531036FULL-0073
531036FULL-0073
    EATON(伊顿)
    FULLEON - 531036FULL-0073 - Beacon, Solex, Xenon, Transparent, Continuous / Flashing, 93mm, 60V, IP2...
531036FULL-0073 数据手册
Combi Signalling Units The Combi Signal Unit is supplied in modular form with a base unit (terminal element) & separate bayonet-fit lense or sounder. These may be used to warn of potential hazards or indicate the status of plant items, doors etc. The Combi signalling units provide an extremely flexible system for the assembly of audible and visual signals that may be used in applications where different levels of warning or status need to be communicated. Combi Signalling Unit STANDARD Combi Bases WHITE RED WHITE RED WHITE RED 2W White 593010FULL-0323 2W Red 593004FULL-0034 3W White 593011FULL-0324 3W Red 593008FULL-0321 4W White 593012FULL-0325 4W Red 593009FULL-0322 The foundation of the system is the Deep Base pre-assembled into linear units of 2, 3 or 4 pieces. Into the assemblies the user can fit audible and visual warnings chosen from the standard ranges of Fulleon RoLP sounders, Solex Xenon beacons and Solista Maxi LED beacons. C o m p a t i b l e p ro d u c t s SOUNDERS ROLP/R/S 540501FULL-0389X ROLP/W/S 540502FULL-0406X RoLP Red DC RoLP White DC ROLPX/R/S 540527FULL-0396 RoLP Maxi Red DC ROLPX/W/S 540577FULL-0780 RoLP Maxi White DC Beacons Xenon - Solex Solex beacon red lens, 3Cd The RoLP and RoLP Maxi allow the user to choose from 32 alarm tones and outputs in excess of 107dB(A). The Solex Xenon beacons are available with three levels of light output and in five colours, the Solista LED beacons again offer five colours and additionally three user selectable modes of operation; steady, single flash, and double flash. LED beacons also are inherently robust and have extremely long operating lifetimes important where access for maintenance may be limited. SO/R/SR/3C 531025FULL-0061 SO/A/SW/3C 531026FULL-0062 Solex beacon amber lens, 3Cd SO/G/SW/3C 531041FULL-0069 Solex beacon green lens, 3Cd SO/B/SW/3C 531040FULL-0068 Solex beacon blue lens, 3Cd SO/C/SW/3C 531039FULL-0067 Solex beacon clear lens, 3Cd SO/R/SR/10C 531024FULL-0060 Solex beacon red lens, 10Cd SO/A/SW/10C 531027FULL-0063 Solex beacon amber lens, 10Cd SO/G/SW/10C 531035FULL-0072 Solex beacon green lens, 10Cd SO/B/SW/10C 531034FULL-0071 Solex beacon blue lens, 10Cd SO/C/SW/10C 531042FULL-0070 Solex beacon clear lens, 10Cd SO/R/SR/15C 531028FULL-0064 Solex beacon red lens, 15Cd SO/A/SW/15C 531029FULL-0065 Solex beacon amber lens, 15Cd F e a t u re s SO/G/SW/15C 531038FULL-0075 Solex beacon green lens,15Cd SO/B/SW/15C 531037FULL-0074 Solex beacon blue lens, 15Cd ᔢ Two, three or four way assemblies to suit the status levels required. SO/C/SW/15C 531036FULL-0073 Solex beacon clear lens, 15Cd SOLX/RF/RL/R/S 811021FULL-0037 Solista Maxi Red Body Red Flash (red lens) SOLX/RF/CL/W/S 811023FULL-0039 Solista Maxi White Body Red Flash, (clear lens) SOLX/AF/CL/W/S 811026FULL-0043 Solista Maxi White Body Amber Flash (clear lens) SOLX/GF/CL/W/S 811029FULL-0046 Solista Maxi White Body Green Flash (clear lens) SOLX/WF/CL/W/S 811032FULL-0049 Solista Maxi White Body White Flash (clear lens) SOLX/BF/CL/W/S Solista Maxi White Body Blue Flash (clear lens) Supply Module Combi Power Module 631203FUL-0137 110-230Vac to 24Vdc Supply Module F: +44 (0)1633 866 346 ᔢ Two stage alarm sounders with 32 tones avoids conflicts with other alarm signals ᔢ Choice of three light outputs for the Xenon beacons, to suit the visibility levels required ᔢ Three user selectable flash modes from the LED beacons allows clear differentiation between signals. ᔢ Audible and visual elements can be locked into the Combi bases for added security ᔢ Bases are available in either red or white to suit the application ᔢ Standard voltage range 9 to 30Vdc. (60Vdc also available) and will suit most commonly available DC supplies ᔢ AC mains operation from 110 to 230Vac, with Combi Power module, allows operation from AC supplies with the need for adjustment. Cooper Fulleon Limited Llantarnam Park, Cwmbran, Gwent, NP44 3AW United Kingdom T: +44 (0)1633 628 500 Please see data sheets for the particular devices for full specification. ᔢ Five colours available with both Xenon and LED light sources to suit most visual requirements Beacons LED - LED Solista Maxi 811035FULL-0052 Supply voltages from 9 to 60Vdc and 110 to 230Vac are available. E: sales@fulleon.co.uk W: www.fulleon.com
531036FULL-0073 价格&库存
很抱歉,暂时无法提供与“531036FULL-0073”相匹配的价格&库存,您可以联系我们找货
