7021121FUL-0004X
7021121FUL-0004X
    EATON(伊顿)
    FULLEON - 7021121FUL-0004X - Beacon, Red, 212 mm, 120 dBA, Flashing, 24 VDC, IP66
7021121FUL-0004X 数据手册
Sounder Beacons Asserta Sounder Beacon The 120dB (A) Asserta Industrial warning sounder beacon is designed to cope with harsh environments requiring protection to IP66. Design features are incorporated to ensure safe and easy installation, while providing flexibility with fewer product variants. Technical Specification Features • Powerful 120dB(A) output • 3 stage alarm and time out function Voltage 18 - 30Vdc 230Vac • 42 alarm tones Current Sounder 110dB(A) 105mA @ 24Vdc (Typical Tone 3) 120dB(A) 450mA @ 24Vdc (Typical Tone 3) • Asymmetric beacon Current Beacon 120 - 620mA @ 24Vdc (dependant on setting) Output 110dB(A) 120dB(A) Benefits Tones 42 • Maximum sound output for high noise environments Alarm Stages 3 • 3 levels of alarm for differing warning states Flash Power 3.6j @ 24Vdc 2.0j @ 230Vac Flash Rate 1Hz (adjustable on 24Vdc) Monitoring Reverse polarity (dc version) Temperature - 25ºC to + 70ºC Protection IP66 • Large range of tone options • Efficient use of light reduces current input generating the same light output as a 5j beacon Dimensions Construction ABS, PC Weight 1.8Kg (dc version) Colour Red or grey Lens colour Red, amber, blue or clear 2.5Kg (mains version) 168mm 155mm 212mm Asserta Sounder Beacon Grey Catalogue Numbers Reference Cat No Description AS/SB/24/120/R/RL AS/SB/24/120/G/AL 7021121FUL-0004X 7092275FUL-0152X Asserta Sounder/Beacon 24v Red 120dB Red Lens Asserta Sounder/Beacon 24v Grey 120dB Amber Lens 32 FULLEON FIRE ALARM DEVICES CAFIRV10614
7021121FUL-0004X 价格&库存
很抱歉,暂时无法提供与“7021121FUL-0004X”相匹配的价格&库存,您可以联系我们找货
