AS 20 L
AS 20 L
    METABO(麦太保)
    METABO - AS 20 L - VACUUM CLEANER, ALL PURPOSE, 20L, EU
AS 20 L 数据手册
6.02012.00 AS 20 L 1200 Watt All-purpose Vacuum Cleaner AS 20 L • Mobile, compact vacuum cleaner for liquids and dry solids with commercial registration • Certified for extracting dust particles of dust class L (AGW values ≥ 1 mg/m³) • Also suitable for absorbing non-flammable liquids • Automatic shutoff that is disconnected while absorbing the suction flow as soon as the maximum filling height of the container is reached • Special air cooling system for long service life of the powerful motor • Sturdy and washable pleated filter with large surface against quick clogging • Easy and quick filter change • Option to wind up the cable • Practical accessory case and storage area Comparative technical values Air output (at fan) 4.200 l/min Vacuum 210 hPa (mbar) Filter surface 3.600 cm² All-purpose vacuum cleaners (dl) 2013-05-14 / en Rated input power 1.200 W Container volume 20 l Suction hose: - Diameter 35 mm - Length 1,75 m Weight 5 kg Scope of delivery Suction hose (Ø 35 mm, 1.75 m long), 2 suction pipes, 1 Cellulose pleated filter, Grouting nozzle, Floor nozzle (260 mm wide) All-purpose vacuum cleaners (dl) 2013-05-14 / en
AS 20 L 价格&库存
很抱歉,暂时无法提供与“AS 20 L”相匹配的价格&库存,您可以联系我们找货
