CAPTURE SENSOR 5-50NM
    GEDORE
    TORQUELEADER - CAPTURE SENSOR 5-50NM - CAPTURE SENSOR, 5-50N-M
CAPTURE SENSOR 5-50NM 数据手册
Want to know how to use this tool? Sensor Watch our video Torque Range from 0.2 to 1500 N.m D Order Code Model 036771 CAPTURE Sensor ISO 1500/90° Adaptor D18205 CAPTURE Sensor ISO-A Mount 036772 CAPTURE Sensor Quick Change Plate H 1.f.f2t 3 W CAPTURE Sensor Key Benefits  Easy to repair due to modular design that allows for  Built-in flexibility as the sensor can be mounted simple component replacement horizontally or vertically without the need for any accessories  Fast to set up when used with a CAPTURE Display due to the imbedded Quicktec technology which passes all the Sensor information to the Display  Remove human error from testing by using the CAPTURE Sensor with the ISO 1500/90° Torque Loading System (Adaptor required – see page 53)  For users with limited space who need to change Sensors between tests the Quick Change Plate increases calibration productivity  Sensors come complete with UKAS certificate to BS 7882:2008 Class 1 or better  Calibrated range is 10% to 100% of capacity  To protect the Sensor when not in use it is supplied in a high impact plastic carry case Order now… call our Sales Hotline +44 (0) 1483 894 476 Order Code Model Range 036805 CS 2 0.2-2 N.m 036807 CS 5 036810 Drive / mm H x W x D kg Hole Centres (mm) Mounting Hole Size Fixings Supplied Order Code 62 x 85 x 65 0.50 56 M8 x 1.25 (10 Deep Min) M8 x 50 * P34320 / 0.5-5 N.m 62 x 85 x 65 0.50 56 M8 x 1.25 (10 Deep Min) M8 x 50 * P34320 CS 10 1-10 N.m 62 x 85 x 65 0.50 56 M8 x 1.25 (10 Deep Min) M8 x 50 * P34320 036815 CS 25 / 2.5-25 N.m 62 x 85 x 65 0.50 56 M8 x 1.25 (10 Deep Min) M8 x 50 * P34320 036820 CS 50 5-50 N.m 62 x 85 x 65 0.57 56 M8 x 1.25 (10 Deep Min) M8 x 50 * P34320 036825 CS 100 / 10-100 N.m 62 x 85 x 65 0.60 56 M8 x 1.25 (10 Deep Min) M8 x 50 * P34320 036830 CS 250 25-250 N.m 82 x 120 x 87 1.45 79 M12 x 1.75 (16 Deep Min) M12 x 1.75 * P34330 036835 CS 500 / 50-500 N.m 82 x 120 x 87 79 M12 x 1.75 (16 Deep Min) M12 x 1.75 * P34330 036845 CS 1500 150-1500 N.m 125 M16 x 2.0 (20 Deep Min) M16 x 90 * P34340 1” 4 1” 4 / 1” 4 3” 8 / 3” 8 1” 2 / 1” 2 3” 4 1” 1.6 100 x 165 x 134 4.00 * Socket Cap Head Screw Calibrate your Sensor… visit www.torqueleader.com for more details about our on site UKAS (United Kingdom Accreditation Service) Calibration Laboratory 47
CAPTURE SENSOR 5-50NM 价格&库存
很抱歉,暂时无法提供与“CAPTURE SENSOR 5-50NM”相匹配的价格&库存,您可以联系我们找货
  • 1+18316.80732
库存:2
