FL/BL/W/D/12V
FL/BL/W/D/12V
    EATON(伊顿)
    FULLEON - FL/BL/W/D/12V - Audio Signal Indicator, Flashni, 101dB, 100mA, IP65, 92mm Ext. Depth
FL/BL/W/D/12V 数据手册
FLASHNI BEACON / SOUNDERS XENON 92mm Specification one single installation point. This greatly reduces installation Voltage 9 - 15Vdc @ 12V dc 18 - 30Vdc @ 24V dc Current 100mA @ 12V dc devices. Versions are available with the sounder and beacon 68mA @ 24V dc linked, or with separate terminals for independent operation. Sound Output 101dB(A)  HIGH OUTPUT SOUNDER BEACON Monitoring Reverse polarity  AUTOMATIC SOUNDER SYNCHRONISATION Beacon 0.7j  VOLUME CONTROL Flash Rate 60/min (1Hz)  CHOICE OF LENS / SOUNDER COLOUR Temperature -10ºC to +55ºC IP Rating IP65 Weight 0.29Kg (Shallow Base) 0.33Kg (Deep / U Base) Tones 12Vdc (preset to tone 5) 24Vdc (preset to tone 3) Lens Colour Red, Amber, Green, Blue or Clear Body Colour Red or White COMBINATIONS  BASE COMPATIBLE WITH THE ROSHNI, CLARIFIRE AND IB BEACONS  LOCKABLE BASE I 121mm The Flashni is an audible and visual device which requires and costs and is much less obtrusive than two separate 48 DEEP U BASE SHALLOW BASE Ø 93mm
FL/BL/W/D/12V 价格&库存
很抱歉,暂时无法提供与“FL/BL/W/D/12V”相匹配的价格&库存,您可以联系我们找货
