FL/AL/W/D/12V
FL/AL/W/D/12V
    EATON(伊顿)
    FULLEON - FL/AL/W/D/12V - Audio Signal Indicator, Flashni, 101dB, 12VDC, 100mA, IP65, 92mm Ext. Dept...
FL/AL/W/D/12V 数据手册
Flashni - Sounder with Xenon Beacon The Flashni is an audible and visual device which requires one single installation point. This greatly reduces installation costs and is less obtrusive than two separate devices. Versions are available with the sounder and beacon linked, or with separate terminals for independent operation. Technical Specification Voltage 9 - 15Vdc (12Vdc version) 18 - 28Vdc (24Vdc version) (*1) Current 110mA 12Vdc version (Typical Tone 5) 68mA 24Vdc version (Typical Tone 3) Sound Output 103dB(A) 12Vdc version (Typical Tone 5) 101dB(A) 24Vdc version (Typical Tone 3) Tones 32 Flash Power 0.7j Flash Rate 1Hz Volume Control 10dB Monitoring Temperature Reverse polarity - 10ºC to + 55ºC Protection IP54 (s)* Construction ABS, PC lens Weight 0.33Kg Colours Red or white Lens Colour Red, amber, blue, green or clear Ø 93mm 92mm Features Benefits ɀ 32 tones (user selectable) ɀ Fire approved and Signalling tone options 12V or 24V ɀ For Fire, Security and Signalling Secure clip fit base ɀ Quick fitting for easy installation Volume control ɀ Reduce output to suit application ɀ ɀ ɀ 121mm (*1) 110 / 230Vac when used with a Deep powered base. (s)* Shallow Base (d)* Deep / U Base DEEP BASE SHALLOW BASE IP65 (d)* Reference Catalogue No. Description FL/RL/R/S SWITCH 640025FULL-0061X FL/RL/R/D SWITCH 640031FULL-0111X FL/AL/W/D SWITCH FL/CL/W/D 12V SND5 FL/BL/W/D 24V FL/CL/R/D/SEPARATE/ SWITCH 640024FULL-0060X 640206FULL-0089 640016FULL-0011 640466FULL-0282 Flashni Sounder/Beacon, Red Lens, Red Body, Shallow Base, Tone Select Switch. Flashni Sounder/Beacon, Red Lens, Red Body, Deep Base, Tone Select Switch. Flashni Sounder/Beacon, Amber Lens, White Body, Deep Base, Tone Select Switch Flashni 12V Sounder/Beacon, Clear Lens, White Body, Deep Base, Tone 5 Flashni XE, Deep Base, 24V, White Base, Blue Lens Flashni XE, Deep Base, Red Base, Clear Lens, Separate Switch 17
FL/AL/W/D/12V 价格&库存
很抱歉,暂时无法提供与“FL/AL/W/D/12V”相匹配的价格&库存,您可以联系我们找货
