HG 20-600
HG 20-600
    METABO(麦太保)
    METABO - HG 20-600 - Heat Gun, 2 kW, 600 Deg C, 240 VAC, 500 lpm
HG 20-600 数据手册
2000 Watt Hot air gun HG 20-600 • Versatile hot air gun with adjusting wheel for easy, variably adjustment of the temperature • High-quality ceramic heating, powerful motor and optimum device cooling for long service life • Wide range of uses: removal of varnish, shaping, crimping, welding and much more • Ergonomic design and handle with non-slip soft-grip surface provides convenient handling • Safe stationary application due to large non-slip floor space Order no. EAN code 602066000 4061792185906 Air volume 150 / 300 / 500 l/ min Number of air volume levels 3 Air temperature 806001.112 °C Number of air temperature levels infinitely variable Rated input power 2.000 W Weight (without power cable) 0,62 kg Scope of delivery - 1 metaBOX 145 L, empty (626884000) Order no. 626884000 EAN 4061792189157 Product may differ from Image Intelligent transport and storage system for mobile working Extremely robust and break-proof due to the material and design for maximum resilience Optimum protection of machine and accessories against dirt and moisture (IP43) Fast and easy stacking and coupling of the boxes in all system widths One box in the stack can easily be opened without having to decouple it A selection of two: Comfortable front handle for carrying the box near you and extra-wide cover handle to carry several stacked-up boxes Numerous tailor-made inserts (accessories) for individual order inside the box Clever accessories: Roller board and trolley for maximum mobility as well as an adapter plate to secure the boxes in the vehicle metaBOX 145 L empty, without inserts www.metabo.com 1/2 Technical data Characteristics Dimensions 496 x 296 x 145 mm / 19.53 x 11.66 x 5.72 " Case volume 14.1 l Max. load cover 125 kg / 275.6 lbs Weight 1.85 kg / 4.1 lbs Material ABS www.metabo.com 2/2
HG 20-600 价格&库存
很抱歉,暂时无法提供与“HG 20-600”相匹配的价格&库存,您可以联系我们找货
