BASIC 250-24 W OF
BASIC 250-24 W OF
    METABO(麦太保)
    METABO - BASIC 250-24 W OF - COMPRESSOR, BASIC, 1.5KW, 8BAR
BASIC 250-24 W OF 数据手册
6.01532.00 Basic 250-24 W OF Compressor Basic 250-24 W OF 0153200S_51.EPS • Powerful, robust compressor for simple, commercial use • Oil-free piston condenser: simple transportation and reduced service requirements • For single phase alternating current • Working pressure can be regulated according to application by means of pressure reducer with manometer • Good cold start feature thanks to push button with safety valve • Overload protection: protects the motor from overheating • Rubberised, stable wheels for mobile use • Testing not necessary before initial operation • Additional manometer for displaying the tank pressure • 10 years tank warranty against rusting Comparative technical values Suction rate 220 l/min Filling capacity 120 l/min Effective delivery volume (at 80% max. pressure) 100 l/min Maximum pressure Rated input power Maximum speed Tank capacity Sound pressure level (LpA) Dimensions 8 bar 1,5 kW 2.850 /min 24 l 97 dB(A) 630 x 406 x 630 mm Weight 24 kg Cable length 1,5 m Scope of delivery Universal quick-action coupling, Pull handle with rubber-coating |1
BASIC 250-24 W OF 价格&库存
很抱歉,暂时无法提供与“BASIC 250-24 W OF”相匹配的价格&库存,您可以联系我们找货
