8500025FULL-0025X
8500025FULL-0025X
    EATON(伊顿)
    FULLEON - 8500025FULL-0025X - Beacon, Red, 95 x 95 mm, 102 dBA, Flashing, 28 VDC, IP65
8500025FULL-0025X 数据手册
Sounder Beacons RoLP LX Wall The RoLP LX Wall is ideal for dual use applications where a visual alarm device is required in addition to an audible alarm. Based on the popular Roshni product platform, the RoLP LX is a reliable, high performing VAD (Visual Alarm Device) that is certified to EN 54-23. Recommended for wall use and requiring just one installation point, the RoLP LX Wall is also available as a base only for use with any standard RoLP sounder, including the high output RoLP Maxi sounder. Technical Specification Features • Ultra low current consumption • RoLP and RoLP Maxi sounder options Mounting Wall • Up to 7.5m coverage volume (switchable to 2.5m) Voltage 18 - 28VDC (Fire Use) 9 - 15 VDC (Fire Use) Current 22 - 37mA dependent on setting (Sounder and beacon; tone 3) • 0.5 or 1Hz flash rate Coverage (y) 7.5m (Switchable to 2.5m)* Benefits Mounting Height (x) 2.4m (max) • Use where current consumption is a key consideration Coverage Volume Code W-2.4-7.5 Coverage Volume 135m3 (15m3) • Delivering up to 106dB(A) sound output Flash Rate 1Hz (Switchable to 0.5Hz) • Ideal for bedrooms, bathrooms and toilets Operating Temperature -25ºC to +70ºC • Switch flash rate to 0.5Hz to reduce current consumption Monitoring Reverse Polarity Protection IP65 Dimensions 95mm 95mm 2 x Ø20mm Weight 200g Body Colour White or Red Flash Colour White or Red Sound Output 102dB(A) (Typical tone 3 - RoLP) * CNPP test results 135mm RoLP LX Wall White RoLP Base White Catalogue Numbers Reference Cat No Description ROLP/W1/LX-W/RF 8500024FULL-0024X ROLP/R1/LX-W/RF 8500025FULL-0025X ROLP/R1/LX-W/WF 8500023FULL-0023X ROLPX/W1/LX-W/RF 8500029FULL-0029X ROLPX/R1/LX-W/RF 8500030FULL-0030X ROLPX/R1/LX-W/WF 8500028FULL-0028X For full list of part numbers, turn to page 80 24 FULLEON FIRE ALARM DEVICES CAFIRV10614 RoLP LX Wall, Red Flash, White Body RoLP LX Wall, Red Flash, Red Body RoLP LX Wall, White Flash, Red Body RoLP Maxi LX Wall, Red Flash, White Body RoLP Maxi LX Wall, Red Flash, Red Body RoLP Maxi, LX Wall, White Flash, Red Body
8500025FULL-0025X 价格&库存
很抱歉,暂时无法提供与“8500025FULL-0025X”相匹配的价格&库存,您可以联系我们找货
