MIDI
HIGH OUTPUT SOUNDER / BEACON
165mm
173mm
132mm
The Asserta Midi Sounder Beacon is a versatile and rugged
Specification
audio-visual alarm designed for industrial environments or
Voltage Range
areas where there is a requirement for a physically robust and
well-protected unit. A range of supply options permit use with
a wide range of fire and process systems.
72
I
Current
AC 115Vac
AC 230Vac
DC 9 - 60Vdc
24Vac - 40mA (typ)
230Vac - 35mA (typ)
9 - 60Vdc - 230mA (typ)
AC OR DC VERSIONS AVAILABLE
Output @ 1m
110dB(A)
110dB(A) OUTPUT
Tones
32
IP66 PROTECTION
Alarm Stages
2
SIMPLE FIRST & SECOND FIX INSTALLATION
Flash Rate
1Hz
FULLY INTEGRATED HIGH EFFICIENCY BEACON
Flash Power
2.5j
32 ALARM TONES
Temperature
- 20ºC to + 70ºC
2 STAGE ALARM
Material
PC / ABS
IP Rating
IP66
Weight
0.8Kg
Body Colour
Red or Grey
Lens Colour
Red, Amber or Clear
很抱歉,暂时无法提供与“AS/M/SB/9-60V/R/RL”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+1940.80732
- 5+1804.12636
