016500
016500
    GEDORE
    GEDORE - 016500 - Torque, Screwdriver, Preset, 0.25" Drive, 184mm Length, 1N-m to 6N-m
016500 数据手册
Title: Quickset Adjustable Torque Screwdrivers Key Benefits: Quickset screwdrivers achieve accurate torque application by eliminating both under and over tightening using Torqueleader’s proven slipping technology. This enables any user to deliver the correct torque with confidence regardless of task and operator skill level Fast and accurate to set, using the quick and clear to read micrometer setting scale A single tool can cover a broad variety of applications due to its wide torque range Long service life is provided through the durable design utilising hard wearing materials such as stainless steel and aluminum Optional Lock on T-Bar for larger models of screwdriver provides extra leverage when required (Order Code: P29530). Note: T-Bar is not included with the Quickset Screwdriver Range Technical Information: Accuracy +/- 6% of reading ISO 6789:2003 Classification 2D Calibration Range Order Code Model Range Drive 016000 Quickset Minor Metric SD 20-120 cN.m 1 cN.m 1/4" Square M 160 158 016040 Quickset Minor Metric FH 20-120 cN.m 1 cN.m 1/4" Hex F 169 165 016020 Quickset Minor Imp SD 20-120 ozf.in 1 ozf.in 1/4" Square M 160 158 016060 Quickset Minor Imp FH 20-120 ozf.in 1 ozf.in 1/4" Hex F 169 165 016080 Quickset Minor lbf.in SD 2-12 lbf.in 0.1 lbf.in 1/4" Square M 160 158 016070 Quickset Minor lbf.in FH 2-12 lbf.in 0.1 lbf.in 1/4" Hex F 169 165 016100 Quickset 6 SD 1-6 N.m 0.1 N.m 1/4" 222 340 Square M 016500 Quickset 6 FH 1-6 N.m 0.1 N.m 1/4" Hex F 184 335 016200 Quickset 50 SD 5-50 lbf.in 1 lbf.in 1/4" Square M 222 340 016600 Quickset 50 FH 5-50 lbf.in 1 lbf.in 1/4" Hex F 184 335 016300 Quickset 9 SD 4-9 N.m 0.1 N.m 1/4" Square M 222 340 016700 Quickset 9 FH 4-9 N.m 0.1 N.m 1/4" Hex F 184 335 016400 Quickset 80 SD 30-80 lbf.in 1 lbf.in 1/4" Square M 222 340 016800 Quickset 80 FH 30-80 lbf.in 1 lbf.in 1/4" Hex F 184 335 Click on the table to enlarge Calibration Range Order Code Model Range Drive 016030 Quickset Minor kgf.cm SD 1-12 kgf.cm 0.1 kgf.cm 1/4" Square M 160 158 016050 Quickset Minor kgf.cm FH 1-12 kgf.cm 0.1 kgf.cm 1/4" Hex F 169 165 016130 Quickset 60 K SD 10-60 kgf.cm 1 kgf.cm 1/4" Square M 222 340 016530 Quickset 60 K FH 10-60 kgf.cm 1 kgf.cm 1/4" Hex F 184 335 016330 Quickset 90 K SD 40-90 kgf.cm 1 kgf.cm 1/4" Square M 222 340 016730 Quickset 90 K FH 40-90 kgf.cm 1 kgf.cm 1/4" Hex F 184 335
016500 价格&库存
很抱歉,暂时无法提供与“016500”相匹配的价格&库存,您可以联系我们找货
