BASIC 250-24 W
BASIC 250-24 W
    METABO(麦太保)
    METABO - BASIC 250-24 W - COMPRESSOR, BASIC, 1.5KW, 8BAR
BASIC 250-24 W 数据手册
6.01533.00 Basic 250-24 W Compressor Basic 250-24 W 0153300S_51.EPS • Powerful, robust compressor for simple, commercial use • Oil-lubricated piston condenser • For single phase alternating current • Working pressure can be regulated according to application by means of pressure reducer with manometer • Good cold start feature thanks to push button with safety valve • Overload protection: protects the motor from overheating • Rubberised, stable wheels for mobile use • Testing not necessary before initial operation • Additional manometer for displaying the tank pressure • Rubber-coated handle for comfortable handling • 10 years tank warranty against rusting Comparative technical values Suction rate 200 l/min Filling capacity 110 l/min Effective delivery volume (at 80% max. pressure) 95 l/min Maximum pressure Rated input power Maximum speed Tank capacity Sound pressure level (LpA) Dimensions 8 bar 1,5 kW 2.850 /min 24 l 97 dB(A) 630 x 406 x 630 mm Weight 27 kg Cable length 1,5 m Scope of delivery Universal quick-action coupling, Pull handle with rubber-coating |1
BASIC 250-24 W 价格&库存
很抱歉,暂时无法提供与“BASIC 250-24 W”相匹配的价格&库存,您可以联系我们找货
