AS/M/SB/115/R/RL
AS/M/SB/115/R/RL
    EATON(伊顿)
    FULLEON - AS/M/SB/115/R/RL - SOUNDER/BEACON, MIDI, RED, 115V
AS/M/SB/115/R/RL 数据手册
MIDI HIGH OUTPUT SOUNDER / BEACON 165mm 173mm 132mm The Asserta Midi Sounder Beacon is a versatile and rugged Specification audio-visual alarm designed for industrial environments or Voltage Range areas where there is a requirement for a physically robust and well-protected unit. A range of supply options permit use with a wide range of fire and process systems. 72 I Current AC 115Vac AC 230Vac DC 9 - 60Vdc 24Vac - 40mA (typ) 230Vac - 35mA (typ) 9 - 60Vdc - 230mA (typ)  AC OR DC VERSIONS AVAILABLE Output @ 1m 110dB(A)  110dB(A) OUTPUT Tones 32  IP66 PROTECTION Alarm Stages 2  SIMPLE FIRST & SECOND FIX INSTALLATION Flash Rate 1Hz  FULLY INTEGRATED HIGH EFFICIENCY BEACON Flash Power 2.5j  32 ALARM TONES Temperature - 20ºC to + 70ºC  2 STAGE ALARM Material PC / ABS IP Rating IP66 Weight 0.8Kg Body Colour Red or Grey Lens Colour Red, Amber or Clear
AS/M/SB/115/R/RL 价格&库存
很抱歉,暂时无法提供与“AS/M/SB/115/R/RL”相匹配的价格&库存,您可以联系我们找货
