1320-24
1320-24
    EATON(伊顿)
    FULLEON - 1320-24 - Electromagnetic Door Retainer, Wall Mounted, 24V, 40Kgf, 390N
1320-24 数据手册
Door Retainers Series 1350 / 1360 The 1350/1360 series is a range wall mounted electromagnetic door retainers that offers the user a choice of holding strengths. Robust and simple to install, they are ideal for a wide range of applications such as nursing homes, hospitals, schools and industrial premises. Doors can be held open under normal conditions and then automatically released in the event of a fire alarm activation. Technical Specification Features • Versatile holding settings • High holding force Holding Force 25-50Kg 245-490N /50-100Kg 490-960N • Low current consumption Voltage 24Vdc • Release button and protection circuit • Adjustable damping keeper plate • Protection diodes as standard Current 25-45mA / 40-100mA Mounting Wall mounting / Floor bracket available Housing Material Steel / ABS cover Temperature Range 10°C to +55°C Protection IP40 Benefits Weight 800g / 1000g • Flexibility in installation Body Colour White / Black • Suitable for large and small fire doors • Requires less power from your system • Door can be manually closed when not activated by the fire system • Allows for door misalignment Dimensions 95mm Square 40mm 60mm Square 48mm Catalogue Numbers Reference Cat No Description FSMD/024/40/W/DIODE 1350-CSA Wall Mounted Magnetic Door Release 24Vdc, 40Kgf/390N (includes diode protection circuit) 58 FULLEON FIRE ALARM DEVICES CAFIRV10614
1320-24 价格&库存
很抱歉,暂时无法提供与“1320-24”相匹配的价格&库存,您可以联系我们找货
