640024FULL-0060X
640024FULL-0060X
    EATON(伊顿)
    FULLEON - 640024FULL-0060X - Beacon, Amber, 93 x 121 mm, 101 dBA, Flashing, 24 VDC, IP65
640024FULL-0060X 数据手册
Sounder Beacons Flashni The Flashni is an audible and visual device which requires one single installation point. This greatly reduces installation costs and is less obtrusive than two separate devices. Versions are available with the sounder and beacon linked, or with separate terminals for independent operation. Technical Specification Features • High output sounder beacon • 12V, 24V and mains module option Voltage • Automatic sounder synchronisation Current 110mA 12V version (Typical Tone 5) 68mA 24V version (Typical Tone 3) Sound Output 103dB(A) 12V version (Typical Tone 5 ) 101dB(A) 24V version (Typical Tone 3) Tones Pre-set to tone 5 (12v) Pre-set to tone 3 (24v) (versions are available with user selectable tones) Flash Power 0.7j Flash Rate 1Hz Volume Control 10dB Monitoring Reverse polarity Temperature - 10ºC to + 55ºC Protection IP54 (s)* IP65 (d)* Construction ABS, PC lens Weight 0.33Kg Colours Red or white Lens Colour Red, amber, blue, green or clear Benefits • Up to 103dB(A) with built in Xenon flash • Suitable for a variety of application • Improved tone clarity, reducing confusion Dimensions Ø93mm 121mm Deep Base 92mm Shallow Base 9 - 15Vdc (12V version) 18 - 28Vdc (24V version) (*1) • Choice of lens colour options (s)* Shallow Base (d)* Deep / U Base Flashni White Catalogue Numbers Reference Cat No Description FL/RL/R/S SWITCH FL/RL/R/D SWITCH FL/AL/W/D SWITCH FL/RL/R/S 12V SND5 FL/RL/W/S 12V SND5 640025FULL-0061X 640031FULL-0111X 640024FULL-0060X 640204FULL-0067 640202FULL-0039 640206FULL-0089 Flashni Sounder/Beacon, Red lens, Red body, Shallow base, Tone select switch Flashni Sounder/Beacon, Red lens, Red body, Deep base, Tone select switch Flashni Sounder/Beacon, Amber lens, White body, Deep base, Tone select switch Flashni 12V Sounder/Beacon, Red lens, Red body, Shallow base, tone 5 Flashni 12V Sounder/Beacon, Red lens, White body, Shallow base, tone 5 FL/CL/W/S 12V SND5 Flashni 12V Sounder/Beacon, Clear lens, White body, Shallow base, tone 5 FULLEON FIRE ALARM DEVICES April 2019
640024FULL-0060X 价格&库存
很抱歉,暂时无法提供与“640024FULL-0060X”相匹配的价格&库存,您可以联系我们找货
