Askari Panel - Process Sounder
A compact sounder, designed to fit through the fascias of control
panels or equipment housings. The single nut fixing ensures
simple installation and maximum audibility, while the high IP rating
allows installation in most process and industrial environments.
Technical Specification
9-28Vdc, 24Vac
Current
18mA (Typical Tone 3)
Sound Output
92dB(A)
Tones
32
Alarm Stages
Temperature
2
- 25ºC to + 70ºC
Protection
IP65
Construction
ABS
Weight
0.9Kg
Colour
Red or white
Ø 50mm
Voltage
45mm
Ø 26mm
Features
Benefits
ɀ
Small size
ɀ
Easily accommodated
ɀ
Dedicated panel fixing
ɀ
Easy to fit into control equipment enclosures
ɀ
9Vdc to 28Vdc
ɀ
Accepts most common DC supplies
ɀ
IP65 protection
ɀ
Can be used in internal and external equipment
Reference
Catalogue No.
Description
AP/W/S/VC
560002FULL-0072
Askari Panel Mounting Sounder, White, Tone Select Switch,
AP/R/S VC
560013FULL-0021
Askari Panel Mounting Sounder, Red, Tone Select Switch,
AP/SV/W/S/VC/24VAC
562002FULL-0076
Askari Panel, 24V, White Base, Switch, Volume Control
Volume Control
Volume Control
9
很抱歉,暂时无法提供与“AP/W/SWITCHED/VC”相匹配的价格&库存,您可以联系我们找货
