Sounders
Symphoni High Output
Compact design delivering up to 120dB the
Symphoni High Output provides an ideal solution to
your signalling challenges. Producing levels of up to
120dB(A) this sounder can be used in open areas or
in situations having higher than normal background
noise levels. Despite its high output the unit is
efficient and offers relatively low current
consumption.
An IP66 rated WP version is also available.
Technical Specification
Features
• High output up to 120dB(A)
• Two stage alarm
Voltage
• 32 tones (user selectable)
Current
240mA (Typical Tone 3)
• Weatherproof option
Sound Output
114dB(A) (Typical Tone 3)
120dB(A) (Typical Tone 6)
Benefits
18 - 28Vdc
Tones
32
Volume Control
20dB
• Ideal for high noise environments
Monitoring
Reverse polarity
• Alert and alarm function
Temperature
- 10ºC to + 55ºC
- 25ºC to + 70ºC (WP)
Protection
IP21C, IP66 (WP)
• 6 tones certified for fire use
• Suitable for outdoor use
Construction
ABS, PC lens
Weight
0.58Kg, 0.68Kg (WP)
Colours
Red or white
Dimensions
Ø108mm
WP version white
Ø108mm
110mm - WP
96mm
110mm - WP
96mm
Catalogue Numbers
Reference
Cat No
Description
SY/HO/R
SY/HO/W1
SYHO/R/IP
SYHO/GW/IP
651004FULL-0009X
651003FULL-0008X
651012FULL-0057X
650022FULL-1029X
Symphoni High Output Sounder, Red Body
Symphoni High Output Sounder, White Body
Symphoni High Output Sounder, Red Body, IP66 Version
Symphoni High Output Sounder, White Body, WP IP66 Version
FULLEON FIRE ALARM DEVICES
CAFIRV10614
11
很抱歉,暂时无法提供与“651012FULL-0057X”相匹配的价格&库存,您可以联系我们找货
