CAPTURE DISPLAY
CAPTURE DISPLAY
    GEDORE
    TORQUELEADER  CAPTURE DISPLAY  CAPTURE DISPLAY, 5DIGIT, TORQUE SENSOR
CAPTURE DISPLAY 数据手册
Want to know how to use this tool? Display Watch our video Intuitive easy to use Display CAPTURE Display Key Benefits Designed to allow users to become productive  quickly due to its intuitive features, such as easy to navigate menus, tool database and Plug & Play integration with CAPTURE Sensors To protect the CAPTURE Display when not in use  it is supplied complete in a high impact plastic carry case. In addition the following items are included with the Display and are stored in the case - USB Power Cable (for charging from Mains or PC and also used for data transfer), Power Supply (multi-national), Calibration Certificate, Start Up Guide and Instructions Versatile design allows static laboratory use and  mobile data collection using an onboard memory and rechargeable battery. The data can then be transferred to PC via USB connection Minimise investment, as the CAPTURE Display is  CAPTURE Display can store 500 tools and 2000  data readings in the onboard memory designed to integrate with customers’ existing industry standard nominal 2mV/V Sensors Work for longer between battery charges as the unit  is fitted with a long life Lithium-ion battery and has an auto power down mode Order now… call our Sales Hotline +44 (0) 1483 894 476 Order Code 46 036700 Model CAPTURE Display Order Code Model 036226 CAPTURE Cable - CAPTURE Display to Custom Sensor 036246 CAPTURE Cable - CAPTURE Display to Capture Sensor 036251 CAPTURE Cable - CAPTURE Display to SDX Screwdriver 036256 CAPTURE Cable - CAPTURE Display to ETX Wrench Want to know how this product works… visit CAPTURE Virtual Tour at www.torqueleader.com
CAPTURE DISPLAY 价格&库存
很抱歉,暂时无法提供与“CAPTURE DISPLAY”相匹配的价格&库存,您可以联系我们找货
