ››With foam-material inlay modules (on request, these can be customised or extended individually) : 9 x 12 N·m 20-100 lbf·ft 15-75 9 x 12 30-150 22-110 14 x 18 40-200 30-150 14 x 18 60-300 45-220 14 x 18 80-400 60-300 TORQUE TOOLS TORCOFIX K Robust torque wrench with square drive and integrated ratchet-head function for controlled bi-directional tightening. Micrometre scale Optimised shape, stable scale frame with redshaded micrometre scale ring. Model-dependent intervals of 0.025, 0.1, 0.25, 0.5 or 1 N·m allow very accurate settings. Scale Easily readable dual scale (N·m / lbf·in / lbf·ft) well protected under a window with a magnifying-glass effect. The torque setting is readable on the scale or, more particularly, on the scale in combination with the scale ring. Classified to DIN EN ISO 6789:2003 Type II Class A, with a factory certificate allowing for operations to be traced back. Calibrated to a permitted +/- 3 % deviation and better. The specifications of the standard (+/- 4 %) are exceeded. Ligthweight and reliable Locking button enables reliable locking of the torque setting. Serial number on the wrench and on the certificate for unambiguous product identification, traceable via in-house DAkkS laboratory to national standards Handgrip with a user aid Black plastic handgrip, new ergonomically enhanced shape, with an indentation in the middle of the handgrip. User aid and reference points for calibration. Chrome-plated ratchet head All 1/4" - 1/2" square drives of the TOROFIX K-series with mushroom head. This mushroom head prevents an unintentional pulling out of the whole square drive when changing the nut socket.   2 95 K b-e Automatic actuation The TORCOFIX actuates with a clear tactile impulse and audible signal and is immediately ready for operation again. Robust steel tube With high corrosion protection, chrome-plated, silk-metal.   2 96 1 - 850 N·m Z jk 2 - 850 N·m   2 97 SE }~ 2 - 400 N·m 294 295 4549 - 4550 - 4551 TORQUE WRENCH TORCOFIX K 1-850 N·m / 0.75-630 lbf·ft Use: ››1/4", 3/8", 1/2" interchangeable mushroom head with ball locking device. (guide for screws M3-6.9 to M24-8.8, M30-5.6) ››Adjustable, releasing and sturdy tubular torque wrench with integrated ratchet and with square drive for industry and the trades Features: ››Classified to DIN EN ISO 6789:2003 Type II Class A, with a factory certificate. Working accuracy: +/- 3 % tolerance of scale set torque. The specification of the standard (+/- 4 %) is exceeded. ››For controlled bi-directional tightening ››Sturdy, varnished tubular steel construction, with zinc-plated ratchet ››Controlled screw tightening in the most widely used range of 1 - 850 N·m / 0.75 - 630 lbf·ft As from 3/4" with push through square drive with pin-locking mechanism head and top-grade plastic parts ››Ergonomically shaped, convenient black plastic handgrip with calibration aid ››Dual scale N·m and lbf·ft below a window with a magnifying-glass effect ››With micrometre scale for main N·m scale for setting interim values ››Release system triggers a tactile and audible signal ››Ergonomic system for torque adjustment 4549-02 a d 4550-30 lw b c a" 1/4 1/4 3/8 1/2 1/2 1/2 3/4 3/4 3/4 3/4 a 6.3 6.3 10.0 12.5 12.5 12.5 20.0 20.0 20.0 20.0 N·m 1-5 5-25 10-50 20-100 40-200 60-300 80-400 110-550 150-750 250-850 lbf·ft 0,75-3,7 3,7-18 7,5-37 15-75 30-150 45-220 60-300 80-405 110-550 185-630 9 0,25 N·m 1 N·m 2,5 N·m 5 N·m 10 N·m 10 N·m 10 N·m 10 N·m 10 N·m 10 N·m Scale ring 0,025 N·m 0,1 N·m 0,25 N·m 0,5 N·m 1 N·m 1 N·m 1 N·m 1 N·m 1 N·m 1 N·m lw 146.0 206.5 256.5 303.2 394.2 485.2 583.2 853.7 1,128.7 1,275.7 FUNCTION a 25.3 25.3 25.3 35.9 35.9 35.9 38.0 38.0 38.0 38.0 b 35 35 35 44 44 46 67 69 69 69 c 26 26 26 35 35 35 46 52 327 1276 d 224.0 284.5 334.5 394.7 485.5 577.5 686.0 957.5 1,232.5 1,379.5 Code 2201429 1545132 1545140 7601530 7601610 7601880 7674330 7674760 1521365 1950525 0 0.323 0.450 0.540 0.900 1.100 1.300 1.860 3.560 4.500 4.700 No. 4549-00 4549-02 4549-05 4550-10 4550-20 4550-30 4550-40 4550-55 4550-75 4551-85 4549 - 4550 MUSHROOM HEAD TORCOFIX K In order to change the turning direction of the TORCOFIX K: ››Press on the protruding square drive with your thumb and take out the mushroom head, turn the wrench and re-insert the square drive. 1 3 2 180 ››With 1/4", 3/8" or 1/2" output square drive with ball locking device ››Made of chrome-vanadium steel, zinc-plated ››With blue mushroom head made of polypropylene 3294 COUPLER 3/4" ››Acc. to DIN 3122, ISO 3315 ››For hand-operated sockets with square drive as a" 3/4 a 20 y 51.5 0 0.133 4550-85S 4550-86S per DIN 3120, ISO 1174, with locking pin ››Chrome-vanadium steel, chrome-plated Code 6279090 No. 3294 Q" 3/8" - 1/4" 3/8" - 1/4" 1/2" - 3/8" 1/2" - 3/8" Q 10.0 10.0 12.5 12.0 a" 1/4 3/8 1/2 3/8 a 6.3 10.0 12.5 10.0 , 35 35 44 44 0 0.021 0.022 0.060 0.060 Code 1545167 1566385 7079370 7079450 No. 4549-87S 4549-88S 4550-85S 4550-86S TORQUE TOOLS TORCOFIX Z TECHNICAL INFORMATION Z ››The large cross-section of the spigot end transfers a maximum torque. "Quick-change system" with a locking pin mechanism guarantees that work takes place flexibly and rapidly. ››Ideal for bolted connections in cramped and hard-to-access locations. Depending on how the torque wrench Z is used, it is possible to work both in the forward direction and also to the side. For anti-clockwise tightening, simply turn the torque wrench through 180° 4400 - 4485 TORQUE WRENCH TORCOFIX Z 5-850 N·m / 3,7-630 lbf·ft ››Controlled screw tightening in the most widely used range of 5 - 850 N·m / 3.7 - 550 lbf·ft ››Adjustable, releasing and sturdy tubular torque wrench with spigot end for industry and the trades ››Ergonomic system for torque adjustment ››Factory depth gauges: 32 mm (Ø 16 mm) or 56 mm (Ø 22 mm) ››Operation only with end fittings with standardised depth gauges, ››Classified to DIN EN ISO 6789:2003 Type II Class A, with a factory certificate. Working accuracy: ››Depending on the application, access is possible from the front Use: Features: +/- 3 % tolerance of scale set torque. The specification of the standard (+/- 4 %) is exceeded. ››For controlled bi-directional tightening ››Sturdy, varnished tubular steel construction, with phosphated spigot end (Ø 16 mm or Ø 22 mm) and otherwise inaccuracies can arise (e.g. open-end fitting) or side (e.g. reversible ratchet and socket) high-grade plastic parts ››Ergonomically shaped, convenient black plastic handgrip with calibration aid ››Dual scale N·m and lbf·ft below a window with a magnifying-glass effect ››With micrometre scale for main N·m scale for setting interim values ››Release system triggers a tactile and audible signal 4400-02 4430-01 c lwz a b lcZ Ø 16 16 16 16 16 16 22 22 22 N·m 5-25 10-50 20-100 40-200 60-300 80-400 110-550 150-750 250-850 lbf·ft 3,7-18 7,5-37 15-75 30-150 45-220 60-300 80-405 110-550 185-630 9 1 N·m 2,5 N·m 5 N·m 10 N·m 10 N·m 10 N·m 10 N·m 10 N·m 10 N·m Scale ring 0,1 N·m 0,25 N·m 0,5 N·m 1 N·m 1 N·m 1 N·m 1 N·m 1 N·m 1 N·m lwZ 210.5 260.5 300.2 391.2 482.2 572.2 838.7 1,119.7 1,266.7 lcZ 32 32 32 32 32 32 56 56 56 a 20.0 20.0 27.5 27.5 27.5 35.0 36.5 38.5 38.0 b 30 30 32 32 32 33 37 318 465 c 278.0 328.0 376.5 467.5 558.5 648.5 917.0 1,198.0 1,345.0 0 0.330 0.390 0.700 0.860 1.080 1.390 3.000 4.060 4.430 Code 1646168 1646176 7097270 7097350 7097430 7094090 7501310 1521381 1997009 No. 4400-02 4405-05 4410-01 4420-01 4430-01 4440-01 4450-01 4475-01 4485-01 296 297 TORCOFIX SE TECHNICAL INFORMATION - QUICK-FITTING CHANGE (SE) Quick-change system with pin locking guarantees flexible and swift working methods. Ideal for installations in confined and poorly accessible spaces. Depending on the application for the TORCOFIX SE, access is possible from the front and side. 4100 - 4301 TORQUE WRENCH TORCOFIX SE 2-400 N·m / 1.5-300 lbf·ft ››Release system triggers a tactile and audible signal ››Ergonomic system for torque adjustment ››Factory depth gauges: 17.5 mm (9x12 mm) or 25 mm (14x18 mm) ››Operation only with end fittings with standardised depth gauges, Use: ››Controlled screw tightening in the most widely used range of 5 - 400 N·m / 3.7 - 300 lbf·ft ››Adjustable, releasing and sturdy tubular torque wrench with rectangular cavity for industry and the trades Features: ››Classified to DIN EN ISO 6789:2003 Type II Class A, with a factory certificate. Working accuracy: +/- 3 % tolerance of scale set torque. The specification of the standard (+/- 4 %) is exceeded. ››For controlled bi-directional tightening ››Sturdy, varnished tubular steel construction, with zinc-plated rectangular cavity (9x12 mm or 14x18 mm) and high-grade plastic parts ››Ergonomically shaped, convenient black plastic handgrip with calibration aid ››Dual scale N·m and lbf·ft below a window with a magnifying-glass effect ››With micrometre scale for main N·m scale for setting interim values otherwise inaccuracies can arise ››Depending on the application, access is possible from the front (e.g. open-end fitting) or side (e.g. reversible ratchet and socket). 4100-01 4300-01 c lwSE a b lcSE : 9 x 12 9 x 12 9 x 12 9 x 12 14 x 18 14 x 18 14 x 18 N·m 5-25 10-50 20-100 30-150 40-200 60-300 80-400 lbf·ft 3,7-18 7,5-37 15-75 22-110 30-150 45-220 60-300 9 1 N·m 2,5 N·m 5 N·m 10 N·m 10 N·m 10 N·m 10 N·m Scale ring 0,1 N·m 0,25 N·m 0,5 N·m 1 N·m 1 N·m 1 N·m 1 N·m lwSE 212.5 262.5 300.2 391.2 401.2 492.2 579.2 lcSE 17.5 17.5 17.5 17.5 25.0 25.0 25.0 a 20.0 20.0 27.5 27.5 27.5 27.5 33.0 b 32 32 32 32 42 42 42 c 273.0 323.0 369.5 460.5 470.5 561.5 648.5 0 0.352 0.450 0.600 0.800 0.900 1.200 1.600 Code 1646192 1646206 7600210 1654934 7600990 7601020 7604120 No. 4101-02 4101-05 4100-01 4200-02 4201-01 4300-01 4301-01 TORQUE TOOLS TORCOFIX FS 4150 - 4151 TORQUE WRENCH FOR PRE-SETTING TORCOFIX FS 5-200 N·m Use: ››Controlled screw tightening in the most widely used range of 5 - 200 N·m without scale ››Pre-set, releasing and sturdy tubular torque wrench with rectangular cavity for industry and the trades Features: ››Classified to DIN EN ISO 6789:2003 Type II Class A, with a factory certificate. Working accuracy: +/- 3 % tolerance of scale set torque. The specification of the standard (+/- 4 %) is exceeded. ››For controlled bi-directional tightening ››Sturdy, varnished tubular steel construction, with zinc-plated rectangular cavity (9x12 mm or 14x18 mm) ››Release system triggers a tactile and audible signal ››Factory depth gauge: 17.5 mm (9x12 mm) or 25 mm (14x18 mm) ››Operation only with end fittings with standardised depth gauges, otherwise inaccuracies can arise ››Depending on the application, access is possible from the front (e.g. open-end fitting) or side (e.g. reversible ratchet and socket). ››If ordering, please specify the N·m value - if a fixed factory pre-setting is desired (price on request) 4150-25 4151-20 c lwFS a b IcFS : 9 x 12 9 x 12 9 x 12 14 x 18 N·m min / max 5 - 25 10 - 50 17 - 85 40 - 200 lwFS 134 194 277 357 lcFS 17.5 17.5 17.5 25.0 a 22 22 22 33 b 31 31 31 45 c 186 246 329 410 0 0.210 0.270 0.340 0.750 Code 7601960 7602180 7602850 7603580 No. 4150-25 4150-50 4150-85 4151-20 298 299 Torque Screwdrivers TORQUE SCREWDRIVER TECHNICAL FEATURES A range of compact and versatile torque screwdrivers with automatically actuating, dial-indicating and measuring torque. TYPE PGN ››Pre-set torque screwdriver without scale for durable and identical value tightening ››Auto setting ››With 1/4" female hexagon drive for use with 1/4" hexagon bits as per DIN 3126 - C 6.3 TYPE FS 755 ››Pre-set torque screwdriver without scale for durable and identical value tightening ››Auto setting ››Bidirectional ››Anodised aluminium handgrip TYPE 756 ››Adjustable torque screwdriver with scale ring ››"Positive-lock"-system ››Drive type made of stainless steel ››Auto setting ››Bidirectional ››Non-slip rubber handgrip ››EPA > see product TYPE S 757 ››Adjustable torque screwdriver with scale ring ››Auto setting ››Bidirectional ››Anodised aluminium handgrip TYPE SP 758 ››Dial-indicating torque screwdriver with dual scale ››Locking of maximum values / maximum value-display ››Bidirectional ››Anodised aluminium handgrip ››EPA > see product SCOPE OF DELIVERY ››We supply a 1/4"-1/4"-drive adaptor with all models ››To make work easier, a sliding or removable T-bar is included with several models SPECIAL MODELS ››Optionally, all torque screwdrivers are also available with a 1/4" male square drive spindle. ››Apart from that: Torque screwdrivers for the medical "clean-room" area are available on request. TORQUE TOOLS NEW PGNP FS TORQUE SCREWDRIVER TYPE PGNP FS 0.05 - 13.5 N·m / pre-set ››Calibration stickers can be easily applied to the purpose designed nose ››The pre-setting can be made at the factory or by the user on suitable torque testers ››If ordering, please specify the N·m value - if a fixed factory setting is Use: ››Controlled screw tightening in the range 0.05 - 13.5 N·m ››Serial manufacture with constant tightening value ››Electronic industry, precision mechanics and industrial manufacturing Features: ››Pre-set torque screwdriver without a scale ››With 1/4" female hexagon drive for use with 1/4" hexagon bits as per DIN 3126 - C 6.3 ››Classified to DIN EN ISO 6789:2003 Type II Class F, with a factory certificate allowing for operations to be traced back ››Calibrated to a permitted +/- 6 % deviation of the set torque ››Precision radial ball clutch and cam design for controlled bi-directional tightening ››Precision mechanism slips very noticeably through when set torque is reached ››Automatic resetting to the starting position ››Fatigue-free working due to an ergonomic hand grip and a smoth tool reset action -" 1/4 1/4 1/4 1/4 6.3 6.3 6.3 6.3 cN·m 5-25 20-150 50-450 250-1350 N·m 0,05-0,25 0,2-1,5 0,5-4,5 2,5-13,5 desired (price on request) Scope of delivery: ››Torque screwdriver type PGNP FS ››Models 4.5 and 13.5 with additional sliding T-bar for ease of use ››Test certificate acc. to DIN EN ISO 6789 ››Delivered in sturdy cardboard packaging y 132 132 140 140 0 0.210 0.210 0.230 0.230 Code 2927756 2927764 2927772 2927780 No. PGNP 0.25 FS PGNP 1.5 FS PGNP 4.5 FS PGNP 13.5 FS NEW PGNS FS TORQUE SCREWDRIVER TYPE PGNS FS 0.2 - 4.5 N·m / pre-set ››Precision mechanism slips very noticeably through when set torque is reached ››For controlled directional tightening, anti-clockwise operation for loosening ››The pre-setting can be made at the factory or by the user on suitable torque Use: ››Controlled screw tightening in the range 0.2 - 4.5 N·m ››Serial manufacture with constant tightening value ››Precision mechanics and industrial manufacturing ››Basic model testers ››If ordering, please specify the N·m value - if a fixed factory setting is Features: ››Pre-set torque screwdriver without a scale ››With 1/4" female hexagon drive for use with 1/4" hexagon bits as per DIN 3126 - C 6.3 ››Working accuracy: +/- 10 % tolerance of the set torque, without calibration certificate ››Acc. to DIN EN ISO 6789, traceable to national standards -" 1/4 1/4 6.3 6.3 cN·m 20-150 50-450 N·m 0,2-1,5 0,5-4,5 desired (price on request) Scope of delivery: ››Torque screwdriver type PGNS FS ››Delivered in sturdy cardboard packaging y 138 138 0 0.198 0.198 Code 2927721 2927748 No. PGNS 1.5 FS PGNS 4.5 FS 300 301 NEW PGNE FS TORQUE SCREWDRIVER TYPE PGNE FS 0.05 - 13.5 N·m / pre-set ››Automatic resetting to the starting position ››Fatigue-free working due to an ergonomic hand grip Use: ››Controlled screw tightening in the range 0.05 - 13.5 N·m ››Serial manufacture with constant tightening value ››Electronic industry, precision mechanics and industrial manufacturing and a smoth tool reset action Features: ››Pre-set torque screwdriver without a scale ››With 1/4" female hexagon drive for use with 1/4" hexagon bits as per DIN 3126 - C 6.3 ››Classified to DIN EN ISO 6789:2003 Type II Class F, with a factory certificate allowing for operations to be traced back ››Calibrated to a permitted +/- 6 % deviation of the set torque ››EPA-conformant (Electrostatic Protected Area), for use in sensitive electrostatic applications ››Precision radial ball clutch and cam design for controlled bi-directional tightening ››Precision mechanism slips very noticeably through when set torque is reached -" 1/4 1/4 1/4 1/4 cN·m 5-25 20-150 50-450 250-1350 6.3 6.3 6.3 6.3 N·m 0,05-0,25 0,2-1,5 0,5-4,5 2,5-13,5 ››Calibration stickers can be easily applied to the purpose designed nose ››The pre-setting can be made at the factory or by the user on suitable torque testers ››If ordering, please specify the N·m value - if a fixed factory setting is desired (price on request) Scope of delivery: ››Torque screwdriver type PGNE FS ››Models 4.5 and 13.5 with additional sliding T-bar for ease of use ››Test certificate acc. to DIN EN ISO 6789 ››Delivered in sturdy cardboard packaging y 132 132 140 140 Code 2927799 2927802 2927810 2927829 0 0.210 0.210 0.230 0.230 No. PGNE 0.25 FS PGNE 1.5 FS PGNE 4.5 FS PGNE 13.5 FS 755 TORQUE SCREWDRIVER TYPE FS 0.04-13.6 N·m / pre-set ››Lightweight construction by virtue of anodised aluminium handgrips ››The pre-setting can be made at the factory or by the Use: ››Controlled screw tightening in the range 0.04 - 13.6 N·m ››Serial manufacture with constant tightening value ››Electronic industry, precision mechanics and industrial manufacturing user on suitable torque testers ››If ordering, please specify the N·m value - if a fixed Features: ››Pre-set torque screwdriver without a scale ››With 1/4" female hexagon drive for use with 1/4" hexagon bits as per DIN 3126 - C 6.3 ››With adaptor also suitable for 1/4" square drive sockets as per DIN 3124 ››Working accuracy: +/- 6 % tolerance of the set torque ››Acc. to DIN EN ISO 6789, traceable to national standards ››Precision radial ball clutch and cam design for controlled bi-directional tightening ››Precision mechanism slips very noticeably through when the set torque is reached ››Automatic resetting to the starting position factory setting is desired (price on request) Scope of delivery: ››Torque screwdriver type 755 ››1/4" square/hexagon drive adaptor (no. 757-20) ››Model 755-05 with additional removable T-bar for ease of use ››Test certificate acc. to DIN EN ISO 6789 ››Delivered in sturdy cardboard packaging 755-05 -" 1/4 1/4 1/4 1/4 1/4 6.3 6.3 6.3 6.3 6.3 a" 1/4 1/4 1/4 1/4 1/4 a 6.3 6.3 6.3 6.3 6.3 cN·m 4,4-22 4,4-22 27-135 80-400 N·m 0,04-0,22 0,04-0,22 0,27-1,35 0,8-4,0 2,8-13,6 y 76 104 111 127 137 0 0.050 0.072 0.210 0.280 0.325 Code 1471481 1471473 1471465 1471457 1228501 No. 755-01 755-02 755-03 755-04 755-05 TORQUE TOOLS TORQUE SCREWDRIVERS 756 Drive adaptor 1/4"-square drive: To fit industrystandard nut sockets. 1/4"-drive type: Made of stainless steel, for industry-standard bits. Rubber handgrip: Ergonomic, can be held securely in your hand. Sliding T-Bar: Made of quality steel, can be adapted to enhance users transmission of power. Drive adaptor 1/4"-hexagon-male: Guarantees a safe and stable connection to the tool. "Positiv-Lock"-system: Locks the set torque, reliably preventing it from wrong setting. Scale: Clearly readable scale ring; enables you to make the setting accurately, quickly and without error. 756 TORQUE SCREWDRIVER TYPE S 0.08-9 N·m ››Micrometre scaling: 1 cN·m and 0.1 N·m ››Very convenient, lightweight and non-slip rubber handgrip ››EPA-conformant (Electrostatic Protected Area), for use in sensitive Use: ››Controlled screw tightening in the range 0.08 - 9 N·m ››High-speed, controlled tightening enables serial production ››Electrical and electronic hardware industry, instrument-making industry and industrial electrostatic applications Scope of delivery: ››Torque wrench type 756 ››1/4" square/hexagon drive adapter (no. 757-20) ››Models 756-06/-09 with additional sliding T-bar for ease of use ››Test certificate acc. to DIN EN ISO 6789 ››Delivered in sturdy cardboard packaging manufacturing or in quality control Features: ››Adjustable torque screwdriver - with scale ››With 1/4" female hexagon drive for use with 1/4" hexagon bits as per DIN 3126 - C 6.3 ››With adapter also suitable for 1/4" square drive sockets as per DIN 3124 ››Actuation accuracy: +/- 6 % tolerance of the set value ››Acc. to DIN EN ISO 6789, traceable to national standards ››Precision radial ball clutch and cam design for controlled bi-directional tightening ››Precision mechanism slips very noticeably through when the set torque is reached ››Automatic resetting to the starting position ››"Positive-Lock" system automatically fixes the set value preventing it from wrong setting. ››4 models in the range 0.05 N·m to 9 N·m -" 1/4 1/4 1/4 1/4 IN 20 6.3 6.3 6.3 6.3 a" 1/4 1/4 1/4 1/4 a 6.3 6.3 6.3 6.3 cN·m 8-40 24-120 120-600 400-900 N·m 0,08-0,4 0,24-1,2 1,2-6 4-9   172 y 159 183 196 196 9 1 cN·m 1 cN·m 0,1 N·m 0,1 Nm 680 - 685 0 0.124 0.165 0.340 0.340 Code 1498738 1400150 1400169 1400177 No. 756-00 756-01 756-06 756-09   2 52 302 303 757 TORQUE SCREWDRIVER TYPE S 0.24-9 N·m ››Locking of the value by means of an adjusting knob ››3 models in the range 24 cN·m to 9 N·m ››Micrometre scale graduation: 1 cN·m / 0.1 N·m ››Lightweight construction by virtue of anodised aluminium handgrips Use: ››Controlled screw tightening in the range 24 cN·m - 9 N·m ››High-speed, controlled tightening enables serial production ››Electrical and electronic hardware industry, instrument-making industry and industrial Scope of delivery: manufacturing or in quality control Features: ››Adjustable torque screwdriver with scale ››With 1/4" female hexagon drive for use with 1/4" hexagon bits as per DIN 3126 - C 6.3 ››With adaptor also suitable for 1/4" square drive sockets as per DIN 3124 ››Working accuracy: +/- 6 % tolerance of the set torque ››Acc. to DIN EN ISO 6789, traceable to national standards ››Precision radial ball clutch and cam design for controlled bi-directional tightening ››Precision mechanism slips very noticeably through when set torque is reached ››Automatic resetting to the starting position ››Torque screwdriver type 757 ››1/4" square/hexagon drive adaptor (no. 757-20) ››Models 757-06/-09 with additional sliding T-bar for ease of use ››Test certificate acc. to DIN EN ISO 6789 ››Delivered in sturdy cardboard packaging 757-09 -" 1/4 1/4 1/4 a" 1/4 1/4 1/4 6.3 6.3 6.3 a 6.3 6.3 6.3 cN·m 24-120 120-600 400-900 N·m 0,24-1,2 1,2-6 4-9 9 1,0 cN·m 0,1 N·m 0,1 N·m y 169 184 184 Code 7718050 7718130 7718210 0 0.165 0.400 0.400 No. 757-01 757-06 757-09 758 TORQUE SCREWDRIVER TYPE SP 10-500 cN·m / 14 ozf·in - 40 lbf·in Use: ››In the torque range 0.1 - 5.0 N·m ››For test and installation work in the electrical and electronic hardware industry, instrument-making industry and industrial manufacturing or in quality control Features: ››Dial-indicating torque and test screwdriver - with dual scale (cN·m/ozf·in/lbf·in) ››With 1/4" female hexagon drive for use with 1/4" hexagon bits as per DIN 3126 - C 6.3 ››With adapter also suitable for 1/4" square drive sockets as per DIN 3124 ››Display accuracy: +/- 6 % tolerance of the indicated value ››Acc. to DIN EN ISO 6789, traceable to national standards ››For controlled bi-directional tightening ››With slave-pointer function -" 1/4 1/4 1/4 1/4 6.3 6.3 6.3 6.3 a" 1/4 1/4 1/4 1/4 a 6.3 6.3 6.3 6.3 cN·m 10-50 20-100 50-250 100-500 N·m 0,1-0,5 0,2-1 0,5-2,5 1,0-5,0 ozf·in / lbf·in 14-70 ozf·in 28-140 ozf·in 4-20 lbf·in 8-40 lbf·in ››For locking of maximum values / maximum-value display ››4 models in the range 0.1 N·m to 5.0 N·m ››Lightweight construction by virtue of anodised aluminium handgrips ››EPA-conformant (Electrostatic Protected Area), for use in sensitive electrostatic applications Scope of delivery: ››Torque screwdriver type 758 ››1/4" square/hexagon drive adapter (no. 757-20) ››Models 758-25/-50 with additional sliding T-bar for ease of use ››Test certificate acc. to DIN EN ISO 6789 ››Delivered in sturdy cardboard packaging y 178 178 250 250 9 2 cN·m / 2 ozf·in 5 cN·m / 5 ozf·in 10 cN·m / 0,5 lbf·in 20 cN·m / 1 lbf·in 0 0.190 0.190 0.465 0.465 Code 7096380 7096460 7096540 7096620 No. 758-05 758-10 758-25 758-50 Torque Tools TSN SLIPPER Pre-set ratchet head torque wrench with automatic actuation and slip function. Over-tightening is not possible. Integrated ratchet function Particularly dependable ratchet having 36 teeth (759-00/-01) or 48 teeth (759-02/-03). Slip-through function guarantees controlled and safe screw tightening, even in hard-to-access locations. High repeatability Guarantees constant tightening torques. Rubber handgrip Ergonomic and pleasant to hold in your hand. Prevents slipping. Robust casting part Made of corrosion-resistant, rustproof material. Output square drive Made of quality steel with ball-locking mechanism Working principle TSN SLIPPER Technical information TSN SLIPPER & TBN Breaker When the pre-set torque value is achieved, the mechanism slips through over the ball (without the possibility of over-tightening). The torque wrench is then immediately ready for the next operation. All TSN SLIPPER and TBN BREAKER torque wrenches (apart from 760-00/-01) are fitted with the patented "Mechanical Torque Adjustment Locking Device" to modify torque tester. 304 305 759 Torque wrench TSN SLIPPER 5-125 N·m / pre-set Use: ››Very convenient non-slip rubber handgrip ››The pre-setting can be made at the factory or by the user on suitable torque testers ››If ordering, please specify the N·m value - if a factory pre-setting is desired Features: ››Pre-set production torque wrench - without scale ››1/4", 3/8" or 1/2" square drive with ball locking device ››With integrated ratchet-function for controlled clockwise tightening ››Working accuracy: +/- 4 % tolerance of the set torque ››Acc. to DIN EN ISO 6789, traceable to national standards ››Precision mechanism slips very noticeably and audibly ("click") when the pre-set value is achieved over-tightening is not possible ››Automatic resetting to the starting position ››Lightweight yet robust and corrosion-resistant construction design ››EPA-conformant (Electrostatic Protected Area), for use in ››Controlled screw tightening in the range 5 - 125 N·m ››Serial / production-line assembling ››Extremely long-term work (price on request) sensitive electrostatic applications Scope of delivery: ››Torque wrench type TSN SLIPPER ››Special adjusting key for changing the pre-set torque value ››Test certificate acc. to DIN EN ISO 6789 ››Delivered in sturdy cardboard packaging ››TSN SLIPPER - the pre-set production torque wrench (without scale). ››With this torque wrench, accidental adjustment while working is ruled out. ››The state-of-the-art lightweight production wrenches “slip” through as soon as the set torque is achieved. ››Over-tightening is impossible. ››The ideal torque tool for all jobs where for a longer time only one tightening torque value is required. ››The automatic resetting and integrated ratchet are the ideal assistance for working swiftly. ››TSNs for counter-clockwise tightening, bi-directional tightening without a ratchetfunction or as a VDE-Wrench can be manufactured specially - on request. a" 1/4 3/8 3/8 1/2 a 6.3 10.0 10.0 12.5 N·m 5-25 5-25 15-55 40-125 y 216 216 324 460 0 0.340 0.340 0.800 1.360 Code 7091900 7092040 7092120 7092200 No. 759-00 759-01 759-02 759-03 Torque Tools 761 Torque wrench TSP SLIPPER 1-10 N·m / pre-set ››Extremely lightweight yet robust and corrosion-resistant construction design ››Very convenient non-slip rubber handgrip ››EPA-conformant (Electrostatic Protected Area), for use in Use: ››Controlled screw tightening in the range 1 - 10 N·m ››Ideal for assembly work where controlled tightening with low torque values is required (e.g. electronic hardware sector, precision mechanics etc.) Features: ››Pre-set production torque wrench - without scale ››1/4" square drive with ball locking device ››With integrated ratchet-function for controlled clockwise tightening ››Working accuracy: +/- 6 % tolerance of the set torque ››Acc. to DIN EN ISO 6789, traceable to national standards ››Precision mechanism slips very noticeably and audibly ("click") when the pre-set value is reached - over-tightening is not possible ››Automatic resetting to the starting position ››2 models in the range 1 N·m to 10 N·m sensitive electrostatic applications ››The pre-setting can be made at the factory or by the user on suitable torque testers ››If ordering, please specify the N·m value - if a fixed factory pre-setting is desired (price on request) Scope of delivery: ››Torque wrench type TSP SLIPPER ››Adjusting tool for changing the pre-set torque value ››Test certificate acc. to DIN EN ISO 6789 ››Delivered in sturdy cardboard packaging ››TSP SLIPPER - the pre-set production torque wrench (without scale) for the lower torque range 1 - 10 N·m. ››Accidental adjustment while working is ruled out. ››The built-in ratchet with clockwise tightening and the corrosion-resistant lightweight construction design make this torque wrench the optimum working partner for quick and controlled screw tightening. ››The integrated slipping mechanism reliably prevents over-tightening - the guarantee for high repeatability and controlled tightening values. a" 1/4 1/4 a 6.3 6.3 N·m 1-5 2-10 y 185 185 Code 1196650 1196731 0 0.190 0.190 No. 761-05 761-10 762 Torque wrench TSC SLIPPER 1-10 N·m ››Automatic resetting to the starting position ››Micrometre scale graduation: 0.05 N·m / 0.1 N·m ››2 models in the range 1 N·m to 10 N·m ››Extremely lightweight yet robust and corrosion-resistant construction design ››Very convenient non-slip rubber handgrip ››EPA-conformant (Electrostatic Protected Area), for use in Use: ››Controlled screw tightening in the range 1 - 10 N·m ››Ideal for assembly work where controlled tightening with low torque values is required (e.g. electronic hardware sector, precision mechanics etc.) Features: ››Adjustable torque wrench - with scale ››1/4" square drive with ball locking device ››With integrated ratchet-head function for controlled clockwise tightening ››Working accuracy: +/- 6 % tolerance of set torque ››Acc. to DIN EN ISO 6789, traceable to national standards ››Precision mechanism slips very noticeably and audibly ("click") when the set torque is reached - over-tightening is not possible sensitive electrostatic applications Scope of delivery: ››Torque wrench type TSC SLIPPER ››Test certificate acc. to DIN EN ISO 6789 ››Delivered in sturdy cardboard packaging ››The scale is situated on the body tube. ››The setting is made by rotating the unlocked handgrip with the integrated micrometre ring. ››TSC SLIPPER - the adjustable torque wrenches (with scale) for the lower torque range 1 - 10 N·m. ››The built-in ratchet with clockwise tightening and the corrosion-resistant lightweight construction design make this torque wrench the optimum working partner for quick and controlled screw tightening. ››The integrated slipping mechanism reliably prevents over-tightening - the guarantee for high repeatability and controlled tightening values. a" 1/4 1/4 a 6.3 6.3 N·m 1-5 2-10 y 195 195 9 0,05 N·m 0,1 N·m 0 0.235 0.235 Code 1196480 1196510 No. 762-05 762-10 306 307 TBN BREAKER Pre-set torque wrench with automatic snap actuation. Torque wrench offering maximum accuracy. Guaranteed tightening values without over-tightening. Drive 16 mm spigot end or 9x12 mm rectangular cavity made of quality steel with pin-locking mechanism Breaking All TBN breaking torque wrenches break by 20° at the pivot point when the set torque is achieved. The models 76000/-01 can also be set to a breaking angle of 90°. Rubber handgrip: Ergonomic and pleasant to hold in your hand. Prevents slipping. Lightweight steel tube Firm, solid, and free of corrosion Patented mechanism Guarantees a long product lifespan with guaranteed accuracy values TBN Knicker j 5 - 135 N·m TBN Knicker } 0,2 - 135 N·m As an option, we also manufacture the TBN BREAKER models 760-00/-01 with interchangeable fittings directly positioned on the tool. Working principle TBN BREAKER Technical information TBN BREAKER When the TBN breaking torque wrench is operated, the rear section of the driver unit presses the roller. When the pre-set torque value is achieved, the lever switches over and the front section of the drive unit breaks. TBN BREAKER 760-00/-01 values are changed using the "Double Positive" adjustment system. Torque Tools 760 Breaking torque wrench TBN 0.4-135 N·m / 1.8-1195 lbf·in / pre-set ››No. 760-00/-01: EPA (Electrostatic Protected Area) compliant ››The pre-setting can be made at the factory or by the user on suitable torque testers ››If ordering, please specify the N·m value - if a fixed factory pre-setting is Use: ››Controlled screw tightening in the range 0.4 - 135 N·m ››Serial / production-line assembling ››Extremely long-term work Features: ››Pre-set production torque wrench - without scale ››With 9x12 mm rectangular-cavity-end or 16 mm spigot-end ››For bi-directional tightening (the wrench only has to be turned by 180°!) ››Working accuracy: +/- 4 % tolerance of the set torque ››Acc. to DIN EN ISO 6789, traceable to national standards ››Breaking of the handgrip by 20° (90° also possible in the case of no. 760-00/-01) when the pre-set torque value is achieved makes over-tightening unlikely ››Automatic resetting to the starting position ››Lightweight yet robust and corrosion-resistant construction design ››Very convenient non-slip rubber handgrip desired (price on request) Scope of delivery: ››TBN breaking torque wrench ››Adjusting tool for changing the pre-set torque value ››Test certificate acc. to DIN EN ISO 6789 ››Delivered in sturdy cardboard packaging 760-00 760-35 760-50 ››TBN breaking torque wrench - the pre-set production torque wrench (without scale). ››With this torque wrench, accidental adjustment while working is ruled out. ››The state-of-the-art lightweight production wrenches “break” as soon as the set torque is achieved. ››Over-tightening is unlikely. ››The ideal torque tool for all jobs where for a longer time only one tightening torque value is required. ››For this reason, it is optimally suited for large series. ››However, the TBN breaking torque wrench is also ideal when varying tightening values are required. : 9 x 12 9 x 12 Ø 16 9 x 12 16 9 x 12 16 9 x 12 N·m 0,4-2,0 2-10 5-25 5-25 13-65 13-65 27-135 27-135 lbf·in 1,8-18 17,8-89 44-221 44-221 115-575 115-575 239-1195 239-1195 EPA x x y 105 105 265 265 302 302 408 408 0 0.110 0.130 0.405 0.405 0.745 0.745 1.027 0.830 Code 7090690 7090770 1824686 1824694 1824708 1824716 1824724 7092630 No. 760-00 760-01 760-30 760-35 760-40 760-45 760-50 760-11 308 309 Torque wrench Type 88 8800 Torque wrench Type 88 100-1500 N·m / 70-1000 lbf·ft Use: ››Dual scale in N·m and lbf·ft ››5 models in the range 100 - 1500 N·m Features: ››Adjustable torque wrench - with scale ››3/4"square drive with integrated ratchet-function or 22 mm spigot-end ››Suitable for bi-directional tightening on account of push-through square drive ››Working accuracy: +/- 4 % tolerance of the value setting ››Acc. to DIN EN ISO 6789, traceable to national standards ››Breaking mechanism as an actuation signal which can be seen and felt and makes over-tightening unlikely ››Type 88 breaking torque wrench ››Operating instructions are provided on a label on the torque wrench ››Test certificate acc. to DIN EN ISO 6789 ››Delivered in sturdy cardboard packaging ››Controlled screw tightening in the range 100 - 1500 N·m ››Industry and vehicle sector (lorries, industrial vehicles), machine maintenance a" 3/4 3/4 3/4 3/4 a 20 20 20 20 Ø 22 N·m 100-500 150-700 300-1000 700-1500 130-550 lbf·ft 70-350 100-500 200-750 500-1000 100-400 Scope of delivery: y 915 1090 1470 1470 915 9 10 N·m 10 N·m 20 N·m 25 N·m 10 N·m 0 5.5 6.0 7.3 10.5 4.8 Code 7715700 7715890 7716000 7716190 7716270 No. 8800-01 8800-02 8800-03 8800-04 8800-06 Torque Tools Torque wrench Type 83 Torque wrenches with slave pointer Ideal for test, control and maintenance work Clear product identification: Provided by the type plate/lable. The article number and the serial number always ensure traceability in the scope of your test- and checking-tool management. Practical handgrip: Handgrip shaped in accordance with the most recent ergonomic findings. Resistant to grease and oil. Solid tube: Light-metal tube with plastic sleeving. Dual scale: N·m and lbf·in/lbf·ft with main and slave pointers, protected by a strong window made of Trogamid "T". Integrated ratchet spindle: With double square drive enables highspeed bi-directional tightening. Features The working principle of the torque wrench with slave pointer type 83 8301 - 8305 Torque wrench with slave pointer Type 83 0.8-2000 N·m / 7 lbf·in - 1500 lbf·ft Use: Scope of delivery: ››Controlled tightening and verification of tightening values ››For use in all areas of industrial manufacturing and in quality control ››Working ranges of 0.8 to 2000 N·m are covered ››Dial-measuring torque wrench type 83 ››Battery (models 8303-40 to 8305-20) ››Test certificate acc. to DIN EN ISO 6789 ››Delivered in a sturdy black plastic box (no. 8301-04 to 8302-20), otherwise in sturdy Features: ››Dial-indicating torque wrench with dual scale and slave pointer ››1/4", 3/8", 1/2", 3/4" or 1" double-square drive with ball locking device cardboard packaging (no. 8303-40 to 8305-20) for controlled bi-directional tightening ››Models 8301-04 to 8304-80: With integrated ratchet-function ››For controlled screw tightening and torque measurements ››Working accuracy: +/- 4 % tolerance of the indicated torque ››Acc. to DIN EN ISO 6789, traceable to national standards ››With dual scale in N·m and lbf·in or lbf·ft double-tinted clearly readable face ››Integrated overload protection - mechanical stop up to max. 25 % overload of the maximum value ››Housing made of lightweight, robust special aluminium construction - lacquered, silver-grey ››Black, non-slip rubber handgrips ››Models 8301-04 to 8301-40: EPA-conformant (Electrostatic Protected Area), 8305-14 for use in sensitive electrostatic applications ››Audio-visual signal is standard on models 8303-40 to 8305-20 Type t t t t t t t t t t a" 1/4 1/4 3/8 3/8 1/2 1/2 3/4 3/4 1 1 a 6,3 6,3 10,0 10,0 12,5 12,5 20,0 20,0 25,0 25,0 N·m 0,8-4 2,4-12 5-25 8-40 16-80 40-200 80-400 160-800 280-1400 400-2000 lbf·in 7-35 22-120 44-240 72-360 lbf·ft 12-60 30-160 60-300 120-600 200-1000 300-1500 8305-20 EPA x x x x y 244 244 244 244 435 515 710 1000 2040 2040 9 0,1 N·m / 1 lbf·in 0,5 N·m / 2 lbf·in 1 N·m / 10 lbf·in 1 N·m / 10 lbf·in 2 N·m / 1 lbf·ft 5 N·m / 5 lbf·ft 10 N·m / 10 lbf·ft 20 N·m / 20 lbf·ft 25 N·m / 25 lbf·ft 50 N·m / 50 lbf·ft Height 61 61 69 69 86 86 111 123 138 138 0 0,5 0,5 0,5 0,5 1,4 1,4 3,2 4,8 16,7 16,7 Code 7651390 7651470 7651550 7651630 7651710 7651980 7652280 7652010 1196790 1196804 No. 8301-04 8301-12 8301-25 8301-40 8302-08 8302-20 8303-40 8304-80 8305-14 8305-20 310 311 Electronic torque wrench E-torc Q Powerful. Variable. Holders: Rectangular-cavity SE 9x12 (E-torc Q 100) and SE 14x18 (E-torc Q 200, 300) Flexible. Positional. Easy-to-handle: Housing-oriented tool holding fixture rotatable through 60° in both directions (120°) All the standard measurement methods: ››Torque ››Torque/rotary angle ››Loosening/tightening ››First movement ››Yield point ››High measurement accuracy e.g. torque +/- 1 %, +/- 1 digit ››Virtual progress bar for torque and angle Extensively. Resilient. Large TFT graphics display of a 109 mm (4.3") diagonal with touch function. This makes a gloves operation possible. Intuitive. Visible. Touch function or six hardware keys for intuitive user software operating and, in addition, an extremely robust enter key. Communication to the high-capacity PC user software or attachment to CAQ systems (optional) ››Clear depiction of the measurement results Ergonomic. Safe. The ergonomic handle ensures easy, safe handling - even with large tightening torques. High-performance lithium-ion rechargeable battery with rapid changing system Charging unit for two lithium-ion rechargeable batteries (optional) ››A variety of users and a user account management can be set up ››Management of fitting and depth gauge parameters ››Measured value compilation and assessment ››Graph representation and evaluation directly possible at E-torc Q ››Wireless (Wi-Fi 2.4 and 5 GHz) or USB mini interface for communication purposes ››Acoustic, visual or vibrationinduced signalling ››Touch screen for clear objective input ››Operating with workflows Only available in Germany, Austria and Switzerland. Further information from: GEDORE TorqueTech GmbH, Solingen ››2D scanner (optional) for reading in barcodes and QR codes Torque Tools Electronic Torque Wrenches ET2SA Electronic torque wrench E-torc 2-1000 N·m / 1.5-750 lbf·ft, with rotary angle measurement Tightening check for torque/rotary angle: Version: ››Optical, acoustic and sensory signalling on reaching the set bolting parameter/with additional ››Large field of operation: 5 models in the range from 2 to 1000 N·m ››Tool holding fixture 1/4" square, 9x12, 14x18 rectangular cavity with pin-locking visualisation of screw tightening by means of LED progress bar. ››Software-enabling graphics evaluation. ››Marked contrast graphics display with backdrop lighting mechanism, 22 and 28 mm spigot end ››Signalling: visual (LED progress bar), acoustic (beep), sensory (vibration) ››Tool holding fixture, as of ET2SKA 150 120° rotatable to the aluminium housing ››Traceable to national standards ››Torque reading precision +/- 1 %, +/- 1 digit from reading figure ››Factory certificate as per DIN ISO 6789 Type I Class C ››Optional certificate as per DAkkS-DKD-R 3-7 ››Rotary angle calibration based on VDI 2648 Sheet 2 ››Backlit graphic display ››Input of depth gauges for a variety of attachment tools ››Power supply: Battery or rechargeable battery operation Drive: ››Spigot end 22/28 mm, 1/4" square drive or 9x12/14x18 mm rectangular cavity with pin-locking mechanism. The installation size determines the drive (model-dependent) ››ET2SKA 150 and ET2SKA 300 incl. 1/2" rectangular reversible ratchet head ››For hard-to-access places and given not enough room. ››Special tools on request. Light and pleasant: ››The aluminium housing and ergonomic handle ensure easy, safe handling - even with large tightening torques. ››Tool holding fixture, as from ET2SKA 150 120° rotatable to the aluminium housing Evaluation: ››Reading a max. 2,000 data records ››Serial interface RS232 for PC (USB adapter enclosed) ››Comprehensive documentation of all screw parameters Function keys: ››Easy to use ››Key pressure taring ››Side ergonomic operating key ››Convertible from N·m to lbf·ft via software Fields of operation: ››Mini-batch assembly ››Quality assurance ››Test labs and testing departments ››Emergency strategies for bolting stations ››Corrective work places ››Inspection and analysis of bolted connections Scope of delivery: Drehmoment ››Electronic torque wrench Etorc2S/A ››Operating instructions with brief guide ››Test certificate acc. to DIN EN ISO 6789:2003 Type I Class C ››2 standard Mignon AA batteries ››Evaluating software and data transmission cable RS232 and USB ››ET2SKA 150 and ET2SKA 300 incl. 1/2" rectangular reversible ratchet head ››Delivered in a robust sheet-metal case with insert Winkel Torque/Angle Editor Main screen Settings a" 1/4 1/2 1/2 a 6.3 12.5 12.5 : Ø 9 x 12 14 x 18 22 28 Parameter N·m 2-25 10-150 30-300 100-600 100-1000 Curve diagram lbf·ft 1,5-18 7-111 22-221 74-443 74-750 lw 275 457 696 990 1423 a 35 35 35 35 40 b 45 45 45 45 45 c 17.5 25.0 56.0 75.0 d 347 514 753 1055 1488 0 0.8 1.3 1.8 3.2 5.7 Code 2795493 2795612 2795620 2795639 2795655 No. ET2SKA 25 ET2SKA 150 ET2SKA 300 ET2SZA 600 ET2SZA 1000 312 313 TT3KH Electronic torque wrench TorcoTronic III 10-350 N·m / 7.4-258.2 lbf·ft Scope of delivery: Use: ››For everyday requirements in installation and torque control ››For use in all areas of manufacturing and development Features: ››Microprocessor-controlled, electronic torque wrench ››For controlled bi-directional tightening ››Acc. to DIN EN ISO 6789, traceable to national standards ››Robust workshop design ››Broad measurement range in N·m, can be switched to lbf·ft ››With 1/2" reversible ratchet. The ratchet is exchangeable, providing the option of using a 9x12 mm ››Electronic torque wrench TorcoTronic III HighLine ››Reversible ratchet 1/2" ››USB cable ››Software on CD-R ››Test certificate acc. to DIN EN ISO 6789:2003 Type I Class C ››Delivered in a transparent plastic box with insert Attention: ››A PC, running a Windows® operating system (from Windows XP®) is required to obtain the full benefit of all the functions of this product. (TT3H 120) or 14x18 mm (TT3H 350) square socket Characteristics: ››Torque and torque angle measure ››4 different measuring modes ››5 parameters storable ››USB interface for data exchange ››2000 storage places ››Measurement accuracy torque +/- 1 %, +/- 1 digit ››Measurement accuracy torque angle +/- 1 %, but min. +/- 1° on 360° with min. 4°/sec ››Different depth gauges for end fittings programmable ››Simple to operate with easy to understand Icon-menu navigation and 4 functional keys ››Clearly readable, illuminated LCD display ››Resolution torque: 0.1 N·m ››Resolution torque angle: 0.1° ››PC-software easy to operate for uncomplicated programming and documentation of data ››Data can be transfered to MS Excel® ››Keyboard lock ››Operation with standard Mignon AA or optional with rechargeable-battery (NiMH) ››Visual signal: 3x LED (yellow, green, red) ››Acoustic signal: buzzer ››TÜV certified, CE and RoHS ››2 models in the range 10 - 350 N·m ››Test certificate acc. to DIN EN ISO 6789:2003 Type I Class C ››Calibration to DAkkS-DKD-R 3-7, Class 1 (on request) Main menu a" 1/2 1/2 Settings a 12.5 12.5 : 9 x 12 14 x 18 Evaluation Parameter N·m 10-120 70-350 lbf·ft 7,4-88,5 51,6-258,2 0 0.9 1.2 Code 2648636 2648644 No. TT3KH 120 TT3KH 350 Torque Tools Torque calibration analysers 8612 Electronic torque tester DREMOTEST E 0.2-3150 N·m / 1.8 lbf·in - 2323 lbf·ft ››For verifying and setting clockwise torque wrenches and torque screwdrivers ››Easy to operate, electronic torque tester with integrated torque transducer (DMS) ››5 models in the range from 0.2 to 3150 N·m ››With fixed hexagon female drive 1/4", 10, 17, 36, 46 mm or Scope of delivery: ››Electronic torque tester ››RS232 cable ››Power supply unit with EURO plug (UK, US, AUS-adaptor on request) ››100 - 240 V, 50 - 60 Hz, max. 500 mA (see type plate) ››2 sockets (size and drive model-dependent) ››Adaptor for 8612-3150 ››Operating instructions ››Packaging 1.1/2" square drive adaptor (model dependent) ››With 1/4", 3/8", 1/2", 3/4", 1" square drive adaptor or bit adaptor (model dependent) ››High measurement accuracy: +/- 1 % tolerance of reading, +/- 1 digit ››Break-Point-measurement (1st peak) ››Autoreset ››Can be switched from N·m to lbf·ft ››Serial interface RS232 ››Optionally available: adaptor for cigarette lighter socket (12 V), no. 8612-390 8612-3150 8612-300 N·m 0,2-12 0,9-55 9-320 90-1100 500-3150 lbf·in 1,8-106 Optional accessories: Description Adaptor for cigarette lighter socket lbf·ft 0,7-40,6 7-236 66-811 369-2323 6.3 10.0 17.0 36.0 Resolution 0,001 0,01 0,1 1 1 Adaptor Q 1/4", 3/8" 1/4", 3/8" 3/8", 1/2" 1/2", 3/4" 1" 0 3.0 3.0 3.0 10.0 26.0 0 0.150 Code 2288311 1947699 1856111 1947702 2529858 Code 1878719 No. 8612-012 8612-050 8612-300 8612-1000 8612-3150 No. 8612-390 314 315 Torsion test device E-tp ETP Electronic torsion test device ››For testing, and verifying clockwise and anti-clockwise torque wrenches ››5 models in the range of 0.5 to 3150 N·m ››Vertical and horizontal testing according to DIN EN ISO 6789 ››Electronic torque tester integrated with measurement electronics ››Robust housing from aluminium cast with separate or detachable operating display ››Serial interface RS232 for PC ››Traceable to national standards ››ETP 15 with integrated overload protection and tool for manual resetting after unintended overload ››Torque reading precision +/- 1 %, +/- 1 digit from reading figure ››Factory certificate based on VDI 2646 ››Optional certificate as per DAkkS-DKD-R 3-8 ››A large LC graphic display ››Wide measuring range in N·m, can be switched to cN·m, lbf·ft or lbf·in (model dependant) ››Power supply unit with EURO plug (UK, US, AUS-adaptor on request) ››Accessories: Operating display, display holder incl. cable, software incl. connection cable for PC Q" 1/4 1/2 3/4 3/4 1.1/2 Q 6.3 12.5 20.0 20.0 40.0 N·m 0,5-15 4-100 20-500 50-1000 300-3150 lbf·ft 0,4-11 3-74 14,8-369 36,9-737,6 221-2323 Resolution 0,001 N·m 0,01 N·m 0,1 N·m 0,1 N·m 1,0 N·m Adaptor 1/4", 3/8" 3/8", 1/2" 3/8", 1/2" 3/4", 1" Code 2795663 2795701 2795728 2795868 2795884 0 4.8 10.0 10.3 10.3 26.8 No. ETP 15 ETP 100 ETP 500 ETP 1000 ETP 3150 ETPG Basic housing ››From aluminium cast (except ETP3150) ››Serial interface RS232 for PC ››Traceable to national standards with factory certificate ››High measurement accuracy: +/- 1 % tolerance of reading, +/- 1 digit ››ETPG 15 with integrated overload protection and tool for manual resetting after unintended overload ››Wide measuring range in N·m, can be switched to cN·m, lbf·ft or lbf·in ››Power supply unit with EURO plug (UK, US, AUS-adaptor on request) Q" 1/4 1/2 3/4 3/4 1.1/2 Q 6.3 12.5 20.0 20.0 40.0 N·m 0,5-15 4-100 20-500 50-1000 300-3150 lbf·ft 0,4-11 3-74 14,8-369 36,9-737,6 221-2323 Resolution 0,001 N·m 0,01 N·m 0,1 N·m 0,1 N·m 1,0 N·m Adaptor 1/4", 3/8" 3/8", 1/2" 3/8", 1/2" 3/4", 1" 0 4.0 9.2 9.5 9.5 26.0 Code 2795892 2795906 2795914 2795930 2795957 No. ETPG 15 ETPG 100 ETPG 500 ETPG 1000 ETPG 3150 Torque Tools Torque angle indicator Torque angle indicator 8200 ››When using torque angle indicator no. 8200, please note: The maximum output of the torque wrenches must not be passed. Please ensure that the maximum load capacity of the square drive including the values achieved by angle-regulated tightening is not exceeded: ››1/2" max. approx. 390 N·m ››3/4" max. approx. 1330 N·m 8200 Torque angle indicator Use: ››Additional angle-regulated tightening for controlled torque and angle activation Features: ››Torque angle indicator with 1/2" or 3/4" square drive ››For additional precise angle tightening (0 - 360°) ››1/2" square drive with ball locking device or 3/4" square drive with pin locking device ››No. 8200-01/-02 models with sliding magnetic and gripping arm ››No. 8200-11 only with magnetic arm - simple design ››To operate with a suitable torque wrench ››The maximum output of the torque wrench must not be passed Scope of delivery: ››Torque angle indicator ››Delivered in a strong plastic case (no. 8200-01/-02), model no. 8200-11 in sturdy hard cardboard packaging 8200-01 8200-02 8200-11 a" 1/2 1/2 3/4 Q" 1/2 1/2 3/4 , 80 82 120 A° 0-360 0-360 0-360 0 0.330 0.330 0.530 Code 1195980 7718480 7716510 No. 8200-01 8200-11 8200-02 316 317 Accessories End fittings 16 Z 8791 (MM) Open end fitting 16 Z ››For accessing bolts in cramped and hard-to-reach locations, easy to change ››Forged ››Chrome-vanadium steel, matt chrome-plated ››With eject-pin for unlocking ! 7 8 9 10 11 12 13 14 15 16 17 18 19 Ø 16 16 16 16 16 16 16 16 16 16 16 16 16 4 5 5 5 7 7 7 8 8 8 9 9 9 10 r 20.5 20.5 20.5 29.0 29.0 29.0 34.5 34.5 34.5 41.5 41.5 41.5 45.0 Depth gauge 32 32 32 32 32 32 32 32 32 32 32 32 32 0 0.080 0.080 0.080 0.090 0.090 0.090 0.120 0.120 0.120 0.160 0.160 0.160 0.180 Code 7774470 7774550 7774630 7710070 7710150 7676890 7710230 7710310 7710580 7710660 7710740 7676970 7710820 No. 8791-07 8791-08 8791-09 8791-10 8791-11 8791-12 8791-13 8791-14 8791-15 8791-16 8791-17 8791-18 8791-19 ! 20 21 22 23 24 25 26 27 28 29 30 32 36 Ø 16 16 16 16 16 16 16 16 16 16 16 16 16 No. 8791-1/4AF 8791-5/16AF 8791-3/8AF 8791-7/16AF 8791-1/2AF 8791-9/16AF 8791-5/8AF 8791-11/16AF 8791-3/4AF 8791-13/16AF 8791-7/8AF 8791-15/16AF " 1 1.1/16 1.1/8 1.3/16 1.1/4 1.5/16 Ø 16 16 16 16 16 16 4 10 10 11 11 11 11 11 12 12 12 12 12 12 r 45.0 45.0 56.0 56.0 56.0 56.0 56.0 60.5 68.0 68.0 68.0 68.0 68.0 Depth gauge 32 32 32 32 32 32 32 32 32 32 32 32 32 0 0.180 0.180 0.220 0.220 0.220 0.220 0.220 0.260 0.300 0.300 0.300 0.300 0.300 Code 7710900 7677000 7711040 1977164 7711120 1552279 1552287 7711200 1207008 1552309 7774710 7774980 1552317 No. 8791-20 8791-21 8791-22 8791-23 8791-24 8791-25 8791-26 8791-27 8791-28 8791-29 8791-30 8791-32 8791-36 8791 (AF) Open end fitting 16 Z ››For accessing bolts in cramped and hard-to-reach locations, easy to change ››Forged ››Chrome-vanadium steel, matt chrome-plated ››With eject-pin for unlocking " 1/4 5/16 3/8 7/16 1/2 9/16 5/8 11/16 3/4 13/16 7/8 15/16 Ø 16 16 16 16 16 16 16 16 16 16 16 16 4 5 5 7 7 8 8 9 9 10 10 11 11 r 20.5 20.5 29.0 29.0 34.5 34.5 41.5 41.5 45.0 45.0 56.0 56.0 Depth gauge 32 32 32 32 32 32 32 32 32 32 32 32 0 0.090 0.080 0.090 0.090 0.090 0.120 0.160 0.160 0.180 0.090 0.220 0.220 Code 1211421 7720030 1211447 7720110 7720380 7720460 7720540 7720620 7720700 1211439 7720890 7720970 4 11 12 12 12 12 12 r 56.0 60.5 68.0 68.0 68.0 68.0 Depth gauge 32 32 32 32 32 32 0 0.220 0.260 0.300 0.300 0.300 0.300 Code 7721000 7721190 7721270 7776170 7776250 7776330 No. 8791-1AF 8791-1.1/16AF 8791-1.1/8AF 8791-1.3/16AF 8791-1.1/4AF 8791-1.5/16AF Torque Tools 8792 (MM) Ring end fitting 16 Z ››For accessing bolts in cramped and hard-to-reach locations, easy to change ››Forged ››Chrome-vanadium steel, matt chrome-plated ››With eject-pin for unlocking ! 7 8 9 10 11 12 13 14 15 16 Ø 16 16 16 16 16 16 16 16 16 16 4 8 8 8 10 10 10 12 12 12 13 r 15.0 15.0 15.0 19.5 19.5 19.5 23.5 23.5 23.5 28.5 Depth gauge 32 32 32 32 32 32 32 32 32 32 Code 7775010 7775280 7775360 7712600 7712790 7677190 7712870 7712950 7713090 7713170 0 0.090 0.090 0.090 0.100 0.100 0.100 0.140 0.140 0.140 0.180 No. 8792-07 8792-08 8792-09 8792-10 8792-11 8792-12 8792-13 8792-14 8792-15 8792-16 ! 17 18 19 20 21 22 23 24 27 Ø 16 16 16 16 16 16 16 16 16 No. 8792-1/4AF 8792-5/16AF 8792-3/8AF 8792-7/16AF 8792-1/2AF 8792-9/16AF 8792-5/8AF " 11/16 3/4 13/16 7/8 15/16 1 1.1/16 Ø 16 16 16 16 16 16 16 ! 16 17 18 19 20 21 22 24 27 Ø 16 16 16 16 16 16 16 16 16 4 13 13 14 14 14 15 15 15 16 r 28.5 28.5 31.5 31.5 31.5 39.5 39.5 39.5 41.5 Depth gauge 32 32 32 32 32 32 32 32 32 Code 7713250 7677270 7713330 7713410 7677350 7713680 1211471 7713760 7713840 0 0.180 0.180 0.210 0.210 0.210 0.260 0.270 0.260 0.300 No. 8792-17 8792-18 8792-19 8792-20 8792-21 8792-22 8792-23 8792-24 8792-27 8792 (AF) Ring end fitting 16 Z ››For accessing bolts in cramped and hard-to-reach locations, easy to change ››Forged ››Chrome-vanadium steel, matt chrome-plated ››With eject-pin for unlocking " 1/4 5/16 3/8 7/16 1/2 9/16 5/8 Ø 16 16 16 16 16 16 16 4 8 8 10 10 12 12 13 r 15.0 15.0 19.5 19.5 23.5 23.5 28.5 Depth gauge 32 32 32 32 32 32 32 0 0.100 0.090 0.100 0.100 0.100 0.140 0.140 Code 1211455 7721350 1211498 7721430 7721510 7721780 7721860 4 13 14 14 15 15 15 16 r 28.5 31.5 31.5 39.5 39.5 39.5 41.5 Depth gauge 32 32 32 32 32 32 32 0 0.180 0.210 0.100 0.260 0.260 0.300 0.300 Code 7721940 7722080 1211463 7722160 7722240 7722320 7722400 No. 8792-11/16AF 8792-3/4AF 8792-13/16AF 8792-7/8AF 8792-15/16AF 8792-1AF 8792-1.1/16AF 8797 Flared end fitting 16 Z ››For accessing bolts in cramped and hard-to-reach locations, easy to change ››Forged ››Chrome-vanadium steel, matt chrome-plated ››With eject-pin for unlocking ! 7 8 9 10 11 12 13 14 15 Ø 16 16 16 16 16 16 16 16 16 4 8 8 8 10 10 10 12 12 12 r 15.0 15.0 15.0 19.5 19.5 19.5 23.5 23.5 23.5 max. N·m 7.0 6.5 5.5 26.0 19.0 13.0 34.0 24.0 18.0 c1 5.5 6.0 6.5 7.0 8.5 9.0 10.0 11.2 12.0 Depth gauge 32 32 32 32 32 32 32 32 32 0 0.090 0.090 0.090 0.100 0.100 0.120 0.140 0.140 0.140 Code 1211587 1211595 1211609 1211625 1211633 1211641 1211668 7664290 1211684 No. 8797-07 8797-08 8797-09 8797-10 8797-11 8797-12 8797-13 8797-14 8797-15 4 13 13 13 14 14 14 15 15 16 r 28.5 28.5 28.5 31.5 31.5 31.5 39.5 39.5 41.5 max. N·m 66.0 56.0 45.0 80.0 60.0 43.0 172.0 118.0 76.0 c1 13.0 14.0 14.5 15.0 16.0 16.5 17.0 18.0 20.0 Depth gauge 32 32 32 32 32 32 32 32 32 0 0.180 0.180 0.200 0.210 0.210 0.210 0.260 0.260 0.300 Code 1211692 1211706 1211714 1211722 1211731 1211749 1211757 1211773 1211781 No. 8797-16 8797-17 8797-18 8797-19 8797-20 8797-21 8797-22 8797-24 8797-27 318 319 8754 Ratchet head 16 Z ››For accessing bolts in cramped and hard-to-reach locations, easy to change ››Forged ››Chrome-vanadium steel, matt chrome-plated ››With eject pin for unlocking ››Max. continuous load of ratchet according to DIN EN ISO 6789:2003 and/or maximum load of cavity 8754-01 8754-02 a" 3/8 1/2 a 10.0 12.5 Ø 16 16 Type 2 2 Depth gauge 32 32 Continuous load 3/8" = 135 N·m 1/2" = 340 N·m 0 0.170 0.270 Code 7711980 7712010 No. 8754-01 8754-02 8756 End fitting in-hex 8790 - 8793 Fixed square head 16 Z 16 Z ››For accessing bolts in cramped and hard-to-reach ››For accessing bolts in cramped and hard-to-reach locations, easy to change ››Forged ››Chrome-vanadium steel, matt chrome-plated ››With eject pin for unlocking ››Max. continuous load of ratchet according to DIN EN ISO 6789:2003 and/or maximum load of cavity locations, easy to change ››Forged ››Chrome-vanadium steel, matt chrome-plated ››With eject-pin for unlocking $ 3 4 5 6 8 Ø 16 16 16 16 16 Depth gauge 32 32 32 32 36 0 0.100 0.100 0.100 0.100 0.110 Code 7773740 7773820 7773900 7774040 7774120 No. 8756-03 8756-04 8756-05 8756-06 8756-08 Ø a" a 3/8 10.0 16 1/2 12.5 16 Type 5 5 Depth gauge Continuous load 32 3/8" = 135 N·m 32 1/2" = 340 N·m 0 Code 0.350 7709490 0.380 7709570 No. 8790-00 8793-00 Torque Tools End fittings 22 Z 8794-00 Fixed square head 22 Z ››For accessing bolts in cramped and hard-to-reach locations, easy to change ››Forged ››Chrome-vanadium steel, matt chrome-plated a" 3/4 Ø 22 a 20 Type 5 Depth gauge 56 Continuous load 3/4" = 850 N·m Code 7708840 0 0.610 No. 8794-00 8795 Open end fitting 22 Z ››For accessing bolts in cramped and hard-to-reach locations, easy to change ››Forged ››Chrome-vanadium steel, matt chrome-plated ››With eject-pin for unlocking ! 22 24 27 30 32 Ø 22 22 22 22 22 4 11 11 12 12 12 r 52.0 52.0 64.0 64.0 75.5 Depth gauge 56 56 56 56 56 0 0.330 0.320 0.380 0.370 0.450 Code 7707010 7707280 7707360 7707440 7707520 No. 8795-22 8795-24 8795-27 8795-30 8795-32 ! 34 36 41 46 Ø 22 22 22 22 4 12 12 12 12 r 75.5 75.5 94.0 94.0 Depth gauge 56 56 56 56 0 0.430 0.430 0.580 0.530 Code 7677430 7707600 7707790 7707870 No. 8795-34 8795-36 8795-41 8795-46 No. 8796-22 8796-24 8796-27 8796-30 8796-32 ! 34 36 41 46 Ø 22 22 22 22 4 20 20 22 22 r 54.0 54.0 68.0 68.0 Depth gauge 56 56 56 56 0 0.420 0.390 0.560 0.520 Code 7677510 7708410 7708680 7708760 No. 8796-34 8796-36 8796-41 8796-46 8796 Ring end fitting 22 Z ››For accessing bolts in cramped and hard-to-reach locations, easy to change ››Forged ››Chrome-vanadium steel, matt chrome-plated ››With eject-pin for unlocking ! 22 24 27 30 32 Ø 22 22 22 22 22 4 15 15 17 17 20 r 38.0 38.0 46.5 46.5 54.0 Depth gauge 56 56 56 56 56 0 0.350 0.330 0.370 0.350 0.420 Code 7707950 7708090 7708170 7708250 7708330 320 321 8794-02 - 8794-03 Ratchet head 22 Z 8794-02 ››For accessing bolts in cramped and hard-to-reach locations, easy to change ››Forged ››Chrome-vanadium steel, matt chrome-plated ››With eject-pin for unlocking a" 3/4 3/4 Ø 22 22 a 20 20 8794-03 8794-02 Type 2 2 Depth gauge 56 56 8794-03 Continuous load 3/4" = 850 N·m 3/4" = 850 N·m 0 1.011 0.950 Code 2961385 1427318 No. 8794-02 8794-03 ! 60 65 70 75 Ø 28 28 28 28 4 24.5 28.0 30.0 31.5 r 129.5 140.5 151.0 163.0 Depth gauge 75 75 75 100 0 2.1 2.4 2.9 4.0 Code 1565397 1565400 1565419 1565427 No. 8798-60 8798-65 8798-70 8798-75 ! 60 65 70 75 80 Ø 28 28 28 28 28 4 26.0 29.0 32.5 34.0 35.0 r 94 101 110 117 123 Depth gauge 75 75 75 100 100 0 2.5 2.9 2.0 4.5 4.8 Code 1565540 1565559 1565567 1565575 1565583 No. 8799-60 8799-65 8799-70 8799-75 8799-80 End fittings 28 Z 8798 Open end fitting 28 Z ››For accessing bolts in cramped and hard-to- reach locations, easy to change ››Chrome-vanadium steel, matt chrome-plated ! 36 41 46 50 55 Ø 28 28 28 28 28 4 18.0 19.5 20.0 21.5 24.5 ››With catch retention ››Special sizes available on request Depth gauge 75 75 75 75 75 r 77.5 89.0 99.0 108.0 118.5 0 1.9 1.9 1.9 1.9 2.1 Code 1565346 1565354 1565362 1565370 1565389 No. 8798-36 8798-41 8798-46 8798-50 8798-55 8799 Ring end fitting 28 Z ››For accessing bolts in cramped and hard-to- reach locations, easy to change ››Chrome-vanadium steel, matt chrome-plated ! 36 41 46 50 55 Ø 28 28 28 28 28 4 19.5 20.5 22.5 23.5 25.0 r 60 66 75 80 88 ››With catch retention ››Special sizes available on request Depth gauge 75 75 75 75 75 0 1.6 1.8 2.1 2.2 2.4 Code 1565494 1565508 1565516 1565524 1565532 No. 8799-36 8799-41 8799-46 8799-50 8799-55 8794 Ratchet head 28 Z ››For accessing bolts in cramped and hard-to- reach locations, easy to change ››Chrome-vanadium steel, matt chrome-plated ››With catch retention ››Max. continuous load of coupler according to DIN EN ISO 6789:2003 and/or maximum support load: 1000 N·m a" 3/4 a 20 Ø 28 Type 2 Depth gauge 0 75 1.8 Code 1566032 No. 8794-05 Torque Tools End fittings 9x12 SE 7112 Rectangular open end fitting 9x12 ››For accessing bolts in cramped and hard-to-reach locations, easy to change ››Forged ››Chrome-vanadium steel, matt chrome-plated ››With eject-pin for unlocking ! 7 8 9 10 11 12 13 14 : 9 x 12 9 x 12 9 x 12 9 x 12 9 x 12 9 x 12 9 x 12 9 x 12 4 5.5 5.5 5.5 5.5 5.5 5.5 5.5 7.5 r 20.0 21.5 23.0 24.5 26.0 27.5 29.0 31.0 Depth gauge 17.5 17.5 17.5 17.5 17.5 17.5 17.5 20.0 0 0.035 0.035 0.035 0.040 0.030 0.035 0.035 0.040 Code 7688390 7688550 7679050 7688630 7688980 7679560 7689010 7689360 No. 7112-07 7112-08 7112-09 7112-10 7112-11 7112-12 7112-13 7112-14 ! 15 16 17 18 19 : 9 x 12 9 x 12 9 x 12 9 x 12 9 x 12 4 7.5 7.5 7.5 7.5 7.5 : 9 x 12 9 x 12 9 x 12 9 x 12 9 x 12 9 x 12 9 x 12 4 12 13 13 13 13 15 15 r 33.0 35.0 37.0 39.0 41.0 Depth gauge 20.0 20.0 20.0 20.0 20.0 0 0.040 0.045 0.050 0.060 0.060 Code 7689440 7679990 7689600 7684560 7689790 No. 7112-15 7112-16 7112-17 7112-18 7112-19 7212 Rectangular ring end fitting 9x12 ››For accessing bolts in cramped and hard-to-reach locations, easy to change ››Forged ››Chrome-vanadium steel, matt chrome-plated ››With eject-pin for unlocking ! 7 8 10 11 12 13 14 : 9 x 12 9 x 12 9 x 12 9 x 12 9 x 12 9 x 12 9 x 12 4 8 8 8 8 12 12 12 r 13.0 14.2 17.2 18.6 20.0 21.5 23.0 Depth gauge 17.5 17.5 17.5 17.5 17.5 17.5 17.5 0 0.030 0.030 0.030 0.030 0.035 0.035 0.040 Code 7691340 7691420 7691690 7691770 7677940 7691930 7692230 No. 7212-07 7212-08 7212-10 7212-11 7212-12 7212-13 7212-14 ! 15 16 17 18 19 21 22 r 24.0 26.0 27.0 28.5 30.5 33.0 34.5 Depth gauge 17.5 17.5 17.5 17.5 17.5 17.5 17.5 0 0.040 0.040 0.040 0.040 0.040 0.050 0.050 Code 7692580 7678080 7692740 7678160 7692820 7678240 7693040 No. 7212-15 7212-16 7212-17 7212-18 7212-19 7212-21 7212-22 7312 Rectangular flared end fitting 9x12 ››For accessing bolts in cramped and hard-to-reach locations, easy to change ››Forged ››Chrome-vanadium steel, matt chrome-plated ››With eject-pin for unlocking ! 10 11 12 13 14 : 9 x 12 9 x 12 9 x 12 9 x 12 9 x 12 4 12 12 12 12 13 r 21.0 22.5 24.0 25.0 27.0 Opening width 7.3 8.7 9.0 10.0 11.0 Depth gaugea 17.5 17.5 17.5 17.5 17.5 0 0.040 0.040 0.040 0.040 0.050 Code 7685290 7685370 7699590 7679210 7679480 No. 7312-10 7312-11 7312-12 7312-13 7312-14 ! 17 18 19 22 : 9 x 12 9 x 12 9 x 12 9 x 12 4 13 15 15 15 r 31.5 33.0 34.5 39.0 Opening width 14.0 14.7 15.3 17.0 Depth gaugea 17.5 17.5 17.5 17.5 0 0.065 0.065 0.065 0.065 Code 7685880 7679640 7686260 7679720 No. 7312-17 7312-18 7312-19 7312-22 322 323 7412 Rectangular reversible ratchet head 9x12 ››For accessing bolts in cramped and hard-to-reach locations, easy to change ››Forged ››Chrome-vanadium steel, matt chrome-plated ››With eject-pin for unlocking ››Fine-toothed ››Return angle 5 degrees ››Max. continuous load of ratchet according to DIN EN ISO 6789:2003 and/or maximum load of cavity a" 1/4 3/8 1/2 a 6.3 10.0 12.5 : 9 x 12 9 x 12 9 x 12 A° 5 5 5 4 16.6 23.2 24.2 r 25 34 34 Depth gauge 17.5 17.5 17.5 Continuous load 1/4" = 30 N·m 3/8" = 135 N·m 1/2" = 150 N·m 0 0.060 0.140 0.150 Code 7672710 7686500 7687230 No. 7412-00 7412-01 7412-02 7612 Rectangular fixed square head 9x12 ››For accessing bolts in cramped and hard-to-reach locations, easy to change ››Forged ››Chrome-vanadium steel, matt chrome-plated ››With eject-pin for unlocking ››Max. continuous load of ratchet according to DIN EN ISO 6789:2003 and/or maximum load of cavity a" 1/4 3/8 1/2 : 9 x 12 9 x 12 9 x 12 a 6.3 10.0 12.5 4 14 14 14 r 20 20 20 Depth gauge 17.5 17.5 17.5 Continuous load 1/4"/30 N·m 3/8"/135 N·m 1/2"/150 N·m 0 0.070 0.070 0.080 Code 7672630 7679800 7687900 No. 7612-00 7612-01 7612-02 7812 Rectangular bit holder 9x12 ››For accessing bolts in cramped and hard-to-reach locations, easy to change ››Forged ››Chrome-vanadium steel, matt chrome-plated ››With eject-pin for unlocking k" 1/4 5/16 k 6.3 8.0 : 9 x 12 9 x 12 4 10.0 12.5 r 14 16 Depth gauge 17.5 17.5 0 0.040 0.040 Code 2101645 7697970 No. 7812-10 7812-00 Torque Tools 7912 Rectangular weld-on fitting 9x12 ››For accessing bolts in cramped and hard-to-reach locations, easy to change ››Bear the depth gauges in mind ››Chrome-vanadium steel 31CrV3 y 14 : 9 x 12 4 14.5 Depth gauge 8 r 19 Code 7698190 0 0.030 No. 7912-00 SUKSE Rectangular ring ratchet spanner, reversible 9x12 ››9x12 mm rectangular cavity with pin-locking ››Flat ring ratchet with UD-profile, fine-toothed ››With recessed lever change ››For loosening or fast tightening with high torque transfer ››Non-glare look thanks to matt chrome-plating, locking insert and pawl manganese-phosphated ››GEDORE vanadium steel 31CrV3, forged ››To operate with a 9x12 mm torque wrench or rectangular handle 9x12 mm ! 10 13 17 19 : 9 x 12 9 x 12 9 x 12 9 x 12 h 7.7 9.0 10.6 11.7 A° 7 7 6 6 b 21.0 25.7 33.6 36.3 Depth gauge 40 42 45 52 Code 2827735 2827743 2827751 2827778 0 0.070 0.090 0.130 0.150 No. SUKSE9 10 SUKSE9 13 SUKSE9 17 SUKSE9 19 AGSE9 Rectangular handle SE 9x12 ››To operate with rectangular end fittings 9x12 ››For removing bolts or nuts, especially in confined spaces ››Without torque function ››GEDORE vanadium steel 31CrV3, matt chrome-plated : 9 x 12 L 267 ››Non-slip 2-component handle with hanging hole ››Max. continuous load of cavity according to DIN EN ISO 6789:2003 and/or maximum support load : 150 N·m h 18.5 b 22 0 0.320 Code 2827786 No. AGSE9 324 325 End fittings 14x18 SE 7118 Rectangular open end fitting 14x18 ››For accessing bolts in cramped and hard-to-reach locations, easy to change ››Forged ››Chrome-vanadium steel, matt chrome-plated ››With eject-pin for unlocking ! 13 14 15 16 17 18 19 21 22 : 14 x 18 14 x 18 14 x 18 14 x 18 14 x 18 14 x 18 14 x 18 14 x 18 14 x 18 4 7 7 7 9 9 9 9 11 11 r 30.0 32.0 34.0 35.5 37.0 39.0 41.0 45.0 47.0 Depth gauge 25.0 25.0 25.0 25.0 25.0 25.0 25.0 25.0 25.0 0 0.120 0.120 0.120 0.125 0.130 0.130 0.130 0.155 0.150 Code 7689870 7690020 7690100 7685610 7690370 7686180 7690450 7686420 7690610 No. 7118-13 7118-14 7118-15 7118-16 7118-17 7118-18 7118-19 7118-21 7118-22 ! 24 27 29 30 32 34 36 41 : 14 x 18 14 x 18 14 x 18 14 x 18 14 x 18 14 x 18 14 x 18 14 x 18 4 11 13 13 13 13 15 15 15 r 51.0 58.5 63.0 67.5 67.5 74.0 78.0 82.0 : 14 x 18 14 x 18 14 x 18 14 x 18 14 x 18 14 x 18 4 17.5 17.5 17.5 19.0 19.0 19.0 r 41.5 45.0 47.5 50.5 53.0 59.0 Depth gauge 25.0 32.5 32.5 32.5 32.5 33.5 36.0 40.0 0 0.170 0.185 0.220 0.220 0.220 0.255 0.257 0.261 Code 7690880 7690960 2212285 7691260 7687740 1963708 1963716 1963724 No. 7118-24 7118-27 7118-29 7118-30 7118-32 7118-34 7118-36 7118-41 Code 7694440 7694790 7695920 7679130 7696220 7696300 No. 7218-27 7218-30 7218-32 7218-34 7218-36 7218-41 7218 Rectangular ring end fitting 14x18 ››For accessing bolts in cramped and hard-to-reach locations, easy to change ››Forged ››Chrome-vanadium steel, matt chrome-plated ››With eject-pin for unlocking ! 13 14 15 16 17 18 19 21 22 24 : 14 x 18 14 x 18 14 x 18 14 x 18 14 x 18 14 x 18 14 x 18 14 x 18 14 x 18 14 x 18 4 12.0 12.0 12.0 12.0 12.0 12.0 12.0 15.0 15.0 15.0 r 21.5 23.0 24.2 25.7 27.2 28.5 30.5 33.0 34.5 37.5 Depth gauge 25 25 25 25 25 25 25 25 25 25 0 0.120 0.120 0.115 0.125 0.125 0.125 0.125 0.140 0.140 0.140 Code 7693120 7693390 7693470 7678320 7693630 7678830 7693710 7678910 7693980 7694280 No. 7218-13 7218-14 7218-15 7218-16 7218-17 7218-18 7218-19 7218-21 7218-22 7218-24 ! 27 30 32 34 36 41 Depth gauge 31 31 31 31 31 31 0 0.150 0.160 0.165 0.195 0.195 0.225 Torque Tools 7418 Rectangular reversible ratchet head 14x18 ››For accessing bolts in cramped and hard-to-reach locations, easy to change ››Forged ››Chrome-vanadium steel, matt chrome-plated ››With eject-pin for unlocking ››Fine-toothed ››Return angle 7 degrees ››Max. continuous load of ratchet according to DIN EN ISO 6789:2003 and/or maximum load of cavity a" 1/2 3/4 a 12.5 20.0 : 14 x 18 14 x 18 A° 7,2 7,2 4 28.8 35.5 Depth gauge 25 33 r 47 64 Continuous load 1/2" = 340 N·m 3/4" = 400 N·m 0 0.350 0.780 Code 7687580 7687660 No. 7418-02 7418-04 7618 Rectangular fixed square head 14x18 ››For accessing bolts in cramped and hard-to-reach locations, easy to change ››Forged ››Chrome-vanadium steel, matt chrome-plated ››With eject pin for unlocking ››Max. continuous load of ratchet according to DIN EN ISO 6789:2003 and/or maximum load of cavity a" 1/2 3/4 a 12.5 20.0 : 14 x 18 14 x 18 4 18 25 r 27 40 Depth gauge 25 25 Continuous load 1/2" = 340 N·m 3/4" = 400 N·m 0 0.200 0.390 Code 7688040 7688200 No. 7618-02 7618-04 7818 Rectangular bit holder 7918 Rectangular weld-on fitting 14x18 14x18 ››For accessing bolts in cramped and hard-to-reach locations, easy to change ››Forged ››Chrome-vanadium steel, matt chrome-plated ››With eject-pin for unlocking ››For accessing bolts in cramped and hard-to-reach locations, easy to change ››Bear the depth gauges in mind ››Chrome-vanadium steel 31CrV3 k" 5/16 k 8 : 14 x 18 4 r 12.5 16 Depth gauge 0 25 0.100 Code 7698000 No. 7818-00 y 25 : 14 x 18 4 r Depth gauge 0 21.5 26 12 0.100 Code 7698430 No. 7918-00 326 327 Empty standard packaging Module Systems - Flexibility with flair ››The module system adapts itself exactly to your wishes and requirements. At last, you can assemble ››Your set is flexibly alterable and extendible at all times. Just replace or add modules. The modules Plastic cassettes empty for DREMOMETER MINI + AM Sheet metal case empty for DREMOMETER A-F your sets completely individually. Exactly and only using the tools you actually need. For every need, our system provides you with the perfect solution. Whether you chose a standard or an individual solution, your DREMASTER®/TORCOFIX torque wrenches with or without accessories, are always stored and transported professionally by virtue of the modular system design. Use: themselves are delivered with dummy plugs. Simply remove the plugs from the cavities you wish to load with your tools or accessory units. The remaining cavities remain closed - that's what we call neat. ››You tell us which tools you would like to combine into a set and we will then take care of the rest and you will get your desired set without delay. Finished and ready! Use: ››Standard packaging for sets of the torque wrench series DREMOMETER MINI and AM ››Robust and solid, best for storage and transport ››Standard packaging for sets of the torque wrench series DREMOMETER A-F ››Robust and solid, best for storage and transport ››With foam rubber inlay and nest-holes for the accessories ››With integrated metal-flight and nest-holes for the accessories ››Hinges, locks and hand grip made of steel ››GEDORE blue powder-coated Features: Features: Scope of delivery: ››Empty black plastic cassettes with foam inlay ››Delivery in sturdy cardboard packaging Description Plastic cassette + foam inlay for DREMO MINI Plastic cassette + foam insert for DREMO AM Scope of delivery: ››Sheet metal case, emtpy ››Delivery in sturdy cardboard packaging L 275 W 150 H 42 0 Code 0.296 1986805 No. 753-88 275 150 42 0.310 7620910 8554-99 Description Sheet metal case for DREMO A Sheet metal case for DREMO B Sheet metal case for DREMO BC/C Sheet metal case for DREMO D/DS Sheet metal case for DREMO DR/DX Sheet metal case for DREMO E / EK Sheet metal case for DREMO F L 370 485 630 830 830 945 1040 W 115 115 115 165 165 270 175 H 50 52 52 73 73 100 100 0 1.200 1.698 1.950 3.713 3.656 10.300 6.700 Code 7621050 7621130 7621210 7621480 7622100 7621560 1742876 No. 8560-90 8561-90 8562-90 8563-90 8571-90 8564-90 8572-90
4549-05 价格&库存
很抱歉,暂时无法提供与“4549-05”相匹配的价格&库存,您可以联系我们找货
