Beacons
Solista LX Ceiling
The Solista LX Ceiling has a unique lens design that
distributes the light in a cylindrical shape to achieve
the required illumination specified by EN 54-23.
Designed for installation at a height of up to 3m and
with a discrete appearance, the device is ideal for a
variety of applications, including bedrooms,
bathrooms and toilets.
Technical Specification
Features
• Ultra low current consumption of 10mA
• Up to 7.5m coverage volume
Mounting Type
Ceiling
• 0.5Hz or 1Hz Flash rate
Voltage
9 - 60VDC
Current
10 - 25mA dependent on setting
• Coverage switch to 3m
Coverage (y)
7.5m (Switchable to 3m)*
Mounting Height (x)
3m (max)
Benefits
Coverage Volume Code
C-3-7.5
• Use where current consumption is a key consideration
Coverage Volume
132m3 (21m3)
• Ideal for bedrooms, bathrooms and toilets
Flash Rate
1Hz (Switchable to 0.5Hz)
• Switch flash rate to 0.5Hz to reduce current consumption
Operating Temperature
-25ºC to +70ºC
Monitoring
Reverse Polarity
• Reduces power consumption by up to 50%
Dimensions
93mm
65mm
Protection
IP33C Shallow Base IP65 Deep and U Base
Weight
100g
Body Colour
White or Red
Flash Colour
White or Red
* CNPP test results
Deep Base
37mm
Shallow Base
Catalogue Numbers
Reference
Cat No
Description
SOL-LX-C/WF/W1/S
SOL-LX-C/WF/W1/D
SOL-LX-C/RF/W1/S
SOL-LX-C/RF/W1/D
812020FULL-0121X
812021FULL-0122X
812022FULL-0123X
812023FULL-0124X
Solista LX Ceiling, White Flash, White Body, Shallow Base
Solista LX Ceiling, White Flash, White Body, Deep Base
Solista LX Ceiling, Red Flash, White Body, Shallow Base
Solista LX Ceiling, Red Flash, White Body, Deep Base
For full list of part numbers, turn to page 79
FULLEON FIRE ALARM DEVICES
CAFIRV10614
19
很抱歉,暂时无法提供与“812020FULL-0121X”相匹配的价格&库存,您可以联系我们找货
