8782 0009 6
8782 0009 6
    RENNSTEIGTOOLS
    RENNSTEIG - 8782 0009 6 - Crimp Tool, SelectorCrimp, Four Indent, Hand, TE DT Series Turned Male and...
8782 0009 6 数据手册
Four Indent Crimping Tool SelectorCrimp HDT-48 Art. No. 8782 0009 6 Selector position easily readable on the pliers Crimp indenter depth setting through an 8 position selector Supplied with universal locator Four Indent Crimping Tool SelectorCrimp HDT-48 · Specialty crimping pliers for processing turned male and female contacts of the DT-series from TE Connectivity (formerly known as Deutsch terminals) · Crimp quality testing through GO-NOGO gauges (optional) · Reliable crimping results through forced locking mechanism and synchronous feed setting of indenters · Optimzed opening width, ergonomic design, and reduced hand force The following table lists all common contacts that can be processed in the four indent crimping tool SelectorCrimp HDT-48. for contacts Contact number AWG mm2 2.0-3.0 mm2 0462-221-16** 20 0.50 mm2 12-14 2.0-3.0 mm 2 0460-010-20** 16-18 0.75-1.0 mm 0462-203-12** 12-14 2.0-3.0 mm 2 0462-005-20** 0462-210-12** 12-14 2.0-3.0 mm 2 0460-215-16** 14* 0462-209-16** 0460-002-16** Contact number AWG mm2 0460-204-12** 12-14 0460-220-12** Contact number AWG M39029/4-110 (TE 0641-1-2031L) 20 M39029/4-111 (TE 0641-2-1631L) 16 16-18 2 0.75-1.0 mm M39029/4-113 (TE 0641-3-1231L) 12 2 0460-202-20** 20-22 0.35-0.50 mm M39029/5-115 (TE 100503L) 20 2.0 mm 2 0462-201-20** 20-22 0.35-0.50 mm M39029/5-116 (TE 100504L) 16 14* 2.0 mm 2 4060-002-12** 12-14 2.0-3.0 mm M39029/5-118 (TE 100505L) 12 16 1.0-1.5 mm2 4062-002-12** 12-14 2.0-3.0 mm2 0460-202-16** 16 1.0-1.5 mm2 4060-001-16** 16-18 0.75-1.5 mm2 0462-201-16** 18 0.75 mm2 4062-001-16** 16-18 0.75-1.5 mm2 2 2 2 * Use 1.5 mm2 setting for this part with 14 AWG. ** = 31, plating is Gold. / ** = 141, plating is Nickel. Art. No. EAN 4049002 Model Picture Capacity 8782 0009 6 145704 Crimping tool with universal locator, 2- comp. handle 0.35 – 3.0 mm² / AWG 22 – 12 8791 7801 01 121456 GO-NOGO pair of Gauges für Zange 8782 0009 6 Rennsteig Werkzeuge GmbH An der Koppel 1 98587 Steinbach-Hallenberg T F W E +49 (0) 36847 / 4 41 - 0 +49 (0) 36847 / 4 41 - 14 www.rennsteig.com info@rennsteig.com max. Ø of contact mm 5.5 mm 230 650 76,5 25 g
8782 0009 6 价格&库存
很抱歉,暂时无法提供与“8782 0009 6”相匹配的价格&库存,您可以联系我们找货
