CL 3000
CL 3000
    GEDORE
    GEDORE - CL 3000 - Torque Sensor, 148 ft-lb to 2210 ft-lb, 200 N-m to 3000 N-m, 36 mm Male Hex, Capt...
CL 3000 数据手册
Capture Lite 1100 And Capture Lite 3000 Available to Order now Call (+44) 01483894476 New Product Information Rugged, robust, lineside torque tester with simple and easy to use functionality.  Two new Capture Lite models CL1100 and CL3000 – Stock code 3297934 Model CL1100 3420523 CL3000 Range 80 -1100Nm (60810lbf.ft) 200- 3000Nm (1482210lbf.ft) Price £1400 £1700  Design details o High quality one piece construction of the aluminium body, machined from solid billet. o Robust powder coating that looks good and stands up to tough industrial environments. o High strength stainless steel torsion shaft with 36mm Hex o Same footprint and mounting hole positions as other Capture Lite models. Mounting kit available separately o Easy to read laser marking of required product information o Fully compliant with UKCA and CE marking  Function details o Similar to other Capture models o Simple one-button operation. o Peak, First Peak and track mode available o Multiple units available: N∙m, lbf∙ft & lbf∙in  Box and contents o WAG euro box with custom foam cut-out. (Same box as Capture sensors) o CL unit o 2 x bolt down bolts o USB cable o Socket 3/4" FS to 36mm FH (Product Code: 6272830) o Socket 1" FS to 36mm FH (Product Code: 6174900) o Calibration certificate o Quick start guide o User Instructions o Register my tool Newest members of the Capture Lite Family  Abbreviation CL1 CL10H CL10S CL150 CL350 CL 1100 CL 3000 Order Code/Article Number 038110 038120 038130 038140 038150 3297934 3420523 Drive range .02-1Nm .25-10Nm .25-10Nm 5-150Nm 10-350Nm 80-1100 200-3000 Size ¼” ¼” ¼” 3/8” ½” 36mm 36mm Type male hex Male hex Female sq Female sq Female sq male hex male hex adaptor FH to FS (FSHA) A35640 MS to MH 029200 ¼” adaptor 031320 3/8” adaptor 031340 ¾” & 1" Socket ¾” & 1" Socket
CL 3000 价格&库存
很抱歉,暂时无法提供与“CL 3000”相匹配的价格&库存,您可以联系我们找货
CL 3000
    • 1+18282.66771
    库存:2
