AS/SB/024/R/120/RL
AS/SB/024/R/120/RL
    EATON(伊顿)
    FULLEON - AS/SB/024/R/120/RL - Beacon / Sounder, Asserta, Multiple Tones, 120dB, 24VDC, IP66
AS/SB/024/R/120/RL 数据手册
A S S E R TA 2 4 V O LT HIGH OUTPUT SOUNDER / BEACON 168mm 212mm 155mm The Asserta Industrial warning sounder / beacon is designed to Specification cope with harsh environments requiring protection to IP66. Voltage 18 - 30Vdc Design features are incorporated to ensure safer and easier Current 110dB(A) = 320mA installation, while providing flexibility with fewer product Output @ 1m 110dB(A) 120dB(A) variants. Tones 42 Alarm Stages 3  24Vdc OPERATION Flash Rate 0.75 / 1.0 / 1.25 / 2Hz (user selectable)  110dB(A) OR 120dB(A) OUTPUT VERSION AVAILABLE Flash Power 3.6j (typ)  IP66 PROTECTION Temperature - 20ºC to + 70ºC  FULLY INTEGRATED ASYMMETRIC BEACON USES Construction Body PC / ABS Construction Lens Polycarbonate IP Rating IP66 Weight 1.8Kg Body Colour Red or Grey Lens Colour Red, Amber or Clear LIGHT MORE EFFICIENTLY  SIMPLE FIRST & SECOND FIX INSTALLATION  42 ALARM TONES  3 STAGE ALARM  SOUNDER TIME OUT - USER ADJUSTABLE  OPTIONAL SWIVEL MOUNT BRACKET 70 I 120dB(A) = 650mA
AS/SB/024/R/120/RL 价格&库存
很抱歉,暂时无法提供与“AS/SB/024/R/120/RL”相匹配的价格&库存,您可以联系我们找货
