Door Retainers
Series 1350 / 1360
The 1350/1360 series is a range wall mounted
electromagnetic door retainers that offers the user
a choice of holding strengths.
Robust and simple to install, they are ideal for a
wide range of applications such as nursing homes,
hospitals, schools and industrial premises. Doors
can be held open under normal conditions and then
automatically released in the event of a fire alarm
activation.
Technical Specification
Features
• Versatile holding settings
• High holding force
Holding Force
25-50Kg 245-490N /50-100Kg 490-960N
• Low current consumption
Voltage
24Vdc
• Release button and protection circuit
• Adjustable damping keeper plate
• Protection diodes as standard
Current
25-45mA / 40-100mA
Mounting
Wall mounting / Floor bracket available
Housing Material
Steel / ABS cover
Temperature Range
10°C to +55°C
Protection
IP40
Benefits
Weight
800g / 1000g
• Flexibility in installation
Body Colour
White / Black
• Suitable for large and small fire doors
• Requires less power from your system
• Door can be manually closed when not activated by
the fire system
• Allows for door misalignment
Dimensions
95mm Square
40mm
60mm Square
48mm
Catalogue Numbers
Reference
Cat No
Description
FSMD/024/40/W/DIODE
1350-CSA
Wall Mounted Magnetic Door Release 24Vdc, 40Kgf/390N
(includes diode protection circuit)
58
FULLEON FIRE ALARM DEVICES
CAFIRV10614
很抱歉,暂时无法提供与“1320-240”相匹配的价格&库存,您可以联系我们找货
