7051111FUL-0128X
7051111FUL-0128X
    EATON(伊顿)
    FULLEON - 7051111FUL-0128X - Beacon, Red, 173 mm, 108 dBA, Flashing, 60 VDC, IP66
7051111FUL-0128X 数据手册
Sounder Beacons Asserta Midi Sounder Beacon The Asserta Midi Sounder Beacon is a versatile and rugged audio-visual alarm designed for industrial environments or areas where there is a requirement for a physically robust and well protected unit. Technical Specification Features • 112dB(A) output • 32 alarm tones Voltage 9 - 60Vdc Current Sounder 23mA @ 24Vdc (Typical Tone 3) 115Vac • 2 stage alarm • Asymmetric beacon Current Beacon 200mA @ 24Vdc Sound Output 108dB(A) @ 24Vdc (Typical Tone 3) Benefits Tones 32 • For Fire and general signalling use Alarm Stages 2 • Large range of tone options Flash Power 2.5j • Alert and alarm function Flash Rate 1Hz Monitoring Reverse polarity (dc version) Temperature - 25ºC to + 70ºC Protection IP66 • Efficient use of light reduces current input generating the same light output as a 5j beacon Dimensions 165mm 132mm Construction ABS Weight 0.8Kg Colour Red or grey Lens Red, amber, blue or clear 173mm Asserta Midi Sounder Beacon Grey Catalogue Numbers Reference Cat No AS/M/SB/9-60V/R/RL 7051111FUL-0128X AS/M/SB/9-60/G/AL 7051212FUL-0015X AS/M/SB/115/R/RL 7054111FUL-0046 AS/M/SB/115/R/AL 7092266FUL-0142 For full list of part numbers, turn to page 83 Description Asserta MIDI Sounder Beacon, 9-60Vdc, Red Body, Red Lens Asserta MIDI Sounder Beacon, 9-60Vdc, Grey Body, Amber Lens Asserta MIDI Sounder Beacon, 115Vac, Red Body, Red Lens Asserta MIDI Sounder Beacon, 115Vac, Grey Body, Amber Lens FULLEON FIRE ALARM DEVICES CAFIRV10614 33
7051111FUL-0128X 价格&库存
很抱歉,暂时无法提供与“7051111FUL-0128X”相匹配的价格&库存,您可以联系我们找货
