AF/W/S/VC
AF/W/S/VC
    EATON(伊顿)
    FULLEON - AF/W/S/VC - Sounder, Askari Flange, Multiple Tones, 92dB, 28VDC, 18mA, IP65
AF/W/S/VC 数据手册
Askari Flange - Process Sounder The small size of the Askari flange allows it to be surface mounted in almost any location, either within or external to equipment housings. The high IP rating allows it to be used in most environments. Technical Specification Voltage Range 9 - 28Vdc Current 18mA (Typical Tone 3) Sound Output 92dB(A) (Typical Tone 3) Tones 32 Alarm Stages Temperature 2 - 25ºC to + 70ºC Protection IP65 Construction ABS Weight 0.9Kg Colour Red or white 53mm 45mm Features Benefits ɀ Small size ɀ Easily fitted within or on control cabinets ɀ Flange type fixing ɀ Can be fitted easily to most surfaces ɀ 9Vdc to 28Vdc ɀ Accepts most common DC supplies ɀ IP65 protection ɀ Can be used in Exposed locations Reference Catalogue No. Description AF/R/S/VC 570033FULL-0058 Askari Flange Mounting Sounder, Red, Tone Select Switch, AF/W/S/VC 570011FULL-0054 Askari Flange Mounting Sounder, White, Tone Select Switch, Volume Control Volume Control 10
AF/W/S/VC 价格&库存
很抱歉,暂时无法提供与“AF/W/S/VC”相匹配的价格&库存,您可以联系我们找货
